[OpenLayers-Commits] r11720 - in trunk/openlayers: lib/OpenLayers/Control tests/Control
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Mar 22 08:30:44 EDT 2011
Author: bartvde
Date: 2011-03-22 05:30:41 -0700 (Tue, 22 Mar 2011)
New Revision: 11720
   trunk/openlayers/lib/OpenLayers/Control/SLDSelect.js
   trunk/openlayers/tests/Control/SLDSelect.html
add srsName to geometry filters written out by OpenLayers.Control.SLDSelect, this fixes the issue on the OpenLayers side, but not yet on the GeoServer side, although this might have been fixed after 2.1RC2 as aaime pointed out on geoserver-users, r=ahocevar (closes #3182)
Modified: trunk/openlayers/lib/OpenLayers/Control/SLDSelect.js
--- trunk/openlayers/lib/OpenLayers/Control/SLDSelect.js	2011-03-22 08:27:27 UTC (rev 11719)
+++ trunk/openlayers/lib/OpenLayers/Control/SLDSelect.js	2011-03-22 12:30:41 UTC (rev 11720)
@@ -11,6 +11,7 @@
  * @requires OpenLayers/Handler/Path.js
  * @requires OpenLayers/Handler/Click.js
  * @requires OpenLayers/Filter/Spatial.js
+ * @requires OpenLayers/Format/SLD/v1_0_0.js
@@ -272,7 +273,7 @@
                     maxScaleDenominator: layer.options.minScale})
-        return new OpenLayers.Format.SLD().write(sld);
+        return new OpenLayers.Format.SLD({srsName: this.map.getProjection()}).write(sld);
Modified: trunk/openlayers/tests/Control/SLDSelect.html
--- trunk/openlayers/tests/Control/SLDSelect.html	2011-03-22 08:27:27 UTC (rev 11719)
+++ trunk/openlayers/tests/Control/SLDSelect.html	2011-03-22 12:30:41 UTC (rev 11720)
@@ -82,7 +82,7 @@
         t.eq(map.layers.length, 2, "Selection layer has been created and added to the map");
         t.eq(map.layers[1] instanceof OpenLayers.Layer.WMS, true, "A WMS layer has been created as the selection layer");
         t.eq(map.layers[1].tileOptions.maxGetUrlLength, 2048, "Selection layer will automatically switch to HTTP Post if content gets longer than 2048");
-        var expected_sld = '<sld:StyledLayerDescriptor xmlns:sld="http://www.opengis.net/sld" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml"><sld:NamedLayer><sld:Name>AAA64</sld:Name><sld:UserStyle><sld:Name>default</sld:Name><sld:FeatureTypeStyle><sld:Rule><ogc:Filter xmlns:ogc="http://www.opengis.net/ogc"><ogc:BBOX><ogc:PropertyName>geometry</ogc:PropertyName><gml:Box xmlns:gml="http://www.opengis.net/gml"><gml:coordinates decimal="." cs="," ts=" ">-3.5355339059327,-3.5355339059327 3.5355339059327,3.5355339059327</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter><sld:LineSymbolizer><sld:Stroke><sld:CssParameter name="stroke">#FF0000</sld:CssParameter><sld:CssParameter name="stroke-width">2</sld:CssParameter></sld:Stroke></sld:LineSymbolizer></sld:Rule></sld:Featur
 eTypeStyle></sld:UserStyle></sld:NamedLayer></sld:StyledLayerDescriptor>';
+        var expected_sld = '<sld:StyledLayerDescriptor xmlns:sld="http://www.opengis.net/sld" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml"><sld:NamedLayer><sld:Name>AAA64</sld:Name><sld:UserStyle><sld:Name>default</sld:Name><sld:FeatureTypeStyle><sld:Rule><ogc:Filter xmlns:ogc="http://www.opengis.net/ogc"><ogc:BBOX><ogc:PropertyName>geometry</ogc:PropertyName><gml:Box xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:4326"><gml:coordinates decimal="." cs="," ts=" ">-3.5355339059327,-3.5355339059327 3.5355339059327,3.5355339059327</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter><sld:LineSymbolizer><sld:Stroke><sld:CssParameter name="stroke">#FF0000</sld:CssParameter><sld:CssParameter name="stroke-width">2</sld:CssParameter></sld:Stroke></sld:LineSymbolizer></s
 ld:Rule></sld:FeatureTypeStyle></sld:UserStyle></sld:NamedLayer></sld:StyledLayerDescriptor>';
         t.xml_eq(map.layers[1].params.SLD_BODY, expected_sld, "SLD generated correctly");
@@ -169,7 +169,7 @@
         var geometry = OpenLayers.Geometry.Polygon.createRegularPolygon(
             new OpenLayers.Geometry.Point(0, 0), 5, 4);
         control.select(geometry);
