[OpenLayers-Commits] r11628 - sandbox/tschaub/click/lib/OpenLayers/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Sun Mar 6 19:19:17 EST 2011
Author: tschaub
Date: 2011-03-06 16:19:16 -0800 (Sun, 06 Mar 2011)
New Revision: 11628
   sandbox/tschaub/click/lib/OpenLayers/Handler/Click.js
The click handler should use the provided pixel tolerance for each touch before determining whether a sequence of touches constitutes a click.
Modified: sandbox/tschaub/click/lib/OpenLayers/Handler/Click.js
--- sandbox/tschaub/click/lib/OpenLayers/Handler/Click.js	2011-03-07 00:18:14 UTC (rev 11627)
+++ sandbox/tschaub/click/lib/OpenLayers/Handler/Click.js	2011-03-07 00:19:16 UTC (rev 11628)
@@ -392,10 +392,39 @@
         var passes = true;
         if (this.pixelTolerance != null && this.down && this.down.xy) {
             passes = this.pixelTolerance >= this.down.xy.distanceTo(evt.xy);
+            // for touch environments, we also enforce that all touches
+            // start and end within the given tolerance to be considered a click
+            if (passes && this.touch &&
+                this.down.touches.length === this.last.touches.length) {
+                // the touchend event doesn't come with touches, so we check
+                // down and last
+                for (var i=0, ii=this.down.touches.length; i<ii; ++i) {
+                    if (this.getTouchDistance(
+                            this.down.touches[i],
+                            this.last.touches[i]
+                        ) > this.pixelTolerance) {
+                        passes = false;
+                        break;
         return passes;
+     * Method: getTouchDistance
+     * Returns:
+     * {Boolean} The pixel displacement between two touches.
+    getTouchDistance: function(from, to) {
+        return Math.sqrt(
+            Math.pow(from.clientX - to.clientX, 2) +
+            Math.pow(from.clientY - to.clientY, 2)
      * Method: passesDblclickTolerance
      * Determine whether the event is within the optional double-cick pixel
More information about the Commits mailing list
