[OpenLayers-Commits] r12129 - in trunk/openlayers: lib/OpenLayers/Format/Filter lib/OpenLayers/Format/GML lib/OpenLayers/Format/WFST lib/OpenLayers/Protocol/WFS tests/Format/Filter tests/Format/GML tests/Format/WFST tests/Protocol
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Jun 29 05:53:38 EDT 2011
Author: ahocevar
Date: 2011-06-29 02:53:37 -0700 (Wed, 29 Jun 2011)
New Revision: 12129
   trunk/openlayers/lib/OpenLayers/Format/Filter/v1_0_0.js
   trunk/openlayers/lib/OpenLayers/Format/Filter/v1_1_0.js
   trunk/openlayers/lib/OpenLayers/Format/GML/Base.js
   trunk/openlayers/lib/OpenLayers/Format/WFST/v1_0_0.js
   trunk/openlayers/lib/OpenLayers/Format/WFST/v1_1_0.js
   trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js
   trunk/openlayers/tests/Format/Filter/v1_0_0.html
   trunk/openlayers/tests/Format/Filter/v1_1_0.html
   trunk/openlayers/tests/Format/GML/v3.html
   trunk/openlayers/tests/Format/WFST/v1_0_0.html
   trunk/openlayers/tests/Format/WFST/v1_1_0.html
   trunk/openlayers/tests/Protocol/WFS.html
making Protocol.WFS work with just featureType and featurePrefix configured. r=bartvde (closes #3368)
Modified: trunk/openlayers/lib/OpenLayers/Format/Filter/v1_0_0.js
--- trunk/openlayers/lib/OpenLayers/Format/Filter/v1_0_0.js	2011-06-27 18:12:24 UTC (rev 12128)
+++ trunk/openlayers/lib/OpenLayers/Format/Filter/v1_0_0.js	2011-06-29 09:53:37 UTC (rev 12129)
@@ -124,7 +124,17 @@
             "BBOX": function(filter) {
                 var node = this.createElementNSPlus("ogc:BBOX");
-                this.writeNode("PropertyName", filter, node);
+                // PropertyName is mandatory in 1.0.0, but e.g. GeoServer also
+                // accepts filters without it. When this is used with
+                // OpenLayers.Protocol.WFS, OpenLayers.Format.WFST will set a
+                // missing filter.property to the geometryName that is
+                // configured with the protocol, which defaults to "the_geom".
+                // So the only way to omit this mandatory property is to not
+                // set the property on the filter and to set the geometryName
+                // on the WFS protocol to null. The latter also happens when
+                // the protocol is configured without a geometryName and a
+                // featureNS.
+                filter.property && this.writeNode("PropertyName", filter, node);
                 var box = this.writeNode("gml:Box", filter.value, node);
                 if(filter.projection) {
                     box.setAttribute("srsName", filter.projection);
Modified: trunk/openlayers/lib/OpenLayers/Format/Filter/v1_1_0.js
--- trunk/openlayers/lib/OpenLayers/Format/Filter/v1_1_0.js	2011-06-27 18:12:24 UTC (rev 12128)
+++ trunk/openlayers/lib/OpenLayers/Format/Filter/v1_1_0.js	2011-06-29 09:53:37 UTC (rev 12129)
@@ -139,7 +139,8 @@
+                // PropertyName is optional in 1.1.0
                 var box = this.writeNode("gml:Envelope", filter.value);
Modified: trunk/openlayers/lib/OpenLayers/Format/GML/Base.js
--- trunk/openlayers/lib/OpenLayers/Format/GML/Base.js	2011-06-27 18:12:24 UTC (rev 12128)
+++ trunk/openlayers/lib/OpenLayers/Format/GML/Base.js	2011-06-29 09:53:37 UTC (rev 12129)
@@ -62,7 +62,8 @@
      * APIProperty: geometry
-     * {String} Name of geometry element.  Defaults to "geometry".
