[OpenLayers-Commits] r11763 - in sandbox/cmoullet/openlayers: . build examples lib lib/OpenLayers/BaseTypes lib/OpenLayers/Control lib/OpenLayers/Feature lib/OpenLayers/Filter lib/OpenLayers/Format lib/OpenLayers/Format/Filter lib/OpenLayers/Format/XLS lib/OpenLayers/Handler lib/OpenLayers/Protocol lib/OpenLayers/Renderer tests tests/BaseTypes tests/Control tests/Format tests/Format/Filter tests/Format/XLS tests/Handler tests/Protocol tests/manual theme/default tools
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Mar 29 23:18:11 EDT 2011
Author: cmoullet
Date: 2011-03-29 20:18:10 -0700 (Tue, 29 Mar 2011)
New Revision: 11763
Added:
   sandbox/cmoullet/openlayers/examples/openls.html
   sandbox/cmoullet/openlayers/lib/OpenLayers/Format/QueryStringFilter.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Format/XLS.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Format/XLS/
   sandbox/cmoullet/openlayers/lib/OpenLayers/Format/XLS/v1.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Format/XLS/v1_1_0.js
   sandbox/cmoullet/openlayers/tests/Format/QueryStringFilter.html
   sandbox/cmoullet/openlayers/tests/Format/XLS/
   sandbox/cmoullet/openlayers/tests/Format/XLS/v1_1_0.html
   sandbox/cmoullet/openlayers/tests/manual/box-quirks.html
   sandbox/cmoullet/openlayers/tests/manual/box-strict.html
Removed:
   sandbox/cmoullet/openlayers/lib/OpenLayers/Protocol/SimpleFilterSerializer.js
   sandbox/cmoullet/openlayers/tests/Protocol/SimpleFilterSerializer.html
   sandbox/cmoullet/openlayers/build/OpenLayers.js
   sandbox/cmoullet/openlayers/examples/mobile-drawing.js
   sandbox/cmoullet/openlayers/examples/proxy.cgi
   sandbox/cmoullet/openlayers/examples/symbolizers-fill-stroke-graphic.html
   sandbox/cmoullet/openlayers/lib/OpenLayers.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/BaseTypes/Bounds.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Control/PanZoomBar.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Feature/Vector.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Filter/FeatureId.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Format/Filter/v1.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Box.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Path.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Point.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Polygon.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Protocol/HTTP.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Protocol/Script.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/Canvas.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/SVG.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/SVG2.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/VML.js
   sandbox/cmoullet/openlayers/tests/BaseTypes/Bounds.html
   sandbox/cmoullet/openlayers/tests/Control/DrawFeature.html
   sandbox/cmoullet/openlayers/tests/Control/PanZoomBar.html
   sandbox/cmoullet/openlayers/tests/Feature.html
   sandbox/cmoullet/openlayers/tests/Format/Filter/v1.html
   sandbox/cmoullet/openlayers/tests/Handler/Box.html
   sandbox/cmoullet/openlayers/tests/Handler/Path.html
   sandbox/cmoullet/openlayers/tests/Handler/Point.html
   sandbox/cmoullet/openlayers/tests/Handler/Polygon.html
   sandbox/cmoullet/openlayers/tests/list-tests.html
   sandbox/cmoullet/openlayers/theme/default/style.css
   sandbox/cmoullet/openlayers/tools/mergejs.py
Merge with trunk and add OpenLS support with example
Property changes on: sandbox/cmoullet/openlayers
___________________________________________________________________
Modified: svn:mergeinfo
   - /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11161-11688,11690-11741
   + /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11161-11688,11690-11762
Modified: sandbox/cmoullet/openlayers/build/OpenLayers.js
--- sandbox/cmoullet/openlayers/build/OpenLayers.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/build/OpenLayers.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -1007,7 +1007,8 @@
 if(this.layerParams){OpenLayers.Util.applyDefaults(params,this.layerParams);}
 var layer=null;var service=layerContext.service;if(service==OpenLayers.Format.Context.serviceTypes.WFS){options.strategies=[new OpenLayers.Strategy.BBOX()];options.protocol=new OpenLayers.Protocol.WFS({url:layerContext.url,featurePrefix:layerContext.name.split(":")[0],featureType:layerContext.name.split(":").pop()});layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.name,options);}else if(service==OpenLayers.Format.Context.serviceTypes.KML){options.strategies=[new OpenLayers.Strategy.Fixed()];options.protocol=new OpenLayers.Protocol.HTTP({url:layerContext.url,format:new OpenLayers.Format.KML()});layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.name,options);}else if(service==OpenLayers.Format.Context.serviceTypes.GML){options.strategies=[new OpenLayers.Strategy.Fixed()];options.protocol=new OpenLayers.Protocol.HTTP({url:layerContext.url,format:new OpenLayers.Format.GML()});layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.na
 me,options);}else if(layerContext.features){layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.name,options);layer.addFeatures(layerContext.features);}else if(layerContext.categoryLayer!==true){layer=new OpenLayers.Layer.WMS(layerContext.title||layerContext.name,layerContext.url,params,options);}
 return layer;},getLayersFromContext:function(layersContext){var layers=[];for(var i=0,len=layersContext.length;i<len;i++){var layer=this.getLayerFromContext(layersContext[i]);if(layer!==null){layers.push(layer);}}
-return layers;},contextToMap:function(context,options){options=OpenLayers.Util.applyDefaults({maxExtent:context.maxExtent,projection:context.projection},options);var map=new OpenLayers.Map(options);map.addLayers(this.getLayersFromContext(context.layersContext));map.setCenter(context.bounds.getCenterLonLat(),map.getZoomForExtent(context.bounds,true));return map;},mergeContextToMap:function(context,map){map.addLayers(this.getLayersFromContext(context.layersContext));return map;},write:function(obj,options){obj=this.toContext(obj);var version=options&&options.version;var parser=this.getParser(version);var context=parser.write(obj,options);return context;},CLASS_NAME:"OpenLayers.Format.Context"});OpenLayers.Format.Context.serviceTypes={"WMS":"urn:ogc:serviceType:WMS","WFS":"urn:ogc:serviceType:WFS","WCS":"urn:ogc:serviceType:WCS","GML":"urn:ogc:serviceType:GML","SLD":"urn:ogc:serviceType:SLD","FES":"urn:ogc:serviceType:FES","KML":"urn:ogc:serviceType:KML"};OpenLayers.Format.OWSC
 ontext=OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"0.3.1",getParser:function(version){var v=version||this.version||this.defaultVersion;if(v==="0.3.0"){v=this.defaultVersion;}
+return layers;},contextToMap:function(context,options){options=OpenLayers.Util.applyDefaults({maxExtent:context.maxExtent,projection:context.projection,units:context.units},options);if(options.maxExtent){options.maxResolution=options.maxExtent.getWidth()/OpenLayers.Map.TILE_WIDTH;}
+var map=new OpenLayers.Map(options);map.addLayers(this.getLayersFromContext(context.layersContext));map.setCenter(context.bounds.getCenterLonLat(),map.getZoomForExtent(context.bounds,true));return map;},mergeContextToMap:function(context,map){map.addLayers(this.getLayersFromContext(context.layersContext));return map;},write:function(obj,options){obj=this.toContext(obj);var version=options&&options.version;var parser=this.getParser(version);var context=parser.write(obj,options);return context;},CLASS_NAME:"OpenLayers.Format.Context"});OpenLayers.Format.Context.serviceTypes={"WMS":"urn:ogc:serviceType:WMS","WFS":"urn:ogc:serviceType:WFS","WCS":"urn:ogc:serviceType:WCS","GML":"urn:ogc:serviceType:GML","SLD":"urn:ogc:serviceType:SLD","FES":"urn:ogc:serviceType:FES","KML":"urn:ogc:serviceType:KML"};OpenLayers.Format.OWSContext=OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"0.3.1",getParser:function(version){var v=version||this.version||this.defaultVersion;if(v==="0.3
 if(!this.parser||this.parser.VERSION!=v){var format=OpenLayers.Format.OWSContext["v"+v.replace(/\./g,"_")];if(!format){throw"Can't find a OWSContext parser for version "+v;}
 this.parser=new format(this.options);}
 return this.parser;},toContext:function(obj){var context={};if(obj.CLASS_NAME=="OpenLayers.Map"){context.bounds=obj.getExtent();context.maxExtent=obj.maxExtent;context.projection=obj.projection;context.size=obj.getSize();context.layers=obj.layers;}
@@ -1136,7 +1137,8 @@
 var from=this.getPixelFromLonLat(center);var to=this.getPixelFromLonLat(lonlat);var vector={x:to.x-from.x,y:to.y-from.y};var last={x:0,y:0};this.panTween.start({x:0,y:0},vector,this.panDuration,{callbacks:{eachStep:OpenLayers.Function.bind(function(px){var x=px.x-last.x,y=px.y-last.y;this.moveByPx(x,y);last.x=Math.round(px.x);last.y=Math.round(px.y);},this),done:OpenLayers.Function.bind(function(px){this.moveTo(lonlat);this.dragging=false;this.events.triggerEvent("moveend");},this)}});}else{this.setCenter(lonlat);}},setCenter:function(lonlat,zoom,dragging,forceZoomChange){this.panTween&&this.panTween.stop();this.moveTo(lonlat,zoom,{'dragging':dragging,'forceZoomChange':forceZoomChange});},moveByPx:function(dx,dy){dx=Math.round(dx);dy=Math.round(dy);var hw=this.size.w/2;var hh=this.size.h/2;var x=hw+dx;var y=hh+dy;var wrapDateLine=this.baseLayer.wrapDateLine;var xRestriction=0;var yRestriction=0;if(this.restrictedExtent){xRestriction=hw;yRestriction=hh;wrapDateLine=false;}
 var valid=y<=this.maxPx.y-yRestriction&&y>=this.minPx.y+yRestriction;var minX=this.minPx.x,maxX=this.maxPx.x;if(!wrapDateLine){valid=valid&&x<=this.maxPx.x-xRestriction&&x>=this.minPx.x+xRestriction;}
 if(valid){if(!this.dragging){this.dragging=true;this.events.triggerEvent("movestart");}
-this.center=null;if(dx){this.layerContainerDiv.style.left=parseInt(this.layerContainerDiv.style.left)-dx+"px";this.minPx.x-=dx;this.maxPx.x-=dx;if(wrapDateLine){if(this.maxPx.x>maxX){this.maxPx.x-=(maxX-minX);};if(this.minPx.x<minX){this.minPx.x+=(maxX-minX);};}}
+this.center=null;if(dx){this.layerContainerDiv.style.left=parseInt(this.layerContainerDiv.style.left)-dx+"px";this.minPx.x-=dx;this.maxPx.x-=dx;if(wrapDateLine){if(this.maxPx.x>maxX){this.maxPx.x-=(maxX-minX);}
+if(this.minPx.x<minX){this.minPx.x+=(maxX-minX);}}}
 if(dy){this.layerContainerDiv.style.top=parseInt(this.layerContainerDiv.style.top)-dy+"px";this.minPx.y-=dy;this.maxPx.y-=dy;}
 var layer,i,len;for(i=0,len=this.layers.length;i<len;++i){layer=this.layers[i];if(layer.visibility){layer.moveByPx(dx,dy);layer.events.triggerEvent("move");}}
 this.events.triggerEvent("move");}},moveTo:function(lonlat,zoom,options){if(!options){options={};}
@@ -1370,7 +1372,7 @@
 maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Tile=OpenLayers.Class({EVENT_TYPES:["loadstart","loadend","reload","unload"],events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,initialize:function(layer,position,bounds,url,size,options){this.layer=layer;this.position=position.clone();this.bounds=bounds.clone();this.url=url;this.size=size.clone();this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);OpenLayers.Util.extend(this,options);},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){this.layer=null;this.bounds=null;this.size=null;this.position=null;this.events.destroy();this.events=null;},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile(this.layer,this.position,this.bounds,t
 his.url,this.size);}
 OpenLayers.Util.applyDefaults(obj,this);return obj;},draw:function(){var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));this.shouldDraw=(withinMaxExtent||this.layer.displayOutsideMaxExtent);this.clear();return this.shouldDraw;},moveTo:function(bounds,position,redraw){if(redraw==null){redraw=true;}
