[OpenLayers-Commits] r11730 - in trunk/openlayers: lib/OpenLayers tests
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Mar 28 09:53:04 EDT 2011
Author: ahocevar
Date: 2011-03-28 06:52:59 -0700 (Mon, 28 Mar 2011)
New Revision: 11730
   trunk/openlayers/lib/OpenLayers/Events.js
   trunk/openlayers/tests/Map.html
making clearMouseCache work when document.body is not ready, which fixes a regression. r=bartvde (closes #3189)
Modified: trunk/openlayers/lib/OpenLayers/Events.js
--- trunk/openlayers/lib/OpenLayers/Events.js	2011-03-27 17:00:38 UTC (rev 11729)
+++ trunk/openlayers/lib/OpenLayers/Events.js	2011-03-28 13:52:59 UTC (rev 11730)
@@ -860,10 +860,9 @@
         // returns incorrect offsets. So our best bet is to not invalidate the
         // offsets once we have them, and hope that the page was not scrolled
         // when we did the initial calculation.
-        if (!((document.body.scrollTop != 0 ||
-                                document.body.scrollLeft != 0) &&
-                                navigator.userAgent.match(/iPhone/i))) {
-            OpenLayers.Console.log("clear");
+        var body = document.body;
+        if (body && !((body.scrollTop != 0 || body.scrollLeft != 0) &&
+                                    navigator.userAgent.match(/iPhone/i))) {
             this.element.offsets = null;
Modified: trunk/openlayers/tests/Map.html
--- trunk/openlayers/tests/Map.html	2011-03-27 17:00:38 UTC (rev 11729)
+++ trunk/openlayers/tests/Map.html	2011-03-28 13:52:59 UTC (rev 11730)
@@ -1593,9 +1593,21 @@
+    // test if we can call updateSize before document.body is ready. updateOk
+    // is tested in the test_updateSize function below
+    var earlyMap = new OpenLayers.Map();
+    var updateOk;
+    try {
+      earlyMap.updateSize();
+      updateOk = true;
+    } catch(e) {}
+    earlyMap.destroy();
     function test_updateSize(t) {
-        t.plan(2);
+        t.plan(3);
+        // checking updateSize from outside this test function (see above)
+        t.ok(updateOk, "updateSize works before document.body is ready");
         var map, moveToCnt, size;
         map = new OpenLayers.Map({div: "map"});
@@ -1625,7 +1637,7 @@
         map.updateSize();
         t.eq(moveToCnt, 1, "updateSize move the map if it has a center");
-        map.destroy();
+        map.destroy();
     function test_invisible_map(t) {
More information about the Commits mailing list
