[OpenLayers-Commits] r11717 - in trunk/openlayers: lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Mar 21 04:29:01 EDT 2011
Author: erilem
Date: 2011-03-21 01:28:58 -0700 (Mon, 21 Mar 2011)
New Revision: 11717
   trunk/openlayers/lib/OpenLayers/Handler/Point.js
   trunk/openlayers/tests/Handler/Point.html
make it possible to activate a drawing handler before the map is centered, r=ahocevar (closes #3179)
Modified: trunk/openlayers/lib/OpenLayers/Handler/Point.js
--- trunk/openlayers/lib/OpenLayers/Handler/Point.js	2011-03-18 12:48:17 UTC (rev 11716)
+++ trunk/openlayers/lib/OpenLayers/Handler/Point.js	2011-03-21 08:28:58 UTC (rev 11717)
@@ -200,13 +200,14 @@
      * pixel - {<OpenLayers.Pixel>} A pixel location on the map.
     createFeature: function(pixel) {
-        if(!pixel) {
-            pixel = new OpenLayers.Pixel(-50, -50);
+        var geometry;
+        if(pixel) {
+            var lonlat = this.map.getLonLatFromPixel(pixel);
+            geometry = new OpenLayers.Geometry.Point(lonlat.lon, lonlat.lat);
+        } else {
+            geometry = new OpenLayers.Geometry.Point();
-        var lonlat = this.map.getLonLatFromPixel(pixel);
-        this.point = new OpenLayers.Feature.Vector(
-            new OpenLayers.Geometry.Point(lonlat.lon, lonlat.lat)
+        this.point = new OpenLayers.Feature.Vector(geometry);
         this.callback("create", [this.point.geometry, this.point]);
         this.point.geometry.clearBounds();
         this.layer.addFeatures([this.point], {silent: true});
Modified: trunk/openlayers/tests/Handler/Point.html
--- trunk/openlayers/tests/Handler/Point.html	2011-03-18 12:48:17 UTC (rev 11716)
+++ trunk/openlayers/tests/Handler/Point.html	2011-03-21 08:28:58 UTC (rev 11717)
@@ -63,7 +63,7 @@
              "activate adds the feature to the layer");
         t.eq(log.length, 1,
              "activate calls \"create\" once");
-        t.geom_eq(log[0].geometry, handler.point.geometry,
+        t.ok(log[0].geometry == handler.point.geometry,
                   "\"create\" called with expected geometry");
         t.ok(log[0].feature == handler.point,
              "\"create\" called with expected feature");
@@ -82,6 +82,32 @@
         map.destroy();
+    // http://trac.osgeo.org/openlayers/ticket/3179
+    function test_activate_before_map_is_centered(t) {
+        t.plan(1);
+        var map = new OpenLayers.Map('map', {
+            resolutions: [1]
+        var layer = new OpenLayers.Layer.Vector("foo", {
+            maxExtent: new OpenLayers.Bounds(-10, -10, 10, 10),
+            isBaseLayer: true
+        map.addLayer(layer);
+        var control = new OpenLayers.Control();
+        var handler = new OpenLayers.Handler.Point(control, {});
+        control.handler = handler;
+        map.addControl(control);
+        var error;
+        try {
+            handler.activate();
+            error = false;
+        } catch(err) {
+            error = true;
+        t.ok(!error, "no error on activate");
     function test_Handler_Point_events(t) {
         t.plan(49);
         var log = [];
@@ -188,8 +214,8 @@
         t.eq(logs.length, 1, "[activate] called back");
         log = logs.shift();
         t.eq(log.type, "create", "[activate] create called");
-        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-200, 125),
-                  "[activate] correct point");
+        t.ok(isNaN(log.args[0].x) && isNaN(log.args[0].y),
+             "[activate] initial point");
         // mouse down
         handler.mousedown(
             {type: "mousedown", xy: new OpenLayers.Pixel(0, 0)});
@@ -239,8 +265,8 @@
                   "[mouseup] correct point");
         log = logs.shift();
         t.eq(log.type, "create", "[mouseup] create called");
+             "[mouseup] initial point");
         // mouse up on same pixel
         handler.mouseup({type: "mouseup", xy: new OpenLayers.Pixel(2, 0)});
         t.eq(logs.length, 0, "[mouseup] not called back");
@@ -249,12 +275,12 @@
         t.eq(logs.length, 2, "[cancel] called back");
         log = logs.shift();
         t.eq(log.type, "cancel", "[cancel] canced called");
-                  "[cancel] correct point");
+             "[cancel] initial point");
         log = logs.shift();
         t.eq(log.type, "create", "[cancel] create called");
+             "[] initial point");
         map.destroy();
More information about the Commits mailing list