 this.bounds=bounds.clone();this.position=position.clone();if(redraw){this.draw();}},clear:function(){},getBoundsFromBaseLayer:function(position){var msg=OpenLayers.i18n('reprojectDeprecated',{'layerName':this.layer.name});OpenLayers.Console.warn(msg);var topLeft=this.layer.map.getLonLatFromLayerPx(position);var bottomRightPx=position.clone();bottomRightPx.x+=this.size.w;bottomRightPx.y+=this.size.h;var bottomRight=this.layer.map.getLonLatFromLayerPx(bottomRightPx);if(topLeft.lon>bottomRight.lon){if(topLeft.lon<0){topLeft.lon=-180-(topLeft.lon+180);}else{bottomRight.lon=180+bottomRight.lon+180;}}
-var bounds=new OpenLayers.Bounds(topLeft.lon,bottomRight.lat,bottomRight.lon,topLeft.lat);return bounds;},showTile:function(){if(this.shouldDraw){this.show();}},show:function(){},hide:function(){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,layerAlphaHack:null,isBackBuffer:false,lastRatio:1,isFirstDraw:true,backBufferTile:null,maxGetUrlLength:null,initialize:function(layer,position,bounds,url,size,options){OpenLayers.Tile.prototype.initialize.apply(this,arguments);if(this.maxGetUrlLength!=null){OpenLayers.Util.extend(this,OpenLayers.Tile.Image.IFrame);}
+var bounds=new OpenLayers.Bounds(topLeft.lon,bottomRight.lat,bottomRight.lon,topLeft.lat);return bounds;},showTile:function(){if(this.shouldDraw){this.show();}},show:function(){},hide:function(){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,layerAlphaHack:null,isBackBuffer:false,isFirstDraw:true,backBufferTile:null,maxGetUrlLength:null,initialize:function(layer,position,bounds,url,size,options){OpenLayers.Tile.prototype.initialize.apply(this,arguments);if(this.maxGetUrlLength!=null){OpenLayers.Util.extend(this,OpenLayers.Tile.Image.IFrame);}
 this.url=url;this.frame=document.createElement('div');this.frame.style.overflow='hidden';this.frame.style.position='absolute';this.layerAlphaHack=this.layer.alpha&&OpenLayers.Util.alphaHack();},destroy:function(){if(this.imgDiv!=null){this.removeImgDiv();}
 this.imgDiv=null;if((this.frame!=null)&&(this.frame.parentNode==this.layer.div)){this.layer.div.removeChild(this.frame);}
 this.frame=null;if(this.backBufferTile){this.backBufferTile.destroy();this.backBufferTile=null;}
@@ -1391,9 +1393,8 @@
 this.imgDiv.viewRequestID=this.layer.map.viewRequestID;},removeImgDiv:function(){OpenLayers.Event.stopObservingElement(this.imgDiv);if(this.imgDiv.parentNode==this.frame){this.frame.removeChild(this.imgDiv);this.imgDiv.map=null;}
 this.imgDiv.urls=null;var child=this.imgDiv.firstChild;if(child){OpenLayers.Event.stopObservingElement(child);this.imgDiv.removeChild(child);delete child;}else{this.imgDiv.src=OpenLayers.Util.getImagesLocation()+"blank.gif";}},checkImgURL:function(){if(this.layer){var loaded=this.layerAlphaHack?this.imgDiv.firstChild.src:this.imgDiv.src;if(!OpenLayers.Util.isEquivalentUrl(loaded,this.url)){this.hide();}}},startTransition:function(){if(!this.backBufferTile||!this.backBufferTile.imgDiv){return;}
 var ratio=1;if(this.backBufferTile.resolution){ratio=this.backBufferTile.resolution/this.layer.getResolution();}
-if(ratio!=this.lastRatio){if(this.layer.transitionEffect=='resize'){var upperLeft=new OpenLayers.LonLat(this.backBufferTile.bounds.left,this.backBufferTile.bounds.top);var size=new OpenLayers.Size(this.backBufferTile.size.w*ratio,this.backBufferTile.size.h*ratio);var px=this.layer.map.getLayerPxFromLonLat(upperLeft);OpenLayers.Util.modifyDOMElement(this.backBufferTile.frame,null,px,size);var imageSize=this.backBufferTile.imageSize;imageSize=new OpenLayers.Size(imageSize.w*ratio,imageSize.h*ratio);var imageOffset=this.backBufferTile.imageOffset;if(imageOffset){imageOffset=new OpenLayers.Pixel(imageOffset.x*ratio,imageOffset.y*ratio);}
-OpenLayers.Util.modifyDOMElement(this.backBufferTile.imgDiv,null,imageOffset,imageSize);this.backBufferTile.show();}}else{if(this.layer.singleTile){this.backBufferTile.show();}else{this.backBufferTile.hide();}}
-this.lastRatio=ratio;},show:function(){this.frame.style.display='';if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(OpenLayers.IS_GECKO===true){this.frame.scrollLeft=this.frame.scrollLeft;}}},hide:function(){this.frame.style.display='none';},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Tile.Image.useBlankTile=(OpenLayers.BROWSER_NAME=="safari"||OpenLayers.BROWSER_NAME=="opera");OpenLayers.Format.ArcXML=OpenLayers.Class(OpenLayers.Format.XML,{fontStyleKeys:['antialiasing','blockout','font','fontcolor','fontsize','fontstyle','glowing','interval','outline','printmode','shadow','transparency'],request:null,response:null,initialize:function(options){this.request=new OpenLayers.Format.ArcXML.Request();this.response=new OpenLayers.Format.ArcXML.Response();if(options){if(options.requesttype=="feature"){this.request.get_image=null;var qry=this.request.get_feature.query;this.addCoordSys(qry.featurecoordsys,options.featureCoordSys);thi
 s.addCoordSys(qry.filtercoordsys,options.filterCoordSys);if(options.polygon){qry.isspatial=true;qry.spatialfilter.polygon=options.polygon;}else if(options.envelope){qry.isspatial=true;qry.spatialfilter.envelope={minx:0,miny:0,maxx:0,maxy:0};this.parseEnvelope(qry.spatialfilter.envelope,options.envelope);}}else if(options.requesttype=="image"){this.request.get_feature=null;var props=this.request.get_image.properties;this.parseEnvelope(props.envelope,options.envelope);this.addLayers(props.layerlist,options.layers);this.addImageSize(props.imagesize,options.tileSize);this.addCoordSys(props.featurecoordsys,options.featureCoordSys);this.addCoordSys(props.filtercoordsys,options.filterCoordSys);}else{this.request=null;}}
+if(ratio!=1){if(this.layer.transitionEffect=='resize'){var upperLeft=new OpenLayers.LonLat(this.backBufferTile.bounds.left,this.backBufferTile.bounds.top);var size=new OpenLayers.Size(this.backBufferTile.size.w*ratio,this.backBufferTile.size.h*ratio);var px=this.layer.map.getLayerPxFromLonLat(upperLeft);OpenLayers.Util.modifyDOMElement(this.backBufferTile.frame,null,px,size);var imageSize=this.backBufferTile.imageSize;imageSize=new OpenLayers.Size(imageSize.w*ratio,imageSize.h*ratio);var imageOffset=this.backBufferTile.imageOffset;if(imageOffset){imageOffset=new OpenLayers.Pixel(imageOffset.x*ratio,imageOffset.y*ratio);}
+OpenLayers.Util.modifyDOMElement(this.backBufferTile.imgDiv,null,imageOffset,imageSize);this.backBufferTile.show();}}else{if(this.layer.singleTile){this.backBufferTile.show();}else{this.backBufferTile.hide();}}},show:function(){this.frame.style.display='';if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(OpenLayers.IS_GECKO===true){this.frame.scrollLeft=this.frame.scrollLeft;}}},hide:function(){this.frame.style.display='none';},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Tile.Image.useBlankTile=(OpenLayers.BROWSER_NAME=="safari"||OpenLayers.BROWSER_NAME=="opera");OpenLayers.Format.ArcXML=OpenLayers.Class(OpenLayers.Format.XML,{fontStyleKeys:['antialiasing','blockout','font','fontcolor','fontsize','fontstyle','glowing','interval','outline','printmode','shadow','transparency'],request:null,response:null,initialize:function(options){this.request=new OpenLayers.Format.ArcXML.Request();this.response=new OpenLayers.Format.ArcXML.R
 esponse();if(options){if(options.requesttype=="feature"){this.request.get_image=null;var qry=this.request.get_feature.query;this.addCoordSys(qry.featurecoordsys,options.featureCoordSys);this.addCoordSys(qry.filtercoordsys,options.filterCoordSys);if(options.polygon){qry.isspatial=true;qry.spatialfilter.polygon=options.polygon;}else if(options.envelope){qry.isspatial=true;qry.spatialfilter.envelope={minx:0,miny:0,maxx:0,maxy:0};this.parseEnvelope(qry.spatialfilter.envelope,options.envelope);}}else if(options.requesttype=="image"){this.request.get_feature=null;var props=this.request.get_image.properties;this.parseEnvelope(props.envelope,options.envelope);this.addLayers(props.layerlist,options.layers);this.addImageSize(props.imagesize,options.tileSize);this.addCoordSys(props.featurecoordsys,options.featureCoordSys);this.addCoordSys(props.filtercoordsys,options.filterCoordSys);}else{this.request=null;}}
 OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},parseEnvelope:function(env,arr){if(arr&&arr.length==4){env.minx=arr[0];env.miny=arr[1];env.maxx=arr[2];env.maxy=arr[3];}},addLayers:function(ll,lyrs){for(var lind=0,len=lyrs.length;lind<len;lind++){ll.push(lyrs[lind]);}},addImageSize:function(imsize,olsize){if(olsize!==null){imsize.width=olsize.w;imsize.height=olsize.h;imsize.printwidth=olsize.w;imsize.printheight=olsize.h;}},addCoordSys:function(featOrFilt,fsys){if(typeof fsys=="string"){featOrFilt.id=parseInt(fsys);featOrFilt.string=fsys;}
 else if(typeof fsys=="object"&&fsys.proj!==null){featOrFilt.id=fsys.proj.srsProjNumber;featOrFilt.string=fsys.proj.srsCode;}else{featOrFilt=fsys;}},iserror:function(data){var ret=null;if(!data){ret=(this.response.error!=='');}else{data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);var errorNodes=data.documentElement.getElementsByTagName("ERROR");ret=(errorNodes!==null&&errorNodes.length>0);}
 return ret;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
@@ -2037,7 +2038,23 @@
 node.appendChild(style);}}
 return node;},write_wmc_OnlineResource:function(href){var node=this.createElementDefaultNS("OnlineResource");this.setAttributeNS(node,this.namespaces.xlink,"xlink:type","simple");this.setAttributeNS(node,this.namespaces.xlink,"xlink:href",href);return node;},CLASS_NAME:"OpenLayers.Format.WMC.v1"});OpenLayers.Format.WMC.v1_1_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.1.0",schemaLocation:"http://www.opengis.net/context http://schemas.opengis.net/context/1.1.0/context.xsd",initialize:function(options){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[options]);},read_sld_MinScaleDenominator:function(layerContext,node){var minScaleDenominator=parseFloat(this.getChildValue(node));if(minScaleDenominator>0){layerContext.maxScale=minScaleDenominator;}},read_sld_MaxScaleDenominator:function(layerContext,node){layerContext.minScale=parseFloat(this.getChildValue(node));},write_wmc_Layer:function(context){var node=OpenLayers.Format.WMC.v1.prototype.write_wmc_Layer.a
 pply(this,[context]);if(context.maxScale){var minSD=this.createElementNS(this.namespaces.sld,"sld:MinScaleDenominator");minSD.appendChild(this.createTextNode(context.maxScale.toPrecision(16)));node.appendChild(minSD);}
 if(context.minScale){var maxSD=this.createElementNS(this.namespaces.sld,"sld:MaxScaleDenominator");maxSD.appendChild(this.createTextNode(context.minScale.toPrecision(16)));node.appendChild(maxSD);}
-node.appendChild(this.write_wmc_FormatList(context));node.appendChild(this.write_wmc_StyleList(context));node.appendChild(this.write_wmc_LayerExtension(context));return node;},CLASS_NAME:"OpenLayers.Format.WMC.v1_1_0"});OpenLayers.Lang["sk"]=OpenLayers.Util.applyDefaults({'unhandledRequest':"Neobslúžené požiadavky vracajú ${statusText}",'permalink':"Trvalý odkaz",'overlays':"Prekrytia",'baseLayer':"Základná vrstva",'sameProjection':"Prehľadová mapka funguje iba vtedy, keď je v rovnakej projekcii ako hlavná mapa",'readNotImplemented':"Čítanie nie je implementované.",'writeNotImplemented':"Zápis nie je implementovaný.",'noFID':"Nie je možné aktualizovať vlastnosť, pre ktorú neexistuje FID.",'errorLoadingGML':"Chyba pri načítaní súboru GML ${url}",'browserNotSupported':"Váš prehliadač nepodporuje vykresľovanie vektorov. Momentálne podporované vykresľovače sú:\n${renderers}",'componentShouldBe':"addFeatures: komponent by mal byť ${geomType}",'
