[OpenLayers-Commits] r11652 - trunk/openlayers/lib/OpenLayers/Format
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Mar 7 09:13:34 EST 2011
Author: fredj
Date: 2011-03-07 06:13:32 -0800 (Mon, 07 Mar 2011)
New Revision: 11652
   trunk/openlayers/lib/OpenLayers/Format/Atom.js
   trunk/openlayers/lib/OpenLayers/Format/Filter.js
   trunk/openlayers/lib/OpenLayers/Format/GeoJSON.js
   trunk/openlayers/lib/OpenLayers/Format/GeoRSS.js
   trunk/openlayers/lib/OpenLayers/Format/JSON.js
   trunk/openlayers/lib/OpenLayers/Format/OWSContext.js
   trunk/openlayers/lib/OpenLayers/Format/SLD.js
   trunk/openlayers/lib/OpenLayers/Format/SOSCapabilities.js
   trunk/openlayers/lib/OpenLayers/Format/SOSGetFeatureOfInterest.js
   trunk/openlayers/lib/OpenLayers/Format/SOSGetObservation.js
   trunk/openlayers/lib/OpenLayers/Format/WFSCapabilities.js
   trunk/openlayers/lib/OpenLayers/Format/WFSDescribeFeatureType.js
   trunk/openlayers/lib/OpenLayers/Format/WMC.js
   trunk/openlayers/lib/OpenLayers/Format/WMSCapabilities.js
   trunk/openlayers/lib/OpenLayers/Format/WMSDescribeLayer.js
   trunk/openlayers/lib/OpenLayers/Format/WMSGetFeatureInfo.js
   trunk/openlayers/lib/OpenLayers/Format/WMTSCapabilities.js
re-add the Constructor API doc removed in r11640 (see #3147)
Modified: trunk/openlayers/lib/OpenLayers/Format/Atom.js
--- trunk/openlayers/lib/OpenLayers/Format/Atom.js	2011-03-07 12:49:51 UTC (rev 11651)
+++ trunk/openlayers/lib/OpenLayers/Format/Atom.js	2011-03-07 14:13:32 UTC (rev 11652)
@@ -60,6 +60,15 @@
     xy: false,
+     * Constructor: OpenLayers.Format.AtomEntry
+     * Create a new parser for Atom.
+     * Parameters:
+     * options - {Object} An optional object whose properties will be set on
+     *     this instance.
      * APIMethod: read
      * Return a list of features from an Atom feed or entry document.
Modified: trunk/openlayers/lib/OpenLayers/Format/Filter.js
--- trunk/openlayers/lib/OpenLayers/Format/Filter.js	2011-03-07 12:49:51 UTC (rev 11651)
+++ trunk/openlayers/lib/OpenLayers/Format/Filter.js	2011-03-07 14:13:32 UTC (rev 11652)
@@ -40,6 +40,15 @@
     parser: null,
+     * Constructor: OpenLayers.Format.Filter
+     * Create a new parser for Filter.
+     * Parameters:
+     *     this instance.
      * APIMethod: write
      * Write an ogc:Filter given a filter object.
Modified: trunk/openlayers/lib/OpenLayers/Format/GeoJSON.js
--- trunk/openlayers/lib/OpenLayers/Format/GeoJSON.js	2011-03-07 12:49:51 UTC (rev 11651)
+++ trunk/openlayers/lib/OpenLayers/Format/GeoJSON.js	2011-03-07 14:13:32 UTC (rev 11652)
@@ -33,6 +33,15 @@
     ignoreExtraDims: false,
+     * Constructor: OpenLayers.Format.GeoJSON
+     * Create a new parser for GeoJSON.
+     * Parameters:
+     *     this instance.
      * APIMethod: read
      * Deserialize a GeoJSON string.
Modified: trunk/openlayers/lib/OpenLayers/Format/GeoRSS.js
--- trunk/openlayers/lib/OpenLayers/Format/GeoRSS.js	2011-03-07 12:49:51 UTC (rev 11651)
+++ trunk/openlayers/lib/OpenLayers/Format/GeoRSS.js	2011-03-07 14:13:32 UTC (rev 11652)
@@ -76,6 +76,15 @@
     xy: false,
+     * Constructor: OpenLayers.Format.GeoRSS
+     * Create a new parser for GeoRSS.
+     * Parameters:
+     *     this instance.
      * Method: createGeometryFromItem
      * Return a geometry from a GeoRSS Item.
