[OpenLayers-Commits] r11712 - in trunk/openlayers: lib lib/OpenLayers/Filter lib/OpenLayers/Format/Filter tests/Format/Filter
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Mar 17 11:47:32 EDT 2011
Author: bartvde
Date: 2011-03-17 08:47:28 -0700 (Thu, 17 Mar 2011)
New Revision: 11712
Added:
   trunk/openlayers/lib/OpenLayers/Filter/Function.js
   trunk/openlayers/lib/OpenLayers.js
   trunk/openlayers/lib/OpenLayers/Format/Filter/v1.js
   trunk/openlayers/lib/OpenLayers/Format/Filter/v1_0_0.js
   trunk/openlayers/lib/OpenLayers/Format/Filter/v1_1_0.js
   trunk/openlayers/tests/Format/Filter/v1_0_0.html
   trunk/openlayers/tests/Format/Filter/v1_1_0.html
Geoserver filter Functions support in OL filter encoding, p=igrcic,r=me (closes #3053)
Added: trunk/openlayers/lib/OpenLayers/Filter/Function.js
--- trunk/openlayers/lib/OpenLayers/Filter/Function.js	                        (rev 0)
+++ trunk/openlayers/lib/OpenLayers/Filter/Function.js	2011-03-17 15:47:28 UTC (rev 11712)
@@ -0,0 +1,52 @@
+/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Filter.js
+ * Class: OpenLayers.Filter.Function
+ * This class represents a filter function.
+ * We are using this class for creation of complex
+ * filters that can contain filter functions as values.
+ * Nesting function as other functions parameter is supported.
+ * Inherits from
+ * - <OpenLayers.Filter>
+OpenLayers.Filter.Function = OpenLayers.Class(OpenLayers.Filter, {
+     * APIProperty: name
+     * {String} Name of the function.
+    name: null,
+     * APIProperty: params
+     * {Array(<OpenLayers.Filter.Function> || String || Number)} Function parameters
+     * For now support only other Functions, String or Number
+    params: null,
+     * Constructor: OpenLayers.Filter.Function
+     * Creates a filter function.
+     * Parameters:
+     * options - {Object} An optional object with properties to set on the
+     *     function.
+     * Returns:
+     * {<OpenLayers.Filter.Function>}
+    initialize: function(options) {
+        OpenLayers.Filter.prototype.initialize.apply(this, [options]);
+    CLASS_NAME: "OpenLayers.Filter.Function"
Modified: trunk/openlayers/lib/OpenLayers/Format/Filter/v1.js
--- trunk/openlayers/lib/OpenLayers/Format/Filter/v1.js	2011-03-17 13:01:37 UTC (rev 11711)
+++ trunk/openlayers/lib/OpenLayers/Format/Filter/v1.js	2011-03-17 15:47:28 UTC (rev 11712)
@@ -186,6 +186,10 @@
             "Distance": function(node, obj) {
                 obj.distance = parseInt(this.getChildValue(node));
                 obj.distanceUnits = node.getAttribute("units");
+            "Function": function(node, obj) {
+                //TODO write decoder for it
+                return;
@@ -234,6 +238,28 @@
+     * Method: writeOgcExpression
+     * Limited support for writing OGC expressions. Currently it supports
+     * (<OpenLayers.Filter.Function> || String || Number)
+     * Parameters:
+     * value - (<OpenLayers.Filter.Function> || String || Number)
+     * node - {DOMElement} A parent DOM element
+     * Returns:
+     * {DOMElement} Updated node element.