+     * {String} Name of geometry element.  Defaults to "geometry". If null, it
+     * will be set on <read> when the first geometry is parsed.
     geometryName: "geometry",
@@ -440,6 +441,9 @@
                 obj.features.push(feature);
             "_geometry": function(node, obj) {
+                if (!this.geometryName) {
+                    this.geometryName = node.nodeName.split(":").pop();
                 this.readChildNodes(node, obj);
             "_attribute": function(node, obj) {
Modified: trunk/openlayers/lib/OpenLayers/Format/WFST/v1_0_0.js
--- trunk/openlayers/lib/OpenLayers/Format/WFST/v1_0_0.js	2011-06-27 18:12:24 UTC (rev 12128)
+++ trunk/openlayers/lib/OpenLayers/Format/WFST/v1_0_0.js	2011-06-29 09:53:37 UTC (rev 12129)
@@ -136,9 +136,10 @@
                     srsName: this.srsName,
                     srsNameInQuery: this.srsNameInQuery
                 }, options);
+                var prefix = options.featurePrefix;
                 var node = this.createElementNSPlus("wfs:Query", {
                     attributes: {
-                        typeName: (options.featureNS ? options.featurePrefix + ":" : "") +
+                        typeName: (prefix ? prefix + ":" : "") +
                             options.featureType
@@ -146,7 +147,7 @@
                     node.setAttribute("srsName", options.srsName);
                 if(options.featureNS) {
-                    node.setAttribute("xmlns:" + options.featurePrefix, options.featureNS);
+                    node.setAttribute("xmlns:" + prefix, options.featureNS);
                 if(options.propertyNames) {
                     for(var i=0,len = options.propertyNames.length; i<len; i++) {
Modified: trunk/openlayers/lib/OpenLayers/Format/WFST/v1_1_0.js
--- trunk/openlayers/lib/OpenLayers/Format/WFST/v1_1_0.js	2011-06-27 18:12:24 UTC (rev 12128)
+++ trunk/openlayers/lib/OpenLayers/Format/WFST/v1_1_0.js	2011-06-29 09:53:37 UTC (rev 12129)
@@ -148,15 +148,16 @@
                     featureType: this.featureType,
                 }, options);
                     attributes: {
                             options.featureType,
                         srsName: options.srsName
Modified: trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js
--- trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js	2011-06-27 18:12:24 UTC (rev 12128)
+++ trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js	2011-06-29 09:53:37 UTC (rev 12129)
@@ -97,14 +97,21 @@
      * url - {String} URL to send requests to (required).
      * featureType - {String} Local (without prefix) feature typeName (required).
      * featureNS - {String} Feature namespace (required, but can be autodetected
-     *     for reading if featurePrefix is provided and identical to the prefix
-     *     in the server response).
+     *     during the first query if GML is used as readFormat and
+     *     featurePrefix is provided and matches the prefix used by the server
+     *     for this featureType).
      * featurePrefix - {String} Feature namespace alias (optional - only used
      *     for writing if featureNS is provided).  Default is 'feature'.
-     * geometryName - {String} Name of geometry attribute.  Default is 'the_geom'.
+     * geometryName - {String} Name of geometry attribute.  If featureNS is not
+     *     configured, the default is null to avoid failing on BBOX filters,
+     *     and it will be set on <read>. Otherwise, the default is 'the_geom'.
