[OpenLayers-Commits] r11659 - in trunk/openlayers: lib/OpenLayers/Protocol/WFS tests/Protocol
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Mar 7 10:40:41 EST 2011
Author: bartvde
Date: 2011-03-07 07:40:37 -0800 (Mon, 07 Mar 2011)
New Revision: 11659
   trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js
   trunk/openlayers/tests/Protocol/WFS.html
need a setFeatureType function on Protocol.WFS, r=erilem (closes #2639)
Modified: trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js
--- trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js	2011-03-07 15:05:06 UTC (rev 11658)
+++ trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js	2011-03-07 15:40:37 UTC (rev 11659)
@@ -183,6 +183,18 @@
         return response;
+     * APIMethod: setFeatureType
+     * Change the feature type on the fly.
+     * Parameters:
+     * featureType - {String} Local (without prefix) feature typeName.
+    setFeatureType: function(featureType) {
+        this.featureType = featureType;
+        this.format.featureType = featureType;
      * Method: handleRead
Modified: trunk/openlayers/tests/Protocol/WFS.html
--- trunk/openlayers/tests/Protocol/WFS.html	2011-03-07 15:05:06 UTC (rev 11658)
+++ trunk/openlayers/tests/Protocol/WFS.html	2011-03-07 15:40:37 UTC (rev 11659)
@@ -24,6 +24,22 @@
              "initialize returns instance of custom versioned protocol")
+    function test_setFeatureType(t) {
+        t.plan(4);
+        var protocol = new OpenLayers.Protocol.WFS({
+            url: "http://some.url.org",
+            featureNS: "http://namespace.org",
+            featureType: "type"
+        t.eq(protocol.featureType, "type", "featureType set correctly by constructor");
+        t.eq(protocol.format.featureType, "type", "featureType correctly set on format by constructor");
+        // change the feature type on the fly
+        protocol.setFeatureType("foo");
+        t.eq(protocol.featureType, "foo", "featureType changed correctly by setFeatureType");
+        t.eq(protocol.format.featureType, "foo", "featureType correctly changed on format by setFeatureType");
+        protocol.destroy();
     function test_read(t) {
         t.plan(7);
More information about the Commits mailing list