+    writeOgcExpression: function(value, node) {
+        if(value instanceof OpenLayers.Filter.Function){
+            var child = this.writeNode("Function", value, node);
+            node.appendChild(child);
+        } else {
+            this.writeNode("Literal", value, node);
+        return node;
      * Method: write
      * Parameters:
@@ -303,35 +329,39 @@
             "PropertyIsLessThan": function(filter) {
                 var node = this.createElementNSPlus("ogc:PropertyIsLessThan");
-                // no ogc:expression handling for now
+                // no ogc:expression handling for PropertyName for now
                 this.writeNode("PropertyName", filter, node);
-                this.writeNode("Literal", filter.value, node);
+                // handle Literals or Functions for now
+                this.writeOgcExpression(filter.value, node);
                 return node;
             "PropertyIsGreaterThan": function(filter) {
                 var node = this.createElementNSPlus("ogc:PropertyIsGreaterThan");
                 return node;
             "PropertyIsLessThanOrEqualTo": function(filter) {
                 var node = this.createElementNSPlus("ogc:PropertyIsLessThanOrEqualTo");
                 return node;
             "PropertyIsGreaterThanOrEqualTo": function(filter) {
                 var node = this.createElementNSPlus("ogc:PropertyIsGreaterThanOrEqualTo");
                 return node;
             "PropertyIsBetween": function(filter) {
                 var node = this.createElementNSPlus("ogc:PropertyIsBetween");
                 this.writeNode("LowerBoundary", filter, node);
                 this.writeNode("UpperBoundary", filter, node);
@@ -350,13 +380,13 @@
             "LowerBoundary": function(filter) {
                 var node = this.createElementNSPlus("ogc:LowerBoundary");
-                this.writeNode("Literal", filter.lowerBoundary, node);
+                this.writeOgcExpression(filter.lowerBoundary, node);
                 return node;
             "UpperBoundary": function(filter) {
                 var node = this.createElementNSPlus("ogc:UpperBoundary");
                 this.writeNode("Literal", filter.upperBoundary, node);
                 return node;
@@ -382,8 +412,20 @@
                     value: filter.distance
+            "Function": function(filter) {
+                var node = this.createElementNSPlus("ogc:Function", {
+                    attributes: {
+                        name: filter.name
+                var params = filter.params;
+                for(var i=0, len=params.length; i<len; i++){
+                    this.writeOgcExpression(params[i], node);
+                return node;
Modified: trunk/openlayers/lib/OpenLayers/Format/Filter/v1_0_0.js
--- trunk/openlayers/lib/OpenLayers/Format/Filter/v1_0_0.js	2011-03-17 13:01:37 UTC (rev 11711)
+++ trunk/openlayers/lib/OpenLayers/Format/Filter/v1_0_0.js	2011-03-17 15:47:28 UTC (rev 11712)
@@ -96,16 +96,18 @@
         "ogc": OpenLayers.Util.applyDefaults({
             "PropertyIsEqualTo": function(filter) {
                 var node = this.createElementNSPlus("ogc:PropertyIsEqualTo");
                 return node;
             "PropertyIsNotEqualTo": function(filter) {
                 var node = this.createElementNSPlus("ogc:PropertyIsNotEqualTo");
                 return node;
             "PropertyIsLike": function(filter) {
@@ -150,6 +152,9 @@
     writeSpatial: function(filter, name) {
         var node = this.createElementNSPlus("ogc:"+name);
+        if(filter.value instanceof OpenLayers.Filter.Function) {
+            this.writeNode("Function", filter.value, node);
+        } else {
         var child;
         if(filter.value instanceof OpenLayers.Geometry) {
             child = this.writeNode("feature:_geometry", filter.value).firstChild;
@@ -160,6 +165,7 @@
             child.setAttribute("srsName", filter.projection);
         return node;
Modified: trunk/openlayers/lib/OpenLayers/Format/Filter/v1_1_0.js
--- trunk/openlayers/lib/OpenLayers/Format/Filter/v1_1_0.js	2011-03-17 13:01:37 UTC (rev 11711)
+++ trunk/openlayers/lib/OpenLayers/Format/Filter/v1_1_0.js	2011-03-17 15:47:28 UTC (rev 11712)
@@ -108,18 +108,20 @@
                 var node = this.createElementNSPlus("ogc:PropertyIsEqualTo", {
                     attributes: {matchCase: filter.matchCase}
                 return node;
                 var node = this.createElementNSPlus("ogc:PropertyIsNotEqualTo", {
                 return node;
@@ -164,6 +166,9 @@
+        } else {
         var child;
@@ -174,6 +179,7 @@
         return node;
Modified: trunk/openlayers/lib/OpenLayers.js
--- trunk/openlayers/lib/OpenLayers.js	2011-03-17 13:01:37 UTC (rev 11711)
+++ trunk/openlayers/lib/OpenLayers.js	2011-03-17 15:47:28 UTC (rev 11712)
@@ -244,6 +244,7 @@
                 "OpenLayers/Filter/Logical.js",