     initialize: function(options) {
         OpenLayers.Protocol.prototype.initialize.apply(this, [options]);
+        if (!options.geometryName && !options.featureNS) {
+            // poorly configured protocol - try to not fail on BBOX filters
+            this.geometryName = null;
         if(!options.format) {
             this.format = OpenLayers.Format.WFST(OpenLayers.Util.extend({
                 version: this.version,
@@ -281,8 +288,18 @@
         if(!doc || doc.length <= 0) {
             return null;
-        return (this.readFormat !== null) ? this.readFormat.read(doc) :
+        var result = (this.readFormat !== null) ? this.readFormat.read(doc) :
             this.format.read(doc, options);
+        if (!this.featureNS) {
+            var format = this.readFormat || this.format;
+            this.featureNS = format.featureNS;
+            // no need to auto-configure again on subsequent reads
+            format.autoConfig = false;
+                this.setGeometryName(format.geometryName);
+        return result;
Modified: trunk/openlayers/tests/Format/Filter/v1_0_0.html
--- trunk/openlayers/tests/Format/Filter/v1_0_0.html	2011-06-27 18:12:24 UTC (rev 12128)
+++ trunk/openlayers/tests/Format/Filter/v1_0_0.html	2011-06-29 09:53:37 UTC (rev 12129)
@@ -78,6 +78,31 @@
         t.xml_eq(node, out, "bbox correctly written");
+    function test_BBOX_noGeometryName(t) {
+        t.plan(1);
+        // WFS 1.0.0 does not allow BBOX filters without property, but
+        // GeoServer accepts them.
+        var filter = new OpenLayers.Filter.Spatial({
+            type: OpenLayers.Filter.Spatial.BBOX,
+            value: new OpenLayers.Bounds(-180, -90, 180, 90),
+            projection: "EPSG:4326"
+        var out =
+            '<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">' +
+                '<ogc:BBOX>' +
+                    '<gml:Box xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:4326">' +
+                        '<gml:coordinates decimal="." cs="," ts=" ">-180,-90 180,90</gml:coordinates>' +
+                    '</gml:Box>' +
+                '</ogc:BBOX>' +
+            '</ogc:Filter>';
+        var parser = new OpenLayers.Format.Filter.v1_0_0();
+        var node = parser.write(filter);
+        t.xml_eq(node, out, "bbox correctly written");
     function test_DWithin(t) {
         t.plan(6);
Modified: trunk/openlayers/tests/Format/Filter/v1_1_0.html
--- trunk/openlayers/tests/Format/Filter/v1_1_0.html	2011-06-27 18:12:24 UTC (rev 12128)
+++ trunk/openlayers/tests/Format/Filter/v1_1_0.html	2011-06-29 09:53:37 UTC (rev 12129)
@@ -167,6 +167,31 @@
+        t.plan(1);
+        var out =
+                '<ogc:BBOX>' +
+                    '<gml:Envelope xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:4326">' +
+                        '<gml:lowerCorner>-180 -90</gml:lowerCorner>' +
+                        '<gml:upperCorner>180 90</gml:upperCorner>' +
+                    '</gml:Envelope>' +
+                '</ogc:BBOX>' +
+            '</ogc:Filter>';
+        var parser = new OpenLayers.Format.Filter.v1_1_0();
     function test_Intersects(t) {
         t.plan(4);
Modified: trunk/openlayers/tests/Format/GML/v3.html
--- trunk/openlayers/tests/Format/GML/v3.html	2011-06-27 18:12:24 UTC (rev 12128)
+++ trunk/openlayers/tests/Format/GML/v3.html	2011-06-29 09:53:37 UTC (rev 12129)
@@ -50,6 +50,19 @@
+    function test_read_setGeometryName(t) {
+        t.plan(1);
+        var doc = readXML("v3/topp-states-gml.xml");
+        var format = new OpenLayers.Format.GML.v3({
+            featureType: "states",
+            featureNS: "http://www.openplans.org/topp",
+            geometryName: null
+        var features = format.read(doc.documentElement);
+        t.eq(format.geometryName, "the_geom", "geometryName set when parsing features");