 getFeatureError':"getFeatureFromEvent bola zavolaná na vrstve bez vykresľovača. To zvyčajne znamená, že ste odstránili vrstvu, ale nie niektorú z obslúh, ktorá je s ňou asociovaná.",'minZoomLevelError':"Vlastnosť minZoomLevel je určený iba na použitie s vrstvami odvodenými od FixedZoomLevels. To, že táto wfs vrstva kontroluje minZoomLevel je pozostatok z minulosti. Nemôžeme ho však odstrániť, aby sme sa vyhli možnému porušeniu aplikácií založených na Open Layers, ktoré na tomto môže závisieť. Preto ho označujeme ako zavrhovaný - dolu uvedená kontrola minZoomLevel bude odstránená vo verzii 3.0. Použite prosím namiesto toho kontrolu min./max. rozlíšenia podľa tu uvedeného popisu: http://trac.openlayers.org/wiki/SettingZoomLevels",'commitSuccess':"Transakcia WFS: ÚSPEŠNÁ ${response}",'commitFailed':"Transakcia WFS: ZLYHALA ${response}",'googleWarning':"Vrstvu Google nebolo možné správne načítať.\x3cbr\x3e\x3cbr\x3eAby ste
 sa tejto správy zbavili vyberte novú BaseLayer v prepínači vrstiev v pravom hornom rohu.\x3cbr\x3e\x3cbr\x3eToto sa stalo pravdepodobne preto, že skript knižnice Google Maps buď nebol načítaný alebo neobsahuje správny kľúč API pre vašu lokalitu.\x3cbr\x3e\x3cbr\x3eVývojári: Tu môžete získať \x3ca href=\'http://trac.openlayers.org/wiki/Google\' target=\'_blank\'\x3epomoc so sfunkčnením\x3c/a\x3e",'getLayerWarning':"Vrstvu ${layerType} nebolo možné správne načítať.\x3cbr\x3e\x3cbr\x3eAby ste sa tejto správy zbavili vyberte novú BaseLayer v prepínači vrstiev v pravom hornom rohu.\x3cbr\x3e\x3cbr\x3eToto sa stalo pravdepodobne preto, že skript knižnice ${layerType} buď nebol načítaný alebo neobsahuje správny kľúč API pre vašu lokalitu.\x3cbr\x3e\x3cbr\x3eVývojári: Tu môžete získať \x3ca href=\'http://trac.openlayers.org/wiki/${layerType}\' target=\'_blank\'\x3epomoc so sfunkčnením\x3c/a\x3e",'scale':"Mierka = 1 : ${scaleDenom}"
 ,'layerAlreadyAdded':"Pokúsili ste sa do mapy pridať vrstvu ${layerName}, ale tá už bola pridaná",'reprojectDeprecated':"Používate voľby „reproject“ vrstvy ${layerType}. Táto voľba je zzavrhovaná: jej použitie bolo navrhnuté na podporu zobrazovania údajov nad komerčnými základovými mapami, ale túto funkcionalitu je teraz možné dosiahnuť pomocou Spherical Mercator. Ďalšie informácie získate na stránke http://trac.openlayers.org/wiki/SphericalMercator.",'methodDeprecated':"Táto metóda je zavrhovaná a bude odstránená vo verzii 3.0. Použite prosím namiesto nej metódu ${newMethod}.",'boundsAddError':"Sčítacej funkcii musíte dať hodnoty x aj y.",'lonlatAddError':"Sčítacej funkcii musíte dať hodnoty lon (zem. dĺžka) aj lat (zem. šírka).",'pixelAddError':"Sčítacej funkcii musíte dať hodnoty x aj y.",'unsupportedGeometryType':"Nepodporovaný typ geometrie: ${geomType}",'pagePositionFailed':"OpenLayers.Util.pagePosition zlyhalo: p
 rvok s id ${elemId} môže byť zle umiestnený.",'filterEvaluateNotImplemented':"evaluate nie je implementovaný pre tento typ filtra"});OpenLayers.Renderer.SVG=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"http://www.w3.org/2000/svg",xlinkns:"http://www.w3.org/1999/xlink",MAX_PIXEL:15000,translationParameters:null,symbolMetrics:null,initialize:function(containerID){if(!this.supported()){return;}
+node.appendChild(this.write_wmc_FormatList(context));node.appendChild(this.write_wmc_StyleList(context));node.appendChild(this.write_wmc_LayerExtension(context));return node;},CLASS_NAME:"OpenLayers.Format.WMC.v1_1_0"});OpenLayers.Format.XLS=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.1.0",version:null,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},write:function(request,options){var version=(options&&options.version)||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.XLS["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find an XLS parser for version "+
+version;}
+this.parser=new format(this.options);}
+var root=this.parser.write(request);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},read:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
+var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
+if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.XLS["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find an XLS parser for version "+
+version;}
+var xls=this.parser.read(data,options);return xls;},CLASS_NAME:"OpenLayers.Format.XLS"});OpenLayers.Format.XLS.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xls:"http://www.opengis.net/xls",gml:"http://www.opengis.net/gml",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},xy:true,defaultPrefix:"xls",schemaLocation:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data,options){options=OpenLayers.Util.applyDefaults(options,this.options);var xls={};this.readChildNodes(data,xls);return xls;},readers:{"xls":{"XLS":function(node,xls){xls.version=node.getAttribute("version");this.readChildNodes(node,xls);},"Response":function(node,xls){this.readChildNodes(node,xls);},"GeocodeResponse":function(node,xls){xls.responseLists=[];this.readChildNodes(node,xls);},"GeocodeResponseList":function(node,xls){var responseList=
 {features:[],numberOfGeocodedAddresses:parseInt(node.getAttribute("numberOfGeocodedAddresses"))};xls.responseLists.push(responseList);this.readChildNodes(node,responseList);},"GeocodedAddress":function(node,responseList){var feature=new OpenLayers.Feature.Vector();responseList.features.push(feature);this.readChildNodes(node,feature);feature.geometry=feature.components[0];},"GeocodeMatchCode":function(node,feature){feature.attributes.matchCode={accuracy:parseFloat(node.getAttribute("accuracy")),matchType:node.getAttribute("matchType")};},"Address":function(node,feature){var address={countryCode:node.getAttribute("countryCode"),addressee:node.getAttribute("addressee"),street:[],place:[]};feature.attributes.address=address;this.readChildNodes(node,address);},"freeFormAddress":function(node,address){address.freeFormAddress=this.getChildValue(node);},"StreetAddress":function(node,address){this.readChildNodes(node,address);},"Building":function(node,address){address.building={'num
 ber':node.getAttribute("number"),subdivision:node.getAttribute("subdivision"),buildingName:node.getAttribute("buildingName")};},"Street":function(node,address){address.street.push(this.getChildValue(node));},"Place":function(node,address){address.place[node.getAttribute("type")]=this.getChildValue(node);},"PostalCode":function(node,address){address.postalCode=this.getChildValue(node);}},"gml":OpenLayers.Format.GML.v3.prototype.readers.gml},write:function(request){return this.writers.xls.XLS.apply(this,[request]);},writers:{"xls":{"XLS":function(request){var root=this.createElementNSPlus("xls:XLS",{attributes:{"version":this.VERSION,"xsi:schemaLocation":this.schemaLocation}});this.writeNode("RequestHeader",request.header,root);this.writeNode("Request",request,root);return root;},"RequestHeader":function(header){return this.createElementNSPlus("xls:RequestHeader");},"Request":function(request){var node=this.createElementNSPlus("xls:Request",{attributes:{methodName:"GeocodeRequ
 est",requestID:request.requestID||"",version:this.VERSION}});this.writeNode("GeocodeRequest",request.addresses,node);return node;},"GeocodeRequest":function(addresses){var node=this.createElementNSPlus("xls:GeocodeRequest");for(var i=0,len=addresses.length;i<len;i++){this.writeNode("Address",addresses[i],node);}
+return node;},"Address":function(address){var node=this.createElementNSPlus("xls:Address",{attributes:{countryCode:address.countryCode}});if(address.freeFormAddress){this.writeNode("freeFormAddess",address.freeFormAddress,node);}else{if(address.street){this.writeNode("StreetAddress",address,node);}
+if(address.municipality){this.writeNode("Municipality",address.municipality,node);}
+if(address.countrySubdivision){this.writeNode("CountrySubdivision",address.countrySubdivision,node);}
+if(address.postalCode){this.writeNode("PostalCode",address.postalCode,node);}}
+return node;},"freeFormAddress":function(freeFormAddress){return this.createElementNSPlus("freeFormAddress",{value:freeFormAddress});},"StreetAddress":function(address){var node=this.createElementNSPlus("xls:StreetAddress");if(address.building){this.writeNode(node,"Building",address.building);}
+var street=address.street;if(!(street instanceof Array)){street=[street];}
+for(var i=0,len=street.length;i<len;i++){this.writeNode("Street",street[i],node);}
+return node;},"Building":function(building){return this.createElementNSPlus("xls:Building",{attributes:{"number":building["number"],"subdivision":building.subdivision,"buildingName":building.buildingName}});},"Street":function(street){return this.createElementNSPlus("xls:Street",{value:street});},"Municipality":function(municipality){return this.createElementNSPlus("xls:Place",{attributes:{type:"Municipality"},value:municipality});},"CountrySubdivision":function(countrySubdivision){return this.createElementNSPlus("xls:Place",{attributes:{type:"CountrySubdivision"},value:countrySubdivision});},"PostalCode":function(postalCode){return this.createElementNSPlus("xls:PostalCode",{value:postalCode});}}},CLASS_NAME:"OpenLayers.Format.XLS.v1"});OpenLayers.Format.XLS.v1_1_0=OpenLayers.Class(OpenLayers.Format.XLS.v1,{VERSION:"1.1",schemaLocation:"http://www.opengis.net/xls http://schemas.opengis.net/ols/1.1.0/LocationUtilityService.xsd",initialize:function(options){OpenLayers.Format.X
 LS.v1.prototype.initialize.apply(this,[options]);},CLASS_NAME:"OpenLayers.Format.XLS.v1_1_0"});OpenLayers.Lang["sk"]=OpenLayers.Util.applyDefaults({'unhandledRequest':"Neobslúžené požiadavky vracajú ${statusText}",'permalink':"Trvalý odkaz",'overlays':"Prekrytia",'baseLayer':"Základná vrstva",'sameProjection':"Prehľadová mapka funguje iba vtedy, keď je v rovnakej projekcii ako hlavná mapa",'readNotImplemented':"Čítanie nie je implementované.",'writeNotImplemented':"Zápis nie je implementovaný.",'noFID':"Nie je možné aktualizovať vlastnosť, pre ktorú neexistuje FID.",'errorLoadingGML':"Chyba pri načítaní súboru GML ${url}",'browserNotSupported':"Váš prehliadač nepodporuje vykresľovanie vektorov. Momentálne podporované vykresľovače sú:\n${renderers}",'componentShouldBe':"addFeatures: komponent by mal byť ${geomType}",'getFeatureError':"getFeatureFromEvent bola zavolaná na vrstve bez vykresľovača. To zvyčajne znamená, že ste odstránili
  vrstvu, ale nie niektorú z obslúh, ktorá je s ňou asociovaná.",'minZoomLevelError':"Vlastnosť minZoomLevel je určený iba na použitie s vrstvami odvodenými od FixedZoomLevels. To, že táto wfs vrstva kontroluje minZoomLevel je pozostatok z minulosti. Nemôžeme ho však odstrániť, aby sme sa vyhli možnému porušeniu aplikácií založených na Open Layers, ktoré na tomto môže závisieť. Preto ho označujeme ako zavrhovaný - dolu uvedená kontrola minZoomLevel bude odstránená vo verzii 3.0. Použite prosím namiesto toho kontrolu min./max. rozlíšenia podľa tu uvedeného popisu: http://trac.openlayers.org/wiki/SettingZoomLevels",'commitSuccess':"Transakcia WFS: ÚSPEŠNÁ ${response}",'commitFailed':"Transakcia WFS: ZLYHALA ${response}",'googleWarning':"Vrstvu Google nebolo možné správne načítať.\x3cbr\x3e\x3cbr\x3eAby ste sa tejto správy zbavili vyberte novú BaseLayer v prepínači vrstiev v pravom hornom rohu.\x3cbr\x3e\x3cbr\x3eToto sa stalo
  pravdepodobne preto, že skript knižnice Google Maps buď nebol načítaný alebo neobsahuje správny kľúč API pre vašu lokalitu.\x3cbr\x3e\x3cbr\x3eVývojári: Tu môžete získať \x3ca href=\'http://trac.openlayers.org/wiki/Google\' target=\'_blank\'\x3epomoc so sfunkčnením\x3c/a\x3e",'getLayerWarning':"Vrstvu ${layerType} nebolo možné správne načítať.\x3cbr\x3e\x3cbr\x3eAby ste sa tejto správy zbavili vyberte novú BaseLayer v prepínači vrstiev v pravom hornom rohu.\x3cbr\x3e\x3cbr\x3eToto sa stalo pravdepodobne preto, že skript knižnice ${layerType} buď nebol načítaný alebo neobsahuje správny kľúč API pre vašu lokalitu.\x3cbr\x3e\x3cbr\x3eVývojári: Tu môžete získať \x3ca href=\'http://trac.openlayers.org/wiki/${layerType}\' target=\'_blank\'\x3epomoc so sfunkčnením\x3c/a\x3e",'scale':"Mierka = 1 : ${scaleDenom}",'layerAlreadyAdded':"Pokúsili ste sa do mapy pridať vrstvu ${layerName}, ale tá už bola pridaná",'reprojectDeprecated':