Modified: trunk/openlayers/lib/OpenLayers/Format/JSON.js
--- trunk/openlayers/lib/OpenLayers/Format/JSON.js	2011-03-07 12:49:51 UTC (rev 11651)
+++ trunk/openlayers/lib/OpenLayers/Format/JSON.js	2011-03-07 14:13:32 UTC (rev 11652)
@@ -68,6 +68,15 @@
+     * Constructor: OpenLayers.Format.JSON
+     * Create a new parser for JSON.
+     * Parameters:
+     *     this instance.
      * APIMethod: read
      * Deserialize a json string.
Modified: trunk/openlayers/lib/OpenLayers/Format/OWSContext.js
--- trunk/openlayers/lib/OpenLayers/Format/OWSContext.js	2011-03-07 12:49:51 UTC (rev 11651)
+++ trunk/openlayers/lib/OpenLayers/Format/OWSContext.js	2011-03-07 14:13:32 UTC (rev 11652)
@@ -23,6 +23,15 @@
      * {String} Version number to assume if none found.  Default is "0.3.1".
     defaultVersion: "0.3.1",
+     * Constructor: OpenLayers.Format.OWSContext
+     * Create a new parser for OWS Context documents.
+     * Parameters:
+     *     this instance.
      * Method: getParser
Modified: trunk/openlayers/lib/OpenLayers/Format/SLD.js
--- trunk/openlayers/lib/OpenLayers/Format/SLD.js	2011-03-07 12:49:51 UTC (rev 11651)
+++ trunk/openlayers/lib/OpenLayers/Format/SLD.js	2011-03-07 14:13:32 UTC (rev 11652)
@@ -51,6 +51,15 @@
     parser: null,
+     * Constructor: OpenLayers.Format.SLD
+     * Create a new parser for SLD.
+     * Parameters:
+     *     this instance.
      * APIMethod: write
      * Write a SLD document given a list of styles.
Modified: trunk/openlayers/lib/OpenLayers/Format/SOSCapabilities.js
--- trunk/openlayers/lib/OpenLayers/Format/SOSCapabilities.js	2011-03-07 12:49:51 UTC (rev 11651)
+++ trunk/openlayers/lib/OpenLayers/Format/SOSCapabilities.js	2011-03-07 14:13:32 UTC (rev 11652)
@@ -35,6 +35,15 @@
     parser: null,
+     * Constructor: OpenLayers.Format.SOSCapabilities
+     * Create a new parser for SOS Capabilities.
+     * Parameters:
+     *     this instance.
      * APIMethod: read
      * Read capabilities data from a string, and return information about
      * the service (offering and observedProperty mostly).
Modified: trunk/openlayers/lib/OpenLayers/Format/SOSGetFeatureOfInterest.js
--- trunk/openlayers/lib/OpenLayers/Format/SOSGetFeatureOfInterest.js	2011-03-07 12:49:51 UTC (rev 11651)
+++ trunk/openlayers/lib/OpenLayers/Format/SOSGetFeatureOfInterest.js	2011-03-07 14:13:32 UTC (rev 11652)
@@ -60,6 +60,14 @@
+     * Constructor: OpenLayers.Format.SOSGetFeatureOfInterest
+     * Parameters:
+     *     this instance.
      * APIMethod: read
      * Parse a GetFeatureOfInterest response and return an array of features
Modified: trunk/openlayers/lib/OpenLayers/Format/SOSGetObservation.js
--- trunk/openlayers/lib/OpenLayers/Format/SOSGetObservation.js	2011-03-07 12:49:51 UTC (rev 11651)
+++ trunk/openlayers/lib/OpenLayers/Format/SOSGetObservation.js	2011-03-07 14:13:32 UTC (rev 11652)
@@ -62,6 +62,14 @@
     defaultPrefix: "sos",
+     * Constructor: OpenLayers.Format.SOSGetObservation
+     * Parameters:
+     *     this instance.
      * Method: read
      * Parameters:
Modified: trunk/openlayers/lib/OpenLayers/Format/WFSCapabilities.js
--- trunk/openlayers/lib/OpenLayers/Format/WFSCapabilities.js	2011-03-07 12:49:51 UTC (rev 11651)
+++ trunk/openlayers/lib/OpenLayers/Format/WFSCapabilities.js	2011-03-07 14:13:32 UTC (rev 11652)
@@ -29,6 +29,15 @@
     version: null,
+     * Constructor: OpenLayers.Format.WFSCapabilities
+     * Create a new parser for WFS capabilities.
+     * Parameters:
+     *     this instance.
