[OpenLayers-Commits] r11605 - in sandbox/crschmidt/ovi-mobile: . examples
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Mar 1 14:47:26 EST 2011
Author: crschmidt
Date: 2011-03-01 11:47:25 -0800 (Tue, 01 Mar 2011)
New Revision: 11605
Added:
   sandbox/crschmidt/ovi-mobile/ovi.OpenLayers.js
   sandbox/crschmidt/ovi-mobile/examples/ovi.html
Add a build for the ovi example.
Modified: sandbox/crschmidt/ovi-mobile/examples/ovi.html
--- sandbox/crschmidt/ovi-mobile/examples/ovi.html	2011-03-01 19:37:49 UTC (rev 11604)
+++ sandbox/crschmidt/ovi-mobile/examples/ovi.html	2011-03-01 19:47:25 UTC (rev 11605)
@@ -6,11 +6,12 @@
     <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
     <link rel="stylesheet" href="style.css" type="text/css" />
         <script src="http://api.maps.ovi.com/jsl.js" type="text/javascript" charset="utf-8"></script>
-    <script src="../lib/OpenLayers.js"></script>
+    <script src="../ovi.OpenLayers.js"></script>
     <script type="text/javascript">
         var map, layer, velayer;
         function init(){
+            OpenLayers.ImgPath="../img/"
             map = new OpenLayers.Map('map');
             yahooLayer = new OpenLayers.Layer.Ovi( "Ovi");
@@ -18,7 +19,6 @@
             map.addLayer(yahooLayer);
             map.setCenter(new OpenLayers.LonLat(-5, 40), 4);
-            map.addControl(new OpenLayers.Control.LayerSwitcher());
     </script>
   </head>
Added: sandbox/crschmidt/ovi-mobile/ovi.OpenLayers.js
--- sandbox/crschmidt/ovi-mobile/ovi.OpenLayers.js	                        (rev 0)
+++ sandbox/crschmidt/ovi-mobile/ovi.OpenLayers.js	2011-03-01 19:47:25 UTC (rev 11605)
@@ -0,0 +1,407 @@
+  OpenLayers.js -- OpenLayers Map Viewer Library
+  Copyright 2005-2011 OpenLayers Contributors, released under the Clear BSD
+  license. Please see http://svn.openlayers.org/trunk/openlayers/license.txt
+  for the full text of the license.
+  Includes compressed code under the following licenses:
+  (For uncompressed versions of the code used please see the
+  OpenLayers SVN repository: <http://openlayers.org/>)
+/* Contains portions of Prototype.js:
+ * Prototype JavaScript framework, version 1.4.0
+ *  (c) 2005 Sam Stephenson <sam at conio.net>
+ *  Prototype is freely distributable under the terms of an MIT-style license.
+ *  For details, see the Prototype web site: http://prototype.conio.net/
+*  Contains portions of Rico <http://openrico.org/>
+*  Copyright 2005 Sabre Airline Solutions
+*  Licensed under the Apache License, Version 2.0 (the "License"); you
+*  may not use this file except in compliance with the License. You
+*  may obtain a copy of the License at
+*         http://www.apache.org/licenses/LICENSE-2.0
+*  Unless required by applicable law or agreed to in writing, software
+*  distributed under the License is distributed on an "AS IS" BASIS,
+*  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
+*  implied. See the License for the specific language governing
+*  permissions and limitations under the License.
+ * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
+ * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Contains portions of Gears <http://code.google.com/apis/gears/>
+ * Copyright 2007, Google Inc.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions are met:
+ *  1. Redistributions of source code must retain the above copyright notice,
+ *     this list of conditions and the following disclaimer.
+ *  2. Redistributions in binary form must reproduce the above copyright notice,
+ *     this list of conditions and the following disclaimer in the documentation
+ *     and/or other materials provided with the distribution.
+ *  3. Neither the name of Google Inc. nor the names of its contributors may be
+ *     used to endorse or promote products derived from this software without
+ *     specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
+ * EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
+ * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
+ * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * Sets up google.gears.*, which is *the only* supported way to access Gears.
+ * Circumvent this file at your own risk!
+ * In the future, Gears may automatically define google.gears.* without this
+ * file. Gears may use these objects to transparently fix bugs and compatibility
+ * issues. Applications that use the code below will continue to work seamlessly
+ * when that happens.
+ * OpenLayers.Util.pagePosition is based on Yahoo's getXY method, which is
+ * Copyright (c) 2006, Yahoo! Inc.
+ * All rights reserved.
+ * Redistribution and use of this software in source and binary forms, with or
+ * without modification, are permitted provided that the following conditions
+ * are met:
+ * * Redistributions of source code must retain the above copyright notice,
+ * * Redistributions in binary form must reproduce the above copyright notice,
+ * * Neither the name of Yahoo! Inc. nor the names of its contributors may be
+ *   specific prior written permission of Yahoo! Inc.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+ * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+ * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+ * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+ * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+ * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+ * POSSIBILITY OF SUCH DAMAGE.
+ */var OpenLayers={VERSION_NUMBER:"$Revision: 10995 $",singleFile:true,_getScriptLocation:function(){for(var a=/(^|(.*?\/))(OpenLayers.js)(\?|$)/,b=document.getElementsByTagName("script"),c,d="",e=0,f=b.length;e<f;e++)if(c=b[e].getAttribute("src"))if(c=c.match(a)){d=c[1];break}return function(){return d}}()};
+OpenLayers.Class=function(){var a=arguments.length,b=arguments[0],c=arguments[a-1],d=typeof c.initialize=="function"?c.initialize:function(){b.apply(this,arguments)};if(a>1){a=[d,b].concat(Array.prototype.slice.call(arguments).slice(1,a-1),c);OpenLayers.inherit.apply(null,a)}else d.prototype=c;return d};OpenLayers.Class.isPrototype=function(){};OpenLayers.Class.create=function(){return function(){arguments&&arguments[0]!=OpenLayers.Class.isPrototype&&this.initialize.apply(this,arguments)}};
+OpenLayers.Class.inherit=function(a){var b=function(){a.call(this)},c=[b].concat(Array.prototype.slice.call(arguments));OpenLayers.inherit.apply(null,c);return b.prototype};OpenLayers.inherit=function(a,b){var c=function(){};c.prototype=b.prototype;a.prototype=new c;var d,e;c=2;for(d=arguments.length;c<d;c++){e=arguments[c];if(typeof e==="function")e=e.prototype;OpenLayers.Util.extend(a.prototype,e)}};OpenLayers.Util=OpenLayers.Util||{};
+OpenLayers.Util.extend=function(a,b){a=a||{};if(b){for(var c in b){var d=b[c];if(d!==undefined)a[c]=d}if(!(typeof window.Event=="function"&&b instanceof window.Event)&&b.hasOwnProperty&&b.hasOwnProperty("toString"))a.toString=b.toString}return a};
+OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},userError:function(a){alert(a)},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};
+(function(){for(var a=document.getElementsByTagName("script"),b=0,c=a.length;b<c;++b)if(a[b].src.indexOf("firebug.js")!=-1)if(console){OpenLayers.Util.extend(OpenLayers.Console,console);break}})();
+OpenLayers.Tween=OpenLayers.Class({INTERVAL:10,easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,interval:null,playing:false,initialize:function(a){this.easing=a?a:OpenLayers.Easing.Expo.easeOut},start:function(a,b,c,d){this.playing=true;this.begin=a;this.finish=b;this.duration=c;this.callbacks=d.callbacks;this.time=0;if(this.interval){window.clearInterval(this.interval);this.interval=null}this.callbacks&&this.callbacks.start&&this.callbacks.start.call(this,this.begin);this.interval=
+window.setInterval(OpenLayers.Function.bind(this.play,this),this.INTERVAL)},stop:function(){if(this.playing){this.callbacks&&this.callbacks.done&&this.callbacks.done.call(this,this.finish);window.clearInterval(this.interval);this.interval=null;this.playing=false}},play:function(){var a={},b;for(b in this.begin){var c=this.begin[b],d=this.finish[b];if(c==null||d==null||isNaN(c)||isNaN(d))OpenLayers.Console.error("invalid value for Tween");a[b]=this.easing.apply(this,[this.time,c,d-c,this.duration])}this.time++;
+this.callbacks&&this.callbacks.eachStep&&this.callbacks.eachStep.call(this,a);this.time>this.duration&&this.stop()},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(a,b,c,d){return c*a/d+b},easeOut:function(a,b,c,d){return c*a/d+b},easeInOut:function(a,b,c,d){return c*a/d+b},CLASS_NAME:"OpenLayers.Easing.Linear"};
+OpenLayers.Easing.Expo={easeIn:function(a,b,c,d){return a==0?b:c*Math.pow(2,10*(a/d-1))+b},easeOut:function(a,b,c,d){return a==d?b+c:c*(-Math.pow(2,-10*a/d)+1)+b},easeInOut:function(a,b,c,d){if(a==0)return b;if(a==d)return b+c;if((a/=d/2)<1)return c/2*Math.pow(2,10*(a-1))+b;return c/2*(-Math.pow(2,-10*--a)+2)+b},CLASS_NAME:"OpenLayers.Easing.Expo"};
+OpenLayers.Easing.Quad={easeIn:function(a,b,c,d){return c*(a/=d)*a+b},easeOut:function(a,b,c,d){return-c*(a/=d)*(a-2)+b},easeInOut:function(a,b,c,d){if((a/=d/2)<1)return c/2*a*a+b;return-c/2*(--a*(a-2)-1)+b},CLASS_NAME:"OpenLayers.Easing.Quad"};
+OpenLayers.Lang={code:null,defaultCode:"en",getCode:function(){OpenLayers.Lang.code||OpenLayers.Lang.setCode();return OpenLayers.Lang.code},setCode:function(a){var b;a||(a=OpenLayers.BROWSER_NAME=="msie"?navigator.userLanguage:navigator.language);a=a.split("-");a[0]=a[0].toLowerCase();if(typeof OpenLayers.Lang[a[0]]=="object")b=a[0];if(a[1]){var c=a[0]+"-"+a[1].toUpperCase();if(typeof OpenLayers.Lang[c]=="object")b=c}if(!b){OpenLayers.Console.warn("Failed to find OpenLayers.Lang."+a.join("-")+" dictionary, falling back to default language");
+b=OpenLayers.Lang.defaultCode}OpenLayers.Lang.code=b},translate:function(a,b){var c=OpenLayers.Lang[OpenLayers.Lang.getCode()];(c=c&&c[a])||(c=a);if(b)c=OpenLayers.String.format(c,b);return c}};OpenLayers.i18n=OpenLayers.Lang.translate;
+OpenLayers.String={startsWith:function(a,b){return a.indexOf(b)==0},contains:function(a,b){return a.indexOf(b)!=-1},trim:function(a){return a.replace(/^\s\s*/,"").replace(/\s\s*$/,"")},camelize:function(a){a=a.split("-");for(var b=a[0],c=1,d=a.length;c<d;c++){var e=a[c];b+=e.charAt(0).toUpperCase()+e.substring(1)}return b},format:function(a,b,c){b||(b=window);return a.replace(OpenLayers.String.tokenRegEx,function(d,e){for(var f,g=e.split(/\.+/),h=0;h<g.length;h++){if(h==0)f=b;f=f[g[h]]}if(typeof f==
+"function")f=c?f.apply(null,c):f();return typeof f=="undefined"?"undefined":f})},tokenRegEx:/\$\{([\w.]+?)\}/g,numberRegEx:/^([+-]?)(?=\d|\.\d)\d*(\.\d*)?([Ee]([+-]?\d+))?$/,isNumeric:function(a){return OpenLayers.String.numberRegEx.test(a)},numericIf:function(a){return OpenLayers.String.isNumeric(a)?parseFloat(a):a}};
+if(!String.prototype.startsWith)String.prototype.startsWith=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.String.startsWith"}));return OpenLayers.String.startsWith(this,a)};if(!String.prototype.contains)String.prototype.contains=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.String.contains"}));return OpenLayers.String.contains(this,a)};
+if(!String.prototype.trim)String.prototype.trim=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.String.trim"}));return OpenLayers.String.trim(this)};if(!String.prototype.camelize)String.prototype.camelize=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.String.camelize"}));return OpenLayers.String.camelize(this)};
+OpenLayers.Number={decimalSeparator:".",thousandsSeparator:",",limitSigDigs:function(a,b){var c=0;if(b>0)c=parseFloat(a.toPrecision(b));return c},format:function(a,b,c,d){b=typeof b!="undefined"?b:0;c=typeof c!="undefined"?c:OpenLayers.Number.thousandsSeparator;d=typeof d!="undefined"?d:OpenLayers.Number.decimalSeparator;if(b!=null)a=parseFloat(a.toFixed(b));var e=a.toString().split(".");if(e.length==1&&b==null)b=0;a=e[0];if(c)for(var f=/(-?[0-9]+)([0-9]{3})/;f.test(a);)a=a.replace(f,"$1"+c+"$2");
+if(b==0)b=a;else{c=e.length>1?e[1]:"0";if(b!=null)c+=Array(b-c.length+1).join("0");b=a+d+c}return b}};if(!Number.prototype.limitSigDigs)Number.prototype.limitSigDigs=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.Number.limitSigDigs"}));return OpenLayers.Number.limitSigDigs(this,a)};
+OpenLayers.Function={bind:function(a,b){var c=Array.prototype.slice.apply(arguments,[2]);return function(){var d=c.concat(Array.prototype.slice.apply(arguments,[0]));return a.apply(b,d)}},bindAsEventListener:function(a,b){return function(c){return a.call(b,c||window.event)}},False:function(){return false},True:function(){return true},Void:function(){}};
+if(!Function.prototype.bind)Function.prototype.bind=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.Function.bind"}));Array.prototype.unshift.apply(arguments,[this]);return OpenLayers.Function.bind.apply(null,arguments)};
+if(!Function.prototype.bindAsEventListener)Function.prototype.bindAsEventListener=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.Function.bindAsEventListener"}));return OpenLayers.Function.bindAsEventListener(this,a)};OpenLayers.Array={filter:function(a,b,c){var d=[];if(Array.prototype.filter)d=a.filter(b,c);else{var e=a.length;if(typeof b!="function")throw new TypeError;for(var f=0;f<e;f++)if(f in a){var g=a[f];b.call(c,g,f,a)&&d.push(g)}}return d}};
+OpenLayers.Date={toISOString:function(){if("toISOString"in Date.prototype)return function(b){return b.toISOString()};else{var a=function(b,c){for(var d=b+"";d.length<c;)d="0"+d;return d};return function(b){return isNaN(b.getTime())?"Invalid Date":b.getUTCFullYear()+"-"+a(b.getUTCMonth()+1,2)+"-"+a(b.getUTCDate(),2)+"T"+a(b.getUTCHours(),2)+":"+a(b.getUTCMinutes(),2)+":"+a(b.getUTCSeconds(),2)+"."+a(b.getUTCMilliseconds(),3)+"Z"}}}(),parse:function(a){var b;if((a=a.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))?$/))&&
+(a[1]||a[7])){b=parseInt(a[1],10)||0;var c=parseInt(a[2],10)-1||0,d=parseInt(a[3],10)||1;b=new Date(Date.UTC(b,c,d));if(c=a[7]){d=parseInt(a[4],10);var e=parseInt(a[5],10),f=parseFloat(a[6]),g=f|0;b.setUTCHours(d,e,g,Math.round(1E3*(f-g)));if(c!=="Z"){c=parseInt(c,10);a=parseInt(a[8],10)||0;b=new Date(b.getTime()+-1E3*(60*c*60+a*60))}}}else b=new Date("invalid");return b}};
+OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,centerLonLat:null,initialize:function(a,b,c,d){if(a!=null)this.left=OpenLayers.Util.toFloat(a);if(b!=null)this.bottom=OpenLayers.Util.toFloat(b);if(c!=null)this.right=OpenLayers.Util.toFloat(c);if(d!=null)this.top=OpenLayers.Util.toFloat(d)},clone:function(){return new OpenLayers.Bounds(this.left,this.bottom,this.right,this.top)},equals:function(a){var b=false;if(a!=null)b=this.left==a.left&&this.right==a.right&&this.top==
+a.top&&this.bottom==a.bottom;return b},toString:function(){return"left-bottom=("+this.left+","+this.bottom+") right-top=("+this.right+","+this.top+")"},toArray:function(a){return a===true?[this.bottom,this.left,this.top,this.right]:[this.left,this.bottom,this.right,this.top]},toBBOX:function(a,b){if(a==null)a=6;var c=Math.pow(10,a),d=Math.round(this.left*c)/c,e=Math.round(this.bottom*c)/c,f=Math.round(this.right*c)/c;c=Math.round(this.top*c)/c;return b===true?e+","+d+","+c+","+f:d+","+e+","+f+","+
+c},toGeometry:function(){return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(this.left,this.bottom),new OpenLayers.Geometry.Point(this.right,this.bottom),new OpenLayers.Geometry.Point(this.right,this.top),new OpenLayers.Geometry.Point(this.left,this.top)])])},getWidth:function(){return this.right-this.left},getHeight:function(){return this.top-this.bottom},getSize:function(){return new OpenLayers.Size(this.getWidth(),this.getHeight())},getCenterPixel:function(){return new OpenLayers.Pixel((this.left+