 "Používate voľby „reproject“ vrstvy ${layerType}. Táto voľba je zzavrhovaná: jej použitie bolo navrhnuté na podporu zobrazovania údajov nad komerčnými základovými mapami, ale túto funkcionalitu je teraz možné dosiahnuť pomocou Spherical Mercator. Ďalšie informácie získate na stránke http://trac.openlayers.org/wiki/SphericalMercator.",'methodDeprecated':"Táto metóda je zavrhovaná a bude odstránená vo verzii 3.0. Použite prosím namiesto nej metódu ${newMethod}.",'boundsAddError':"Sčítacej funkcii musíte dať hodnoty x aj y.",'lonlatAddError':"Sčítacej funkcii musíte dať hodnoty lon (zem. dĺžka) aj lat (zem. šírka).",'pixelAddError':"Sčítacej funkcii musíte dať hodnoty x aj y.",'unsupportedGeometryType':"Nepodporovaný typ geometrie: ${geomType}",'pagePositionFailed':"OpenLayers.Util.pagePosition zlyhalo: prvok s id ${elemId} môže byť zle umiestnený.",'filterEvaluateNotImplemented':"evaluate nie je implementovaný pre tento t
 OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);this.translationParameters={x:0,y:0};this.symbolMetrics={};},destroy:function(){OpenLayers.Renderer.Elements.prototype.destroy.apply(this,arguments);},supported:function(){var svgFeature="http://www.w3.org/TR/SVG11/feature#";return(document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature(svgFeature+"SVG","1.1")||document.implementation.hasFeature(svgFeature+"BasicStructure","1.1")));},inValidRange:function(x,y,xyOnly){var left=x+(xyOnly?0:this.translationParameters.x);var top=y+(xyOnly?0:this.translationParameters.y);return(left>=-this.MAX_PIXEL&&left<=this.MAX_PIXEL&&top>=-this.MAX_PIXEL&&top<=this.MAX_PIXEL);},setExtent:function(extent,resolutionChanged){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();var left=-extent.left/resolution;var top=extent.top/resolution;if(resolutionChanged)
 {this.left=left;this.top=top;var extentString="0 0 "+this.size.w+" "+this.size.h;this.rendererRoot.setAttributeNS(null,"viewBox",extentString);this.translate(0,0);return true;}else{var inRange=this.translate(left-this.left,top-this.top);if(!inRange){this.setExtent(extent,true);}
 return inRange;}},translate:function(x,y){if(!this.inValidRange(x,y,true)){return false;}else{var transformString="";if(x||y){transformString="translate("+x+","+y+")";}
 this.root.setAttributeNS(null,"transform",transformString);this.translationParameters={x:x,y:y};return true;}},setSize:function(size){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);this.rendererRoot.setAttributeNS(null,"width",this.size.w);this.rendererRoot.setAttributeNS(null,"height",this.size.h);},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":if(style.externalGraphic){nodeType="image";}else if(this.isComplexSymbol(style.graphicName)){nodeType="svg";}else{nodeType="circle";}
@@ -2702,7 +2719,8 @@
 var end=(closeLine)?" x e":" e";node.path="m"+parts.join("")+end;return node;},drawPolygon:function(node,geometry){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var path=[];var j,jj,points,area,first,second,i,ii,comp,pathComp,x,y;for(j=0,jj=geometry.components.length;j<jj;j++){path.push("m");points=geometry.components[j].components;area=(j===0);first=null;second=null;for(i=0,ii=points.length;i<ii;i++){comp=points[i];x=(comp.x/resolution-this.offset.x)|0;y=(comp.y/resolution-this.offset.y)|0;pathComp=" "+x+","+y;path.push(pathComp);if(i==0){path.push(" l");}
 if(!area){if(!first){first=pathComp;}else if(first!=pathComp){if(!second){second=pathComp;}else if(second!=pathComp){area=true;}}}}
 path.push(area?" x ":" ");}
-path.push("e");node.path=path.join("");return node;},drawRectangle:function(node,geometry){var resolution=this.getResolution();node.style.left=((geometry.x/resolution-this.offset.x)|0)+"px";node.style.top=((geometry.y/resolution-this.offset.y)|0)+"px";node.style.width=((geometry.width/resolution)|0)+"px";node.style.height=((geometry.height/resolution)|0)+"px";return node;},drawText:function(featureId,style,location){var label=this.nodeFactory(featureId+this.LABEL_ID_SUFFIX,"olv:rect");var textbox=this.nodeFactory(featureId+this.LABEL_ID_SUFFIX+"_textbox","olv:textbox");var resolution=this.getResolution();label.style.left=((location.x/resolution-this.offset.x)|0)+"px";label.style.top=((location.y/resolution-this.offset.y)|0)+"px";label.style.flip="y";textbox.innerText=style.label;if(style.fontColor){textbox.style.color=style.fontColor;}
+path.push("e");node.path=path.join("");return node;},drawRectangle:function(node,geometry){var resolution=this.getResolution();node.style.left=((geometry.x/resolution-this.offset.x)|0)+"px";node.style.top=((geometry.y/resolution-this.offset.y)|0)+"px";node.style.width=((geometry.width/resolution)|0)+"px";node.style.height=((geometry.height/resolution)|0)+"px";return node;},drawText:function(featureId,style,location){var label=this.nodeFactory(featureId+this.LABEL_ID_SUFFIX,"olv:rect");var textbox=this.nodeFactory(featureId+this.LABEL_ID_SUFFIX+"_textbox","olv:textbox");var resolution=this.getResolution();label.style.left=((location.x/resolution-this.offset.x)|0)+"px";label.style.top=((location.y/resolution-this.offset.y)|0)+"px";label.style.flip="y";textbox.innerText=style.label;if(style.cursor!="inherit"&&style.cursor!=null){textbox.style.cursor=style.cursor;}
+if(style.fontColor){textbox.style.color=style.fontColor;}
 if(style.fontOpacity){textbox.style.filter='alpha(opacity='+(style.fontOpacity*100)+')';}
 if(style.fontFamily){textbox.style.fontFamily=style.fontFamily;}
 if(style.fontSize){textbox.style.fontSize=style.fontSize;}
Modified: sandbox/cmoullet/openlayers/examples/mobile-drawing.js
--- sandbox/cmoullet/openlayers/examples/mobile-drawing.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/examples/mobile-drawing.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -1,9 +1,30 @@
 function init() {
+    // create a vector layer for drawing
     var vector = new OpenLayers.Layer.Vector();
-    var toolbar = new OpenLayers.Control.EditingToolbar(vector);
+    // OpenLayers' EditingToolbar internally creates a Navigation control, we
+    // want a TouchNavigation control here so we create our own editing toolbar
+    var toolbar = new OpenLayers.Control.Panel({
+        displayClass: 'olControlEditingToolbar'
+    toolbar.addControls([
+        // this control is just there to be able to deactivate the drawing
+        // tools
+        new OpenLayers.Control({
+            displayClass: 'olControlNavigation'
+        new OpenLayers.Control.DrawFeature(vector, OpenLayers.Handler.Point, {
+            displayClass: 'olControlDrawFeaturePoint'
+        new OpenLayers.Control.DrawFeature(vector, OpenLayers.Handler.Path, {
+            displayClass: 'olControlDrawFeaturePath'
+        new OpenLayers.Control.DrawFeature(vector, OpenLayers.Handler.Polygon, {
+            displayClass: 'olControlDrawFeaturePolygon'
     map = new OpenLayers.Map({
         div: 'map',
         projection: 'EPSG:900913',
@@ -28,6 +49,7 @@
         theme: null
+    // activate the first control to render the "navigation icon"
+    // as active
     toolbar.controls[0].activate();
Added: sandbox/cmoullet/openlayers/examples/openls.html
--- sandbox/cmoullet/openlayers/examples/openls.html	                        (rev 0)
+++ sandbox/cmoullet/openlayers/examples/openls.html	2011-03-30 03:18:10 UTC (rev 11763)
@@ -0,0 +1,85 @@
+<html xmlns="http://www.w3.org/1999/xhtml">
+<head>
+    <meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;"/>
+    <meta name="apple-mobile-web-app-capable" content="yes"/>
+    <link rel="stylesheet" href="../theme/default/style.css" type="text/css"/>
+    <link rel="stylesheet" href="style.css" type="text/css"/>
+    <title>OpenLS: Geocoding Example</title>
+    <script type="text/javascript" src="../lib/OpenLayers.js"></script>
+    <script type="text/javascript">
+        var map, layer;
+        function init() {
+            OpenLayers.ProxyHost = "proxy.cgi?url=";
+            map = new OpenLayers.Map('map', {
+                controls: [
+                    new OpenLayers.Control.PanZoom(),
+                    new OpenLayers.Control.Permalink(),
+                    new OpenLayers.Control.Navigation()
+            layer = new OpenLayers.Layer.OSM("OpenStreetMap", null, {
+                transitionEffect: 'resize'
+            map.addLayers([layer]);
+            map.zoomToMaxExtent();
+        function submitform() {
+            var queryString = document.forms[0].query.value;
+            OpenLayers.Request.POST({
+                url: "http://www.openrouteservice.org/php/OpenLSLUS_Geocode.php",
+                scope: this,
+                failure: this.requestFailure,
+                success: this.requestSuccess,
+                headers: {"Content-Type": "application/x-www-form-urlencoded"},
+                data: "FreeFormAdress=" + encodeURIComponent(queryString) + "&MaxResponse=1"
+        function requestSuccess(response) {
+            var format = new OpenLayers.Format.XLS();
+            var output = format.read(response.responseXML);
+            if (output.responseLists[0]) {
+                var foundPosition = new OpenLayers.LonLat(output.responseLists[0].features[0].geometry.x, output.responseLists[0].features[0].geometry.y).transform(
+                        new OpenLayers.Projection("EPSG:4326"),
+                        map.getProjectionObject()
+                map.setCenter(foundPosition, 16);
+            } else {
+                alert("Sorry, no address found");
+        function requestFailure(response) {
+            alert("no");
+    </script>
+</head>
+<body onload="init()">
+<h1 id="title">OpenLS Geocoding Example</h1>
+<div id="tags">
+    OpenLS, XLS, Geocoding
+</div>
+<p id="shortdesc">
+    Show how to use an OpenLS service.
+</p>
+<form name="input" action="javascript: submitform();" method="post">
+    <label for="query">Search for address:</label> <input type="text" id="query" size=50 name="query"
+                                                          value="Rue des Berges 37 Payerne"/>
+    <input type="submit" value="Submit"/>
+</form>
+<br>
+<div id="map" class="smallmap"></div>
+<div id="docs">
+    <p>
+        Geocoding example using the http://www.openrouteservice.org/ OpenLS service. Recenter to the first item of the results.
+    </p>
+</div>
+</body>
+</html>
Modified: sandbox/cmoullet/openlayers/examples/proxy.cgi
--- sandbox/cmoullet/openlayers/examples/proxy.cgi	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/examples/proxy.cgi	2011-03-30 03:18:10 UTC (rev 11763)
@@ -21,7 +21,7 @@
                 'sigma.openplans.org', 'demo.opengeo.org',
                 'www.openstreetmap.org', 'sample.azavea.com',
                 'v2.suite.opengeo.org', 'v-swe.uni-muenster.de:8080',
-                'vmap0.tiles.osgeo.org']
+                'vmap0.tiles.osgeo.org', 'www.openrouteservice.org']
 method = os.environ["REQUEST_METHOD"]
Modified: sandbox/cmoullet/openlayers/examples/symbolizers-fill-stroke-graphic.html
--- sandbox/cmoullet/openlayers/examples/symbolizers-fill-stroke-graphic.html	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/examples/symbolizers-fill-stroke-graphic.html	2011-03-30 03:18:10 UTC (rev 11763)
@@ -28,7 +28,8 @@
                                 symbolizer: {
                                     graphic: false,
                                     label: "Label for invisible point",
-                                    labelSelect: true
+                                    labelSelect: true,
+                                    fontStyle: "italic"
                                 filter: new OpenLayers.Filter.Comparison({
                                     type: "==",
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/BaseTypes/Bounds.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/BaseTypes/Bounds.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/BaseTypes/Bounds.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -121,11 +121,9 @@
      * Returns:
      * {String} String representation of bounds object.