                 "OpenLayers/Filter/Comparison.js",
                 "OpenLayers/Filter/Spatial.js",
+                "OpenLayers/Filter/Function.js",
                 "OpenLayers/Protocol.js",
                 "OpenLayers/Protocol/HTTP.js",
                 "OpenLayers/Protocol/SimpleFilterSerializer.js",
Modified: trunk/openlayers/tests/Format/Filter/v1_0_0.html
--- trunk/openlayers/tests/Format/Filter/v1_0_0.html	2011-03-17 13:01:37 UTC (rev 11711)
+++ trunk/openlayers/tests/Format/Filter/v1_0_0.html	2011-03-17 15:47:28 UTC (rev 11712)
@@ -152,7 +152,117 @@
+    function test_FilterFunctions(t) {
+        t.plan(2);
+        var parser = new OpenLayers.Format.Filter.v1_0_0();
+        //test spatial intersects with filter function
+        var filter = new OpenLayers.Filter.Spatial({
+            property: 'the_geom',
+            type: OpenLayers.Filter.Spatial.INTERSECTS,
+            value: new OpenLayers.Filter.Function({
+                name  : 'querySingle',
+                params: ['sf:restricted', 'the_geom', 'cat=3']
+        var out =
+            '<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">' +
+                '<ogc:Intersects>' +
+                    '<ogc:PropertyName>the_geom</ogc:PropertyName>' +
+                    '<ogc:Function name="querySingle">' +
+                        '<ogc:Literal>sf:restricted</ogc:Literal>' +
+                        '<ogc:Literal>the_geom</ogc:Literal>' +
+                        '<ogc:Literal>cat=3</ogc:Literal>' +
+                    '</ogc:Function>' +
+                '</ogc:Intersects>' +
+            '</ogc:Filter>';
+        var node = parser.write(filter);
+        //test writer
+        t.xml_eq(node, out, "spatial intersect filter with functions correctly written");
+        //test logical filter with custom function
+        filter = new OpenLayers.Filter.Logical({
+            type: OpenLayers.Filter.Logical.AND,
+            filters: [
+                new OpenLayers.Filter.Comparison({
+                    type: OpenLayers.Filter.Comparison.NOT_EQUAL_TO,
+                    property: "FOO",
+                        name : 'customFunction',
+                        params : ['param1', 'param2']
+        out =
+                '<ogc:And>' +
+                    '<ogc:PropertyIsNotEqualTo>' +
+                        '<ogc:PropertyName>FOO</ogc:PropertyName>' +
+                        '<ogc:Function name="customFunction">' +
+                            '<ogc:Literal>param1</ogc:Literal>' +
+                            '<ogc:Literal>param2</ogc:Literal>' +
+                    '</ogc:PropertyIsNotEqualTo>' +
+                '</ogc:And>' +
+            '</ogc:Filter>';
+        node = parser.write(filter);
+        //test writer
+        t.xml_eq(node, out, "comparison filter with filter functions correctly written");
+    function test_NestedFilterFunctions(t) {
+        t.plan(1);
+        //test spatial dwithin with nested filter function
+           type: OpenLayers.Filter.Spatial.DWITHIN,
+               name : 'collectGeometries',
+               params: [
+                    new OpenLayers.Filter.Function({
+                        name  : 'queryCollection',
+                        params: ['sf:roads', 'the_geom', 'INCLUDE']
+           distanceUnits: "meters",
+           distance: 200
+        var out =
+                '<ogc:DWithin>' +
+                    '<ogc:Function name="collectGeometries">' +
+                        '<ogc:Function name="queryCollection">' +
+                            '<ogc:Literal>sf:roads</ogc:Literal>' +
+                            '<ogc:Literal>INCLUDE</ogc:Literal>' +
+                    '<ogc:Distance units="meters">200</ogc:Distance>' +
+                '</ogc:DWithin>' +
+            '</ogc:Filter>';
+        //test writer
+        t.xml_eq(node, out, "spatial dwithin filter with nested functions correctly written");
     </script>
 </head>
 <body>
Modified: trunk/openlayers/tests/Format/Filter/v1_1_0.html
--- trunk/openlayers/tests/Format/Filter/v1_1_0.html	2011-03-17 13:01:37 UTC (rev 11711)
+++ trunk/openlayers/tests/Format/Filter/v1_1_0.html	2011-03-17 15:47:28 UTC (rev 11712)
@@ -203,6 +203,118 @@
+        t.plan(2);
+        var parser = new OpenLayers.Format.Filter.v1_1_0();
+        var out =
+            '</ogc:Filter>';
+        //test writer
+            filters: [
+                    matchCase: false,
+                    property: "FOO",
+        out =
+                '<ogc:And>' +
+                    '<ogc:PropertyIsNotEqualTo matchCase="false">' +
+                '</ogc:And>' +
+            '</ogc:Filter>';
+        //test writer
+        t.plan(1);
+               params: [
+           distance: 200
+        var out =
+                '<ogc:DWithin>' +
+            '</ogc:Filter>';
+        //test writer
     </script>
 </head>
 <body>
More information about the Commits mailing list