+this.right)/2,(this.bottom+this.top)/2)},getCenterLonLat:function(){if(!this.centerLonLat)this.centerLonLat=new OpenLayers.LonLat((this.left+this.right)/2,(this.bottom+this.top)/2);return this.centerLonLat},scale:function(a,b){if(b==null)b=this.getCenterLonLat();var c,d;if(b.CLASS_NAME=="OpenLayers.LonLat"){c=b.lon;d=b.lat}else{c=b.x;d=b.y}return new OpenLayers.Bounds((this.left-c)*a+c,(this.bottom-d)*a+d,(this.right-c)*a+c,(this.top-d)*a+d)},add:function(a,b){if(a==null||b==null){var c=OpenLayers.i18n("boundsAddError");
+OpenLayers.Console.error(c);return null}return new OpenLayers.Bounds(this.left+a,this.bottom+b,this.right+a,this.top+b)},extend:function(a){var b=null;if(a){switch(a.CLASS_NAME){case "OpenLayers.LonLat":b=new OpenLayers.Bounds(a.lon,a.lat,a.lon,a.lat);break;case "OpenLayers.Geometry.Point":b=new OpenLayers.Bounds(a.x,a.y,a.x,a.y);break;case "OpenLayers.Bounds":b=a}if(b){this.centerLonLat=null;if(this.left==null||b.left<this.left)this.left=b.left;if(this.bottom==null||b.bottom<this.bottom)this.bottom=
+b.bottom;if(this.right==null||b.right>this.right)this.right=b.right;if(this.top==null||b.top>this.top)this.top=b.top}}},containsLonLat:function(a,b){return this.contains(a.lon,a.lat,b)},containsPixel:function(a,b){return this.contains(a.x,a.y,b)},contains:function(a,b,c){if(c==null)c=true;if(a==null||b==null)return false;a=OpenLayers.Util.toFloat(a);b=OpenLayers.Util.toFloat(b);var d=false;return d=c?a>=this.left&&a<=this.right&&b>=this.bottom&&b<=this.top:a>this.left&&a<this.right&&b>this.bottom&&
+b<this.top},intersectsBounds:function(a,b){if(b==null)b=true;var c=false,d=this.left==a.right||this.right==a.left||this.top==a.bottom||this.bottom==a.top;if(b||!d){c=a.top>=this.bottom&&a.top<=this.top||this.top>a.bottom&&this.top<a.top;d=a.left>=this.left&&a.left<=this.right||this.left>=a.left&&this.left<=a.right;var e=a.right>=this.left&&a.right<=this.right||this.right>=a.left&&this.right<=a.right;c=(a.bottom>=this.bottom&&a.bottom<=this.top||this.bottom>=a.bottom&&this.bottom<=a.top||c)&&(d||e)}return c},
+containsBounds:function(a,b,c){if(b==null)b=false;if(c==null)c=true;var d=this.contains(a.left,a.bottom,c),e=this.contains(a.right,a.bottom,c),f=this.contains(a.left,a.top,c);a=this.contains(a.right,a.top,c);return b?d||e||f||a:d&&e&&f&&a},determineQuadrant:function(a){var b="",c=this.getCenterLonLat();b+=a.lat<c.lat?"b":"t";b+=a.lon<c.lon?"l":"r";return b},transform:function(a,b){this.centerLonLat=null;var c=OpenLayers.Projection.transform({x:this.left,y:this.bottom},a,b),d=OpenLayers.Projection.transform({x:this.right,
+y:this.bottom},a,b),e=OpenLayers.Projection.transform({x:this.left,y:this.top},a,b),f=OpenLayers.Projection.transform({x:this.right,y:this.top},a,b);this.left=Math.min(c.x,e.x);this.bottom=Math.min(c.y,d.y);this.right=Math.max(d.x,f.x);this.top=Math.max(e.y,f.y);return this},wrapDateLine:function(a,b){b=b||{};var c=b.leftTolerance||0,d=b.rightTolerance||0,e=this.clone();if(a){for(;e.left<a.left&&e.right-d<=a.left;)e=e.add(a.getWidth(),0);for(;e.left+c>=a.right&&e.right>a.right;)e=e.add(-a.getWidth(),
+0)}return e},CLASS_NAME:"OpenLayers.Bounds"});OpenLayers.Bounds.fromString=function(a,b){var c=a.split(",");return OpenLayers.Bounds.fromArray(c,b)};OpenLayers.Bounds.fromArray=function(a,b){return b===true?new OpenLayers.Bounds(parseFloat(a[1]),parseFloat(a[0]),parseFloat(a[3]),parseFloat(a[2])):new OpenLayers.Bounds(parseFloat(a[0]),parseFloat(a[1]),parseFloat(a[2]),parseFloat(a[3]))};OpenLayers.Bounds.fromSize=function(a){return new OpenLayers.Bounds(0,a.h,a.w,0)};
+OpenLayers.Bounds.oppositeQuadrant=function(a){var b="";b+=a.charAt(0)=="t"?"b":"t";b+=a.charAt(1)=="l"?"r":"l";return b};
+OpenLayers.Element={visible:function(a){return OpenLayers.Util.getElement(a).style.display!="none"},toggle:function(){for(var a=0,b=arguments.length;a<b;a++){var c=OpenLayers.Util.getElement(arguments[a]),d=OpenLayers.Element.visible(c)?"hide":"show";OpenLayers.Element[d](c)}},hide:function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"element.style.display = 'none';"}));for(var a=0,b=arguments.length;a<b;a++){var c=OpenLayers.Util.getElement(arguments[a]);if(c)c.style.display=
+"none"}},show:function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"element.style.display = '';"}));for(var a=0,b=arguments.length;a<b;a++){var c=OpenLayers.Util.getElement(arguments[a]);if(c)c.style.display=""}},remove:function(a){a=OpenLayers.Util.getElement(a);a.parentNode.removeChild(a)},getHeight:function(a){a=OpenLayers.Util.getElement(a);return a.offsetHeight},getDimensions:function(a){a=OpenLayers.Util.getElement(a);if(OpenLayers.Element.getStyle(a,"display")!=
+"none")return{width:a.offsetWidth,height:a.offsetHeight};var b=a.style,c=b.visibility,d=b.position,e=b.display;b.visibility="hidden";b.position="absolute";b.display="";var f=a.clientWidth;a=a.clientHeight;b.display=e;b.position=d;b.visibility=c;return{width:f,height:a}},hasClass:function(a,b){var c=a.className;return!!c&&RegExp("(^|\\s)"+b+"(\\s|$)").test(c)},addClass:function(a,b){OpenLayers.Element.hasClass(a,b)||(a.className+=(a.className?" ":"")+b);return a},removeClass:function(a,b){var c=a.className;
+if(c)a.className=OpenLayers.String.trim(c.replace(RegExp("(^|\\s+)"+b+"(\\s+|$)")," "));return a},toggleClass:function(a,b){OpenLayers.Element.hasClass(a,b)?OpenLayers.Element.removeClass(a,b):OpenLayers.Element.addClass(a,b);return a},getStyle:function(a,b){a=OpenLayers.Util.getElement(a);var c=null;if(a&&a.style){c=a.style[OpenLayers.String.camelize(b)];if(!c)if(document.defaultView&&document.defaultView.getComputedStyle)c=(c=document.defaultView.getComputedStyle(a,null))?c.getPropertyValue(b):
+null;else if(a.currentStyle)c=a.currentStyle[OpenLayers.String.camelize(b)];var d=["left","top","right","bottom"];if(window.opera&&OpenLayers.Util.indexOf(d,b)!=-1&&OpenLayers.Element.getStyle(a,"position")=="static")c="auto"}return c=="auto"?null:c}};
+OpenLayers.LonLat=OpenLayers.Class({lon:0,lat:0,initialize:function(a,b){this.lon=OpenLayers.Util.toFloat(a);this.lat=OpenLayers.Util.toFloat(b)},toString:function(){return"lon="+this.lon+",lat="+this.lat},toShortString:function(){return this.lon+", "+this.lat},clone:function(){return new OpenLayers.LonLat(this.lon,this.lat)},add:function(a,b){if(a==null||b==null){var c=OpenLayers.i18n("lonlatAddError");OpenLayers.Console.error(c);return null}return new OpenLayers.LonLat(this.lon+OpenLayers.Util.toFloat(a),
+this.lat+OpenLayers.Util.toFloat(b))},equals:function(a){var b=false;if(a!=null)b=this.lon==a.lon&&this.lat==a.lat||isNaN(this.lon)&&isNaN(this.lat)&&isNaN(a.lon)&&isNaN(a.lat);return b},transform:function(a,b){var c=OpenLayers.Projection.transform({x:this.lon,y:this.lat},a,b);this.lon=c.x;this.lat=c.y;return this},wrapDateLine:function(a){var b=this.clone();if(a){for(;b.lon<a.left;)b.lon+=a.getWidth();for(;b.lon>a.right;)b.lon-=a.getWidth()}return b},CLASS_NAME:"OpenLayers.LonLat"});
+OpenLayers.LonLat.fromString=function(a){a=a.split(",");return new OpenLayers.LonLat(a[0],a[1])};
+OpenLayers.Pixel=OpenLayers.Class({x:0,y:0,initialize:function(a,b){this.x=parseFloat(a);this.y=parseFloat(b)},toString:function(){return"x="+this.x+",y="+this.y},clone:function(){return new OpenLayers.Pixel(this.x,this.y)},equals:function(a){var b=false;if(a!=null)b=this.x==a.x&&this.y==a.y||isNaN(this.x)&&isNaN(this.y)&&isNaN(a.x)&&isNaN(a.y);return b},distanceTo:function(a){return Math.sqrt(Math.pow(this.x-a.x,2)+Math.pow(this.y-a.y,2))},add:function(a,b){if(a==null||b==null){var c=OpenLayers.i18n("pixelAddError");
+OpenLayers.Console.error(c);return null}return new OpenLayers.Pixel(this.x+a,this.y+b)},offset:function(a){var b=this.clone();if(a)b=this.add(a.x,a.y);return b},CLASS_NAME:"OpenLayers.Pixel"});
+OpenLayers.Size=OpenLayers.Class({w:0,h:0,initialize:function(a,b){this.w=parseFloat(a);this.h=parseFloat(b)},toString:function(){return"w="+this.w+",h="+this.h},clone:function(){return new OpenLayers.Size(this.w,this.h)},equals:function(a){var b=false;if(a!=null)b=this.w==a.w&&this.h==a.h||isNaN(this.w)&&isNaN(this.h)&&isNaN(a.w)&&isNaN(a.h);return b},CLASS_NAME:"OpenLayers.Size"});OpenLayers.Util=OpenLayers.Util||{};
+OpenLayers.Util.getElement=function(){for(var a=[],b=0,c=arguments.length;b<c;b++){var d=arguments[b];if(typeof d=="string")d=document.getElementById(d);if(arguments.length==1)return d;a.push(d)}return a};OpenLayers.Util.isElement=function(a){return!!(a&&a.nodeType===1)};if(typeof window.$==="undefined")window.$=OpenLayers.Util.getElement;OpenLayers.Util.removeItem=function(a,b){for(var c=a.length-1;c>=0;c--)a[c]==b&&a.splice(c,1);return a};
+OpenLayers.Util.clearArray=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"array = []"}));a.length=0};OpenLayers.Util.indexOf=function(a,b){if(typeof a.indexOf=="function")return a.indexOf(b);else{for(var c=0,d=a.length;c<d;c++)if(a[c]==b)return c;return-1}};
+OpenLayers.Util.modifyDOMElement=function(a,b,c,d,e,f,g,h){if(b)a.id=b;if(c){a.style.left=c.x+"px";a.style.top=c.y+"px"}if(d){a.style.width=d.w+"px";a.style.height=d.h+"px"}if(e)a.style.position=e;if(f)a.style.border=f;if(g)a.style.overflow=g;if(parseFloat(h)>=0&&parseFloat(h)<1){a.style.filter="alpha(opacity="+h*100+")";a.style.opacity=h}else if(parseFloat(h)==1){a.style.filter="";a.style.opacity=""}};
+OpenLayers.Util.createDiv=function(a,b,c,d,e,f,g,h){var i=document.createElement("div");if(d)i.style.backgroundImage="url("+d+")";a||(a=OpenLayers.Util.createUniqueID("OpenLayersDiv"));e||(e="absolute");OpenLayers.Util.modifyDOMElement(i,a,b,c,e,f,g,h);return i};
+OpenLayers.Util.createImage=function(a,b,c,d,e,f,g,h){var i=document.createElement("img");a||(a=OpenLayers.Util.createUniqueID("OpenLayersDiv"));e||(e="relative");OpenLayers.Util.modifyDOMElement(i,a,b,c,e,f,null,g);if(h){i.style.display="none";OpenLayers.Event.observe(i,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,i));OpenLayers.Event.observe(i,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,i))}i.style.alt=a;i.galleryImg="no";if(d)i.src=d;return i};
+OpenLayers.Util.setOpacity=function(a,b){OpenLayers.Util.modifyDOMElement(a,null,null,null,null,null,null,b)};OpenLayers.Util.onImageLoad=function(){if(!this.viewRequestID||this.map&&this.viewRequestID==this.map.viewRequestID)this.style.display="";OpenLayers.Element.removeClass(this,"olImageLoadError")};OpenLayers.IMAGE_RELOAD_ATTEMPTS=0;
+OpenLayers.Util.onImageLoadError=function(){this._attempts=this._attempts?this._attempts+1:1;if(this._attempts<=OpenLayers.IMAGE_RELOAD_ATTEMPTS){var a=this.urls;if(a&&a instanceof Array&&a.length>1){var b=this.src.toString(),c,d;for(d=0;c=a[d];d++)if(b.indexOf(c)!=-1)break;var e=Math.floor(a.length*Math.random());e=a[e];for(d=0;e==c&&d++<4;){e=Math.floor(a.length*Math.random());e=a[e]}this.src=b.replace(c,e)}else this.src=this.src}else OpenLayers.Element.addClass(this,"olImageLoadError");this.style.display=
+""};OpenLayers.Util.alphaHackNeeded=null;OpenLayers.Util.alphaHack=function(){if(OpenLayers.Util.alphaHackNeeded==null){var a=navigator.appVersion.split("MSIE");a=parseFloat(a[1]);var b=false;try{b=!!document.body.filters}catch(c){}OpenLayers.Util.alphaHackNeeded=b&&a>=5.5&&a<7}return OpenLayers.Util.alphaHackNeeded};
+OpenLayers.Util.modifyAlphaImageDiv=function(a,b,c,d,e,f,g,h,i){OpenLayers.Util.modifyDOMElement(a,b,c,d,f,null,null,i);b=a.childNodes[0];if(e)b.src=e;OpenLayers.Util.modifyDOMElement(b,a.id+"_innerImage",null,d,"relative",g);if(OpenLayers.Util.alphaHack()){if(a.style.display!="none")a.style.display="inline-block";if(h==null)h="scale";a.style.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader(src='"+b.src+"', sizingMethod='"+h+"')";if(parseFloat(a.style.opacity)>=0&&parseFloat(a.style.opacity)<
+1)a.style.filter+=" alpha(opacity="+a.style.opacity*100+")";b.style.filter="alpha(opacity=0)"}};
+OpenLayers.Util.createAlphaImageDiv=function(a,b,c,d,e,f,g,h,i){var j=OpenLayers.Util.createDiv(),k=OpenLayers.Util.createImage(null,null,null,null,null,null,null,false);j.appendChild(k);if(i){k.style.display="none";OpenLayers.Event.observe(k,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,j));OpenLayers.Event.observe(k,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,j))}OpenLayers.Util.modifyAlphaImageDiv(j,a,b,c,d,e,f,g,h);return j};
+OpenLayers.Util.upperCaseObject=function(a){var b={},c;for(c in a)b[c.toUpperCase()]=a[c];return b};OpenLayers.Util.applyDefaults=function(a,b){a=a||{};var c=typeof window.Event=="function"&&b instanceof window.Event,d;for(d in b)if(a[d]===undefined||!c&&b.hasOwnProperty&&b.hasOwnProperty(d)&&!a.hasOwnProperty(d))a[d]=b[d];if(!c&&b&&b.hasOwnProperty&&b.hasOwnProperty("toString")&&!a.hasOwnProperty("toString"))a.toString=b.toString;return a};
+OpenLayers.Util.getParameterString=function(a){var b=[],c;for(c in a){var d=a[c];if(d!=null&&typeof d!="function"){if(typeof d=="object"&&d.constructor==Array){for(var e=[],f,g=0,h=d.length;g<h;g++){f=d[g];e.push(encodeURIComponent(f===null||f===undefined?"":f))}d=e.join(",")}else d=encodeURIComponent(d);b.push(encodeURIComponent(c)+"="+d)}}return b.join("&")};OpenLayers.Util.urlAppend=function(a,b){var c=a;if(b){var d=(a+" ").split(/[?&]/);c+=d.pop()===" "?b:d.length?"&"+b:"?"+b}return c};
+OpenLayers.ImgPath="";OpenLayers.Util.getImagesLocation=function(){return OpenLayers.ImgPath||OpenLayers._getScriptLocation()+"img/"};OpenLayers.Util.Try=function(){for(var a=null,b=0,c=arguments.length;b<c;b++){var d=arguments[b];try{a=d();break}catch(e){}}return a};OpenLayers.Util.getNodes=function(a,b){return OpenLayers.Util.Try(function(){return OpenLayers.Util._getNodes(a.documentElement.childNodes,b)},function(){return OpenLayers.Util._getNodes(a.childNodes,b)})};
+OpenLayers.Util._getNodes=function(a,b){for(var c=[],d=0,e=a.length;d<e;d++)a[d].nodeName==b&&c.push(a[d]);return c};OpenLayers.Util.getTagText=function(a,b,c){if((a=OpenLayers.Util.getNodes(a,b))&&a.length>0){c||(c=0);if(a[c].childNodes.length>1)return a.childNodes[1].nodeValue;else if(a[c].childNodes.length==1)return a[c].firstChild.nodeValue}else return""};
+OpenLayers.Util.getXmlNodeValue=function(a){var b=null;OpenLayers.Util.Try(function(){b=a.text;if(!b)b=a.textContent;if(!b)b=a.firstChild.nodeValue},function(){b=a.textContent});return b};OpenLayers.Util.mouseLeft=function(a,b){for(var c=a.relatedTarget?a.relatedTarget:a.toElement;c!=b&&c!=null;)c=c.parentNode;return c!=b};OpenLayers.Util.DEFAULT_PRECISION=14;
+OpenLayers.Util.toFloat=function(a,b){if(b==null)b=OpenLayers.Util.DEFAULT_PRECISION;if(typeof a!=="number")a=parseFloat(a);return b===0?a:parseFloat(a.toPrecision(b))};OpenLayers.Util.rad=function(a){return a*Math.PI/180};OpenLayers.Util.deg=function(a){return a*180/Math.PI};OpenLayers.Util.VincentyConstants={a:6378137,b:6356752.3142,f:1/298.257223563};
+OpenLayers.Util.distVincenty=function(a,b){var c=OpenLayers.Util.VincentyConstants,d=c.a,e=c.b;c=c.f;var f=OpenLayers.Util.rad(b.lon-a.lon),g=Math.atan((1-c)*Math.tan(OpenLayers.Util.rad(a.lat))),h=Math.atan((1-c)*Math.tan(OpenLayers.Util.rad(b.lat))),i=Math.sin(g);g=Math.cos(g);var j=Math.sin(h);h=Math.cos(h);for(var k=f,s=2*Math.PI,m=20;Math.abs(k-s)>1.0E-12&&--m>0;){var l=Math.sin(k),n=Math.cos(k),q=Math.sqrt(h*l*h*l+(g*j-i*h*n)*(g*j-i*h*n));if(q==0)return 0;n=i*j+g*h*n;var o=Math.atan2(q,n),p=
+Math.asin(g*h*l/q),r=Math.cos(p)*Math.cos(p);l=n-2*i*j/r;var t=c/16*r*(4+c*(4-3*r));s=k;k=f+(1-t)*c*Math.sin(p)*(o+t*q*(l+t*n*(-1+2*l*l)))}if(m==0)return NaN;d=r*(d*d-e*e)/(e*e);c=d/1024*(256+d*(-128+d*(74-47*d)));return(e*(1+d/16384*(4096+d*(-768+d*(320-175*d))))*(o-c*q*(l+c/4*(n*(-1+2*l*l)-c/6*l*(-3+4*q*q)*(-3+4*l*l))))).toFixed(3)/1E3};