-     *          (ex.<i>"left-bottom=(5,42) right-top=(10,45)"</i>)
     toString:function() {
-        return ( "left-bottom=(" + this.left + "," + this.bottom + ")"
-                 + " right-top=(" + this.right + "," + this.top + ")" );
+        return [this.left, this.bottom, this.right, this.top].join(",");
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Control/PanZoomBar.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Control/PanZoomBar.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Control/PanZoomBar.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -60,6 +60,14 @@
     zoomWorldIcon: false,
+     * APIProperty: panIcons
+     * {Boolean} Set this property to false not to display the pan icons. If
+     * false the zoom world icon is placed under the zoom bar. Defaults to
+     * true.
+    panIcons: true,
      * APIProperty: forceFixedZoomLevel
      * {Boolean} Force a fixed zoom level even though the map has
      *     fractionalZoom
@@ -144,26 +152,37 @@
         this.buttons = [];
         var sz = new OpenLayers.Size(18,18);
-        var centered = new OpenLayers.Pixel(px.x+sz.w/2, px.y);
-        var wposition = sz.w;
+        if (this.panIcons) {
+            var centered = new OpenLayers.Pixel(px.x+sz.w/2, px.y);
+            var wposition = sz.w;
-        if (this.zoomWorldIcon) {
-            centered = new OpenLayers.Pixel(px.x+sz.w, px.y);
+            if (this.zoomWorldIcon) {
+                centered = new OpenLayers.Pixel(px.x+sz.w, px.y);
-        this._addButton("panup", "north-mini.png", centered, sz);
-        px.y = centered.y+sz.h;
-        this._addButton("panleft", "west-mini.png", px, sz);
-            this._addButton("zoomworld", "zoom-world-mini.png", px.add(sz.w, 0), sz);
-            wposition *= 2;
+            this._addButton("panup", "north-mini.png", centered, sz);
+            px.y = centered.y+sz.h;
+            this._addButton("panleft", "west-mini.png", px, sz);
+                this._addButton("zoomworld", "zoom-world-mini.png", px.add(sz.w, 0), sz);
+                wposition *= 2;
+            this._addButton("panright", "east-mini.png", px.add(wposition, 0), sz);
+            this._addButton("pandown", "south-mini.png", centered.add(0, sz.h*2), sz);
+            this._addButton("zoomin", "zoom-plus-mini.png", centered.add(0, sz.h*3+5), sz);
+            centered = this._addZoomBar(centered.add(0, sz.h*4 + 5));
+            this._addButton("zoomout", "zoom-minus-mini.png", centered, sz);
-        this._addButton("panright", "east-mini.png", px.add(wposition, 0), sz);
-        this._addButton("pandown", "south-mini.png", centered.add(0, sz.h*2), sz);
-        this._addButton("zoomin", "zoom-plus-mini.png", centered.add(0, sz.h*3+5), sz);
-        centered = this._addZoomBar(centered.add(0, sz.h*4 + 5));
-        this._addButton("zoomout", "zoom-minus-mini.png", centered, sz);
+        else {
+            this._addButton("zoomin", "zoom-plus-mini.png", px, sz);
+            centered = this._addZoomBar(px.add(0, sz.h));
+                centered = centered.add(0, sz.h+3);
+                this._addButton("zoomworld", "zoom-world-mini.png", centered, sz);
         return this.div;
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Feature/Vector.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Feature/Vector.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Feature/Vector.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -387,6 +387,7 @@
  * fontOpacity - {Number} Opacity (0-1) for the label
  * fontFamily - {String} The font family for the label, to be provided like in CSS.
  * fontSize - {String} The font size for the label, to be provided like in CSS.
+ * fontStyle - {String} The font style for the label, to be provided like in CSS.
  * fontWeight - {String} The font weight for the label, to be provided like in CSS.
  * display - {String} Symbolizers will have no effect if display is set to "none".  All other values have no effect.
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Filter/FeatureId.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Filter/FeatureId.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Filter/FeatureId.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -26,6 +26,12 @@
     fids: null,
+     * Property: type
+     * {String} Type to identify this filter.
+    type: "FID",
      * Constructor: OpenLayers.Filter.FeatureId
      * Creates an ogc:FeatureId rule.
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Format/Filter/v1.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Format/Filter/v1.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Format/Filter/v1.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -273,6 +273,19 @@
+     * Method: writeFeatureIdNodes
+     * Parameters:
+     * filter - {<OpenLayers.Filter.FeatureId}
+     * node - {DOMElement}
+    writeFeatureIdNodes: function(filter, node) {
+        for (var i=0, ii=filter.fids.length; i<ii; ++i) {
+            this.writeNode("FeatureId", filter.fids[i], node);
      * Property: writers
      * As a compliment to the readers property, this structure contains public
      *     writing functions grouped by namespace alias and named like the
@@ -282,11 +295,8 @@
         "ogc": {
             "Filter": function(filter) {
                 var node = this.createElementNSPlus("ogc:Filter");
-                var sub = filter.CLASS_NAME.split(".").pop();
-                if(sub == "FeatureId") {
-                    for(var i=0; i<filter.fids.length; ++i) {
-                        this.writeNode("FeatureId", filter.fids[i], node);
+                if (filter.type === "FID") {
+                    this.writeFeatureIdNodes(filter, node);
                 } else {
                     this.writeNode(this.getFilterType(filter), filter, node);
@@ -300,31 +310,43 @@
             "And": function(filter) {
                 var node = this.createElementNSPlus("ogc:And");
                 var childFilter;
-                for(var i=0; i<filter.filters.length; ++i) {
+                for (var i=0, ii=filter.filters.length; i<ii; ++i) {
                     childFilter = filter.filters[i];
+                    if (childFilter.type === "FID") {
+                        this.writeFeatureIdNodes(childFilter, node);
+                    } else {
                     this.writeNode(
                         this.getFilterType(childFilter), childFilter, node
                 return node;
             "Or": function(filter) {
                 var node = this.createElementNSPlus("ogc:Or");
                 var childFilter;
+                    } else {
                     this.writeNode(
                 return node;
             "Not": function(filter) {
                 var node = this.createElementNSPlus("ogc:Not");
                 var childFilter = filter.filters[0];
+                } else {
                 this.writeNode(
                 return node;
             "PropertyIsLessThan": function(filter) {
@@ -460,7 +482,8 @@
         "DWITHIN": "DWITHIN",
         "WITHIN": "WITHIN",
         "CONTAINS": "CONTAINS",
-        "INTERSECTS": "INTERSECTS"
+        "INTERSECTS": "INTERSECTS",
+        "FID": "FeatureId"
     CLASS_NAME: "OpenLayers.Format.Filter.v1"
Copied: sandbox/cmoullet/openlayers/lib/OpenLayers/Format/QueryStringFilter.js (from rev 11762, trunk/openlayers/lib/OpenLayers/Format/QueryStringFilter.js)
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Format/QueryStringFilter.js	                        (rev 0)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Format/QueryStringFilter.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -0,0 +1,180 @@
+/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Format.js
+ * @requires OpenLayers/Filter/Comparison.js
+ * Class: OpenLayers.Format.QueryStringFilter
+ * Parser for reading a query string and creating a simple filter.
+ * Inherits from:
+ *  - <OpenLayers.Format>
+OpenLayers.Format.QueryStringFilter = (function() {
+     * Map the OpenLayers.Filter.Comparison types to the operation strings of
+     * the protocol.
+    var cmpToStr = {};
+    cmpToStr[OpenLayers.Filter.Comparison.EQUAL_TO] = "eq";
+    cmpToStr[OpenLayers.Filter.Comparison.NOT_EQUAL_TO] = "ne";
+    cmpToStr[OpenLayers.Filter.Comparison.LESS_THAN] = "lt";
+    cmpToStr[OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO] = "lte";
+    cmpToStr[OpenLayers.Filter.Comparison.GREATER_THAN] = "gt";
+    cmpToStr[OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO] = "gte";
+    cmpToStr[OpenLayers.Filter.Comparison.LIKE] = "ilike";
+     * Function: regex2value
+     * Convert the value from a regular expression string to a LIKE/ILIKE
+     * string known to the web service.
+     * Parameters:
+     * value - {String} The regex string.
+     * Returns:
+     * {String} The converted string.
+    function regex2value(value) {
+        // highly sensitive!! Do not change this without running the
+        // Protocol/HTTP.html unit tests
+        // convert % to \%
+        value = value.replace(/%/g, "\\%");
+        // convert \\. to \\_ (\\.* occurences converted later)
+        value = value.replace(/\\\\\.(\*)?/g, function($0, $1) {
+            return $1 ? $0 : "\\\\_";
+        // convert \\.* to \\%
+        value = value.replace(/\\\\\.\*/g, "\\\\%");
+        // convert . to _ (\. and .* occurences converted later)
+        value = value.replace(/(\\)?\.(\*)?/g, function($0, $1, $2) {
+            return $1 || $2 ? $0 : "_";
+        // convert .* to % (\.* occurnces converted later)
+        value = value.replace(/(\\)?\.\*/g, function($0, $1) {
+            return $1 ? $0 : "%";
+        // convert \. to .
+        value = value.replace(/\\\./g, ".");
+        // replace \* with * (watching out for \\*)
+        value = value.replace(/(\\)?\\\*/g, function($0, $1) {
+            return $1 ? $0 : "*";
+        return value;
+    return OpenLayers.Class(OpenLayers.Format, {
+         * Property: wildcarded.
+         * {Boolean} If true percent signs are added around values
+         *     read from LIKE filters, for example if the protocol
+         *     read method is passed a LIKE filter whose property
+         *     is "foo" and whose value is "bar" the string
+         *     "foo__ilike=%bar%" will be sent in the query string;
+         *     defaults to false.
+        wildcarded: false,
+         * APIProperty: srsInBBOX
+         * {Boolean} Include the SRS identifier in BBOX query string parameter.
+         *     Default is false.  If true and the layer has a projection object set,
+         *     any BBOX filter will be serialized with a fifth item identifying the
+         *     projection.  E.g. bbox=-1000,-1000,1000,1000,EPSG:900913
+        srsInBBOX: false,
+         * APIMethod: write
+         * Serialize an <OpenLayers.Filter> objects using the "simple" filter syntax for
+         *     query string parameters.  This function must be called as a method of
+         *     a protocol instance.
+         * Parameters:
+         * filter - {<OpenLayers.Filter>} filter to convert.
+         * params - {Object} The parameters object.
+         * Returns:
+         * {Object} The resulting parameters object.
+        write: function(filter, params) {
+            params = params || {};
+            var className = filter.CLASS_NAME;
+            var filterType = className.substring(className.lastIndexOf(".") + 1);
+            switch (filterType) {
+                case "Spatial":
+                    switch (filter.type) {
+                        case OpenLayers.Filter.Spatial.BBOX:
+                            params.bbox = filter.value.toArray();
+                            if (this.srsInBBOX && filter.projection) {
+                                params.bbox.push(filter.projection.getCode());
+                            break;
+                        case OpenLayers.Filter.Spatial.DWITHIN:
+                            params.tolerance = filter.distance;
+                            // no break here
+                        case OpenLayers.Filter.Spatial.WITHIN:
+                            params.lon = filter.value.x;
+                            params.lat = filter.value.y;
+                            break;
+                        default:
+                            OpenLayers.Console.warn(
+                                "Unknown spatial filter type " + filter.type);
+                    break;
+                case "Comparison":
+                    var op = cmpToStr[filter.type];
+                    if (op !== undefined) {
+                        var value = filter.value;
+                        if (filter.type == OpenLayers.Filter.Comparison.LIKE) {
+                            value = regex2value(value);
+                            if (this.wildcarded) {
+                                value = "%" + value + "%";
+                        params[filter.property + "__" + op] = value;
+                        params.queryable = params.queryable || [];
+                        params.queryable.push(filter.property);
+                    } else {
+                            "Unknown comparison filter type " + filter.type);
+                    break;
+                case "Logical":
+                    if (filter.type === OpenLayers.Filter.Logical.AND) {
+                        for (var i=0,len=filter.filters.length; i<len; i++) {
+                            params = this.write(filter.filters[i], params);
+                    } else {
+                            "Unsupported logical filter type " + filter.type);
+                    break;
+                default:
+                    OpenLayers.Console.warn("Unknown filter type " + filterType);
+            return params;
+        CLASS_NAME: "OpenLayers.Format.QueryStringFilter"
\ No newline at end of file
Added: sandbox/cmoullet/openlayers/lib/OpenLayers/Format/XLS/v1.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Format/XLS/v1.js	                        (rev 0)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Format/XLS/v1.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -0,0 +1,307 @@
+/* Copyright (c) 2006-2010 by OpenLayers Contributors (see authors.txt for
+ * @requires OpenLayers/Format/XLS.js
+ * @requires OpenLayers/Format/GML/v3.js
+ * Class: OpenLayers.Format.XLS.v1
+ * Superclass for XLS version 1 parsers. Only supports GeocodeRequest for now.
