[OpenLayers-Commits] r11647 - in trunk/openlayers: lib/OpenLayers/Format tests/Format
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Mar 7 06:21:34 EST 2011
Author: crschmidt
Date: 2011-03-07 03:21:32 -0800 (Mon, 07 Mar 2011)
New Revision: 11647
   trunk/openlayers/lib/OpenLayers/Format/OSM.js
   trunk/openlayers/tests/Format/OSM.html
Add support to Format.OSM to reproject on writing. Initial suggestion from
Arnd Wipperman, turned into a patch by me, r=bartvde (Closes #2988)
Modified: trunk/openlayers/lib/OpenLayers/Format/OSM.js
--- trunk/openlayers/lib/OpenLayers/Format/OSM.js	2011-03-07 11:20:12 UTC (rev 11646)
+++ trunk/openlayers/lib/OpenLayers/Format/OSM.js	2011-03-07 11:21:32 UTC (rev 11647)
@@ -347,6 +347,13 @@
         'point': function(point) {
             var id = null;
             var geometry = point.geometry ? point.geometry : point;
+            if (this.internalProjection && this.externalProjection) {
+                geometry = geometry.clone();
+                geometry.transform(this.internalProjection,
+                                   this.externalProjection);
             var already_exists = false; // We don't return anything if the node
                                         // has already been created
             if (point.osm_id) {
Modified: trunk/openlayers/tests/Format/OSM.html
--- trunk/openlayers/tests/Format/OSM.html	2011-03-07 11:20:12 UTC (rev 11646)
+++ trunk/openlayers/tests/Format/OSM.html	2011-03-07 11:21:32 UTC (rev 11647)
@@ -95,6 +95,18 @@
             output = output.replace(/<\?[^>]*\?>/, '');
             t.eq(output, osm_serialized_data[key], key + " serialized correctly");
+    function test_Format_OSM_write_reproject(t) {
+        t.plan(1);
+        var f = new OpenLayers.Format.OSM({'internalProjection': new OpenLayers.Projection("EPSG:900913")});
+        var feat = new OpenLayers.Feature.Vector(
+            new OpenLayers.Geometry.Point(100000, 100000)
+        var data = f.write([feat]);
+        var f = new OpenLayers.Format.OSM();
+        var features = f.read(data);
+        t.eq(OpenLayers.Util.toFloat(features[0].geometry.x, 3), .898, "exported to lonlat and re-read as lonlat correctly")
     </script>
 </head>
More information about the Commits mailing list