+OpenLayers.Util.destinationVincenty=function(a,b,c){var d=OpenLayers.Util,e=d.VincentyConstants,f=e.a,g=e.b;e=e.f;var h=a.lon,i=a.lat;a=d.rad(b);b=Math.sin(a);a=Math.cos(a);var j=(1-e)*Math.tan(d.rad(i));i=1/Math.sqrt(1+j*j);var k=j*i,s=Math.atan2(j,a);j=i*b;var m=1-j*j;f=m*(f*f-g*g)/(g*g);var l=1+f/16384*(4096+f*(-768+f*(320-175*f))),n=f/1024*(256+f*(-128+f*(74-47*f)));f=c/(g*l);for(var q=2*Math.PI;Math.abs(f-q)>1.0E-12;){var o=Math.cos(2*s+f),p=Math.sin(f),r=Math.cos(f),t=n*p*(o+n/4*(r*(-1+2*o*
+o)-n/6*o*(-3+4*p*p)*(-3+4*o*o)));q=f;f=c/(g*l)+t}c=k*p-i*r*a;c=Math.atan2(k*r+i*p*a,(1-e)*Math.sqrt(j*j+c*c));g=e/16*m*(4+e*(4-3*m));return new OpenLayers.LonLat(h+d.deg(Math.atan2(p*b,i*r-k*p*a)-(1-g)*e*j*(f+g*p*(o+g*r*(-1+2*o*o)))),d.deg(c))};
+OpenLayers.Util.getParameters=function(a){a=a||window.location.href;var b="";if(OpenLayers.String.contains(a,"?")){b=a.indexOf("?")+1;var c=OpenLayers.String.contains(a,"#")?a.indexOf("#"):a.length;b=a.substring(b,c)}a={};b=b.split(/[&;]/);c=0;for(var d=b.length;c<d;++c){var e=b[c].split("=");if(e[0]){var f=e[0];try{f=decodeURIComponent(f)}catch(g){f=unescape(f)}e=(e[1]||"").replace(/\+/g," ");try{e=decodeURIComponent(e)}catch(h){e=unescape(e)}e=e.split(",");if(e.length==1)e=e[0];a[f]=e}}return a};
+OpenLayers.Util.getArgs=function(a){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{newMethod:"OpenLayers.Util.getParameters"}));return OpenLayers.Util.getParameters(a)};OpenLayers.Util.lastSeqID=0;OpenLayers.Util.createUniqueID=function(a){if(a==null)a="id_";OpenLayers.Util.lastSeqID+=1;return a+OpenLayers.Util.lastSeqID};OpenLayers.INCHES_PER_UNIT={inches:1,ft:12,mi:63360,m:39.3701,km:39370.1,dd:4374754,yd:36};OpenLayers.INCHES_PER_UNIT["in"]=OpenLayers.INCHES_PER_UNIT.inches;
+OpenLayers.INCHES_PER_UNIT.degrees=OpenLayers.INCHES_PER_UNIT.dd;OpenLayers.INCHES_PER_UNIT.nmi=1852*OpenLayers.INCHES_PER_UNIT.m;OpenLayers.METERS_PER_INCH=0.0254000508001016;
+OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT,{Inch:OpenLayers.INCHES_PER_UNIT.inches,Meter:1/OpenLayers.METERS_PER_INCH,Foot:0.3048006096012192/OpenLayers.METERS_PER_INCH,IFoot:0.3048/OpenLayers.METERS_PER_INCH,ClarkeFoot:0.3047972651151/OpenLayers.METERS_PER_INCH,SearsFoot:0.30479947153867626/OpenLayers.METERS_PER_INCH,GoldCoastFoot:0.3047997101815088/OpenLayers.METERS_PER_INCH,IInch:0.0254/OpenLayers.METERS_PER_INCH,MicroInch:2.54E-5/OpenLayers.METERS_PER_INCH,Mil:2.54E-8/OpenLayers.METERS_PER_INCH,
+Centimeter:0.01/OpenLayers.METERS_PER_INCH,Kilometer:1E3/OpenLayers.METERS_PER_INCH,Yard:0.9144018288036576/OpenLayers.METERS_PER_INCH,SearsYard:0.914398414616029/OpenLayers.METERS_PER_INCH,IndianYard:0.9143985307444408/OpenLayers.METERS_PER_INCH,IndianYd37:0.91439523/OpenLayers.METERS_PER_INCH,IndianYd62:0.9143988/OpenLayers.METERS_PER_INCH,IndianYd75:0.9143985/OpenLayers.METERS_PER_INCH,IndianFoot:0.30479951/OpenLayers.METERS_PER_INCH,IndianFt37:0.30479841/OpenLayers.METERS_PER_INCH,IndianFt62:0.3047996/
+OpenLayers.METERS_PER_INCH,IndianFt75:0.3047995/OpenLayers.METERS_PER_INCH,Mile:1609.3472186944373/OpenLayers.METERS_PER_INCH,IYard:0.9144/OpenLayers.METERS_PER_INCH,IMile:1609.344/OpenLayers.METERS_PER_INCH,NautM:1852/OpenLayers.METERS_PER_INCH,"Lat-66":110943.31648893273/OpenLayers.METERS_PER_INCH,"Lat-83":110946.25736872235/OpenLayers.METERS_PER_INCH,Decimeter:0.1/OpenLayers.METERS_PER_INCH,Millimeter:0.0010/OpenLayers.METERS_PER_INCH,Dekameter:10/OpenLayers.METERS_PER_INCH,Decameter:10/OpenLayers.METERS_PER_INCH,
+Hectometer:100/OpenLayers.METERS_PER_INCH,GermanMeter:1.0000135965/OpenLayers.METERS_PER_INCH,CaGrid:0.999738/OpenLayers.METERS_PER_INCH,ClarkeChain:20.1166194976/OpenLayers.METERS_PER_INCH,GunterChain:20.11684023368047/OpenLayers.METERS_PER_INCH,BenoitChain:20.116782494375872/OpenLayers.METERS_PER_INCH,SearsChain:20.11676512155/OpenLayers.METERS_PER_INCH,ClarkeLink:0.201166194976/OpenLayers.METERS_PER_INCH,GunterLink:0.2011684023368047/OpenLayers.METERS_PER_INCH,BenoitLink:0.20116782494375873/OpenLayers.METERS_PER_INCH,
+SearsLink:0.2011676512155/OpenLayers.METERS_PER_INCH,Rod:5.02921005842012/OpenLayers.METERS_PER_INCH,IntnlChain:20.1168/OpenLayers.METERS_PER_INCH,IntnlLink:0.201168/OpenLayers.METERS_PER_INCH,Perch:5.02921005842012/OpenLayers.METERS_PER_INCH,Pole:5.02921005842012/OpenLayers.METERS_PER_INCH,Furlong:201.1684023368046/OpenLayers.METERS_PER_INCH,Rood:3.778266898/OpenLayers.METERS_PER_INCH,CapeFoot:0.3047972615/OpenLayers.METERS_PER_INCH,Brealey:375/OpenLayers.METERS_PER_INCH,ModAmFt:0.304812252984506/
+OpenLayers.METERS_PER_INCH,Fathom:1.8288/OpenLayers.METERS_PER_INCH,"NautM-UK":1853.184/OpenLayers.METERS_PER_INCH,"50kilometers":5E4/OpenLayers.METERS_PER_INCH,"150kilometers":15E4/OpenLayers.METERS_PER_INCH});
+OpenLayers.Util.extend(OpenLayers.INCHES_PER_UNIT,{mm:OpenLayers.INCHES_PER_UNIT.Meter/1E3,cm:OpenLayers.INCHES_PER_UNIT.Meter/100,dm:OpenLayers.INCHES_PER_UNIT.Meter*100,km:OpenLayers.INCHES_PER_UNIT.Meter*1E3,kmi:OpenLayers.INCHES_PER_UNIT.nmi,fath:OpenLayers.INCHES_PER_UNIT.Fathom,ch:OpenLayers.INCHES_PER_UNIT.IntnlChain,link:OpenLayers.INCHES_PER_UNIT.IntnlLink,"us-in":OpenLayers.INCHES_PER_UNIT.inches,"us-ft":OpenLayers.INCHES_PER_UNIT.Foot,"us-yd":OpenLayers.INCHES_PER_UNIT.Yard,"us-ch":OpenLayers.INCHES_PER_UNIT.GunterChain,
+"us-mi":OpenLayers.INCHES_PER_UNIT.Mile,"ind-yd":OpenLayers.INCHES_PER_UNIT.IndianYd37,"ind-ft":OpenLayers.INCHES_PER_UNIT.IndianFt37,"ind-ch":20.11669506/OpenLayers.METERS_PER_INCH});OpenLayers.DOTS_PER_INCH=72;OpenLayers.Util.normalizeScale=function(a){return a>1?1/a:a};OpenLayers.Util.getResolutionFromScale=function(a,b){var c;if(a){if(b==null)b="degrees";c=1/(OpenLayers.Util.normalizeScale(a)*OpenLayers.INCHES_PER_UNIT[b]*OpenLayers.DOTS_PER_INCH)}return c};
+OpenLayers.Util.getScaleFromResolution=function(a,b){if(b==null)b="degrees";return a*OpenLayers.INCHES_PER_UNIT[b]*OpenLayers.DOTS_PER_INCH};OpenLayers.Util.safeStopPropagation=function(a){OpenLayers.Event.stop(a,true)};
+OpenLayers.Util.pagePosition=function(a){var b=[0,0],c=OpenLayers.Util.getViewportElement();if(!a||a==window||a==c)return b;var d=OpenLayers.IS_GECKO&&document.getBoxObjectFor&&OpenLayers.Element.getStyle(a,"position")=="absolute"&&(a.style.top==""||a.style.left==""),e=null;if(a.getBoundingClientRect){a=a.getBoundingClientRect();e=c.scrollTop;b[0]=a.left+c.scrollLeft;b[1]=a.top+e}else if(document.getBoxObjectFor&&!d){a=document.getBoxObjectFor(a);c=document.getBoxObjectFor(c);b[0]=a.screenX-c.screenX;
+b[1]=a.screenY-c.screenY}else{b[0]=a.offsetLeft;b[1]=a.offsetTop;e=a.offsetParent;if(e!=a)for(;e;){b[0]+=e.offsetLeft;b[1]+=e.offsetTop;e=e.offsetParent}c=OpenLayers.BROWSER_NAME;if(c=="opera"||c=="safari"&&OpenLayers.Element.getStyle(a,"position")=="absolute")b[1]-=document.body.offsetTop;for(e=a.offsetParent;e&&e!=document.body;){b[0]-=e.scrollLeft;if(c!="opera"||e.tagName!="TR")b[1]-=e.scrollTop;e=e.offsetParent}}return b};
+OpenLayers.Util.getViewportElement=function(){var a=arguments.callee.viewportElement;if(a==undefined){a=OpenLayers.BROWSER_NAME=="msie"&&document.compatMode!="CSS1Compat"?document.body:document.documentElement;arguments.callee.viewportElement=a}return a};
+OpenLayers.Util.isEquivalentUrl=function(a,b,c){c=c||{};OpenLayers.Util.applyDefaults(c,{ignoreCase:true,ignorePort80:true,ignoreHash:true});a=OpenLayers.Util.createUrlObject(a,c);b=OpenLayers.Util.createUrlObject(b,c);for(var d in a)if(d!=="args")if(a[d]!=b[d])return false;for(d in a.args){if(a.args[d]!=b.args[d])return false;delete b.args[d]}for(d in b.args)return false;return true};
+OpenLayers.Util.createUrlObject=function(a,b){b=b||{};if(!/^\w+:\/\//.test(a)){var c=window.location,d=c.port?":"+c.port:"";d=c.protocol+"//"+c.host.split(":").shift()+d;if(a.indexOf("/")===0)a=d+a;else{c=c.pathname.split("/");c.pop();a=d+c.join("/")+"/"+a}}if(b.ignoreCase)a=a.toLowerCase();c=document.createElement("a");c.href=a;d={};d.host=c.host.split(":").shift();d.protocol=c.protocol;d.port=b.ignorePort80?c.port=="80"||c.port=="0"?"":c.port:c.port==""||c.port=="0"?"80":c.port;d.hash=b.ignoreHash||
+c.hash==="#"?"":c.hash;var e=c.search;if(!e){e=a.indexOf("?");e=e!=-1?a.substr(e):""}d.args=OpenLayers.Util.getParameters(e);d.pathname=c.pathname.charAt(0)=="/"?c.pathname:"/"+c.pathname;return d};OpenLayers.Util.removeTail=function(a){var b=null;b=a.indexOf("?");var c=a.indexOf("#");return b=b==-1?c!=-1?a.substr(0,c):a:c!=-1?a.substr(0,Math.min(b,c)):a.substr(0,b)};OpenLayers.IS_GECKO=function(){var a=navigator.userAgent.toLowerCase();return a.indexOf("webkit")==-1&&a.indexOf("gecko")!=-1}();
+OpenLayers.BROWSER_NAME=function(){var a="",b=navigator.userAgent.toLowerCase();if(b.indexOf("opera")!=-1)a="opera";else if(b.indexOf("msie")!=-1)a="msie";else if(b.indexOf("safari")!=-1)a="safari";else if(b.indexOf("mozilla")!=-1)a=b.indexOf("firefox")!=-1?"firefox":"mozilla";return a}();OpenLayers.Util.getBrowserName=function(){return OpenLayers.BROWSER_NAME};
+OpenLayers.Util.getRenderedDimensions=function(a,b,c){var d,e,f=document.createElement("div");f.style.visibility="hidden";var g=c&&c.containerElement?c.containerElement:document.body;if(b)if(b.w){d=b.w;f.style.width=d+"px"}else if(b.h){e=b.h;f.style.height=e+"px"}if(c&&c.displayClass)f.className=c.displayClass;b=document.createElement("div");b.innerHTML=a;b.style.overflow="visible";if(b.childNodes){a=0;for(c=b.childNodes.length;a<c;a++)if(b.childNodes[a].style)b.childNodes[a].style.overflow="visible"}f.appendChild(b);
+g.appendChild(f);a=false;for(c=f.parentNode;c&&c.tagName.toLowerCase()!="body";){var h=OpenLayers.Element.getStyle(c,"position");if(h=="absolute"){a=true;break}else if(h&&h!="static")break;c=c.parentNode}if(!a)f.style.position="absolute";if(!d){d=parseInt(b.scrollWidth);f.style.width=d+"px"}e||(e=parseInt(b.scrollHeight));f.removeChild(b);g.removeChild(f);return new OpenLayers.Size(d,e)};
+OpenLayers.Util.getScrollbarWidth=function(){var a=OpenLayers.Util._scrollbarWidth;if(a==null){var b=null,c=null;b=a=0;b=document.createElement("div");b.style.position="absolute";b.style.top="-1000px";b.style.left="-1000px";b.style.width="100px";b.style.height="50px";b.style.overflow="hidden";c=document.createElement("div");c.style.width="100%";c.style.height="200px";b.appendChild(c);document.body.appendChild(b);a=c.offsetWidth;b.style.overflow="scroll";b=c.offsetWidth;document.body.removeChild(document.body.lastChild);
+OpenLayers.Util._scrollbarWidth=a-b;a=OpenLayers.Util._scrollbarWidth}return a};
+OpenLayers.Util.getFormattedLonLat=function(a,b,c){c||(c="dms");var d=Math.abs(a),e=Math.floor(d),f=d=(d-e)/(1/60);d=Math.floor(d);f=Math.round((f-d)/(1/60)*10);f/=10;if(f>=60){f-=60;d+=1;if(d>=60){d-=60;e+=1}}if(e<10)e="0"+e;e+="\u00b0";if(c.indexOf("dm")>=0){if(d<10)d="0"+d;e+=d+"'";if(c.indexOf("dms")>=0){if(f<10)f="0"+f;e+=f+'"'}}e+=b=="lon"?a<0?OpenLayers.i18n("W"):OpenLayers.i18n("E"):a<0?OpenLayers.i18n("S"):OpenLayers.i18n("N");return e};
+OpenLayers.Event={observers:false,KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(a){return a.target||a.srcElement},isSingleTouch:function(a){return a.touches&&a.touches.length==1},isMultiTouch:function(a){return a.touches&&a.touches.length>1},isLeftClick:function(a){return a.which&&a.which==1||a.button&&a.button==1},isRightClick:function(a){return a.which&&a.which==3||a.button&&a.button==2},stop:function(a,b){if(!b)if(a.preventDefault)a.preventDefault();
+else a.returnValue=false;if(a.stopPropagation)a.stopPropagation();else a.cancelBubble=true},findElement:function(a,b){for(var c=OpenLayers.Event.element(a);c.parentNode&&(!c.tagName||c.tagName.toUpperCase()!=b.toUpperCase());)c=c.parentNode;return c},observe:function(a,b,c,d){a=OpenLayers.Util.getElement(a);d=d||false;if(b=="keypress"&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||a.attachEvent))b="keydown";if(!this.observers)this.observers={};if(!a._eventCacheID){var e="eventCacheID_";if(a.id)e=
+a.id+"_"+e;a._eventCacheID=OpenLayers.Util.createUniqueID(e)}e=a._eventCacheID;this.observers[e]||(this.observers[e]=[]);this.observers[e].push({element:a,name:b,observer:c,useCapture:d});if(a.addEventListener)a.addEventListener(b,c,d);else a.attachEvent&&a.attachEvent("on"+b,c)},stopObservingElement:function(a){a=OpenLayers.Util.getElement(a)._eventCacheID;this._removeElementObservers(OpenLayers.Event.observers[a])},_removeElementObservers:function(a){if(a)for(var b=a.length-1;b>=0;b--){var c=a[b];
+OpenLayers.Event.stopObserving.apply(this,[c.element,c.name,c.observer,c.useCapture])}},stopObserving:function(a,b,c,d){d=d||false;a=OpenLayers.Util.getElement(a);var e=a._eventCacheID;if(b=="keypress")if(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||a.detachEvent)b="keydown";var f=false,g=OpenLayers.Event.observers[e];if(g)for(var h=0;!f&&h<g.length;){var i=g[h];if(i.name==b&&i.observer==c&&i.useCapture==d){g.splice(h,1);g.length==0&&delete OpenLayers.Event.observers[e];f=true;break}h++}if(f)if(a.removeEventListener)a.removeEventListener(b,
+c,d);else a&&a.detachEvent&&a.detachEvent("on"+b,c);return f},unloadCache:function(){if(OpenLayers.Event&&OpenLayers.Event.observers){for(var a in OpenLayers.Event.observers)OpenLayers.Event._removeElementObservers.apply(this,[OpenLayers.Event.observers[a]]);OpenLayers.Event.observers=false}},CLASS_NAME:"OpenLayers.Event"};OpenLayers.Event.observe(window,"unload",OpenLayers.Event.unloadCache,false);if(window.Event)OpenLayers.Util.applyDefaults(window.Event,OpenLayers.Event);else var Event=OpenLayers.Event;
+OpenLayers.Events=OpenLayers.Class({BROWSER_EVENTS:["mouseover","mouseout","mousedown","mouseup","mousemove","click","dblclick","rightclick","dblrightclick","resize","focus","blur","touchstart","touchmove","touchend"],listeners:null,object:null,element:null,eventTypes:null,eventHandler:null,fallThrough:null,includeXY:false,clearMouseListener:null,initialize:function(a,b,c,d,e){OpenLayers.Util.extend(this,e);this.object=a;this.fallThrough=d;this.listeners={};this.eventHandler=OpenLayers.Function.bindAsEventListener(this.handleBrowserEvent,
+this);this.clearMouseListener=OpenLayers.Function.bind(this.clearMouseCache,this);this.eventTypes=[];if(c!=null){a=0;for(d=c.length;a<d;a++)this.addEventType(c[a])}b!=null&&this.attachToElement(b)},destroy:function(){if(this.element){OpenLayers.Event.stopObservingElement(this.element);this.element.hasScrollEvent&&OpenLayers.Event.stopObserving(window,"scroll",this.clearMouseListener)}this.eventHandler=this.fallThrough=this.eventTypes=this.object=this.listeners=this.element=null},addEventType:function(a){if(!this.listeners[a]){this.eventTypes.push(a);
+this.listeners[a]=[]}},attachToElement:function(a){this.element&&OpenLayers.Event.stopObservingElement(this.element);this.element=a;for(var b=0,c=this.BROWSER_EVENTS.length;b<c;b++){var d=this.BROWSER_EVENTS[b];this.addEventType(d);OpenLayers.Event.observe(a,d,this.eventHandler)}OpenLayers.Event.observe(a,"dragstart",OpenLayers.Event.stop)},on:function(a){for(var b in a)b!="scope"&&this.register(b,a.scope,a[b])},register:function(a,b,c){if(c!=null&&OpenLayers.Util.indexOf(this.eventTypes,a)!=-1){if(b==
+null)b=this.object;this.listeners[a].push({obj:b,func:c})}},registerPriority:function(a,b,c){if(c!=null){if(b==null)b=this.object;a=this.listeners[a];a!=null&&a.unshift({obj:b,func:c})}},un:function(a){for(var b in a)b!="scope"&&this.unregister(b,a.scope,a[b])},unregister:function(a,b,c){if(b==null)b=this.object;a=this.listeners[a];if(a!=null)for(var d=0,e=a.length;d<e;d++)if(a[d].obj==b&&a[d].func==c){a.splice(d,1);break}},remove:function(a){if(this.listeners[a]!=null)this.listeners[a]=[]},triggerEvent:function(a,
+b){var c=this.listeners[a];if(!(!c||c.length==0)){if(b==null)b={};b.object=this.object;b.element=this.element;if(!b.type)b.type=a;c=c.slice();for(var d,e=0,f=c.length;e<f;e++){d=c[e];d=d.func.apply(d.obj,[b]);if(d!=undefined&&d==false)break}this.fallThrough||OpenLayers.Event.stop(b,true);return d}},handleBrowserEvent:function(a){var b=a.type,c=this.listeners[b];if(!(!c||c.length==0)){if((c=a.touches)&&c[0]){for(var d=0,e=0,f=c.length,g,h=0;h<f;++h){g=c[h];d+=g.clientX;e+=g.clientY}a.clientX=d/f;a.clientY=
