[OpenLayers-Commits] r11635 - in trunk/openlayers: lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Mar 7 03:21:54 EST 2011
Author: erilem
Date: 2011-03-07 00:21:51 -0800 (Mon, 07 Mar 2011)
New Revision: 11635
   trunk/openlayers/lib/OpenLayers/Handler/Drag.js
   trunk/openlayers/tests/Handler/Drag.html
the map may jump on mouseup after dragging, p=me, r=crschmidt (closes #2936)
Modified: trunk/openlayers/lib/OpenLayers/Handler/Drag.js
--- trunk/openlayers/lib/OpenLayers/Handler/Drag.js	2011-03-07 08:07:40 UTC (rev 11634)
+++ trunk/openlayers/lib/OpenLayers/Handler/Drag.js	2011-03-07 08:21:51 UTC (rev 11635)
@@ -63,6 +63,14 @@
     start: null,
+     * Property: lastMoveEvt
+     * {Object} The last mousemove event that occurred. Used to
+     *     position the map correctly when our "delay drag"
+     *     timeout expired.
+    lastMoveEvt: null,
      * Property: oldOnselectstart
      * {Function}
@@ -209,7 +217,7 @@
                 this.oldOnselectstart = document.onselectstart;
                 document.onselectstart = OpenLayers.Function.False;
-            this.last = this.evt.xy;
+            this.last = evt.xy;
         return true;
@@ -341,6 +349,7 @@
      * {Boolean} Let the event propagate.
     mousemove: function(evt) {
+        this.lastMoveEvt = evt;
         return this.dragmove(evt);
@@ -364,6 +373,12 @@
     removeTimeout: function() {
         this.timeoutId = null;
+        // if timeout expires while we're still dragging (mouseup
+        // hasn't occurred) then call mousemove to move to the
+        // correct position
+        if(this.dragging) {
+            this.mousemove(this.lastMoveEvt);
Modified: trunk/openlayers/tests/Handler/Drag.html
--- trunk/openlayers/tests/Handler/Drag.html	2011-03-07 08:07:40 UTC (rev 11634)
+++ trunk/openlayers/tests/Handler/Drag.html	2011-03-07 08:21:51 UTC (rev 11635)
@@ -440,7 +440,159 @@
              "deactivate sets start to null");
+    function test_interval_timer_after_mouseup(t) {
+        t.plan(5);
+        // set up
+        var map = new OpenLayers.Map('map');
+        var control = new OpenLayers.Control();
+        map.addControl(control);
+        var moveCnt;
+        var handler = new OpenLayers.Handler.Drag(control, {}, {
+            interval: 1,
+            move: function() {
+                moveCnt++;
+        handler.activate();
+        handler.checkModifiers = function() { return true; };
+        var ilc = OpenLayers.Event.isLeftClick;
+        OpenLayers.Event.isLeftClick = function() { return true; };
+        // test
+        moveCnt = 0;
+        var xy1 = new OpenLayers.Pixel(1, 2);
+        handler.mousedown({xy: xy1});
+        t.ok(handler.last == xy1, "[mousedown] last is as expected");
+        var xy2 = new OpenLayers.Pixel(2, 3);
+        handler.mousemove({xy: xy2});
+        t.ok(handler.last == xy2, "[mousemove 1] last is as expected");
+        t.ok(handler.timeoutId != null, "[mousemove 1] timeoutId is set");
+        var xy3 = new OpenLayers.Pixel(3, 4);
+        handler.mousemove({xy: xy3});
+        t.ok(handler.last == xy2, "[mousemove 2] last is as expected");
+        var xy4 = new OpenLayers.Pixel(4, 5);
+        handler.mouseup({xy: xy4});
+        t.delay_call(3, function() {
+            // the timer should not cause a move
+            t.eq(moveCnt, 1, "move called once");
+            // tear down
+            OpenLayers.Event.isLeftClick = ilc;
+    function test_interval_timer_after_mousedown(t) {
+        t.plan(5);
+        // set up
+        var moveCnt;
+            interval: 1,
+                moveCnt++;
+        // test
+        moveCnt = 0;
+        var xy5 = new OpenLayers.Pixel(5, 6);
+        handler.mousedown({xy: xy4});
+            // tear down
+    function test_interval_timer_before_mouseup(t) {
+        t.plan(5);
+        // set up
+        var moveCnt;
+            interval: 1,
+                moveCnt++;
+        // test
+        moveCnt = 0;
+            // the timer should cause a move
+            t.eq(moveCnt, 2, "move called twice");
+            // tear down
   </script>
 </head>
 <body>
More information about the Commits mailing list