+ * Inherits from:
+ *  - <OpenLayers.Format.XML>
+OpenLayers.Format.XLS.v1 = OpenLayers.Class(OpenLayers.Format.XML, {
+     * Property: namespaces
+     * {Object} Mapping of namespace aliases to namespace URIs.
+    namespaces: {
+        xls: "http://www.opengis.net/xls",
+        gml: "http://www.opengis.net/gml",
+        xsi: "http://www.w3.org/2001/XMLSchema-instance"
+     * Property: regExes
+     * Compiled regular expressions for manipulating strings.
+    regExes: {
+        trimSpace: (/^\s*|\s*$/g),
+        removeSpace: (/\s*/g),
+        splitSpace: (/\s+/),
+        trimComma: (/\s*,\s*/g)
+     * APIProperty: xy
+     * {Boolean} Order of the GML coordinate true:(x,y) or false:(y,x)
+     * Changing is not recommended, a new Format should be instantiated.
+    xy: true,
+     * Property: defaultPrefix
+    defaultPrefix: "xls",
+     * Property: schemaLocation
+     * {String} Schema location for a particular minor version.
+    schemaLocation: null,
+     * Constructor: OpenLayers.Format.XLS.v1
+     * Instances of this class are not created directly.  Use the
+     *     <OpenLayers.Format.XLS> constructor instead.
+     * Parameters:
+     * options - {Object} An optional object whose properties will be set on
+     *     this instance.
+    initialize: function(options) {
+        OpenLayers.Format.XML.prototype.initialize.apply(this, [options]);
+     * Method: read
+     * Parameters:
+     * data - {DOMElement} An XLS document element.
+     * options - {Object} Options for the reader.
+     * Returns:
+     * {Object} An object representing the XLSResponse.
+    read: function(data, options) {
+        options = OpenLayers.Util.applyDefaults(options, this.options);
+        var xls = {};
+        this.readChildNodes(data, xls);
+        return xls;
+     * Property: readers
+     * Contains public functions, grouped by namespace prefix, that will
+     *     be applied when a namespaced node is found matching the function
+     *     name.  The function will be applied in the scope of this parser
+     *     with two arguments: the node being read and a context object passed
+     *     from the parent.
+    readers: {
+        "xls": {
+            "XLS": function(node, xls) {
+                xls.version = node.getAttribute("version");
+                this.readChildNodes(node, xls);
+            "Response": function(node, xls) {
+            "GeocodeResponse": function(node, xls) {
+               xls.responseLists = [];
+            "GeocodeResponseList": function(node, xls) {
+                var responseList = {
+                    features: [],
+                    numberOfGeocodedAddresses:
+                        parseInt(node.getAttribute("numberOfGeocodedAddresses"))
+                xls.responseLists.push(responseList);
+                this.readChildNodes(node, responseList);
+            "GeocodedAddress": function(node, responseList) {
+                var feature = new OpenLayers.Feature.Vector();
+                responseList.features.push(feature);
+                this.readChildNodes(node, feature);
+                // post-process geometry
+                feature.geometry = feature.components[0];
+            "GeocodeMatchCode": function(node, feature) {
+                feature.attributes.matchCode = {
+                    accuracy: parseFloat(node.getAttribute("accuracy")),
+                    matchType: node.getAttribute("matchType")
+            "Address": function(node, feature) {
+                var address = {
+                    countryCode: node.getAttribute("countryCode"),
+                    addressee: node.getAttribute("addressee"),
+                    street: [],
+                    place: []
+                feature.attributes.address = address;
+                this.readChildNodes(node, address);
+            "freeFormAddress": function(node, address) {
+                address.freeFormAddress = this.getChildValue(node);
+            "StreetAddress": function(node, address) {
+            "Building": function(node, address) {
+                address.building = {
+                    'number': node.getAttribute("number"),
+                    subdivision: node.getAttribute("subdivision"),
+                    buildingName: node.getAttribute("buildingName")
+            "Street": function(node, address) {
+                // only support the built-in primitive type for now
+                address.street.push(this.getChildValue(node));
+            "Place": function(node, address) {
+                // type is one of CountrySubdivision,
+                // CountrySecondarySubdivision, Municipality or
+                // MunicipalitySubdivision
+                address.place[node.getAttribute("type")] =
+                    this.getChildValue(node);
+            "PostalCode": function(node, address) {
+                address.postalCode = this.getChildValue(node);
+        "gml": OpenLayers.Format.GML.v3.prototype.readers.gml
+     * Method: write
+     * Parameters:
+     * request - {Object} An object representing the geocode request.
+     * Returns:
+     * {DOMElement} The root of an XLS document.
+    write: function(request) {
+        return this.writers.xls.XLS.apply(this, [request]);
+     * Property: writers
+     * As a compliment to the readers property, this structure contains public
+     *     writing functions grouped by namespace alias and named like the
+     *     node names they produce.
+    writers: {
+        "xls": {
+            "XLS": function(request) {
+                var root = this.createElementNSPlus(
+                    "xls:XLS",
+                    {attributes: {
+                        "version": this.VERSION,
+                        "xsi:schemaLocation": this.schemaLocation
+                this.writeNode("RequestHeader", request.header, root);
+                this.writeNode("Request", request, root);
+                return root;
+            "RequestHeader": function(header) {
+                return this.createElementNSPlus("xls:RequestHeader");
+            "Request": function(request) {
+                var node = this.createElementNSPlus("xls:Request", {
+                    attributes: {
+                        methodName: "GeocodeRequest",
+                        requestID: request.requestID || "",
+                        version: this.VERSION
+                this.writeNode("GeocodeRequest", request.addresses, node);
+                return node;
+            "GeocodeRequest": function(addresses) {
+                var node = this.createElementNSPlus("xls:GeocodeRequest");
+                for (var i=0, len=addresses.length; i<len; i++) {
+                    this.writeNode("Address", addresses[i], node);
+                return node;
+            "Address": function(address) {
+                var node = this.createElementNSPlus("xls:Address", {
+                    attributes: {
+                        countryCode: address.countryCode
+                if (address.freeFormAddress) {
+                    this.writeNode("freeFormAddess", address.freeFormAddress, node);
+                } else {
+                    if (address.street) {
+                        this.writeNode("StreetAddress", address, node);
+                    if (address.municipality) {
+                        this.writeNode("Municipality", address.municipality, node);
+                    if (address.countrySubdivision) {
+                        this.writeNode("CountrySubdivision", address.countrySubdivision, node);
+                    if (address.postalCode) {
+                        this.writeNode("PostalCode", address.postalCode, node);
+                return node;
+            "freeFormAddress": function(freeFormAddress) {
+                return this.createElementNSPlus("freeFormAddress",
+                    {value: freeFormAddress});
+            "StreetAddress": function(address) {
+                var node = this.createElementNSPlus("xls:StreetAddress");
+                if (address.building) {
+                    this.writeNode(node, "Building", address.building);
+                var street = address.street;
+                if (!(street instanceof Array)) {
+                    street = [street];
+                for (var i=0, len=street.length; i < len; i++) {
+                    this.writeNode("Street", street[i], node);
+                return node;
+            "Building": function(building) {
+                return this.createElementNSPlus("xls:Building", {
+                    attributes: {
+                        "number": building["number"],
+                        "subdivision": building.subdivision,
+                        "buildingName": building.buildingName
+            "Street": function(street) {
+                return this.createElementNSPlus("xls:Street", {value: street});
+            "Municipality": function(municipality) {
+                return this.createElementNSPlus("xls:Place", {
+                    attributes: {
+                        type: "Municipality"
+                    value: municipality
+            "CountrySubdivision": function(countrySubdivision) {
+                    attributes: {
+                        type: "CountrySubdivision"
+                    value: countrySubdivision
+            "PostalCode": function(postalCode) {
+                return this.createElementNSPlus("xls:PostalCode", {
+                    value: postalCode
+    CLASS_NAME: "OpenLayers.Format.XLS.v1"
Added: sandbox/cmoullet/openlayers/lib/OpenLayers/Format/XLS/v1_1_0.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Format/XLS/v1_1_0.js	                        (rev 0)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Format/XLS/v1_1_0.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -0,0 +1,53 @@
+ * @requires OpenLayers/Format/XLS/v1.js
+ * Class: OpenLayers.Format.XLS.v1_1_0
+ * Read / write XLS version 1.1.0.
+ * Inherits from:
+ *  - <OpenLayers.Format.XLS.v1>
+OpenLayers.Format.XLS.v1_1_0 = OpenLayers.Class(
+    OpenLayers.Format.XLS.v1, {
+     * Constant: VERSION
+     * {String} 1.1
+    VERSION: "1.1",
+     * {String} http://www.opengis.net/xls
+     *   http://schemas.opengis.net/ols/1.1.0/LocationUtilityService.xsd
+    schemaLocation: "http://www.opengis.net/xls http://schemas.opengis.net/ols/1.1.0/LocationUtilityService.xsd",
+     * Constructor: OpenLayers.Format.XLS.v1_1_0
+     * Parameters:
+     *     this instance.
+        OpenLayers.Format.XLS.v1.prototype.initialize.apply(
+            this, [options]
+    CLASS_NAME: "OpenLayers.Format.XLS.v1_1_0"
+// Support non standard implementation
+OpenLayers.Format.XLS.v1_1 = OpenLayers.Format.XLS.v1_1_0;
Added: sandbox/cmoullet/openlayers/lib/OpenLayers/Format/XLS.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Format/XLS.js	                        (rev 0)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Format/XLS.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -0,0 +1,118 @@
+ * @requires OpenLayers/Format/XML.js
+ * Read/Wite XLS (OpenLS). Create a new instance with the <OpenLayers.Format.XLS>
+ *     constructor. Currently only implemented for Location Utility Services, more
+ *     specifically only for Geocoding. No support for Reverse Geocoding as yet.
+ * Inherits from:
+OpenLayers.Format.XLS = OpenLayers.Class(OpenLayers.Format.XML, {
+     * APIProperty: defaultVersion
+     * {String} Version number to assume if none found.  Default is "1.1.0".
+    defaultVersion: "1.1.0",
+     * APIProperty: version
+     * {String} Specify a version string if one is known.
+    version: null,
+     * Property: parser
+     * {Object} Instance of the versioned parser.  Cached for multiple read and
+     *     write calls of the same version.
+    parser: null,
+     * Create a new parser for XLS.
+     * Parameters:
+     *     this instance.
+     * Write out an XLS request.
+     * Parameters:
+     * request - {Object} An object representing the LUS request.
+     * options - {Object} Optional configuration object.
+     * Returns:
+     * {String} An XLS document string.
+    write: function(request, options) {
+        var version = (options && options.version) ||
+                      this.version || this.defaultVersion;
+        if(!this.parser || this.parser.VERSION != version) {
+            var format = OpenLayers.Format.XLS[
+                "v" + version.replace(/\./g, "_")
+            if(!format) {
+                throw "Can't find an XLS parser for version " +
+                      version;
+            this.parser = new format(this.options);
+        var root = this.parser.write(request);
+        return OpenLayers.Format.XML.prototype.write.apply(this, [root]);
+     * APIMethod: read
+     * Read an XLS doc and return an object representing the result.
+     * Parameters:
+     * data - {String | DOMElement} Data to read.
+     * Returns:
+     * {Object} An object representing the GeocodeResponse.
+        if(typeof data == "string") {
+            data = OpenLayers.Format.XML.prototype.read.apply(this, [data]);
+        var root = data.documentElement;
+        var version = this.version;
+        if(!version) {
+            version = root.getAttribute("version");
+            if(!version) {
+                version = this.defaultVersion;
+            if(!format) {
+                      version;
+        var xls = this.parser.read(data, options);
+        return xls;
+    CLASS_NAME: "OpenLayers.Format.XLS"
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Box.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Box.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Box.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -32,11 +32,11 @@
     boxDivClassName: 'olHandlerBoxZoomBox',
-     * Property: boxCharacteristics
-     * {Object} Caches some box characteristics from css. This is used
-     *     by the getBoxCharacteristics method.
+     * Property: boxOffsets
+     * {Object} Caches box offsets from css. This is used by the getBoxOffsets
+     * method.