+e/f}if(this.includeXY)a.xy=this.getMousePosition(a);this.triggerEvent(b,a)}},clearMouseCache:function(){this.element.scrolls=null;this.element.lefttop=null;this.element.offsets=null},getMousePosition:function(a){if(this.includeXY){if(!this.element.hasScrollEvent){OpenLayers.Event.observe(window,"scroll",this.clearMouseListener);this.element.hasScrollEvent=true}}else this.clearMouseCache();if(!this.element.scrolls){var b=OpenLayers.Util.getViewportElement();this.element.scrolls=[b.scrollLeft,b.scrollTop]}if(!this.element.lefttop)this.element.lefttop=
+[document.documentElement.clientLeft||0,document.documentElement.clientTop||0];if(!this.element.offsets)this.element.offsets=OpenLayers.Util.pagePosition(this.element);return new OpenLayers.Pixel(a.clientX+this.element.scrolls[0]-this.element.offsets[0]-this.element.lefttop[0],a.clientY+this.element.scrolls[1]-this.element.offsets[1]-this.element.lefttop[1])},CLASS_NAME:"OpenLayers.Events"});
+OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,Overlay:325,Feature:725,Popup:750,Control:1E3},EVENT_TYPES:["preaddlayer","addlayer","removelayer","changelayer","movestart","move","moveend","zoomend","popupopen","popupclose","addmarker","removemarker","clearmarkers","mouseover","mouseout","mousemove","dragstart","drag","dragend","changebaselayer"],id:null,fractionalZoom:false,events:null,allOverlays:false,div:null,dragging:false,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,
+layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,panRatio:1.5,viewRequestID:0,tileSize:null,projection:"EPSG:4326",units:"degrees",resolutions:null,maxResolution:1.40625,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:true,panTween:null,eventListeners:null,panMethod:OpenLayers.Easing.Expo.easeOut,panDuration:50,paddingForPopups:null,minPx:null,maxPx:null,
+initialize:function(a,b){if(arguments.length===1&&typeof a==="object")a=(b=a)&&b.div;this.tileSize=new OpenLayers.Size(OpenLayers.Map.TILE_WIDTH,OpenLayers.Map.TILE_HEIGHT);this.maxExtent=new OpenLayers.Bounds(-180,-90,180,90);this.paddingForPopups=new OpenLayers.Bounds(15,15,15,15);this.theme=OpenLayers._getScriptLocation()+"theme/default/style.css";OpenLayers.Util.extend(this,b);this.layers=[];this.id=OpenLayers.Util.createUniqueID("OpenLayers.Map_");this.div=OpenLayers.Util.getElement(a);if(!this.div){this.div=
+document.createElement("div");this.div.style.height="1px";this.div.style.width="1px"}OpenLayers.Element.addClass(this.div,"olMap");var c=this.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(c,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width="100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);c=document.createElement("div");c.id=this.id+"_events";c.style.position="absolute";c.style.width=
+"100%";c.style.height="100%";c.style.zIndex=this.Z_INDEX_BASE.Control-1;this.viewPortDiv.appendChild(c);this.eventsDiv=c;this.events=new OpenLayers.Events(this,this.eventsDiv,this.EVENT_TYPES,this.fallThrough,{includeXY:true});c=this.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(c);this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE.Popup-1;this.eventsDiv.appendChild(this.layerContainerDiv);this.updateSize();if(this.eventListeners instanceof Object)this.events.on(this.eventListeners);
+this.events.register("movestart",this,this.updateSize);if(OpenLayers.String.contains(navigator.appName,"Microsoft"))this.events.register("resize",this,this.updateSize);else{this.updateSizeDestroy=OpenLayers.Function.bind(this.updateSize,this);OpenLayers.Event.observe(window,"resize",this.updateSizeDestroy)}if(this.theme){c=true;for(var d=document.getElementsByTagName("link"),e=0,f=d.length;e<f;++e)if(OpenLayers.Util.isEquivalentUrl(d.item(e).href,this.theme)){c=false;break}if(c){c=document.createElement("link");
+c.setAttribute("rel","stylesheet");c.setAttribute("type","text/css");c.setAttribute("href",this.theme);document.getElementsByTagName("head")[0].appendChild(c)}}if(this.controls==null)this.controls=OpenLayers.Control!=null?[new OpenLayers.Control.Navigation,new OpenLayers.Control.PanZoom,new OpenLayers.Control.ArgParser,new OpenLayers.Control.Attribution]:[];e=0;for(f=this.controls.length;e<f;e++)this.addControlToMap(this.controls[e]);this.popups=[];this.unloadDestroy=OpenLayers.Function.bind(this.destroy,
+this);OpenLayers.Event.observe(window,"unload",this.unloadDestroy);if(b&&b.layers){delete this.center;this.addLayers(b.layers);b.center&&this.setCenter(b.center,b.zoom)}},render:function(a){this.div=OpenLayers.Util.getElement(a);OpenLayers.Element.addClass(this.div,"olMap");this.viewPortDiv.parentNode.removeChild(this.viewPortDiv);this.div.appendChild(this.viewPortDiv);this.updateSize()},unloadDestroy:null,updateSizeDestroy:null,destroy:function(){if(!this.unloadDestroy)return false;if(this.panTween){this.panTween.stop();
+this.panTween=null}OpenLayers.Event.stopObserving(window,"unload",this.unloadDestroy);this.unloadDestroy=null;this.updateSizeDestroy?OpenLayers.Event.stopObserving(window,"resize",this.updateSizeDestroy):this.events.unregister("resize",this,this.updateSize);this.paddingForPopups=null;if(this.controls!=null){for(var a=this.controls.length-1;a>=0;--a)this.controls[a].destroy();this.controls=null}if(this.layers!=null){for(a=this.layers.length-1;a>=0;--a)this.layers[a].destroy(false);this.layers=null}this.viewPortDiv&&
+this.div.removeChild(this.viewPortDiv);this.viewPortDiv=null;if(this.eventListeners){this.events.un(this.eventListeners);this.eventListeners=null}this.events.destroy();this.events=null},setOptions:function(a){OpenLayers.Util.extend(this,a)},getTileSize:function(){return this.tileSize},getBy:function(a,b,c){var d=typeof c.test=="function";return OpenLayers.Array.filter(this[a],function(e){return e[b]==c||d&&c.test(e[b])})},getLayersBy:function(a,b){return this.getBy("layers",a,b)},getLayersByName:function(a){return this.getLayersBy("name",
+a)},getLayersByClass:function(a){return this.getLayersBy("CLASS_NAME",a)},getControlsBy:function(a,b){return this.getBy("controls",a,b)},getControlsByClass:function(a){return this.getControlsBy("CLASS_NAME",a)},getLayer:function(a){for(var b=null,c=0,d=this.layers.length;c<d;c++){var e=this.layers[c];if(e.id==a){b=e;break}}return b},setLayerZIndex:function(a,b){a.setZIndex(this.Z_INDEX_BASE[a.isBaseLayer?"BaseLayer":"Overlay"]+b*5)},resetLayersZIndex:function(){for(var a=0,b=this.layers.length;a<
+b;a++)this.setLayerZIndex(this.layers[a],a)},addLayer:function(a){for(var b=0,c=this.layers.length;b<c;b++)if(this.layers[b]==a){a=OpenLayers.i18n("layerAlreadyAdded",{layerName:a.name});OpenLayers.Console.warn(a);return false}if(this.allOverlays)a.isBaseLayer=false;if(this.events.triggerEvent("preaddlayer",{layer:a})!==false){a.div.className="olLayerDiv";a.div.style.overflow="";this.setLayerZIndex(a,this.layers.length);a.isFixed?this.viewPortDiv.appendChild(a.div):this.layerContainerDiv.appendChild(a.div);
+this.layers.push(a);a.setMap(this);if(a.isBaseLayer||this.allOverlays&&!this.baseLayer)this.baseLayer==null?this.setBaseLayer(a):a.setVisibility(false);else a.redraw();this.events.triggerEvent("addlayer",{layer:a});a.events.triggerEvent("added",{map:this,layer:a});a.afterAdd()}},addLayers:function(a){for(var b=0,c=a.length;b<c;b++)this.addLayer(a[b])},removeLayer:function(a,b){if(b==null)b=true;a.isFixed?this.viewPortDiv.removeChild(a.div):this.layerContainerDiv.removeChild(a.div);OpenLayers.Util.removeItem(this.layers,
+a);a.removeMap(this);a.map=null;if(this.baseLayer==a){this.baseLayer=null;if(b)for(var c=0,d=this.layers.length;c<d;c++){var e=this.layers[c];if(e.isBaseLayer||this.allOverlays){this.setBaseLayer(e);break}}}this.resetLayersZIndex();this.events.triggerEvent("removelayer",{layer:a});a.events.triggerEvent("removed",{map:this,layer:a})},getNumLayers:function(){return this.layers.length},getLayerIndex:function(a){return OpenLayers.Util.indexOf(this.layers,a)},setLayerIndex:function(a,b){var c=this.getLayerIndex(a);
+if(b<0)b=0;else if(b>this.layers.length)b=this.layers.length;if(c!=b){this.layers.splice(c,1);this.layers.splice(b,0,a);c=0;for(var d=this.layers.length;c<d;c++)this.setLayerZIndex(this.layers[c],c);this.events.triggerEvent("changelayer",{layer:a,property:"order"});if(this.allOverlays)if(b===0)this.setBaseLayer(a);else this.baseLayer!==this.layers[0]&&this.setBaseLayer(this.layers[0])}},raiseLayer:function(a,b){var c=this.getLayerIndex(a)+b;this.setLayerIndex(a,c)},setBaseLayer:function(a){if(a!=
+this.baseLayer)if(OpenLayers.Util.indexOf(this.layers,a)!=-1){var b=this.getCachedCenter(),c=OpenLayers.Util.getResolutionFromScale(this.getScale(),a.units);this.baseLayer!=null&&!this.allOverlays&&this.baseLayer.setVisibility(false);this.baseLayer=a;this.viewRequestID++;if(!this.allOverlays||this.baseLayer.visibility)this.baseLayer.setVisibility(true);if(b!=null){a=this.getZoomForResolution(c||this.resolution,true);this.setCenter(b,a,false,true)}this.events.triggerEvent("changebaselayer",{layer:this.baseLayer})}},
+addControl:function(a,b){this.controls.push(a);this.addControlToMap(a,b)},addControls:function(a,b){for(var c=arguments.length===1?[]:b,d=0,e=a.length;d<e;d++)this.addControl(a[d],c[d]?c[d]:null)},addControlToMap:function(a,b){a.outsideViewport=a.div!=null;if(this.displayProjection&&!a.displayProjection)a.displayProjection=this.displayProjection;a.setMap(this);var c=a.draw(b);if(c)if(!a.outsideViewport){c.style.zIndex=this.Z_INDEX_BASE.Control+this.controls.length;this.viewPortDiv.appendChild(c)}a.autoActivate&&
+a.activate()},getControl:function(a){for(var b=null,c=0,d=this.controls.length;c<d;c++){var e=this.controls[c];if(e.id==a){b=e;break}}return b},removeControl:function(a){if(a&&a==this.getControl(a.id)){a.div&&a.div.parentNode==this.viewPortDiv&&this.viewPortDiv.removeChild(a.div);OpenLayers.Util.removeItem(this.controls,a)}},addPopup:function(a,b){if(b)for(var c=this.popups.length-1;c>=0;--c)this.removePopup(this.popups[c]);a.map=this;this.popups.push(a);if(c=a.draw()){c.style.zIndex=this.Z_INDEX_BASE.Popup+
+this.popups.length;this.layerContainerDiv.appendChild(c)}},removePopup:function(a){OpenLayers.Util.removeItem(this.popups,a);if(a.div)try{this.layerContainerDiv.removeChild(a.div)}catch(b){}a.map=null},getSize:function(){var a=null;if(this.size!=null)a=this.size.clone();return a},updateSize:function(){var a=this.getCurrentSize();if(a&&!isNaN(a.h)&&!isNaN(a.w)){this.events.clearMouseCache();var b=this.getSize();if(b==null)this.size=b=a;if(!a.equals(b)){this.size=a;a=0;for(b=this.layers.length;a<b;a++)this.layers[a].onMapResize();
+a=this.getCachedCenter();if(this.baseLayer!=null&&a!=null){b=this.getZoom();this.zoom=null;this.setCenter(a,b)}}}},getCurrentSize:function(){var a=new OpenLayers.Size(this.div.clientWidth,this.div.clientHeight);if(a.w==0&&a.h==0||isNaN(a.w)&&isNaN(a.h)){a.w=this.div.offsetWidth;a.h=this.div.offsetHeight}if(a.w==0&&a.h==0||isNaN(a.w)&&isNaN(a.h)){a.w=parseInt(this.div.style.width);a.h=parseInt(this.div.style.height)}return a},calculateBounds:function(a,b){var c=null;if(a==null)a=this.getCachedCenter();
+if(b==null)b=this.getResolution();if(a!=null&&b!=null){var d=this.getSize();c=d.w*b;d=d.h*b;c=new OpenLayers.Bounds(a.lon-c/2,a.lat-d/2,a.lon+c/2,a.lat+d/2)}return c},getCenter:function(){var a=null,b=this.getCachedCenter();if(b)a=b.clone();return a},getCachedCenter:function(){if(!this.center&&this.size)this.center=this.getLonLatFromViewPortPx(new OpenLayers.Pixel(this.size.w/2,this.size.h/2));return this.center},getZoom:function(){return this.zoom},pan:function(a,b,c){c=OpenLayers.Util.applyDefaults(c,
+{animate:true,dragging:false});if(c.dragging){if(a!=0||b!=0)this.moveByPx(a,b)}else{var d=!this.center,e=this.getViewPortPxFromLonLat(this.getCachedCenter());a=e.add(a,b);if(d||!a.equals(e)){d=this.getLonLatFromViewPortPx(a);c.animate?this.panTo(d):this.setCenter(d,null,c.dragging)}}},panTo:function(a){if(this.panMethod&&this.getExtent().scale(this.panRatio).containsLonLat(a)){if(!this.panTween)this.panTween=new OpenLayers.Tween(this.panMethod);var b=this.getCachedCenter();if(!(a.lon==b.lon&&a.lat==
+b.lat)){b=this.getPixelFromLonLat(b);var c=this.getPixelFromLonLat(a),d={x:0,y:0};this.panTween.start({x:0,y:0},{x:c.x-b.x,y:c.y-b.y},this.panDuration,{callbacks:{start:OpenLayers.Function.bind(function(){this.events.triggerEvent("movestart")},this),eachStep:OpenLayers.Function.bind(function(e){this.moveByPx(e.x-d.x,e.y-d.y);d.x=Math.round(e.x);d.y=Math.round(e.y)},this),done:OpenLayers.Function.bind(function(){this.moveTo(a,this.zoom,{noEvent:true});this.events.triggerEvent("moveend")},this)}})}}else this.setCenter(a)},
+setCenter:function(a,b,c,d){this.moveTo(a,b,{dragging:c,forceZoomChange:d,caller:"setCenter"})},moveByPx:function(a,b){a=Math.round(a);b=Math.round(b);var c=this.size.w/2,d=this.size.h/2,e=c+a,f=d+b,g=f<=this.maxPx.y&&f>=this.minPx.y,h,i;if(this.baseLayer.wrapDateLine===true){h=this.minPx.x;i=this.maxPx.x}else g=g&&e<=this.maxPx.x&&e>=this.minPx.x;if(this.restrictedExtent&&g)g=!(this.maxPx.x-e<c||e-this.minPx.x<c||this.maxPx.y-f<d||f-this.minPx.y<d);if(g){this.center=null;if(a){this.layerContainerDiv.style.left=
+parseInt(this.layerContainerDiv.style.left)-a+"px";this.minPx.x-=a;this.maxPx.x-=a;if(this.baseLayer.wrapDateLine===true){if(this.maxPx.x>i)this.maxPx.x-=i-h;if(this.minPx.x<h)this.minPx.x+=i-h}}if(b){this.layerContainerDiv.style.top=parseInt(this.layerContainerDiv.style.top)-b+"px";this.minPx.y-=b;this.maxPx.y-=b}d=0;for(e=this.layers.length;d<e;++d){c=this.layers[d];if(c.visibility){c.moveByPx(a,b);c.events.triggerEvent("move")}}this.events.triggerEvent("move")}},moveTo:function(a,b,c){c||(c={});
+if(b!=null){b=parseFloat(b);this.fractionalZoom||(b=Math.round(b))}var d=c.dragging,e=c.forceZoomChange,f=c.noEvent;this.panTween&&c.caller=="setCenter"&&this.panTween.stop();if(!this.getCachedCenter()&&!this.isValidLonLat(a))a=this.maxExtent.getCenterLonLat();if(this.restrictedExtent!=null){if(a==null)a=this.center;if(b==null)b=this.getZoom();c=this.getResolutionForZoom(b);c=this.calculateBounds(a,c);if(!this.restrictedExtent.containsBounds(c)){var g=this.restrictedExtent.getCenterLonLat();if(c.getWidth()>
+this.restrictedExtent.getWidth())a=new OpenLayers.LonLat(g.lon,a.lat);else if(c.left<this.restrictedExtent.left)a=a.add(this.restrictedExtent.left-c.left,0);else if(c.right>this.restrictedExtent.right)a=a.add(this.restrictedExtent.right-c.right,0);if(c.getHeight()>this.restrictedExtent.getHeight())a=new OpenLayers.LonLat(a.lon,g.lat);else if(c.bottom<this.restrictedExtent.bottom)a=a.add(0,this.restrictedExtent.bottom-c.bottom);else if(c.top>this.restrictedExtent.top)a=a.add(0,this.restrictedExtent.top-
+c.top)}}e=e||this.isValidZoomLevel(b)&&b!=this.getZoom();c=this.isValidLonLat(a)&&!a.equals(this.center);if(e||c||!d){!this.dragging&&!f&&this.events.triggerEvent("movestart");if(c){!e&&this.center&&this.centerLayerContainer(a);this.center=a.clone()}a=e?this.getResolutionForZoom(b):this.getResolution();if(e||this.layerContainerOrigin==null){this.layerContainerOrigin=this.getCachedCenter();this.layerContainerDiv.style.left="0px";this.layerContainerDiv.style.top="0px";var h=this.getMaxExtent({restricted:true});
+c=h.getCenterLonLat();g=this.center.lon-c.lon;var i=c.lat-this.center.lat;c=Math.round(h.getWidth()/a);h=Math.round(h.getHeight()/a);g=(this.size.w-c)/2-g/a;i=(this.size.h-h)/2-i/a;this.minPx=new OpenLayers.Pixel(g,i);this.maxPx=new OpenLayers.Pixel(g+c,i+h)}if(e){this.zoom=b;this.resolution=a;this.viewRequestID++}b=this.getExtent();if(this.baseLayer.visibility){this.baseLayer.moveTo(b,e,d);d?this.baseLayer.events.triggerEvent("move"):this.baseLayer.events.triggerEvent("moveend",{zoomChanged:e})}b=