      * APIMethod: read
      * Read capabilities data from a string, and return a list of layers.
Modified: trunk/openlayers/lib/OpenLayers/Format/WFSDescribeFeatureType.js
--- trunk/openlayers/lib/OpenLayers/Format/WFSDescribeFeatureType.js	2011-03-07 12:49:51 UTC (rev 11651)
+++ trunk/openlayers/lib/OpenLayers/Format/WFSDescribeFeatureType.js	2011-03-07 14:13:32 UTC (rev 11652)
@@ -22,8 +22,17 @@
     namespaces: {
         xsd: "http://www.w3.org/2001/XMLSchema"
+     * Constructor: OpenLayers.Format.WFSDescribeFeatureType
+     * Create a new parser for WFS DescribeFeatureType responses.
+     * Parameters:
+     *     this instance.
      * Property: readers
      * Contains public functions, grouped by namespace prefix, that will
      *     be applied when a namespaced node is found matching the function
Modified: trunk/openlayers/lib/OpenLayers/Format/WMC.js
--- trunk/openlayers/lib/OpenLayers/Format/WMC.js	2011-03-07 12:49:51 UTC (rev 11651)
+++ trunk/openlayers/lib/OpenLayers/Format/WMC.js	2011-03-07 14:13:32 UTC (rev 11652)
@@ -22,6 +22,15 @@
      * {String} Version number to assume if none found.  Default is "1.1.0".
     defaultVersion: "1.1.0",
+     * Constructor: OpenLayers.Format.WMC
+     * Create a new parser for Web Map Context documents.
+     * Parameters:
+     *     this instance.
      * Method: getParser
Modified: trunk/openlayers/lib/OpenLayers/Format/WMSCapabilities.js
--- trunk/openlayers/lib/OpenLayers/Format/WMSCapabilities.js	2011-03-07 12:49:51 UTC (rev 11651)
+++ trunk/openlayers/lib/OpenLayers/Format/WMSCapabilities.js	2011-03-07 14:13:32 UTC (rev 11652)
@@ -44,6 +44,15 @@
     parser: null,
+     * Constructor: OpenLayers.Format.WMSCapabilities
+     * Create a new parser for WMS capabilities.
+     * Parameters:
+     *     this instance.
      * APIMethod: read
Modified: trunk/openlayers/lib/OpenLayers/Format/WMSDescribeLayer.js
--- trunk/openlayers/lib/OpenLayers/Format/WMSDescribeLayer.js	2011-03-07 12:49:51 UTC (rev 11651)
+++ trunk/openlayers/lib/OpenLayers/Format/WMSDescribeLayer.js	2011-03-07 14:13:32 UTC (rev 11652)
@@ -30,6 +30,15 @@
     version: null,
+     * Constructor: OpenLayers.Format.WMSDescribeLayer
+     * Create a new parser for WMS DescribeLayer responses.
+     * Parameters:
+     *     this instance.
      * APIMethod: read
      * Read DescribeLayer data from a string, and return the response.
      * The OGC currently defines 2 formats which are allowed for output,
Modified: trunk/openlayers/lib/OpenLayers/Format/WMSGetFeatureInfo.js
--- trunk/openlayers/lib/OpenLayers/Format/WMSGetFeatureInfo.js	2011-03-07 12:49:51 UTC (rev 11651)
+++ trunk/openlayers/lib/OpenLayers/Format/WMSGetFeatureInfo.js	2011-03-07 14:13:32 UTC (rev 11652)
@@ -49,6 +49,15 @@
     gmlFormat: null,
+     * Constructor: OpenLayers.Format.WMSGetFeatureInfo
+     * Create a new parser for WMS GetFeatureInfo responses
+     * Parameters:
+     *     this instance.
      * APIMethod: read
      * Read WMS GetFeatureInfo data from a string, and return an array of features
Modified: trunk/openlayers/lib/OpenLayers/Format/WMTSCapabilities.js
--- trunk/openlayers/lib/OpenLayers/Format/WMTSCapabilities.js	2011-03-07 12:49:51 UTC (rev 11651)
+++ trunk/openlayers/lib/OpenLayers/Format/WMTSCapabilities.js	2011-03-07 14:13:32 UTC (rev 11652)
@@ -48,6 +48,15 @@
+     * Constructor: OpenLayers.Format.WMTSCapabilities
+     * Create a new parser for WMTS capabilities.
+     * Parameters:
+     *     this instance.
      * APIMethod: read
More information about the Commits mailing list