-    boxCharacteristics: null,
+    boxOffsets: null,
      * Constructor: OpenLayers.Handler.Box
@@ -96,7 +96,13 @@
              new OpenLayers.Pixel(-9999, -9999));
         this.zoomBox.className = this.boxDivClassName;
         this.zoomBox.style.zIndex = this.map.Z_INDEX_BASE["Popup"] - 1;
         this.map.eventsDiv.appendChild(this.zoomBox);
+        var offset = this.getBoxOffsets();
+        var pos = this.dragHandler.start;
+        this.zoomBox.style.left = (pos.x - offset.left) + "px";
+        this.zoomBox.style.top = (pos.y - offset.top) + "px";
         OpenLayers.Element.addClass(
             this.map.eventsDiv, "olDrawBox"
@@ -111,24 +117,14 @@
         var startY = this.dragHandler.start.y;
         var deltaX = Math.abs(startX - xy.x);
         var deltaY = Math.abs(startY - xy.y);
-        this.zoomBox.style.width = Math.max(1, deltaX) + "px";
-        this.zoomBox.style.height = Math.max(1, deltaY) + "px";
-        this.zoomBox.style.left = xy.x < startX ? xy.x+"px" : startX+"px";
-        this.zoomBox.style.top = xy.y < startY ? xy.y+"px" : startY+"px";
-        // depending on the box model, modify width and height to take borders
-        // of the box into account
-        var box = this.getBoxCharacteristics();
-        if (box.newBoxModel) {
-            if (xy.x > startX) {
-                    Math.max(1, deltaX - box.xOffset) + "px";
-            if (xy.y > startY) {
-                    Math.max(1, deltaY - box.yOffset) + "px";
+        this.zoomBox.style.width = (deltaX + offset.width + 1) + "px";
+        this.zoomBox.style.height = (deltaY + offset.height + 1) + "px";
+        this.zoomBox.style.left = (xy.x < startX ?
+            startX - deltaX - offset.left : startX - offset.left) + "px";
+        this.zoomBox.style.top = (xy.y < startY ?
+            startY - deltaY - offset.top : startY - offset.top) + "px";
@@ -159,7 +155,7 @@
     removeBox: function() {
         this.map.eventsDiv.removeChild(this.zoomBox);
         this.zoomBox = null;
-        this.boxCharacteristics = null;
+        this.boxOffsets = null;
         OpenLayers.Element.removeClass(
@@ -195,34 +191,53 @@
-     * Method: getCharacteristics
-     * Determines offset and box model for a box.
+     * Method: getBoxOffsets
+     * Determines border offsets for a box, according to the box model.
      * Returns:
-     * {Object} a hash with the following properties:
-     *     - xOffset - Corner offset in x-direction
-     *     - yOffset - Corner offset in y-direction
-     *     - newBoxModel - true for all browsers except IE in quirks mode
+     * {Object} an object with the following offsets:
+     *     - left
+     *     - right
+     *     - top
+     *     - bottom
+     *     - width
+     *     - height
-    getBoxCharacteristics: function() {
-        if (!this.boxCharacteristics) {
-            var xOffset = parseInt(OpenLayers.Element.getStyle(this.zoomBox,
-                "border-left-width")) + parseInt(OpenLayers.Element.getStyle(
-                this.zoomBox, "border-right-width")) + 1;
-            var yOffset = parseInt(OpenLayers.Element.getStyle(this.zoomBox,
-                "border-top-width")) + parseInt(OpenLayers.Element.getStyle(
-                this.zoomBox, "border-bottom-width")) + 1;
-            // all browsers use the new box model, except IE in quirks mode
-            var newBoxModel = OpenLayers.BROWSER_NAME == "msie" ?
-                document.compatMode != "BackCompat" : true;
-            this.boxCharacteristics = {
-                xOffset: xOffset,
-                yOffset: yOffset,
-                newBoxModel: newBoxModel
+    getBoxOffsets: function() {
+        if (!this.boxOffsets) {
+            // Determine the box model. If the testDiv's clientWidth is 3, then
+            // the borders are outside and we are dealing with the w3c box
+            // model. Otherwise, the browser uses the traditional box model and
+            // the borders are inside the box bounds, leaving us with a
+            // clientWidth of 1.
+            var testDiv = document.createElement("div");
+            //testDiv.style.visibility = "hidden";
+            testDiv.style.position = "absolute";
+            testDiv.style.border = "1px solid black";
+            testDiv.style.width = "3px";
+            document.body.appendChild(testDiv);
+            var w3cBoxModel = testDiv.clientWidth == 3;
+            document.body.removeChild(testDiv);
+            var left = parseInt(OpenLayers.Element.getStyle(this.zoomBox,
+                "border-left-width"));
+            var right = parseInt(OpenLayers.Element.getStyle(
+                this.zoomBox, "border-right-width"));
+            var top = parseInt(OpenLayers.Element.getStyle(this.zoomBox,
+                "border-top-width"));
+            var bottom = parseInt(OpenLayers.Element.getStyle(
+                this.zoomBox, "border-bottom-width"));
+            this.boxOffsets = {
+                left: left,
+                right: right,
+                top: top,
+                bottom: bottom,
+                width: w3cBoxModel === false ? left + right : 0,
+                height: w3cBoxModel === false ? top + bottom : 0
-        return this.boxCharacteristics;
+        return this.boxOffsets;
     CLASS_NAME: "OpenLayers.Handler.Box"
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Path.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Path.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Path.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -79,13 +79,14 @@
      *     feature.
     createFeature: function(pixel) {
-        if(!pixel) {
-            pixel = new OpenLayers.Pixel(-50, -50);
+        var geometry;
+        if(pixel) {
+            var lonlat = this.map.getLonLatFromPixel(pixel);
+            geometry = new OpenLayers.Geometry.Point(lonlat.lon, lonlat.lat);
+        } else {
+            geometry = new OpenLayers.Geometry.Point();
-        var lonlat = this.control.map.getLonLatFromPixel(pixel);
-        this.point = new OpenLayers.Feature.Vector(
-            new OpenLayers.Geometry.Point(lonlat.lon, lonlat.lat)
+        this.point = new OpenLayers.Feature.Vector(geometry);
         this.line = new OpenLayers.Feature.Vector(
             new OpenLayers.Geometry.LineString([this.point.geometry])
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Point.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Point.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Point.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -98,11 +98,11 @@
      * APIProperty: pixelTolerance
-     * {Number} Maximum number of pixels between mouseup and mousedown for an
-     *     event to be considered a click.  Default is 5.  If set to an
-     *     integer value, clicks with a drag greater than the value will be
-     *     ignored.  This property can only be set when the handler is
-     *     constructed.
+     * {Number} Maximum number of pixels between down and up (mousedown
+     *     and mouseup, or touchstart and touchend) for the handler to
+     *     add a new point. If set to an integer value, if the
+     *     displacement between down and up is great to this value
+     *     no point will be added. Default value is 5.
     pixelTolerance: 5,
@@ -420,7 +420,7 @@
         this.last = evt.xy;
         if (this.timerId &&
-                this.passesTolerance(last, evt.xy, this.dblclickTolerance)) {
+            this.passesTolerance(last, evt.xy, this.dblclickTolerance)) {
             this.isDblclick = true;
             // a valid touch immediately adds a component and leaves us with a
             // complete geometry
@@ -521,7 +521,7 @@
     down: function(evt) {
         this.mouseDown = true;
         this.lastDown = evt.xy;
-        if (!this.touch) {
+        if(!this.touch) { // no point displayed until up on touch devices
             this.modifyFeature(evt.xy);
         this.stoppedDown = this.stopDown;
@@ -540,7 +540,8 @@
      * {Boolean} Allow event propagation
     move: function (evt) {
-        if(!this.touch && (!this.mouseDown || this.stoppedDown)) {
+        if(!this.touch // no point displayed until up on touch devices
+           && (!this.mouseDown || this.stoppedDown)) {
         return true;
@@ -567,11 +568,11 @@
         // ignore double-clicks
         if (this.lastUp && this.passesTolerance(this.lastUp, evt.xy,
-                                                    this.dblclickTolerance)) {
+                                                this.dblclickTolerance)) {
             return true;
         if (this.lastDown && this.passesTolerance(this.lastDown, evt.xy,
-                                                    this.pixelTolerance)) {
+                                                  this.pixelTolerance)) {
             if (this.touch) {
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Polygon.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Polygon.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Polygon.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -75,13 +75,14 @@
      *     feature.
-        if(!pixel) {
+        var geometry;
+        if(pixel) {
+        } else {
             new OpenLayers.Geometry.LinearRing([this.point.geometry])
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Protocol/HTTP.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Protocol/HTTP.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Protocol/HTTP.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -15,7 +15,7 @@
  * TODO: remove this dependency in 3.0
- * @requires OpenLayers/Protocol/SimpleFilterSerializer.js
+ * @requires OpenLayers/Format/QueryStringFilter.js
@@ -115,10 +115,14 @@
         this.headers = {};
         OpenLayers.Protocol.prototype.initialize.apply(this, arguments);
-        if (!this.filterToParams && OpenLayers.Protocol.simpleFilterSerializer) {
-            this.filterToParams = OpenLayers.Function.bind(
-                OpenLayers.Protocol.simpleFilterSerializer, this
+        if (!this.filterToParams && OpenLayers.Format.QueryStringFilter) {
+            var format = new OpenLayers.Format.QueryStringFilter({
+                wildcarded: this.wildcarded,
+                srsInBBOX: this.srsInBBOX
+            this.filterToParams = function(filter, params) {
+                return format.write(filter, params);
@@ -146,7 +150,7 @@
      * Returns:
      * APIMethod: read
      * Construct a request for reading new features.
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Protocol/Script.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Protocol/Script.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Protocol/Script.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -91,6 +91,17 @@
     pendingRequests: null,
+     *     Setting this property has no effect if a custom filterToParams method
+     *     is provided.   Default is false.  If true and the layer has a
+     *     projection object set, any BBOX filter will be serialized with a
+     *     fifth item identifying the projection.
+     *     E.g. bbox=-1000,-1000,1000,1000,EPSG:900913
+    srsInBBOX: false,
      * Constructor: OpenLayers.Protocol.Script
      * A class for giving layers generic Script protocol.
@@ -113,10 +124,13 @@
             this.format = new OpenLayers.Format.GeoJSON();
Deleted: sandbox/cmoullet/openlayers/lib/OpenLayers/Protocol/SimpleFilterSerializer.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Protocol/SimpleFilterSerializer.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Protocol/SimpleFilterSerializer.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -1,145 +0,0 @@
-/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
- * full list of contributors). Published under the Clear BSD license.
- * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
- * full text of the license. */
- * @requires OpenLayers/Protocol.js
- * Function: OpenLayers.Protocol.simpleFilterSerializer
- * Serialize an <OpenLayers.Filter> objects using the "simple" filter syntax for
- *     query string parameters.  This function must be called as a method of
- *     a protocol instance.
- * Parameters:
- * filter - {<OpenLayers.Filter>} filter to convert.
- * params - {Object} The parameters object.
- * Returns:
- * {Object} The resulting parameters object.
-OpenLayers.Protocol.simpleFilterSerializer = (function() {
-     * Map the OpenLayers.Filter.Comparison types to the operation strings of
-     * the protocol.
-    var cmpToStr = {};
-    cmpToStr[OpenLayers.Filter.Comparison.EQUAL_TO] = "eq";
-    cmpToStr[OpenLayers.Filter.Comparison.NOT_EQUAL_TO] = "ne";
-    cmpToStr[OpenLayers.Filter.Comparison.LESS_THAN] = "lt";
-    cmpToStr[OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO] = "lte";
-    cmpToStr[OpenLayers.Filter.Comparison.GREATER_THAN] = "gt";
-    cmpToStr[OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO] = "gte";
-    cmpToStr[OpenLayers.Filter.Comparison.LIKE] = "ilike";
-     * Function: regex2value
-     * Convert the value from a regular expression string to a LIKE/ILIKE
-     * string known to the web service.
-     * Parameters:
-     * value - {String} The regex string.
-     * Returns:
-     * {String} The converted string.
-    function regex2value(value) {
-        // highly sensitive!! Do not change this without running the
-        // Protocol/HTTP.html unit tests
-        // convert % to \%
-        value = value.replace(/%/g, "\\%");
-        // convert \\. to \\_ (\\.* occurences converted later)
-        value = value.replace(/\\\\\.(\*)?/g, function($0, $1) {
-            return $1 ? $0 : "\\\\_";
-        // convert \\.* to \\%
-        value = value.replace(/\\\\\.\*/g, "\\\\%");
-        // convert . to _ (\. and .* occurences converted later)
-        value = value.replace(/(\\)?\.(\*)?/g, function($0, $1, $2) {
-            return $1 || $2 ? $0 : "_";
-        // convert .* to % (\.* occurnces converted later)
-        value = value.replace(/(\\)?\.\*/g, function($0, $1) {
-            return $1 ? $0 : "%";
-        // convert \. to .