+this.baseLayer.getExtent();a=0;for(c=this.layers.length;a<c;a++){g=this.layers[a];if(g!==this.baseLayer&&!g.isBaseLayer){i=g.calculateInRange();if(g.inRange!=i){(g.inRange=i)||g.display(false);this.events.triggerEvent("changelayer",{layer:g,property:"visibility"})}if(i&&g.visibility){g.moveTo(b,e,d);d?g.events.triggerEvent("move"):g.events.triggerEvent("moveend",{zoomChanged:e})}}}if(e){a=0;for(c=this.popups.length;a<c;a++)this.popups[a].updatePosition()}this.events.triggerEvent("move");e&&this.events.triggerEvent("zoomend")}!d&&
+!f&&this.events.triggerEvent("moveend");this.dragging=!!d},centerLayerContainer:function(a){var b=this.getViewPortPxFromLonLat(this.layerContainerOrigin),c=this.getViewPortPxFromLonLat(a);if(b!=null&&c!=null){var d=parseInt(this.layerContainerDiv.style.left);a=parseInt(this.layerContainerDiv.style.top);var e=Math.round(b.x-c.x);b=Math.round(b.y-c.y);this.layerContainerDiv.style.left=e+"px";this.layerContainerDiv.style.top=b+"px";d-=e;a-=b;this.minPx.x-=d;this.maxPx.x-=d;this.minPx.y-=a;this.maxPx.y-=
+a}},isValidZoomLevel:function(a){return a!=null&&a>=this.getRestrictedMinZoom()&&a<this.getNumZoomLevels()},isValidLonLat:function(a){var b=false;if(a!=null)b=this.getMaxExtent().containsLonLat(a);return b},getProjection:function(){var a=this.getProjectionObject();return a?a.getCode():null},getProjectionObject:function(){var a=null;if(this.baseLayer!=null)a=this.baseLayer.projection;return a},getMaxResolution:function(){var a=null;if(this.baseLayer!=null)a=this.baseLayer.maxResolution;return a},getMaxExtent:function(a){var b=
+null;if(a&&a.restricted&&this.restrictedExtent)b=this.restrictedExtent;else if(this.baseLayer!=null)b=this.baseLayer.maxExtent;return b},getRestrictedMinZoom:function(){var a=null;if(this.baseLayer!=null)a=this.baseLayer.restrictedMinZoom;return a},getNumZoomLevels:function(){var a=null;if(this.baseLayer!=null)a=this.baseLayer.numZoomLevels;return a},getExtent:function(){var a=null;if(this.baseLayer!=null)a=this.baseLayer.getExtent();return a},getResolution:function(){var a=null;if(this.baseLayer!=
+null)a=this.baseLayer.getResolution();else if(this.allOverlays===true&&this.layers.length>0)a=this.layers[0].getResolution();return a},getUnits:function(){var a=null;if(this.baseLayer!=null)a=this.baseLayer.units;return a},getScale:function(){var a=null;if(this.baseLayer!=null){a=this.getResolution();a=OpenLayers.Util.getScaleFromResolution(a,this.baseLayer.units)}return a},getZoomForExtent:function(a,b){var c=null;if(this.baseLayer!=null)c=this.baseLayer.getZoomForExtent(a,b);return c},getResolutionForZoom:function(a){var b=
+null;if(this.baseLayer)b=this.baseLayer.getResolutionForZoom(a);return b},getZoomForResolution:function(a,b){var c=null;if(this.baseLayer!=null)c=this.baseLayer.getZoomForResolution(a,b);return c},zoomTo:function(a){this.isValidZoomLevel(a)&&this.setCenter(null,a)},zoomIn:function(){this.zoomTo(this.getZoom()+1)},zoomOut:function(){this.zoomTo(this.getZoom()-1)},zoomToExtent:function(a,b){var c=a.getCenterLonLat();if(this.baseLayer.wrapDateLine){c=this.getMaxExtent();for(a=a.clone();a.right<a.left;)a.right+=
+c.getWidth();c=a.getCenterLonLat().wrapDateLine(c)}this.setCenter(c,this.getZoomForExtent(a,b))},zoomToMaxExtent:function(a){this.zoomToExtent(this.getMaxExtent({restricted:a?a.restricted:true}))},zoomToScale:function(a,b){var c=OpenLayers.Util.getResolutionFromScale(a,this.baseLayer.units),d=this.getSize(),e=d.w*c;c*=d.h;d=this.getCachedCenter();this.zoomToExtent(new OpenLayers.Bounds(d.lon-e/2,d.lat-c/2,d.lon+e/2,d.lat+c/2),b)},getLonLatFromViewPortPx:function(a){var b=null;if(this.baseLayer!=null)b=
+this.baseLayer.getLonLatFromViewPortPx(a);return b},getViewPortPxFromLonLat:function(a){var b=null;if(this.baseLayer!=null)b=this.baseLayer.getViewPortPxFromLonLat(a);return b},getLonLatFromPixel:function(a){return this.getLonLatFromViewPortPx(a)},getPixelFromLonLat:function(a){a=this.getViewPortPxFromLonLat(a);a.x=Math.round(a.x);a.y=Math.round(a.y);return a},getGeodesicPixelSize:function(a){var b=a?this.getLonLatFromPixel(a):this.getCachedCenter()||new OpenLayers.LonLat(0,0),c=this.getResolution();
+a=b.add(-c/2,0);var d=b.add(c/2,0),e=b.add(0,-c/2);b=b.add(0,c/2);c=new OpenLayers.Projection("EPSG:4326");var f=this.getProjectionObject()||c;if(!f.equals(c)){a.transform(f,c);d.transform(f,c);e.transform(f,c);b.transform(f,c)}return new OpenLayers.Size(OpenLayers.Util.distVincenty(a,d),OpenLayers.Util.distVincenty(e,b))},getViewPortPxFromLayerPx:function(a){var b=null;if(a!=null){b=parseInt(this.layerContainerDiv.style.left);var c=parseInt(this.layerContainerDiv.style.top);b=a.add(b,c)}return b},
+getLayerPxFromViewPortPx:function(a){var b=null;if(a!=null){b=-parseInt(this.layerContainerDiv.style.left);var c=-parseInt(this.layerContainerDiv.style.top);b=a.add(b,c);if(isNaN(b.x)||isNaN(b.y))b=null}return b},getLonLatFromLayerPx:function(a){a=this.getViewPortPxFromLayerPx(a);return this.getLonLatFromViewPortPx(a)},getLayerPxFromLonLat:function(a){return this.getLayerPxFromViewPortPx(this.getPixelFromLonLat(a))},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;
+OpenLayers.Map.TILE_HEIGHT=256;
+OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",autoActivate:false,active:null,handler:null,eventListeners:null,events:null,EVENT_TYPES:["activate","deactivate"],initialize:function(a){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,a);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object)this.events.on(this.eventListeners);if(this.id==
+null)this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},destroy:function(){if(this.events){this.eventListeners&&this.events.un(this.eventListeners);this.events.destroy();this.events=null}this.eventListeners=null;if(this.handler){this.handler.destroy();this.handler=null}if(this.handlers){for(var a in this.handlers)this.handlers.hasOwnProperty(a)&&typeof this.handlers[a].destroy=="function"&&this.handlers[a].destroy();this.handlers=null}if(this.map){this.map.removeControl(this);this.map=null}},
+setMap:function(a){this.map=a;this.handler&&this.handler.setMap(a)},draw:function(a){if(this.div==null){this.div=OpenLayers.Util.createDiv(this.id);this.div.className=this.displayClass;if(!this.allowSelection){this.div.className+=" olControlNoSelect";this.div.setAttribute("unselectable","on",0);this.div.onselectstart=OpenLayers.Function.False}if(this.title!="")this.div.title=this.title}if(a!=null)this.position=a.clone();this.moveTo(this.position);return this.div},moveTo:function(a){if(a!=null&&this.div!=
+null){this.div.style.left=a.x+"px";this.div.style.top=a.y+"px"}},activate:function(){if(this.active)return false;this.handler&&this.handler.activate();this.active=true;this.map&&OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");this.events.triggerEvent("activate");return true},deactivate:function(){if(this.active){this.handler&&this.handler.deactivate();this.active=false;this.map&&OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,
+"")+"Active");this.events.triggerEvent("deactivate");return true}return false},CLASS_NAME:"OpenLayers.Control"});OpenLayers.Control.TYPE_BUTTON=1;OpenLayers.Control.TYPE_TOGGLE=2;OpenLayers.Control.TYPE_TOOL=3;
+OpenLayers.Control.Attribution=OpenLayers.Class(OpenLayers.Control,{separator:", ",initialize:function(){OpenLayers.Control.prototype.initialize.apply(this,arguments)},destroy:function(){this.map.events.un({removelayer:this.updateAttribution,addlayer:this.updateAttribution,changelayer:this.updateAttribution,changebaselayer:this.updateAttribution,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments)},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.map.events.on({changebaselayer:this.updateAttribution,
+changelayer:this.updateAttribution,addlayer:this.updateAttribution,removelayer:this.updateAttribution,scope:this});this.updateAttribution();return this.div},updateAttribution:function(){var a=[];if(this.map&&this.map.layers){for(var b=0,c=this.map.layers.length;b<c;b++){var d=this.map.layers[b];d.attribution&&d.getVisibility()&&OpenLayers.Util.indexOf(a,d.attribution)===-1&&a.push(d.attribution)}this.div.innerHTML=a.join(this.separator)}},CLASS_NAME:"OpenLayers.Control.Attribution"});
+OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,initialize:function(a,b,c){OpenLayers.Util.extend(this,c);this.control=a;this.callbacks=b;(a=this.map||a.map)&&this.setMap(a);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},setMap:function(a){this.map=a},checkModifiers:function(a){if(this.keyMask==null)return true;return((a.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(a.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(a.altKey?OpenLayers.Handler.MOD_ALT:
+0))==this.keyMask},activate:function(){if(this.active)return false;for(var a=OpenLayers.Events.prototype.BROWSER_EVENTS,b=0,c=a.length;b<c;b++)this[a[b]]&&this.register(a[b],this[a[b]]);return this.active=true},deactivate:function(){if(!this.active)return false;for(var a=OpenLayers.Events.prototype.BROWSER_EVENTS,b=0,c=a.length;b<c;b++)this[a[b]]&&this.unregister(a[b],this[a[b]]);this.active=false;return true},callback:function(a,b){a&&this.callbacks[a]&&this.callbacks[a].apply(this.control,b)},register:function(a,
+b){this.map.events.registerPriority(a,this,b);this.map.events.registerPriority(a,this,this.setEvent)},unregister:function(a,b){this.map.events.unregister(a,this,b);this.map.events.unregister(a,this,this.setEvent)},setEvent:function(a){this.evt=a;return true},destroy:function(){this.deactivate();this.control=this.map=null},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;
+OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,"double":false,pixelTolerance:0,stopSingle:false,stopDouble:false,timerId:null,down:null,last:null,rightclickTimerId:null,initialize:function(){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.pixelTolerance!=null)this.mousedown=function(a){this.down=this.getEventInfo(a);return true}},mousedown:null,touchstart:function(a){this.down=this.getEventInfo(a);this.last=null;return true},mouseup:function(a){var b=
+true;if(this.checkModifiers(a)&&this.control.handleRightClicks&&OpenLayers.Event.isRightClick(a))b=this.rightclick(a);return b},rightclick:function(a){if(this.passesTolerance(a))if(this.rightclickTimerId!=null){this.clearTimer();this.callback("dblrightclick",[a]);return!this.stopDouble}else{a=this["double"]?OpenLayers.Util.extend({},a):this.callback("rightclick",[a]);a=OpenLayers.Function.bind(this.delayedRightCall,this,a);this.rightclickTimerId=window.setTimeout(a,this.delay)}return!this.stopSingle},
+delayedRightCall:function(a){this.rightclickTimerId=null;a&&this.callback("rightclick",[a]);return!this.stopSingle},dblclick:function(a){var b=this.down||this.last;if(this.passesTolerance(a)&&(!b||!b.touches||b.touches.length==1)){this["double"]&&this.callback("dblclick",[a]);this.clearTimer()}return!this.stopDouble},touchmove:function(a){this.last=this.getEventInfo(a)},touchend:function(a){var b=this.last||this.down;if(!a||!b)return false;a.xy=b.xy;a.lastTouches=b.touches;return a.xy?this.click(a):
+false},click:function(a){if(this.down&&this.down.touches&&a.type==="click")return!this.stopSingle;if(this.passesTolerance(a))if(this.timerId!=null){var b=this.down||this.last;b&&b.touches&&b.touches.length>0?this.dblclick(a):this.clearTimer()}else{a=this.single?OpenLayers.Util.extend({},a):null;this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,a),this.delay)}return!this.stopSingle},passesTolerance:function(a){var b=true;if(this.pixelTolerance!=null&&this.down&&this.down.xy)if(Math.sqrt(Math.pow(this.down.xy.x-
+a.xy.x,2)+Math.pow(this.down.xy.y-a.xy.y,2))>this.pixelTolerance)b=false;return b},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null}if(this.rightclickTimerId!=null){window.clearTimeout(this.rightclickTimerId);this.rightclickTimerId=null}},delayedCall:function(a){this.timerId=null;a&&this.callback("click",[a])},getEventInfo:function(a){var b;if(a.touches){var c=a.touches.length;b=Array(c);for(var d,e=0;e<c;e++){d=a.touches[e];b[e]={clientX:d.clientX,
+clientY:d.clientY}}}return{xy:a.xy,touches:b}},deactivate:function(){var a=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();this.last=this.down=null;a=true}return a},CLASS_NAME:"OpenLayers.Handler.Click"});
+OpenLayers.Kinetic=OpenLayers.Class({threshold:0,interval:10,deceleration:0.0035,nbPoints:100,delay:200,points:undefined,timerId:undefined,initialize:function(a){OpenLayers.Util.extend(this,a)},begin:function(){clearInterval(this.timerId);this.timerId=undefined;this.points=[]},update:function(a){this.points.unshift({xy:a,tick:(new Date).getTime()});this.points.length>this.nbPoints&&this.points.pop()},end:function(a){for(var b,c=(new Date).getTime(),d=0,e=this.points.length,f;d<e;d++){f=this.points[d];
+if(c-f.tick>this.delay)break;b=f}if(b){d=(new Date).getTime()-b.tick;c=Math.sqrt(Math.pow(a.x-b.xy.x,2)+Math.pow(a.y-b.xy.y,2));d=c/d;if(!(d==0||d<this.threshold)){c=Math.asin((a.y-b.xy.y)/c);if(b.xy.x<=a.x)c=Math.PI-c;return{speed:d,theta:c}}}},move:function(a,b){var c=a.speed,d=Math.cos(a.theta),e=-Math.sin(a.theta),f=0,g=(new Date).getTime(),h=0,i=0;this.timerId=window.setInterval(OpenLayers.Function.bind(function(){if(this.timerId!=null){f+=this.interval;var j=(new Date).getTime()-g;j=(f+j)/2;
+var k=-this.deceleration*Math.pow(j,2)/2+c*j,s=k*d;k*=e;var m={};m.end=false;if(-this.deceleration*j+c<=0){clearInterval(this.timerId);this.timerId=null;m.end=true}m.x=s-h;m.y=k-i;h=s;i=k;b(m.x,m.y,m.end)}},this),this.interval)},CLASS_NAME:"OpenLayers.Kinetic"});OpenLayers.Rico=OpenLayers.Rico||{};
+OpenLayers.Rico.Color=OpenLayers.Class({initialize:function(a,b,c){this.rgb={r:a,g:b,b:c}},setRed:function(a){this.rgb.r=a},setGreen:function(a){this.rgb.g=a},setBlue:function(a){this.rgb.b=a},setHue:function(a){var b=this.asHSB();b.h=a;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(b.h,b.s,b.b)},setSaturation:function(a){var b=this.asHSB();b.s=a;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(b.h,b.s,b.b)},setBrightness:function(a){var b=this.asHSB();b.b=a;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(b.h,b.s,b.b)},
+darken:function(a){var b=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(b.h,b.s,Math.max(b.b-a,0))},brighten:function(a){var b=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(b.h,b.s,Math.min(b.b+a,1))},blend:function(a){this.rgb.r=Math.floor((this.rgb.r+a.rgb.r)/2);this.rgb.g=Math.floor((this.rgb.g+a.rgb.g)/2);this.rgb.b=Math.floor((this.rgb.b+a.rgb.b)/2)},isBright:function(){this.asHSB();return this.asHSB().b>0.5},isDark:function(){return!this.isBright()},asRGB:function(){return"rgb("+
+this.rgb.r+","+this.rgb.g+","+this.rgb.b+")"},asHex:function(){return"#"+this.rgb.r.toColorPart()+this.rgb.g.toColorPart()+this.rgb.b.toColorPart()},asHSB:function(){return OpenLayers.Rico.Color.RGBtoHSB(this.rgb.r,this.rgb.g,this.rgb.b)},toString:function(){return this.asHex()}});
+OpenLayers.Rico.Color.createFromHex=function(a){if(a.length==4){var b=a;a="#";for(var c=1;c<4;c++)a+=b.charAt(c)+b.charAt(c)}if(a.indexOf("#")==0)a=a.substring(1);b=a.substring(0,2);c=a.substring(2,4);a=a.substring(4,6);return new OpenLayers.Rico.Color(parseInt(b,16),parseInt(c,16),parseInt(a,16))};
+OpenLayers.Rico.Color.createColorFromBackground=function(a){var b=RicoUtil.getElementsComputedStyle(OpenLayers.Util.getElement(a),"backgroundColor","background-color");if(b=="transparent"&&a.parentNode)return OpenLayers.Rico.Color.createColorFromBackground(a.parentNode);if(b==null)return new OpenLayers.Rico.Color(255,255,255);if(b.indexOf("rgb(")==0){a=b.substring(4,b.length-1).split(",");return new OpenLayers.Rico.Color(parseInt(a[0]),parseInt(a[1]),parseInt(a[2]))}else return b.indexOf("#")==0?