     function test_readNode_bounds(t) {
         var files = ["v3/envelope.xml"];
Modified: trunk/openlayers/tests/Format/WFST/v1_0_0.html
--- trunk/openlayers/tests/Format/WFST/v1_0_0.html	2011-06-27 18:12:24 UTC (rev 12128)
+++ trunk/openlayers/tests/Format/WFST/v1_0_0.html	2011-06-29 09:53:37 UTC (rev 12129)
@@ -67,6 +67,17 @@
+    function test_write_poorconfig(t) {
+        t.plan(1);
+        var format = new OpenLayers.Format.WFST.v1_0_0({
+            featurePrefix: "topp"
+        var exp = "topp:states";
+        var got = format.writeNode("wfs:Query").getAttribute("typeName");
+        t.eq(got, exp, "Query without featureNS but with featurePrefix queries for the correct featureType");
     var xmlFormat = new OpenLayers.Format.XML();
     function readXML(id) {
Modified: trunk/openlayers/tests/Format/WFST/v1_1_0.html
--- trunk/openlayers/tests/Format/WFST/v1_1_0.html	2011-06-27 18:12:24 UTC (rev 12128)
+++ trunk/openlayers/tests/Format/WFST/v1_1_0.html	2011-06-29 09:53:37 UTC (rev 12129)
@@ -95,6 +95,17 @@
+        t.plan(1);
+        var format = new OpenLayers.Format.WFST.v1_1_0({
         var xml = document.getElementById(id).firstChild.nodeValue;
Modified: trunk/openlayers/tests/Protocol/WFS.html
--- trunk/openlayers/tests/Protocol/WFS.html	2011-06-27 18:12:24 UTC (rev 12128)
+++ trunk/openlayers/tests/Protocol/WFS.html	2011-06-29 09:53:37 UTC (rev 12129)
@@ -104,7 +104,21 @@
         OpenLayers.Request.POST = _POST;
+    function test_parseResponse_poorconfig(t) {
+        t.plan(2);
+        var protocol = new OpenLayers.Protocol.WFS({
+            url: "http://some.url.org",
+            featurePrefix: "topp",
+            featureType: "tasmania_roads"
+        protocol.parseResponse({responseText: document.getElementById("query_response").firstChild.nodeValue});
+        t.eq(protocol.geometryName, "geom", "geometryName configured correctly");
+        t.eq(protocol.featureNS, "http://www.openplans.org/topp", "featureNS configured correctly");
     function test_exception(t) {
         t.plan(8);
         var url = "http://some.url.org";
@@ -439,7 +453,6 @@
     <wfs:Delete typeName="feature:type" xmlns:feature="http://namespace.org">
             <ogc:BBOX>
-                <ogc:PropertyName/>
                     <gml:coordinates decimal="." cs="," ts=" ">-5,-5 5,5</gml:coordinates>
                 </gml:Box>
@@ -448,5 +461,9 @@
     </wfs:Delete>
 </wfs:Transaction>
 --></div>
+<div id="query_response"><!--
+<?xml version="1.0" encoding="UTF-8"?>
+<wfs:FeatureCollection xmlns:ogc="http://www.opengis.net/ogc" xmlns:wfs="http://www.opengis.net/wfs" xmlns:topp="http://www.openplans.org/topp" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ows="http://www.opengis.net/ows" xmlns:gml="http://www.opengis.net/gml" xmlns:xlink="http://www.w3.org/1999/xlink"><gml:boundedBy><gml:Envelope srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326"><gml:lowerCorner>5450000.0 500000.0</gml:lowerCorner><gml:upperCorner>5450000.0 540000.0</gml:upperCorner></gml:Envelope></gml:boundedBy><gml:featureMembers><topp:tasmania_roads gml:id="tasmania_roads.1"><gml:boundedBy><gml:Envelope srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326"><gml:lowerCorner>5450000.0 500000.0</gml:lowerCorner><gml:upperCorner>5450000.0 540000.0</gml:upperCorner></gml:Envelope></gml:boundedBy><topp:geom><gml:MultiLineString srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326"><gml:lineStringMember><gml:LineString><gml:posList>5450000.0 500000.0 5450
 000.0 540000.0</gml:posList></gml:LineString></gml:lineStringMember></gml:MultiLineString></topp:geom><topp:TYPE>street</topp:TYPE></topp:tasmania_roads></gml:featureMembers></wfs:FeatureCollection>
+--></div>
 </body>
 </html>
More information about the Commits mailing list
