[OpenLayers-Commits] r12132 - trunk/openlayers/lib/OpenLayers/Layer
commits-20090109 at openlayers.org
Wed Jun 29 19:30:25 EDT 2011
Author: tschaub
Date: 2011-06-29 16:30:24 -0700 (Wed, 29 Jun 2011)
New Revision: 12132
trunk/openlayers/lib/OpenLayers/Layer/TMS.js
Clarifying that it is the bottom-left corner of the map.maxExtent property that determines the tileOrigin if not explicitly provided.
Modified: trunk/openlayers/lib/OpenLayers/Layer/TMS.js
--- trunk/openlayers/lib/OpenLayers/Layer/TMS.js 2011-06-29 22:56:58 UTC (rev 12131)
+++ trunk/openlayers/lib/OpenLayers/Layer/TMS.js 2011-06-29 23:30:24 UTC (rev 12132)
@@ -66,8 +66,8 @@
* {<OpenLayers.LonLat>} Optional origin for aligning the grid of tiles.
* If provided, requests for tiles at all resolutions will be aligned
* with this location (no tiles shall overlap this location). If
- * not provided, the grid of tiles will be aligned with the map's
- * <maxExtent>. Default is ``null``.
+ * not provided, the grid of tiles will be aligned with the bottom-left
+ * corner of the map's <maxExtent>. Default is ``null``.
* Example:
* (code)
More information about the Commits