+OpenLayers.Rico.Color.createFromHex(b):new OpenLayers.Rico.Color(255,255,255)};
+OpenLayers.Rico.Color.HSBtoRGB=function(a,b,c){var d=0,e=0,f=0;if(b==0)f=e=d=parseInt(c*255+0.5);else{a=(a-Math.floor(a))*6;var g=a-Math.floor(a),h=c*(1-b),i=c*(1-b*g);b=c*(1-b*(1-g));switch(parseInt(a)){case 0:d=c*255+0.5;e=b*255+0.5;f=h*255+0.5;break;case 1:d=i*255+0.5;e=c*255+0.5;f=h*255+0.5;break;case 2:d=h*255+0.5;e=c*255+0.5;f=b*255+0.5;break;case 3:d=h*255+0.5;e=i*255+0.5;f=c*255+0.5;break;case 4:d=b*255+0.5;e=h*255+0.5;f=c*255+0.5;break;case 5:d=c*255+0.5;e=h*255+0.5;f=i*255+0.5}}return{r:parseInt(d),
+g:parseInt(e),b:parseInt(f)}};OpenLayers.Rico.Color.RGBtoHSB=function(a,b,c){var d,e=a>b?a:b;if(c>e)e=c;var f=a<b?a:b;if(c<f)f=c;d=e!=0?(e-f)/e:0;if(d==0)a=0;else{var g=(e-a)/(e-f),h=(e-b)/(e-f);c=(e-c)/(e-f);a=a==e?c-h:b==e?2+g-c:4+h-g;a/=6;if(a<0)a+=1}return{h:a,s:d,b:e/255}};OpenLayers.Rico=OpenLayers.Rico||{};
+OpenLayers.Rico.Corner={round:function(a,b){a=OpenLayers.Util.getElement(a);this._setOptions(b);var c=this.options.color;if(this.options.color=="fromElement")c=this._background(a);var d=this.options.bgColor;if(this.options.bgColor=="fromParent")d=this._background(a.offsetParent);this._roundCornersImpl(a,c,d)},changeColor:function(a,b){a.style.backgroundColor=b;for(var c=a.parentNode.getElementsByTagName("span"),d=0;d<c.length;d++)c[d].style.backgroundColor=b},changeOpacity:function(a,b){var c="alpha(opacity="+
+b*100+")";a.style.opacity=b;a.style.filter=c;for(var d=a.parentNode.getElementsByTagName("span"),e=0;e<d.length;e++){d[e].style.opacity=b;d[e].style.filter=c}},reRound:function(a,b){var c=a.parentNode.childNodes[2];a.parentNode.removeChild(a.parentNode.childNodes[0]);a.parentNode.removeChild(c);this.round(a.parentNode,b)},_roundCornersImpl:function(a,b,c){this.options.border&&this._renderBorder(a,c);this._isTopRounded()&&this._roundTopCorners(a,b,c);this._isBottomRounded()&&this._roundBottomCorners(a,
+b,c)},_renderBorder:function(a,b){var c="1px solid "+this._borderColor(b);a.innerHTML="<div "+("style='"+("border-left: "+c)+";"+("border-right: "+c)+"'")+">"+a.innerHTML+"</div>"},_roundTopCorners:function(a,b,c){for(var d=this._createCorner(c),e=0;e<this.options.numSlices;e++)d.appendChild(this._createCornerSlice(b,c,e,"top"));a.style.paddingTop=0;a.insertBefore(d,a.firstChild)},_roundBottomCorners:function(a,b,c){for(var d=this._createCorner(c),e=this.options.numSlices-1;e>=0;e--)d.appendChild(this._createCornerSlice(b,
+c,e,"bottom"));a.style.paddingBottom=0;a.appendChild(d)},_createCorner:function(a){var b=document.createElement("div");b.style.backgroundColor=this._isTransparent()?"transparent":a;return b},_createCornerSlice:function(a,b,c,d){var e=document.createElement("span"),f=e.style;f.backgroundColor=a;f.display="block";f.height="1px";f.overflow="hidden";f.fontSize="1px";a=this._borderColor(a,b);if(this.options.border&&c==0){f.borderTopStyle="solid";f.borderTopWidth="1px";f.borderLeftWidth="0px";f.borderRightWidth=
+"0px";f.borderBottomWidth="0px";f.height="0px";f.borderColor=a}else if(a){f.borderColor=a;f.borderStyle="solid";f.borderWidth="0px 1px"}if(!this.options.compact&&c==this.options.numSlices-1)f.height="2px";this._setMargin(e,c,d);this._setBorder(e,c,d);return e},_setOptions:function(a){this.options={corners:"all",color:"fromElement",bgColor:"fromParent",blend:true,border:false,compact:false};OpenLayers.Util.extend(this.options,a||{});this.options.numSlices=this.options.compact?2:4;if(this._isTransparent())this.options.blend=
+false},_whichSideTop:function(){if(this._hasString(this.options.corners,"all","top"))return"";if(this.options.corners.indexOf("tl")>=0&&this.options.corners.indexOf("tr")>=0)return"";if(this.options.corners.indexOf("tl")>=0)return"left";else if(this.options.corners.indexOf("tr")>=0)return"right";return""},_whichSideBottom:function(){if(this._hasString(this.options.corners,"all","bottom"))return"";if(this.options.corners.indexOf("bl")>=0&&this.options.corners.indexOf("br")>=0)return"";if(this.options.corners.indexOf("bl")>=
+0)return"left";else if(this.options.corners.indexOf("br")>=0)return"right";return""},_borderColor:function(a,b){return a=="transparent"?b:this.options.border?this.options.border:this.options.blend?this._blend(b,a):""},_setMargin:function(a,b,c){b=this._marginSize(b);c=c=="top"?this._whichSideTop():this._whichSideBottom();if(c=="left"){a.style.marginLeft=b+"px";a.style.marginRight="0px"}else if(c=="right"){a.style.marginRight=b+"px";a.style.marginLeft="0px"}else{a.style.marginLeft=b+"px";a.style.marginRight=
+b+"px"}},_setBorder:function(a,b,c){b=this._borderSize(b);c=c=="top"?this._whichSideTop():this._whichSideBottom();if(c=="left"){a.style.borderLeftWidth=b+"px";a.style.borderRightWidth="0px"}else if(c=="right"){a.style.borderRightWidth=b+"px";a.style.borderLeftWidth="0px"}else{a.style.borderLeftWidth=b+"px";a.style.borderRightWidth=b+"px"}if(this.options.border!=false){a.style.borderLeftWidth=b+"px";a.style.borderRightWidth=b+"px"}},_marginSize:function(a){if(this._isTransparent())return 0;var b=[5,
+3,2,1],c=[3,2,1,0],d=[2,1],e=[1,0];return this.options.compact&&this.options.blend?e[a]:this.options.compact?d[a]:this.options.blend?c[a]:b[a]},_borderSize:function(a){var b=[5,3,2,1],c=[2,1,1,1],d=[1,0],e=[0,2,0,0];if(this.options.compact&&(this.options.blend||this._isTransparent()))return 1;else if(this.options.compact)return d[a];else if(this.options.blend)return c[a];else if(this.options.border)return e[a];else if(this._isTransparent())return b[a];return 0},_hasString:function(a){for(var b=1;b<
+arguments.length;b++)if(a.indexOf(arguments[b])>=0)return true;return false},_blend:function(a,b){var c=OpenLayers.Rico.Color.createFromHex(a);c.blend(OpenLayers.Rico.Color.createFromHex(b));return c},_background:function(a){try{return OpenLayers.Rico.Color.createColorFromBackground(a).asHex()}catch(b){return"#ffffff"}},_isTransparent:function(){return this.options.color=="transparent"},_isTopRounded:function(){return this._hasString(this.options.corners,"all","top","tl","tr")},_isBottomRounded:function(){return this._hasString(this.options.corners,
+"all","bottom","bl","br")},_hasSingleTextChild:function(a){return a.childNodes.length==1&&a.childNodes[0].nodeType==3}};
+OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,titleRegEx:/\+title=[^\+]*/,initialize:function(a,b){OpenLayers.Util.extend(this,b);this.projCode=a;if(window.Proj4js)this.proj=new Proj4js.Proj(a)},getCode:function(){return this.proj?this.proj.srsCode:this.projCode},getUnits:function(){return this.proj?this.proj.units:null},toString:function(){return this.getCode()},equals:function(a){var b=false;if(a)if(window.Proj4js&&this.proj.defData&&a.proj.defData)b=this.proj.defData.replace(this.titleRegEx,
+"")==a.proj.defData.replace(this.titleRegEx,"");else if(a.getCode){b=this.getCode();a=a.getCode();b=b==a||!!OpenLayers.Projection.transforms[b]&&OpenLayers.Projection.transforms[b][a]===OpenLayers.Projection.nullTransform}return b},destroy:function(){delete this.proj;delete this.projCode},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};
+OpenLayers.Projection.addTransform=function(a,b,c){OpenLayers.Projection.transforms[a]||(OpenLayers.Projection.transforms[a]={});OpenLayers.Projection.transforms[a][b]=c};OpenLayers.Projection.transform=function(a,b,c){if(b.proj&&c.proj)a=Proj4js.transform(b.proj,c.proj,a);else if(b&&c&&OpenLayers.Projection.transforms[b.getCode()]&&OpenLayers.Projection.transforms[b.getCode()][c.getCode()])OpenLayers.Projection.transforms[b.getCode()][c.getCode()](a);return a};
+OpenLayers.Projection.nullTransform=function(a){return a};
+OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:null,alwaysInRange:null,EVENT_TYPES:["loadstart","loadend","loadcancel","visibilitychanged","move","moveend","added","removed"],RESOLUTION_PROPERTIES:["scales","resolutions","maxScale","minScale","maxResolution","minResolution","numZoomLevels","maxZoomLevel"],events:null,map:null,isBaseLayer:false,alpha:false,displayInLayerSwitcher:true,visibility:true,attribution:null,inRange:false,imageSize:null,imageOffset:null,options:null,
+eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution:null,numZoomLevels:null,restrictedMinZoom:0,minScale:null,maxScale:null,displayOutsideMaxExtent:false,wrapDateLine:false,transitionEffect:null,SUPPORTED_TRANSITIONS:["resize"],metadata:{},initialize:function(a,b){this.addOptions(b);this.name=a;if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.div=OpenLayers.Util.createDiv(this.id);
+this.div.style.width="100%";this.div.style.height="100%";this.div.dir="ltr";this.events=new OpenLayers.Events(this,this.div,this.EVENT_TYPES);if(this.eventListeners instanceof Object)this.events.on(this.eventListeners)}if(this.wrapDateLine)this.displayOutsideMaxExtent=true},destroy:function(a){if(a==null)a=true;this.map!=null&&this.map.removeLayer(this,a);this.options=this.div=this.name=this.map=this.projection=null;if(this.events){this.eventListeners&&this.events.un(this.eventListeners);this.events.destroy()}this.events=
+this.eventListeners=null},clone:function(a){if(a==null)a=new OpenLayers.Layer(this.name,this.getOptions());OpenLayers.Util.applyDefaults(a,this);a.map=null;return a},getOptions:function(){var a={},b;for(b in this.options)a[b]=this[b];return a},setName:function(a){if(a!=this.name){this.name=a;this.map!=null&&this.map.events.triggerEvent("changelayer",{layer:this,property:"name"})}},addOptions:function(a){if(this.options==null)this.options={};OpenLayers.Util.extend(this.options,a);OpenLayers.Util.extend(this,
+a);if(typeof this.projection=="string")this.projection=new OpenLayers.Projection(this.projection);if(this.projection&&this.projection.getUnits())this.units=this.projection.getUnits();if(this.map){var b=this.RESOLUTION_PROPERTIES.concat(["projection","units","minExtent","maxExtent"]),c;for(c in a)if(a.hasOwnProperty(c)&&OpenLayers.Util.indexOf(b,c)>=0){this.initResolutions();break}}},onMapResize:function(){},redraw:function(){var a=false;if(this.map){this.inRange=this.calculateInRange();var b=this.getExtent();
+if(b&&this.inRange&&this.visibility){this.moveTo(b,true,false);this.events.triggerEvent("moveend",{zoomChanged:true});a=true}}return a},moveTo:function(){var a=this.visibility;this.isBaseLayer||(a=a&&this.inRange);this.display(a)},moveByPx:function(){},setMap:function(a){if(this.map==null){this.map=a;this.maxExtent=this.maxExtent||this.map.maxExtent;this.minExtent=this.minExtent||this.map.minExtent;this.projection=this.projection||this.map.projection;if(typeof this.projection=="string")this.projection=
+new OpenLayers.Projection(this.projection);this.units=this.projection.getUnits()||this.units||this.map.units;this.initResolutions();if(!this.isBaseLayer){this.inRange=this.calculateInRange();this.div.style.display=this.visibility&&this.inRange?"":"none"}this.setTileSize()}},afterAdd:function(){},removeMap:function(){},getImageSize:function(){return this.imageSize||this.tileSize},setTileSize:function(a){this.tileSize=a=a?a:this.tileSize?this.tileSize:this.map.getTileSize();if(this.gutter){this.imageOffset=
+new OpenLayers.Pixel(-this.gutter,-this.gutter);this.imageSize=new OpenLayers.Size(a.w+2*this.gutter,a.h+2*this.gutter)}},getVisibility:function(){return this.visibility},setVisibility:function(a){if(a!=this.visibility){this.visibility=a;this.display(a);this.redraw();this.map!=null&&this.map.events.triggerEvent("changelayer",{layer:this,property:"visibility"});this.events.triggerEvent("visibilitychanged")}},display:function(a){if(a!=(this.div.style.display!="none"))this.div.style.display=a&&this.calculateInRange()?
+"block":"none"},calculateInRange:function(){var a=false;if(this.alwaysInRange)a=true;else if(this.map){a=this.map.getResolution();a=this.map.getZoom()>=this.restrictedMinZoom&&a>=this.minResolution&&a<=this.maxResolution}return a},setIsBaseLayer:function(a){if(a!=this.isBaseLayer){this.isBaseLayer=a;this.map!=null&&this.map.events.triggerEvent("changebaselayer",{layer:this})}},initResolutions:function(){var a,b,c,d={},e=true;a=0;for(b=this.RESOLUTION_PROPERTIES.length;a<b;a++){c=this.RESOLUTION_PROPERTIES[a];
+d[c]=this.options[c];if(e&&this.options[c])e=false}if(this.alwaysInRange==null)this.alwaysInRange=e;if(d.resolutions==null)d.resolutions=this.resolutionsFromScales(d.scales);if(d.resolutions==null)d.resolutions=this.calculateResolutions(d);if(d.resolutions==null){a=0;for(b=this.RESOLUTION_PROPERTIES.length;a<b;a++){c=this.RESOLUTION_PROPERTIES[a];d[c]=this.options[c]!=null?this.options[c]:this.map[c]}if(d.resolutions==null)d.resolutions=this.resolutionsFromScales(d.scales);if(d.resolutions==null)d.resolutions=
+this.calculateResolutions(d)}var f;if(this.options.maxResolution&&this.options.maxResolution!=="auto")f=this.options.maxResolution;if(this.options.minScale)f=OpenLayers.Util.getResolutionFromScale(this.options.minScale,this.units);var g;if(this.options.minResolution&&this.options.minResolution!=="auto")g=this.options.minResolution;if(this.options.maxScale)g=OpenLayers.Util.getResolutionFromScale(this.options.maxScale,this.units);if(d.resolutions){d.resolutions.sort(function(h,i){return i-h});f||(f=
+d.resolutions[0]);g||(g=d.resolutions[d.resolutions.length-1])}if(this.resolutions=d.resolutions){b=this.resolutions.length;this.scales=Array(b);for(a=0;a<b;a++)this.scales[a]=OpenLayers.Util.getScaleFromResolution(this.resolutions[a],this.units);this.numZoomLevels=b}if(this.minResolution=g)this.maxScale=OpenLayers.Util.getScaleFromResolution(g,this.units);if(this.maxResolution=f)this.minScale=OpenLayers.Util.getScaleFromResolution(f,this.units)},resolutionsFromScales:function(a){if(a!=null){var b,
+c,d;d=a.length;b=Array(d);for(c=0;c<d;c++)b[c]=OpenLayers.Util.getResolutionFromScale(a[c],this.units);return b}},calculateResolutions:function(a){var b,c,d=a.maxResolution;if(a.minScale!=null)d=OpenLayers.Util.getResolutionFromScale(a.minScale,this.units);else if(d=="auto"&&this.maxExtent!=null){b=this.map.getSize();c=this.maxExtent.getWidth()/b.w;b=this.maxExtent.getHeight()/b.h;d=Math.max(c,b)}c=a.minResolution;if(a.maxScale!=null)c=OpenLayers.Util.getResolutionFromScale(a.maxScale,this.units);
+else if(a.minResolution=="auto"&&this.minExtent!=null){b=this.map.getSize();c=this.minExtent.getWidth()/b.w;b=this.minExtent.getHeight()/b.h;c=Math.max(c,b)}b=a.maxZoomLevel;a=a.numZoomLevels;if(typeof c==="number"&&typeof d==="number"&&a===undefined)a=Math.floor(Math.log(d/c)/Math.log(2))+1;else if(a===undefined&&b!=null)a=b+1;if(!(typeof a!=="number"||a<=0||typeof d!=="number"&&typeof c!=="number")){b=Array(a);var e=2;if(typeof c=="number"&&typeof d=="number")e=Math.pow(d/c,1/(a-1));var f;if(typeof d===
+"number")for(f=0;f<a;f++)b[f]=d/Math.pow(e,f);else for(f=0;f<a;f++)b[a-1-f]=c*Math.pow(e,f);return b}},getResolution:function(){return this.getResolutionForZoom(this.map.getZoom())},getExtent:function(){return this.map.calculateBounds()},getZoomForExtent:function(a,b){var c=this.map.getSize();return this.getZoomForResolution(Math.max(a.getWidth()/c.w,a.getHeight()/c.h),b)},getDataExtent:function(){},getResolutionForZoom:function(a){a=Math.max(0,Math.min(a,this.resolutions.length-1));if(this.map.fractionalZoom){var b=
+Math.floor(a);a=this.resolutions[b]-(a-b)*(this.resolutions[b]-this.resolutions[Math.ceil(a)])}else a=this.resolutions[Math.round(a)];return a},getZoomForResolution:function(a,b){var c,d;if(this.map.fractionalZoom){var e=0,f=this.resolutions[e],g=this.resolutions[this.resolutions.length-1],h;c=0;for(d=this.resolutions.length;c<d;++c){h=this.resolutions[c];if(h>=a){f=h;e=c}if(h<=a){g=h;break}}c=f-g;c=c>0?e+(f-a)/c:e}else{f=Number.POSITIVE_INFINITY;c=0;for(d=this.resolutions.length;c<d;c++)if(b){e=
+Math.abs(this.resolutions[c]-a);if(e>f)break;f=e}else if(this.resolutions[c]<a)break;c=Math.max(0,c-1)}return Math.max(this.restrictedMinZoom,c)},getLonLatFromViewPortPx:function(a){var b=null,c=this.map;if(a!=null&&c.minPx){b=c.getResolution();var d=c.getMaxExtent();b=new OpenLayers.LonLat((a.x-c.minPx.x)*b+d.left,(c.minPx.y-a.y)*b+d.top);if(this.wrapDateLine)b=b.wrapDateLine(this.maxExtent)}return b},getViewPortPxFromLonLat:function(a){var b=null;if(a!=null){b=this.map.getResolution();var c=this.map.getExtent();
+b=new OpenLayers.Pixel(1/b*(a.lon-c.left),1/b*(c.top-a.lat))}return b},setOpacity:function(a){if(a!=this.opacity){this.opacity=a;for(var b=0,c=this.div.childNodes.length;b<c;++b)OpenLayers.Util.modifyDOMElement(this.div.childNodes[b].firstChild,null,null,null,null,null,null,a);this.map!=null&&this.map.events.triggerEvent("changelayer",{layer:this,property:"opacity"})}},getZIndex:function(){return this.div.style.zIndex},setZIndex:function(a){this.div.style.zIndex=a},adjustBounds:function(a){if(this.gutter){var b=
+this.gutter*this.map.getResolution();a=new OpenLayers.Bounds(a.left-b,a.bottom-b,a.right+b,a.top+b)}if(this.wrapDateLine){b={rightTolerance:this.getResolution()};a=a.wrapDateLine(this.maxExtent,b)}return a},CLASS_NAME:"OpenLayers.Layer"});
+OpenLayers.Layer.FixedZoomLevels=OpenLayers.Class({initialize:function(){},initResolutions:function(){for(var a=["minZoomLevel","maxZoomLevel","numZoomLevels"],b=0,c=a.length;b<c;b++){var d=a[b];this[d]=this.options[d]!=null?this.options[d]:this.map[d]}if(this.minZoomLevel==null||this.minZoomLevel<this.MIN_ZOOM_LEVEL)this.minZoomLevel=this.MIN_ZOOM_LEVEL;a=this.MAX_ZOOM_LEVEL-this.minZoomLevel+1;b=this.options.numZoomLevels==null&&this.options.maxZoomLevel!=null||this.numZoomLevels==null&&this.maxZoomLevel!=
