[OpenLayers-Commits] r11710 - in sandbox/august/trunk: . examples lib lib/OpenLayers
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Mar 16 12:13:54 EDT 2011
Author: augusttown
Date: 2011-03-16 09:13:53 -0700 (Wed, 16 Mar 2011)
New Revision: 11710
   sandbox/august/trunk/
   sandbox/august/trunk/examples/dynamic-text-layer.html
   sandbox/august/trunk/lib/OpenLayers.js
   sandbox/august/trunk/lib/OpenLayers/Events.js
   sandbox/august/trunk/lib/OpenLayers/Layer.js
Property changes on: sandbox/august/trunk
___________________________________________________________________
Modified: svn:mergeinfo
   - /trunk/openlayers:10329-10354,10357-10502,10504-11704
   + /trunk/openlayers:10329-10354,10357-10502,10504-11709
Modified: sandbox/august/trunk/examples/dynamic-text-layer.html
--- sandbox/august/trunk/examples/dynamic-text-layer.html	2011-03-16 16:05:53 UTC (rev 11709)
+++ sandbox/august/trunk/examples/dynamic-text-layer.html	2011-03-16 16:13:53 UTC (rev 11710)
@@ -41,7 +41,13 @@
             // Needed only for interaction, not for the display.
             function onPopupClose(evt) {
                 // 'this' is the popup.
-                selectControl.unselect(this.feature);
+                var feature = this.feature;
+                if (feature.layer) { // The feature is not destroyed
+                    selectControl.unselect(feature);
+                } else { // After "moveend" or "refresh" events on POIs layer all
+                         //     features have been destroyed by the Strategy.BBOX
+                    this.destroy();
             function onFeatureSelect(evt) {
                 feature = evt.feature;
@@ -53,7 +59,7 @@
                                          null, true, onPopupClose);
                 feature.popup = popup;
                 popup.feature = feature;
-                map.addPopup(popup);
+                map.addPopup(popup, true);
             function onFeatureUnselect(evt) {
Modified: sandbox/august/trunk/lib/OpenLayers/Events.js
--- sandbox/august/trunk/lib/OpenLayers/Events.js	2011-03-16 16:05:53 UTC (rev 11709)
+++ sandbox/august/trunk/lib/OpenLayers/Events.js	2011-03-16 16:13:53 UTC (rev 11710)
@@ -854,7 +854,18 @@
     clearMouseCache: function() {
         this.element.scrolls = null;
         this.element.lefttop = null;
-        this.element.offsets = null;
+        // OpenLayers.Util.pagePosition needs to use
+        // element.getBoundingClientRect to correctly calculate the offsets
+        // for the iPhone, but once the page is scrolled, getBoundingClientRect
+        // returns incorrect offsets. So our best bet is to not invalidate the
+        // offsets once we have them, and hope that the page was not scrolled
+        // when we did the initial calculation.
+        if (!((document.body.scrollTop != 0 ||
+                                document.body.scrollLeft != 0) &&
+                                navigator.userAgent.match(/iPhone/i))) {
+            OpenLayers.Console.log("clear");
+            this.element.offsets = null;
Modified: sandbox/august/trunk/lib/OpenLayers/Layer.js
--- sandbox/august/trunk/lib/OpenLayers/Layer.js	2011-03-16 16:05:53 UTC (rev 11709)
+++ sandbox/august/trunk/lib/OpenLayers/Layer.js	2011-03-16 16:13:53 UTC (rev 11710)
@@ -1322,7 +1322,8 @@
         if (this.wrapDateLine) {
             // wrap around the date line, within the limits of rounding error
             var wrappingOptions = {
-                'rightTolerance':this.getResolution()
+                'rightTolerance':this.getResolution(),
+                'leftTolerance':this.getResolution()
             bounds = bounds.wrapDateLine(this.maxExtent, wrappingOptions);
Modified: sandbox/august/trunk/lib/OpenLayers.js
--- sandbox/august/trunk/lib/OpenLayers.js	2011-03-16 16:05:53 UTC (rev 11709)
+++ sandbox/august/trunk/lib/OpenLayers.js	2011-03-16 16:13:53 UTC (rev 11710)
@@ -93,7 +93,7 @@
      * OpenLayers library code as it will be appended at the end of this file.
     if(!singleFile) {
-        var jsfiles = new Array(
+        var jsFiles = new Array(
             "OpenLayers/BaseTypes/Class.js",
             "OpenLayers/Util.js",
             "OpenLayers/BaseTypes.js",
More information about the Commits mailing list
