[OpenLayers-Commits] r11608 - in trunk/openlayers: lib/OpenLayers tests
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Mar 2 06:09:28 EST 2011
Author: ahocevar
Date: 2011-03-02 03:09:24 -0800 (Wed, 02 Mar 2011)
New Revision: 11608
   trunk/openlayers/lib/OpenLayers/Map.js
   trunk/openlayers/tests/Map.html
make setOptions work for restrictedExtent change, like it was before #3062. r=bartvde (closes #3144)
Modified: trunk/openlayers/lib/OpenLayers/Map.js
--- trunk/openlayers/lib/OpenLayers/Map.js	2011-03-02 09:55:28 UTC (rev 11607)
+++ trunk/openlayers/lib/OpenLayers/Map.js	2011-03-02 11:09:24 UTC (rev 11608)
@@ -739,7 +739,13 @@
      * options - {Object} Hashtable of options to tag to the map
     setOptions: function(options) {
+        var updatePxExtent = this.minPx &&
+            options.restrictedExtent != this.restrictedExtent;
         OpenLayers.Util.extend(this, options);
+        // force recalculation of minPx and maxPx
+        updatePxExtent && this.moveTo(this.getCachedCenter(), this.zoom, {
+            forceZoomChange: true
Modified: trunk/openlayers/tests/Map.html
--- trunk/openlayers/tests/Map.html	2011-03-02 09:55:28 UTC (rev 11607)
+++ trunk/openlayers/tests/Map.html	2011-03-02 11:09:24 UTC (rev 11608)
@@ -1052,7 +1052,7 @@
     function test_Map_restrictedExtent(t) {
-        t.plan(24);
+        t.plan(25);
         var extent = new OpenLayers.Bounds(-180, -90, 180, 90);
         var options = {
             maxResolution: "auto"
@@ -1147,8 +1147,28 @@
              "map extent not restricted with null restrictedExtent for se");
         map.destroy();
+        extent = new OpenLayers.Bounds(8, 44.5, 19, 50);
+        var options = {
+            restrictedExtent: extent
+        map = new OpenLayers.Map('map', options);
+        var wms = new OpenLayers.Layer.WMS(
+            "OpenLayers WMS",
+            "http://vmap0.tiles.osgeo.org/wms/vmap0?",
+            {layers: 'basic'}
+        map.addLayers([wms]);
+        map.zoomToExtent(extent);
+        map.zoomIn();
+        map.setOptions({restrictedExtent: null});
+        map.pan(-250, -250);
+        t.ok((map.getExtent().bottom == 48.3486328125 && map.getExtent().left == 7.45751953125), "Expected extent when toggling restrictedExtent");
+        map.destroy();
     function test_Map_getResolutionForZoom(t) {
         t.plan(2);
         var map = new OpenLayers.Map("map");
More information about the Commits mailing list