+null?this.maxZoomLevel-this.minZoomLevel+1:this.numZoomLevels;this.numZoomLevels=b!=null?Math.min(b,a):a;this.maxZoomLevel=this.minZoomLevel+this.numZoomLevels-1;if(this.RESOLUTIONS!=null){a=0;this.resolutions=[];for(b=this.minZoomLevel;b<=this.maxZoomLevel;b++)this.resolutions[a++]=this.RESOLUTIONS[b];this.maxResolution=this.resolutions[0];this.minResolution=this.resolutions[this.resolutions.length-1]}},getResolution:function(){if(this.resolutions!=null)return OpenLayers.Layer.prototype.getResolution.apply(this,
+arguments);else{var a=null,b=this.map.getSize(),c=this.getExtent();if(b!=null&&c!=null)a=Math.max(c.getWidth()/b.w,c.getHeight()/b.h);return a}},getExtent:function(){var a=null,b=this.map.getSize(),c=this.getLonLatFromViewPortPx(new OpenLayers.Pixel(0,0));b=this.getLonLatFromViewPortPx(new OpenLayers.Pixel(b.w,b.h));if(c!=null&&b!=null)a=new OpenLayers.Bounds(c.lon,b.lat,b.lon,c.lat);return a},getZoomForResolution:function(){return this.resolutions!=null?OpenLayers.Layer.prototype.getZoomForResolution.apply(this,
+arguments):this.getZoomForExtent(OpenLayers.Layer.prototype.getExtent.apply(this,[]))},getOLZoomFromMapObjectZoom:function(a){var b=null;if(a!=null)b=a-this.minZoomLevel;return b},getMapObjectZoomFromOLZoom:function(a){var b=null;if(a!=null)b=a+this.minZoomLevel;return b},CLASS_NAME:"OpenLayers.Layer.FixedZoomLevels"});
+OpenLayers.Handler.Drag=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:true,dragging:false,last:null,start:null,oldOnselectstart:null,interval:0,timeoutId:null,documentDrag:false,documentEvents:null,initialize:function(){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.documentDrag===true){var a=this;this._docMove=function(b){a.mousemove({xy:{x:b.clientX,y:b.clientY},element:document})};this._docUp=function(b){a.mouseup({xy:{x:b.clientX,y:b.clientY}})}}},dragstart:function(a){var b=
+true;this.dragging=false;if(this.checkModifiers(a)&&(OpenLayers.Event.isLeftClick(a)||OpenLayers.Event.isSingleTouch(a))){this.started=true;this.last=this.start=a.xy;OpenLayers.Element.addClass(this.map.viewPortDiv,"olDragDown");this.down(a);this.callback("down",[a.xy]);OpenLayers.Event.stop(a);if(!this.oldOnselectstart)this.oldOnselectstart=document.onselectstart?document.onselectstart:OpenLayers.Function.True;document.onselectstart=OpenLayers.Function.False;b=!this.stopDown}else{this.started=false;
+this.last=this.start=null}return b},dragmove:function(a){if(this.started&&!this.timeoutId&&(a.xy.x!=this.last.x||a.xy.y!=this.last.y)){if(this.documentDrag===true&&this.documentEvents)if(a.element===document){this.adjustXY(a);this.setEvent(a)}else this.removeDocumentEvents();if(this.interval>0)this.timeoutId=setTimeout(OpenLayers.Function.bind(this.removeTimeout,this),this.interval);this.dragging=true;this.move(a);this.callback("move",[a.xy]);if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart;
+document.onselectstart=OpenLayers.Function.False}this.last=this.evt.xy}return true},dragend:function(a){if(this.started){if(this.documentDrag===true&&this.documentEvents){this.adjustXY(a);this.removeDocumentEvents()}var b=this.start!=this.last;this.dragging=this.started=false;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.up(a);this.callback("up",[a.xy]);b&&this.callback("done",[a.xy]);document.onselectstart=this.oldOnselectstart}return true},down:function(){},move:function(){},
+up:function(){},out:function(){},mousedown:function(a){return this.dragstart(a)},touchstart:function(a){return this.dragstart(a)},mousemove:function(a){return this.dragmove(a)},touchmove:function(a){return this.dragmove(a)},removeTimeout:function(){this.timeoutId=null},mouseup:function(a){return this.dragend(a)},touchend:function(a){a.xy=this.last;return this.dragend(a)},mouseout:function(a){if(this.started&&OpenLayers.Util.mouseLeft(a,this.map.viewPortDiv))if(this.documentDrag===true)this.addDocumentEvents();
+else{var b=this.start!=this.last;this.dragging=this.started=false;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");this.out(a);this.callback("out",[]);b&&this.callback("done",[a.xy]);if(document.onselectstart)document.onselectstart=this.oldOnselectstart}return true},click:function(){return this.start==this.last},activate:function(){var a=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragging=false;a=true}return a},deactivate:function(){var a=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,
+arguments)){this.dragging=this.started=false;this.last=this.start=null;a=true;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown")}return a},adjustXY:function(a){var b=OpenLayers.Util.pagePosition(this.map.viewPortDiv);a.xy.x-=b[0];a.xy.y-=b[1]},addDocumentEvents:function(){OpenLayers.Element.addClass(document.body,"olDragDown");this.documentEvents=true;OpenLayers.Event.observe(document,"mousemove",this._docMove);OpenLayers.Event.observe(document,"mouseup",this._docUp)},removeDocumentEvents:function(){OpenLayers.Element.removeClass(document.body,
+"olDragDown");this.documentEvents=false;OpenLayers.Event.stopObserving(document,"mousemove",this._docMove);OpenLayers.Event.stopObserving(document,"mouseup",this._docUp)},CLASS_NAME:"OpenLayers.Handler.Drag"});
+OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:"olHandlerBoxZoomBox",boxCharacteristics:null,initialize:function(){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.dragHandler=new OpenLayers.Handler.Drag(this,{down:this.startBox,move:this.moveBox,out:this.removeBox,up:this.endBox},{keyMask:this.keyMask})},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);if(this.dragHandler){this.dragHandler.destroy();this.dragHandler=
+null}},setMap:function(a){OpenLayers.Handler.prototype.setMap.apply(this,arguments);this.dragHandler&&this.dragHandler.setMap(a)},startBox:function(){this.zoomBox=OpenLayers.Util.createDiv("zoomBox",new OpenLayers.Pixel(-9999,-9999));this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE.Popup-1;this.map.eventsDiv.appendChild(this.zoomBox);OpenLayers.Element.addClass(this.map.eventsDiv,"olDrawBox")},moveBox:function(a){var b=this.dragHandler.start.x,c=this.dragHandler.start.y,
+d=Math.abs(b-a.x),e=Math.abs(c-a.y);this.zoomBox.style.width=Math.max(1,d)+"px";this.zoomBox.style.height=Math.max(1,e)+"px";this.zoomBox.style.left=a.x<b?a.x+"px":b+"px";this.zoomBox.style.top=a.y<c?a.y+"px":c+"px";var f=this.getBoxCharacteristics();if(f.newBoxModel){if(a.x>b)this.zoomBox.style.width=Math.max(1,d-f.xOffset)+"px";if(a.y>c)this.zoomBox.style.height=Math.max(1,e-f.yOffset)+"px"}},endBox:function(a){if(Math.abs(this.dragHandler.start.x-a.x)>5||Math.abs(this.dragHandler.start.y-a.y)>
+5){var b=this.dragHandler.start;a=new OpenLayers.Bounds(Math.min(b.x,a.x),Math.max(b.y,a.y),Math.max(b.x,a.x),Math.min(b.y,a.y))}else a=this.dragHandler.start.clone();this.removeBox();this.callback("done",[a])},removeBox:function(){this.map.eventsDiv.removeChild(this.zoomBox);this.boxCharacteristics=this.zoomBox=null;OpenLayers.Element.removeClass(this.map.eventsDiv,"olDrawBox")},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true}else return false},
+deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.dragHandler.deactivate();return true}else return false},getBoxCharacteristics:function(){if(!this.boxCharacteristics){var a=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-left-width"))+parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-right-width"))+1,b=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-top-width"))+parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-bottom-width"))+
+1;this.boxCharacteristics={xOffset:a,yOffset:b,newBoxModel:OpenLayers.BROWSER_NAME=="msie"?document.compatMode!="BackCompat":true}}return this.boxCharacteristics},CLASS_NAME:"OpenLayers.Handler.Box"});
+OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,alwaysZoom:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask})},zoomBox:function(a){if(a instanceof OpenLayers.Bounds){var b;if(this.out){b=Math.min(this.map.size.h/Math.abs(a.top-a.bottom),this.map.size.w/Math.abs(a.right-a.left));var c=this.map.getExtent(),d=this.map.getLonLatFromPixel(a.getCenterPixel());a=d.lon-c.getWidth()/2*b;
+var e=d.lon+c.getWidth()/2*b,f=d.lat-c.getHeight()/2*b;b=d.lat+c.getHeight()/2*b;b=new OpenLayers.Bounds(a,f,e,b)}else{b=this.map.getLonLatFromPixel(new OpenLayers.Pixel(a.left,a.bottom));c=this.map.getLonLatFromPixel(new OpenLayers.Pixel(a.right,a.top));b=new OpenLayers.Bounds(b.lon,b.lat,c.lon,c.lat)}c=this.map.getZoom();this.map.zoomToExtent(b);if(c==this.map.getZoom()&&this.alwaysZoom==true)this.map.zoomTo(c+(this.out?-1:1))}else this.out?this.map.setCenter(this.map.getLonLatFromPixel(a),this.map.getZoom()-
+1):this.map.setCenter(this.map.getLonLatFromPixel(a),this.map.getZoom()+1)},CLASS_NAME:"OpenLayers.Control.ZoomBox"});
+OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,interval:25,documentDrag:false,kinetic:null,enableKinetic:false,kineticInterval:10,draw:function(){if(this.enableKinetic){var a={interval:this.kineticInterval};if(typeof this.enableKinetic==="object")a=OpenLayers.Util.extend(a,this.enableKinetic);this.kinetic=new OpenLayers.Kinetic(a)}this.handler=new OpenLayers.Handler.Drag(this,{move:this.panMap,done:this.panMapDone,down:this.panMapStart},
+{interval:this.interval,documentDrag:this.documentDrag})},panMapStart:function(){this.kinetic&&this.kinetic.begin()},panMap:function(a){this.kinetic&&this.kinetic.update(a);this.panned=true;this.map.pan(this.handler.last.x-a.x,this.handler.last.y-a.y,{dragging:true,animate:false})},panMapDone:function(a){if(this.panned){var b=null;if(this.kinetic)b=this.kinetic.end(a);this.map.pan(this.handler.last.x-a.x,this.handler.last.y-a.y,{dragging:!!b,animate:false});if(b){var c=this;this.kinetic.move(b,function(d,
+e,f){c.map.pan(d,e,{dragging:!f,animate:false})})}this.panned=false}},CLASS_NAME:"OpenLayers.Control.DragPan"});
+OpenLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,mousePosition:null,interval:0,delta:0,cumulative:true,initialize:function(){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this)},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.wheelListener=null},onWheelEvent:function(a){if(this.map&&this.checkModifiers(a)){for(var b=false,c=false,d=false,
+e=OpenLayers.Event.element(a);e!=null&&!d&&!b;){if(!b)try{var f=e.currentStyle?e.currentStyle.overflow:document.defaultView.getComputedStyle(e,null).getPropertyValue("overflow");b=f&&f=="auto"||f=="scroll"}catch(g){}if(!c){d=0;for(var h=this.map.layers.length;d<h;d++)if(e==this.map.layers[d].div||e==this.map.layers[d].pane){c=true;break}}d=e==this.map.div;e=e.parentNode}if(!b&&d){if(c){b=0;if(!a)a=window.event;if(a.wheelDelta){b=a.wheelDelta/120;if(window.opera&&window.opera.version()<9.2)b=-b}else if(a.detail)b=
+-a.detail/3;this.delta+=b;if(this.interval){window.clearTimeout(this._timeoutId);this._timeoutId=window.setTimeout(OpenLayers.Function.bind(function(){this.wheelZoom(a)},this),this.interval)}else this.wheelZoom(a)}OpenLayers.Event.stop(a)}}},wheelZoom:function(a){var b=this.delta;this.delta=0;if(b){if(this.mousePosition)a.xy=this.mousePosition;if(!a.xy)a.xy=this.map.getPixelFromLonLat(this.map.getCenter());b<0?this.callback("down",[a,this.cumulative?b:-1]):this.callback("up",[a,this.cumulative?b:
+1])}},mousemove:function(a){this.mousePosition=a.xy},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var a=this.wheelListener;OpenLayers.Event.observe(window,"DOMMouseScroll",a);OpenLayers.Event.observe(window,"mousewheel",a);OpenLayers.Event.observe(document,"mousewheel",a);return true}else return false},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){var a=this.wheelListener;OpenLayers.Event.stopObserving(window,"DOMMouseScroll",
+a);OpenLayers.Event.stopObserving(window,"mousewheel",a);OpenLayers.Event.stopObserving(document,"mousewheel",a);return true}else return false},CLASS_NAME:"OpenLayers.Handler.MouseWheel"});
+OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,documentDrag:false,zoomBox:null,zoomBoxEnabled:true,zoomWheelEnabled:true,mouseWheelOptions:null,handleRightClicks:false,zoomBoxKeyMask:OpenLayers.Handler.MOD_SHIFT,autoActivate:true,initialize:function(){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments)},destroy:function(){this.deactivate();this.dragPan&&this.dragPan.destroy();this.dragPan=null;this.zoomBox&&this.zoomBox.destroy();
+this.zoomBox=null;OpenLayers.Control.prototype.destroy.apply(this,arguments)},activate:function(){this.dragPan.activate();this.zoomWheelEnabled&&this.handlers.wheel.activate();this.handlers.click.activate();this.zoomBoxEnabled&&this.zoomBox.activate();return OpenLayers.Control.prototype.activate.apply(this,arguments)},deactivate:function(){this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,
+arguments)},draw:function(){if(this.handleRightClicks)this.map.viewPortDiv.oncontextmenu=OpenLayers.Function.False;this.handlers.click=new OpenLayers.Handler.Click(this,{click:this.defaultClick,dblclick:this.defaultDblClick,dblrightclick:this.defaultDblRightClick},{"double":true,stopDouble:true});this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:this.zoomBoxKeyMask});
+this.dragPan.draw();this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{up:this.wheelUp,down:this.wheelDown},this.mouseWheelOptions)},defaultClick:function(a){a.lastTouches&&a.lastTouches.length==2&&this.map.zoomOut()},defaultDblClick:function(a){this.map.setCenter(this.map.getLonLatFromViewPortPx(a.xy),this.map.zoom+1)},defaultDblRightClick:function(a){this.map.setCenter(this.map.getLonLatFromViewPortPx(a.xy),this.map.zoom-1)},wheelChange:function(a,b){var c=this.map.getZoom(),
+d=this.map.getZoom()+Math.round(b);d=Math.max(d,0);d=Math.min(d,this.map.getNumZoomLevels());if(d!==c){var e=this.map.getSize();c=e.w/2-a.xy.x;e=a.xy.y-e.h/2;var f=this.map.baseLayer.getResolutionForZoom(d),g=this.map.getLonLatFromPixel(a.xy);this.map.setCenter(new OpenLayers.LonLat(g.lon+c*f,g.lat+e*f),d)}},wheelUp:function(a,b){this.wheelChange(a,b||1)},wheelDown:function(a,b){this.wheelChange(a,b||-1)},disableZoomBox:function(){this.zoomBoxEnabled=false;this.zoomBox.deactivate()},enableZoomBox:function(){this.zoomBoxEnabled=
+true;this.active&&this.zoomBox.activate()},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate()},enableZoomWheel:function(){this.zoomWheelEnabled=true;this.active&&this.handlers.wheel.activate()},CLASS_NAME:"OpenLayers.Control.Navigation"});
+OpenLayers.Control.PanZoom=OpenLayers.Class(OpenLayers.Control,{slideFactor:50,slideRatio:null,buttons:null,position:null,initialize:function(){this.position=new OpenLayers.Pixel(OpenLayers.Control.PanZoom.X,OpenLayers.Control.PanZoom.Y);OpenLayers.Control.prototype.initialize.apply(this,arguments)},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);this.removeButtons();this.position=this.buttons=null},draw:function(a){OpenLayers.Control.prototype.draw.apply(this,arguments);
+a=this.position;this.buttons=[];var b=new OpenLayers.Size(18,18),c=new OpenLayers.Pixel(a.x+b.w/2,a.y);this._addButton("panup","north-mini.png",c,b);a.y=c.y+b.h;this._addButton("panleft","west-mini.png",a,b);this._addButton("panright","east-mini.png",a.add(b.w,0),b);this._addButton("pandown","south-mini.png",c.add(0,b.h*2),b);this._addButton("zoomin","zoom-plus-mini.png",c.add(0,b.h*3+5),b);this._addButton("zoomworld","zoom-world-mini.png",c.add(0,b.h*4+5),b);this._addButton("zoomout","zoom-minus-mini.png",
+c.add(0,b.h*5+5),b);return this.div},_addButton:function(a,b,c,d){b=OpenLayers.Util.getImagesLocation()+b;c=OpenLayers.Util.createAlphaImageDiv(this.id+"_"+a,c,d,b,"absolute");c.style.cursor="pointer";this.div.appendChild(c);OpenLayers.Event.observe(c,"mousedown",OpenLayers.Function.bindAsEventListener(this.buttonDown,c));OpenLayers.Event.observe(c,"dblclick",OpenLayers.Function.bindAsEventListener(this.doubleClick,c));OpenLayers.Event.observe(c,"click",OpenLayers.Function.bindAsEventListener(this.doubleClick,
+c));c.action=a;c.map=this.map;if(this.slideRatio){var e=this.slideRatio;a=function(g){return this.map.getSize()[g]*e}}else{var f=this.slideFactor;a=function(){return f}}c.getSlideFactor=a;this.buttons.push(c);return c},_removeButton:function(a){OpenLayers.Event.stopObservingElement(a);a.map=null;a.getSlideFactor=null;this.div.removeChild(a);OpenLayers.Util.removeItem(this.buttons,a)},removeButtons:function(){for(var a=this.buttons.length-1;a>=0;--a)this._removeButton(this.buttons[a])},doubleClick:function(a){OpenLayers.Event.stop(a);
+return false},buttonDown:function(a){if(OpenLayers.Event.isLeftClick(a)){switch(this.action){case "panup":this.map.pan(0,-this.getSlideFactor("h"));break;case "pandown":this.map.pan(0,this.getSlideFactor("h"));break;case "panleft":this.map.pan(-this.getSlideFactor("w"),0);break;case "panright":this.map.pan(this.getSlideFactor("w"),0);break;case "zoomin":this.map.zoomIn();break;case "zoomout":this.map.zoomOut();break;case "zoomworld":this.map.zoomToMaxExtent()}OpenLayers.Event.stop(a)}},CLASS_NAME:"OpenLayers.Control.PanZoom"});
+OpenLayers.Control.PanZoom.X=4;OpenLayers.Control.PanZoom.Y=4;
+OpenLayers.Control.ArgParser=OpenLayers.Class(OpenLayers.Control,{center:null,zoom:null,layers:null,displayProjection:null,initialize:function(){OpenLayers.Control.prototype.initialize.apply(this,arguments)},getParameters:function(a){a=a||window.location.href;var b=OpenLayers.Util.getParameters(a),c=a.indexOf("#");if(c>0){a="?"+a.substring(c+1,a.length);OpenLayers.Util.extend(b,OpenLayers.Util.getParameters(a))}return b},setMap:function(){OpenLayers.Control.prototype.setMap.apply(this,arguments);