-        var expected_sld = '<sld:StyledLayerDescriptor xmlns:sld="http://www.opengis.net/sld" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml"><sld:NamedLayer><sld:Name>KGNAT.VKUNSTWERK</sld:Name><sld:UserStyle><sld:Name>default</sld:Name><sld:FeatureTypeStyle><sld:Rule><ogc:Filter xmlns:ogc="http://www.opengis.net/ogc"><ogc:BBOX><ogc:PropertyName>geometry</ogc:PropertyName><gml:Box xmlns:gml="http://www.opengis.net/gml"><gml:coordinates decimal="." cs="," ts=" ">-3.5355339059327,-3.5355339059327 3.5355339059327,3.5355339059327</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter><sld:PolygonSymbolizer><sld:Fill><sld:CssParameter name="fill">#FF0000</sld:CssParameter></sld:Fill></sld:PolygonSymbolizer></sld:Rule></sld:FeatureTypeStyle></sld:UserStyle></sld:NamedLayer><sl
 d:NamedLayer><sld:Name>KGNAT.LKUNSTWERK</sld:Name><sld:UserStyle><sld:Name>default</sld:Name><sld:FeatureTypeStyle><sld:Rule><ogc:Filter xmlns:ogc="http://www.opengis.net/ogc"><ogc:BBOX><ogc:PropertyName>geometry</ogc:PropertyName><gml:Box xmlns:gml="http://www.opengis.net/gml"><gml:coordinates decimal="." cs="," ts=" ">-3.5355339059327,-3.5355339059327 3.5355339059327,3.5355339059327</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter><sld:LineSymbolizer><sld:Stroke><sld:CssParameter name="stroke">#FF0000</sld:CssParameter><sld:CssParameter name="stroke-width">2</sld:CssParameter></sld:Stroke></sld:LineSymbolizer></sld:Rule></sld:FeatureTypeStyle></sld:UserStyle></sld:NamedLayer><sld:NamedLayer><sld:Name>KGNAT.PKUNSTWERK</sld:Name><sld:UserStyle><sld:Name>default</sld:Name><sld:FeatureTypeStyle><sld:Rule><ogc:Filter xmlns:ogc="http://www.opengis.net/ogc"><ogc:BBOX><ogc:PropertyName>geometry</ogc:PropertyName><gml:Box xmlns:gml="http://www.opengis.net/gml"><gml:coordinates de
 cimal="." cs="," ts=" ">-3.5355339059327,-3.5355339059327 3.5355339059327,3.5355339059327</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter><sld:PointSymbolizer><sld:Graphic><sld:Mark><sld:WellKnownName>square</sld:WellKnownName><sld:Fill><sld:CssParameter name="fill">#FF0000</sld:CssParameter></sld:Fill><sld:Stroke/></sld:Mark><sld:Size>10</sld:Size></sld:Graphic></sld:PointSymbolizer></sld:Rule></sld:FeatureTypeStyle></sld:UserStyle></sld:NamedLayer></sld:StyledLayerDescriptor>';
+        var expected_sld = '<sld:StyledLayerDescriptor xmlns:sld="http://www.opengis.net/sld" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml"><sld:NamedLayer><sld:Name>KGNAT.VKUNSTWERK</sld:Name><sld:UserStyle><sld:Name>default</sld:Name><sld:FeatureTypeStyle><sld:Rule><ogc:Filter xmlns:ogc="http://www.opengis.net/ogc"><ogc:BBOX><ogc:PropertyName>geometry</ogc:PropertyName><gml:Box xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:4326"><gml:coordinates decimal="." cs="," ts=" ">-3.5355339059327,-3.5355339059327 3.5355339059327,3.5355339059327</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter><sld:PolygonSymbolizer><sld:Fill><sld:CssParameter name="fill">#FF0000</sld:CssParameter></sld:Fill></sld:PolygonSymbolizer></sld:Rule></sld:FeatureTypeStyle></sld:UserStyle>
 </sld:NamedLayer><sld:NamedLayer><sld:Name>KGNAT.LKUNSTWERK</sld:Name><sld:UserStyle><sld:Name>default</sld:Name><sld:FeatureTypeStyle><sld:Rule><ogc:Filter xmlns:ogc="http://www.opengis.net/ogc"><ogc:BBOX><ogc:PropertyName>geometry</ogc:PropertyName><gml:Box xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:4326"><gml:coordinates decimal="." cs="," ts=" ">-3.5355339059327,-3.5355339059327 3.5355339059327,3.5355339059327</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter><sld:LineSymbolizer><sld:Stroke><sld:CssParameter name="stroke">#FF0000</sld:CssParameter><sld:CssParameter name="stroke-width">2</sld:CssParameter></sld:Stroke></sld:LineSymbolizer></sld:Rule></sld:FeatureTypeStyle></sld:UserStyle></sld:NamedLayer><sld:NamedLayer><sld:Name>KGNAT.PKUNSTWERK</sld:Name><sld:UserStyle><sld:Name>default</sld:Name><sld:FeatureTypeStyle><sld:Rule><ogc:Filter xmlns:ogc="http://www.opengis.net/ogc"><ogc:BBOX><ogc:PropertyName>geometry</ogc:PropertyName><gml:Box xmlns:gml="http://
 www.opengis.net/gml" srsName="EPSG:4326"><gml:coordinates decimal="." cs="," ts=" ">-3.5355339059327,-3.5355339059327 3.5355339059327,3.5355339059327</gml:coordinates></gml:Box></ogc:BBOX></ogc:Filter><sld:PointSymbolizer><sld:Graphic><sld:Mark><sld:WellKnownName>square</sld:WellKnownName><sld:Fill><sld:CssParameter name="fill">#FF0000</sld:CssParameter></sld:Fill><sld:Stroke/></sld:Mark><sld:Size>10</sld:Size></sld:Graphic></sld:PointSymbolizer></sld:Rule></sld:FeatureTypeStyle></sld:UserStyle></sld:NamedLayer></sld:StyledLayerDescriptor>';
         map.destroy();
More information about the Commits mailing list