+for(var a=0,b=this.map.controls.length;a<b;a++){var c=this.map.controls[a];if(c!=this&&c.CLASS_NAME=="OpenLayers.Control.ArgParser"){if(c.displayProjection!=this.displayProjection)this.displayProjection=c.displayProjection;break}}if(a==this.map.controls.length){a=this.getParameters();if(a.layers){this.layers=a.layers;this.map.events.register("addlayer",this,this.configureLayers);this.configureLayers()}if(a.lat&&a.lon){this.center=new OpenLayers.LonLat(parseFloat(a.lon),parseFloat(a.lat));if(a.zoom)this.zoom=
+parseInt(a.zoom);this.map.events.register("changebaselayer",this,this.setCenter);this.setCenter()}}},setCenter:function(){if(this.map.baseLayer){this.map.events.unregister("changebaselayer",this,this.setCenter);this.displayProjection&&this.center.transform(this.displayProjection,this.map.getProjectionObject());this.map.setCenter(this.center,this.zoom)}},configureLayers:function(){if(this.layers.length==this.map.layers.length){this.map.events.unregister("addlayer",this,this.configureLayers);for(var a=
+0,b=this.layers.length;a<b;a++){var c=this.map.layers[a],d=this.layers.charAt(a);if(d=="B")this.map.setBaseLayer(c);else if(d=="T"||d=="F")c.setVisibility(d=="T")}}},CLASS_NAME:"OpenLayers.Control.ArgParser"});
+OpenLayers.Control.Permalink=OpenLayers.Class(OpenLayers.Control,{argParserClass:OpenLayers.Control.ArgParser,element:null,anchor:false,base:"",displayProjection:null,initialize:function(a,b,c){if(a!==null&&typeof a=="object"&&!OpenLayers.Util.isElement(a)){this.base=document.location.href;OpenLayers.Control.prototype.initialize.apply(this,[a]);if(this.element!=null)this.element=OpenLayers.Util.getElement(this.element)}else{OpenLayers.Control.prototype.initialize.apply(this,[c]);this.element=OpenLayers.Util.getElement(a);
+this.base=b||document.location.href}},destroy:function(){this.element.parentNode==this.div&&this.div.removeChild(this.element);this.element=null;this.map.events.unregister("moveend",this,this.updateLink);OpenLayers.Control.prototype.destroy.apply(this,arguments)},setMap:function(){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var a=0,b=this.map.controls.length;a<b;a++){var c=this.map.controls[a];if(c.CLASS_NAME==this.argParserClass.CLASS_NAME){if(c.displayProjection!=this.displayProjection)this.displayProjection=
+c.displayProjection;break}}a==this.map.controls.length&&this.map.addControl(new this.argParserClass({displayProjection:this.displayProjection}))},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element&&!this.anchor){this.element=document.createElement("a");this.element.innerHTML=OpenLayers.i18n("permalink");this.element.href="";this.div.appendChild(this.element)}this.map.events.on({moveend:this.updateLink,changelayer:this.updateLink,changebaselayer:this.updateLink,
+scope:this});this.updateLink();return this.div},updateLink:function(){var a=this.anchor?"#":"?",b=this.base;if(b.indexOf(a)!=-1)b=b.substring(0,b.indexOf(a));b+=a+OpenLayers.Util.getParameterString(this.createParams());if(this.anchor&&!this.element)window.location.href=b;else this.element.href=b},createParams:function(a,b,c){a=a||this.map.getCenter();var d=OpenLayers.Util.getParameters(this.base);if(a){d.zoom=b||this.map.getZoom();b=a.lat;a=a.lon;if(this.displayProjection){b=OpenLayers.Projection.transform({x:a,
+y:b},this.map.getProjectionObject(),this.displayProjection);a=b.x;b=b.y}d.lat=Math.round(b*1E5)/1E5;d.lon=Math.round(a*1E5)/1E5;c=c||this.map.layers;d.layers="";a=0;for(b=c.length;a<b;a++){var e=c[a];d.layers+=e.isBaseLayer?e==this.map.baseLayer?"B":"0":e.getVisibility()?"T":"F"}}return d},CLASS_NAME:"OpenLayers.Control.Permalink"});
+OpenLayers.Layer.EventPane=OpenLayers.Class(OpenLayers.Layer,{smoothDragPan:true,isBaseLayer:true,isFixed:true,pane:null,mapObject:null,initialize:function(){OpenLayers.Layer.prototype.initialize.apply(this,arguments);if(this.pane==null)this.pane=OpenLayers.Util.createDiv(this.div.id+"_EventPane")},destroy:function(){this.pane=this.mapObject=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments)},setMap:function(){OpenLayers.Layer.prototype.setMap.apply(this,arguments);this.pane.style.zIndex=
+parseInt(this.div.style.zIndex)+1;this.pane.style.display=this.div.style.display;this.pane.style.width="100%";this.pane.style.height="100%";if(OpenLayers.BROWSER_NAME=="msie")this.pane.style.background="url("+OpenLayers.Util.getImagesLocation()+"blank.gif)";this.isFixed?this.map.viewPortDiv.appendChild(this.pane):this.map.layerContainerDiv.appendChild(this.pane);this.loadMapObject();this.mapObject==null&&this.loadWarningMessage()},removeMap:function(){this.pane&&this.pane.parentNode&&this.pane.parentNode.removeChild(this.pane);
+OpenLayers.Layer.prototype.removeMap.apply(this,arguments)},loadWarningMessage:function(){this.div.style.backgroundColor="darkblue";var a=this.map.getSize(),b=new OpenLayers.Size(Math.min(a.w,300),Math.min(a.h,200));a=(new OpenLayers.Pixel(a.w/2,a.h/2)).add(-b.w/2,-b.h/2);b=OpenLayers.Util.createDiv(this.name+"_warning",a,b,null,null,null,"auto");b.style.padding="7px";b.style.backgroundColor="yellow";b.innerHTML=this.getWarningHTML();this.div.appendChild(b)},getWarningHTML:function(){return""},display:function(){OpenLayers.Layer.prototype.display.apply(this,
+arguments);this.pane.style.display=this.div.style.display},setZIndex:function(){OpenLayers.Layer.prototype.setZIndex.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1},moveByPx:function(a,b){OpenLayers.Layer.prototype.moveByPx.apply(this,arguments);this.dragPanMapObject?this.dragPanMapObject(a,-b):this.moveTo()},moveTo:function(a,b,c){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(this.mapObject!=null){var d=this.map.getCenter(),e=this.map.getZoom();if(d!=
+null){var f=this.getOLLonLatFromMapObjectLonLat(this.getMapObjectCenter()),g=this.getOLZoomFromMapObjectZoom(this.getMapObjectZoom());if(!d.equals(f)||e!=g)if(c&&this.dragPanMapObject&&this.smoothDragPan){e=this.map.getViewPortPxFromLonLat(f);d=this.map.getViewPortPxFromLonLat(d);this.dragPanMapObject(d.x-e.x,e.y-d.y)}else{d=this.getMapObjectLonLatFromOLLonLat(d);e=this.getMapObjectZoomFromOLZoom(e);this.setMapObjectCenter(d,e,c)}}}},getLonLatFromViewPortPx:function(a){var b=null;if(this.mapObject!=
+null&&this.getMapObjectCenter()!=null)b=this.getOLLonLatFromMapObjectLonLat(this.getMapObjectLonLatFromMapObjectPixel(this.getMapObjectPixelFromOLPixel(a)));return b},getViewPortPxFromLonLat:function(a){var b=null;if(this.mapObject!=null&&this.getMapObjectCenter()!=null)b=this.getOLPixelFromMapObjectPixel(this.getMapObjectPixelFromMapObjectLonLat(this.getMapObjectLonLatFromOLLonLat(a)));return b},getOLLonLatFromMapObjectLonLat:function(a){var b=null;if(a!=null){b=this.getLongitudeFromMapObjectLonLat(a);
+a=this.getLatitudeFromMapObjectLonLat(a);b=new OpenLayers.LonLat(b,a)}return b},getMapObjectLonLatFromOLLonLat:function(a){var b=null;if(a!=null)b=this.getMapObjectLonLatFromLonLat(a.lon,a.lat);return b},getOLPixelFromMapObjectPixel:function(a){var b=null;if(a!=null){b=this.getXFromMapObjectPixel(a);a=this.getYFromMapObjectPixel(a);b=new OpenLayers.Pixel(b,a)}return b},getMapObjectPixelFromOLPixel:function(a){var b=null;if(a!=null)b=this.getMapObjectPixelFromXY(a.x,a.y);return b},CLASS_NAME:"OpenLayers.Layer.EventPane"});
+OpenLayers.Layer.SphericalMercator={getExtent:function(){var a=null;return a=this.sphericalMercator?this.map.calculateBounds():OpenLayers.Layer.FixedZoomLevels.prototype.getExtent.apply(this)},getLonLatFromViewPortPx:function(){return OpenLayers.Layer.prototype.getLonLatFromViewPortPx.apply(this,arguments)},getViewPortPxFromLonLat:function(){return OpenLayers.Layer.prototype.getViewPortPxFromLonLat.apply(this,arguments)},initMercatorParameters:function(){this.RESOLUTIONS=[];for(var a=0;a<=this.MAX_ZOOM_LEVEL;++a)this.RESOLUTIONS[a]=
+156543.03390625/Math.pow(2,a);this.units="m";this.projection=this.projection||"EPSG:900913"},forwardMercator:function(a,b){var c;c=Math.log(Math.tan((90+b)*Math.PI/360))/(Math.PI/180);return new OpenLayers.LonLat(a*2.003750834E7/180,c*2.003750834E7/180)},inverseMercator:function(a,b){var c;c=180/Math.PI*(2*Math.atan(Math.exp(b/2.003750834E7*180*Math.PI/180))-Math.PI/2);return new OpenLayers.LonLat(a/2.003750834E7*180,c)},projectForward:function(a){var b=OpenLayers.Layer.SphericalMercator.forwardMercator(a.x,
+a.y);a.x=b.lon;a.y=b.lat;return a},projectInverse:function(a){var b=OpenLayers.Layer.SphericalMercator.inverseMercator(a.x,a.y);a.x=b.lon;a.y=b.lat;return a}};(function(){var a=["EPSG:900913","EPSG:3857","EPSG:102113","EPSG:102100"],b=OpenLayers.Projection.addTransform,c=OpenLayers.Layer.SphericalMercator,d=OpenLayers.Projection.nullTransform,e,f,g,h,i;e=0;for(f=a.length;e<f;++e){g=a[e];b("EPSG:4326",g,c.projectForward);b(g,"EPSG:4326",c.projectInverse);for(i=e+1;i<f;++i){h=a[i];b(g,h,d);b(h,g,d)}}})();
+OpenLayers.Layer.Ovi=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:17,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,6.866455078125E-4,3.4332275390625E-4,1.71661376953125E-4,8.58306884765625E-5,4.291534423828125E-5,2.145767211914062E-5,1.072883605957031E-5],type:null,wrapDateLine:true,sphericalMercator:false,initialize:function(){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,
+arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters()}},loadMapObject:function(){try{this.mapObject=new ovi.mapsapi.map.Display(this.div)}catch(a){}},onMapResize:function(){try{this.mapObject.resizeTo(this.getMapObjectSizeFromOLSize(this.map.getSize()))}catch(a){}},setMap:function(){OpenLayers.Layer.EventPane.prototype.setMap.apply(this,arguments)},
+fixOviEventPane:function(){},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{layerType:"Ovi",layerLib:"Ovi"})},setMapObjectCenter:function(a,b){this.mapObject.set({center:a,zoomLevel:b})},getMapObjectCenter:function(){return this.mapObject.get("center")},getMapObjectZoom:function(){return this.mapObject.get("zoomLevel")},getMapObjectLonLatFromMapObjectPixel:function(a){return(a=OpenLayers.Layer.prototype.getLonLatFromViewPortPx.apply(this,[new OpenLayers.Pixel(a[0],a[1])]))?{latitude:a.lat,
+longitude:a.lon}:null},getMapObjectPixelFromMapObjectLonLat:function(a){return(a=OpenLayers.Layer.prototype.getViewPortPxFromLonLat.apply(this,[new OpenLayers.LonLat(a[0],a[1])]))?[a.x,a.y]:null},getLongitudeFromMapObjectLonLat:function(a){return this.sphericalMercator?this.forwardMercator(a.longitude,a.latitude).lon:a.longitude},getLatitudeFromMapObjectLonLat:function(a){return this.sphericalMercator?this.forwardMercator(a.longitude,a.latitude).lat:a.latitude},getMapObjectLonLatFromLonLat:function(a,
+b){var c;if(this.sphericalMercator){c=this.inverseMercator(a,b);c=[c.lat,c.lon]}else c=[b,a];return c},getXFromMapObjectPixel:function(a){return a.x},getYFromMapObjectPixel:function(a){return a.y},getMapObjectPixelFromXY:function(a,b){return[a,b]},getMapObjectSizeFromOLSize:function(a){return[a.w,a.h]},CLASS_NAME:"OpenLayers.Layer.Ovi"});
+OpenLayers.Control.LayerSwitcher=OpenLayers.Class(OpenLayers.Control,{roundedCorner:true,roundedCornerColor:"darkblue",layerStates:null,layersDiv:null,baseLayersDiv:null,baseLayers:null,dataLbl:null,dataLayersDiv:null,dataLayers:null,minimizeDiv:null,maximizeDiv:null,ascending:true,initialize:function(){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.layerStates=[]},destroy:function(){OpenLayers.Event.stopObservingElement(this.div);OpenLayers.Event.stopObservingElement(this.minimizeDiv);
+OpenLayers.Event.stopObservingElement(this.maximizeDiv);this.clearLayersArray("base");this.clearLayersArray("data");this.map.events.un({addlayer:this.redraw,changelayer:this.redraw,removelayer:this.redraw,changebaselayer:this.redraw,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments)},setMap:function(){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.on({addlayer:this.redraw,changelayer:this.redraw,removelayer:this.redraw,changebaselayer:this.redraw,scope:this})},
+draw:function(){OpenLayers.Control.prototype.draw.apply(this);this.loadContents();this.outsideViewport||this.minimizeControl();this.redraw();return this.div},clearLayersArray:function(a){var b=this[a+"Layers"];if(b)for(var c=0,d=b.length;c<d;c++){var e=b[c];OpenLayers.Event.stopObservingElement(e.inputElem);OpenLayers.Event.stopObservingElement(e.labelSpan)}this[a+"LayersDiv"].innerHTML="";this[a+"Layers"]=[]},checkRedraw:function(){var a=false;if(!this.layerStates.length||this.map.layers.length!=
+this.layerStates.length)a=true;else for(var b=0,c=this.layerStates.length;b<c;b++){var d=this.layerStates[b],e=this.map.layers[b];if(d.name!=e.name||d.inRange!=e.inRange||d.id!=e.id||d.visibility!=e.visibility){a=true;break}}return a},redraw:function(){if(!this.checkRedraw())return this.div;this.clearLayersArray("base");this.clearLayersArray("data");var a=false,b=false,c=this.map.layers.length;this.layerStates=Array(c);for(var d=0;d<c;d++){var e=this.map.layers[d];this.layerStates[d]={name:e.name,
+visibility:e.visibility,inRange:e.inRange,id:e.id}}var f=this.map.layers.slice();this.ascending||f.reverse();d=0;for(c=f.length;d<c;d++){e=f[d];var g=e.isBaseLayer;if(e.displayInLayerSwitcher){if(g)b=true;else a=true;var h=g?e==this.map.baseLayer:e.getVisibility(),i=document.createElement("input");i.id=this.id+"_input_"+e.name;i.name=g?this.id+"_baseLayers":e.name;i.type=g?"radio":"checkbox";i.value=e.name;i.checked=h;i.defaultChecked=h;if(!g&&!e.inRange)i.disabled=true;var j={inputElem:i,layer:e,
+layerSwitcher:this};OpenLayers.Event.observe(i,"mouseup",OpenLayers.Function.bindAsEventListener(this.onInputClick,j));h=document.createElement("span");OpenLayers.Element.addClass(h,"labelSpan");if(!g&&!e.inRange)h.style.color="gray";h.innerHTML=e.name;h.style.verticalAlign=g?"bottom":"baseline";OpenLayers.Event.observe(h,"click",OpenLayers.Function.bindAsEventListener(this.onInputClick,j));j=document.createElement("br");(g?this.baseLayers:this.dataLayers).push({layer:e,inputElem:i,labelSpan:h});
+e=g?this.baseLayersDiv:this.dataLayersDiv;e.appendChild(i);e.appendChild(h);e.appendChild(j)}}this.dataLbl.style.display=a?"":"none";this.baseLbl.style.display=b?"":"none";return this.div},onInputClick:function(a){if(!this.inputElem.disabled)if(this.inputElem.type=="radio"){this.inputElem.checked=true;this.layer.map.setBaseLayer(this.layer)}else{this.inputElem.checked=!this.inputElem.checked;this.layerSwitcher.updateMap()}OpenLayers.Event.stop(a)},onLayerClick:function(){this.updateMap()},updateMap:function(){for(var a=
+0,b=this.baseLayers.length;a<b;a++){var c=this.baseLayers[a];c.inputElem.checked&&this.map.setBaseLayer(c.layer,false)}a=0;for(b=this.dataLayers.length;a<b;a++){c=this.dataLayers[a];c.layer.setVisibility(c.inputElem.checked)}},maximizeControl:function(a){this.div.style.width="";this.div.style.height="";this.showControls(false);a!=null&&OpenLayers.Event.stop(a)},minimizeControl:function(a){this.div.style.width="0px";this.div.style.height="0px";this.showControls(true);a!=null&&OpenLayers.Event.stop(a)},
+showControls:function(a){this.maximizeDiv.style.display=a?"":"none";this.minimizeDiv.style.display=a?"none":"";this.layersDiv.style.display=a?"none":""},loadContents:function(){OpenLayers.Event.observe(this.div,"mouseup",OpenLayers.Function.bindAsEventListener(this.mouseUp,this));OpenLayers.Event.observe(this.div,"click",this.ignoreEvent);OpenLayers.Event.observe(this.div,"mousedown",OpenLayers.Function.bindAsEventListener(this.mouseDown,this));OpenLayers.Event.observe(this.div,"dblclick",this.ignoreEvent);
+this.layersDiv=document.createElement("div");this.layersDiv.id=this.id+"_layersDiv";OpenLayers.Element.addClass(this.layersDiv,"layersDiv");this.baseLbl=document.createElement("div");this.baseLbl.innerHTML=OpenLayers.i18n("baseLayer");OpenLayers.Element.addClass(this.baseLbl,"baseLbl");this.baseLayersDiv=document.createElement("div");OpenLayers.Element.addClass(this.baseLayersDiv,"baseLayersDiv");this.dataLbl=document.createElement("div");this.dataLbl.innerHTML=OpenLayers.i18n("overlays");OpenLayers.Element.addClass(this.dataLbl,
+"dataLbl");this.dataLayersDiv=document.createElement("div");OpenLayers.Element.addClass(this.dataLayersDiv,"dataLayersDiv");if(this.ascending){this.layersDiv.appendChild(this.baseLbl);this.layersDiv.appendChild(this.baseLayersDiv);this.layersDiv.appendChild(this.dataLbl);this.layersDiv.appendChild(this.dataLayersDiv)}else{this.layersDiv.appendChild(this.dataLbl);this.layersDiv.appendChild(this.dataLayersDiv);this.layersDiv.appendChild(this.baseLbl);this.layersDiv.appendChild(this.baseLayersDiv)}this.div.appendChild(this.layersDiv);
+if(this.roundedCorner){OpenLayers.Rico.Corner.round(this.div,{corners:"tl bl",bgColor:"transparent",color:this.roundedCornerColor,blend:false});OpenLayers.Rico.Corner.changeOpacity(this.layersDiv,0.75)}var a=OpenLayers.Util.getImagesLocation(),b=new OpenLayers.Size(18,18);this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MaximizeDiv",null,b,a+"layer-switcher-maximize.png","absolute");OpenLayers.Element.addClass(this.maximizeDiv,"maximizeDiv");this.maximizeDiv.style.display=
+"none";OpenLayers.Event.observe(this.maximizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.maximizeControl,this));this.div.appendChild(this.maximizeDiv);a+="layer-switcher-minimize.png";b=new OpenLayers.Size(18,18);this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MinimizeDiv",null,b,a,"absolute");OpenLayers.Element.addClass(this.minimizeDiv,"minimizeDiv");this.minimizeDiv.style.display="none";OpenLayers.Event.observe(this.minimizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.minimizeControl,
+this));this.div.appendChild(this.minimizeDiv)},ignoreEvent:function(a){OpenLayers.Event.stop(a)},mouseDown:function(a){this.isMouseDown=true;this.ignoreEvent(a)},mouseUp:function(a){if(this.isMouseDown){this.isMouseDown=false;this.ignoreEvent(a)}},CLASS_NAME:"OpenLayers.Control.LayerSwitcher"});
More information about the Commits mailing list