-        value = value.replace(/\\\./g, ".");
-        // replace \* with * (watching out for \\*)
-        value = value.replace(/(\\)?\\\*/g, function($0, $1) {
-            return $1 ? $0 : "*";
-        return value;
-    return function simpleFilterSerializer(filter, params) {
-        params = params || {};
-        var className = filter.CLASS_NAME;
-        var filterType = className.substring(className.lastIndexOf(".") + 1);
-        switch (filterType) {
-            case "Spatial":
-                switch (filter.type) {
-                    case OpenLayers.Filter.Spatial.BBOX:
-                        params.bbox = filter.value.toArray();
-                        if (this.srsInBBOX && filter.projection) {
-                            params.bbox.push(filter.projection.getCode());
-                        break;
-                    case OpenLayers.Filter.Spatial.DWITHIN:
-                        params.tolerance = filter.distance;
-                        // no break here
-                    case OpenLayers.Filter.Spatial.WITHIN:
-                        params.lon = filter.value.x;
-                        params.lat = filter.value.y;
-                        break;
-                    default:
-                        OpenLayers.Console.warn(
-                            "Unknown spatial filter type " + filter.type);
-                break;
-            case "Comparison":
-                var op = cmpToStr[filter.type];
-                if (op !== undefined) {
-                    var value = filter.value;
-                    if (filter.type == OpenLayers.Filter.Comparison.LIKE) {
-                        value = regex2value(value);
-                        if (this.wildcarded) {
-                            value = "%" + value + "%";
-                    params[filter.property + "__" + op] = value;
-                    params.queryable = params.queryable || [];
-                    params.queryable.push(filter.property);
-                } else {
-                        "Unknown comparison filter type " + filter.type);
-                break;
-            case "Logical":
-                if (filter.type === OpenLayers.Filter.Logical.AND) {
-                    for (var i=0,len=filter.filters.length; i<len; i++) {
-                        params = this.filterToParams(filter.filters[i], params);
-                } else {
-                        "Unsupported logical filter type " + filter.type);
-                break;
-            default:
-                OpenLayers.Console.warn("Unknown filter type " + filterType);
-        return params;
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/Canvas.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/Canvas.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/Canvas.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -333,7 +333,11 @@
         this.setCanvasStyle("reset");
         this.canvas.fillStyle = style.fontColor;
         this.canvas.globalAlpha = style.fontOpacity || 1.0;
-        var fontStyle = style.fontWeight + " " + style.fontSize + " " + style.fontFamily;
+        var fontStyle = [style.fontStyle ? style.fontStyle : "normal",
+                         "normal", // "font-variant" not supported
+                         style.fontWeight ? style.fontWeight : "normal",
+                         style.fontSize ? style.fontSize : "10px",
+                         style.fontFamily ? style.fontFamily : "sans-serif"].join(" ");
         if (this.canvas.fillText) {
             // HTML5
             var labelAlign =
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/SVG.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/SVG.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/SVG.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -712,6 +712,9 @@
         if (style.fontWeight) {
             label.setAttributeNS(null, "font-weight", style.fontWeight);
+        if (style.fontStyle) {
+            label.setAttributeNS(null, "font-style", style.fontStyle);
         if(style.labelSelect === true) {
             label.setAttributeNS(null, "pointer-events", "visible");
             label._featureId = featureId;
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/SVG2.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/SVG2.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/SVG2.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -606,6 +606,9 @@
             text.setAttributeNS(null, "font-weight", style.fontWeight);
+            text.setAttributeNS(null, "font-style", style.fontStyle);
             text.setAttributeNS(null, "pointer-events", "visible");
             text._featureId = featureId;
@@ -790,4 +793,4 @@
 OpenLayers.Renderer.SVG2.preventDefault = function(e) {
     e.preventDefault && e.preventDefault();
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/VML.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/VML.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/VML.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -855,6 +855,9 @@
             textbox.style.fontWeight = style.fontWeight;
+            textbox.style.fontStyle = style.fontStyle;
             textbox._featureId = featureId;
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers.js	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers.js	2011-03-30 03:18:10 UTC (rev 11763)
@@ -247,7 +247,6 @@
                 "OpenLayers/Filter/Function.js",
                 "OpenLayers/Protocol.js",
                 "OpenLayers/Protocol/HTTP.js",
-                "OpenLayers/Protocol/SimpleFilterSerializer.js",
                 "OpenLayers/Protocol/SQL.js",
                 "OpenLayers/Protocol/SQL/Gears.js",
                 "OpenLayers/Protocol/WFS.js",
@@ -264,6 +263,7 @@
                 "OpenLayers/StyleMap.js",
                 "OpenLayers/Rule.js",
                 "OpenLayers/Format.js",
+                "OpenLayers/Format/QueryStringFilter.js",
                 "OpenLayers/Format/XML.js",
                 "OpenLayers/Format/Context.js",
                 "OpenLayers/Format/ArcXML.js",
@@ -329,6 +329,9 @@
                 "OpenLayers/Format/OWSContext/v0_3_1.js",
                 "OpenLayers/Format/WMTSCapabilities.js",
                 "OpenLayers/Format/WMTSCapabilities/v1_0_0.js",
+                "OpenLayers/Format/XLS.js",
+ 		        "OpenLayers/Format/XLS/v1.js",
+ 		        "OpenLayers/Format/XLS/v1_1_0.js",
                 "OpenLayers/Layer/WFS.js",
                 "OpenLayers/Control/GetFeature.js",
                 "OpenLayers/Control/MouseToolbar.js",
Modified: sandbox/cmoullet/openlayers/tests/BaseTypes/Bounds.html
--- sandbox/cmoullet/openlayers/tests/BaseTypes/Bounds.html	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/tests/BaseTypes/Bounds.html	2011-03-30 03:18:10 UTC (rev 11763)
@@ -76,7 +76,7 @@
     function test_Bounds_toString(t) {
         t.plan( 1 );
         bounds = new OpenLayers.Bounds(1,2,3,4);
-        t.eq( bounds.toString(), "left-bottom=(1,2) right-top=(3,4)", "toString() returns correct value." );
+        t.eq( bounds.toString(), "1,2,3,4", "toString() returns correct value." );
     function test_Bounds_toArray(t) {
         t.plan( 1 );
Modified: sandbox/cmoullet/openlayers/tests/Control/DrawFeature.html
--- sandbox/cmoullet/openlayers/tests/Control/DrawFeature.html	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/tests/Control/DrawFeature.html	2011-03-30 03:18:10 UTC (rev 11763)
@@ -94,7 +94,8 @@
         log = {};
         control.activate();
         t.eq(log.sketchstarted.type, "sketchstarted", "[activate] sketchstarted triggered");
-        t.geom_eq(log.sketchstarted.vertex, new OpenLayers.Geometry.Point(-250, 175), "[activate] correct vertex");
+        t.ok(isNaN(log.sketchstarted.vertex.x) && isNaN(log.sketchstarted.vertex.y),
+             "[activate] correct vertex (NaN)");
         log = {};
         map.events.triggerEvent("mousemove", {xy: new OpenLayers.Pixel(0, 0)});
@@ -123,7 +124,8 @@
                   "[dblclick] correct geometry");
         t.eq(log.sketchstarted.type, "sketchstarted", "[dblclick] sketchstarted triggered");
-        t.geom_eq(log.sketchstarted.vertex, new OpenLayers.Geometry.Point(-250, 175), "[dblclick] correct vertex");
+             "[dblclick] correct vertex (NaN)");
         map.destroy();
Modified: sandbox/cmoullet/openlayers/tests/Control/PanZoomBar.html
--- sandbox/cmoullet/openlayers/tests/Control/PanZoomBar.html	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/tests/Control/PanZoomBar.html	2011-03-30 03:18:10 UTC (rev 11763)
@@ -166,6 +166,50 @@
             t.ok(map.zoom >= 0, 'map.zoom is never < 0 after random handle drag with forceFixedZoomLevel=true and fractionalZoom=true');
+    function test_Control_PanZoomBar_shows (t) {
+        t.plan(22);
+        var control, map;
+        control = new OpenLayers.Control.PanZoomBar({panIcons: true, zoomWorldIcon: false});
+        map = new OpenLayers.Map('map', {controls: [control]});
+        t.eq(control.buttons.length, 6, "(a) pan, no world - expected number of buttons");
+        t.ok(control.buttons[0].id.match("_panup$"), "(a) pan, no world - pan up");
+        t.ok(control.buttons[1].id.match("_panleft$"), "(a) pan, no world - pan left");
+        t.ok(control.buttons[2].id.match("_panright$"), "(a) pan, no world - pan right");
+        t.ok(control.buttons[3].id.match("_pandown$"), "(a) pan, no world - pan down");
+        t.ok(control.buttons[4].id.match("_zoomin$"), "(a) pan, no world - zoom in");
+        t.ok(control.buttons[5].id.match("_zoomout$"), "(a) pan, no world - zoom out");
+        map.destroy();
+        control = new OpenLayers.Control.PanZoomBar({panIcons: true, zoomWorldIcon: true});
+        map = new OpenLayers.Map('map', {controls:[control]});
+        t.eq(control.buttons.length, 7, "(b) pan, world - expected number of buttons");
+        t.ok(control.buttons[0].id.match("_panup$"), "(b) pan, world - pan up");
+        t.ok(control.buttons[1].id.match("_panleft$"), "(b) pan, world - pan left");
+        t.ok(control.buttons[2].id.match("_zoomworld$"), "(b) pan, world - zoom world");
+        t.ok(control.buttons[3].id.match("_panright$"), "(b) pan, world - pan right");
+        t.ok(control.buttons[4].id.match("_pandown$"), "(b) pan, world - pan down");
+        t.ok(control.buttons[5].id.match("_zoomin$"), "(b) pan, world - zoom in");
+        t.ok(control.buttons[6].id.match("_zoomout$"), "(b) pan, world - zoom out");
+        map.destroy();
+        control = new OpenLayers.Control.PanZoomBar({panIcons: false, zoomWorldIcon: false});
+        t.eq(control.buttons.length, 2, "(c) no pan, no world - expected number of buttons");
+        t.ok(control.buttons[0].id.match("_zoomin$"), "(c) no pan, no world - zoom in");
+        t.ok(control.buttons[1].id.match("_zoomout$"), "(c) no pan, no world - zoom out");
+        map.destroy();
+        control = new OpenLayers.Control.PanZoomBar({panIcons: false, zoomWorldIcon: true});
+        t.eq(control.buttons.length, 3, "(d) no pan, world - expected number of buttons");
+        t.ok(control.buttons[0].id.match("_zoomin$"), "(d) no pan, world - zoom in");
+        t.ok(control.buttons[1].id.match("_zoomout$"), "(d) no pan, world - zoom out");
+        t.ok(control.buttons[2].id.match("_zoomworld$"), "(d) no pan, world - zoom world");
+        map.destroy();
   </script>
 </head>
 <body>
Modified: sandbox/cmoullet/openlayers/tests/Feature.html
--- sandbox/cmoullet/openlayers/tests/Feature.html	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/tests/Feature.html	2011-03-30 03:18:10 UTC (rev 11763)
@@ -122,7 +122,7 @@
         t.ok( !feature2.onScreen(), "feature knows it's offscreen" );
-    function test_Feature_createPopup(t) {
+    function test_Feature_createPopup_2(t) {
         t.plan(11);
     //no lonlat
Modified: sandbox/cmoullet/openlayers/tests/Format/Filter/v1.html
--- sandbox/cmoullet/openlayers/tests/Format/Filter/v1.html	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/tests/Format/Filter/v1.html	2011-03-30 03:18:10 UTC (rev 11763)
@@ -166,9 +166,96 @@
+    function test_logical_fid(t) {
+        // the Filter Encoding spec doesn't allow for FID filters inside logical filters
+        // however, to be liberal, we will write them without complaining
+        t.plan(3);
+        var filter = new OpenLayers.Filter.Logical({
+            type: OpenLayers.Filter.Logical.OR,
+            filters: [
+                new OpenLayers.Filter.Comparison({
+                    type: OpenLayers.Filter.Comparison.LIKE,
+                    property: "person",
+                    value: "me"
+                new OpenLayers.Filter.FeatureId({fids: ["foo.1", "foo.2"]})
+        var format = new OpenLayers.Format.Filter.v1_0_0();
+        var got = format.write(filter);
+        var exp = readXML("LogicalFeatureId");
+        t.xml_eq(got, exp, "wrote FID filter in logical OR without complaint");
+        filter = new OpenLayers.Filter.Logical({
+            type: OpenLayers.Filter.Logical.AND,
+            filters: [
+                    value: "me"
+        got = format.write(filter);
+        exp = readXML("LogicalFeatureIdAnd");
+        t.xml_eq(got, exp, "wrote FID filter in logical AND without complaint");
+            type: OpenLayers.Filter.Logical.NOT,
+            filters: [
+                new OpenLayers.Filter.FeatureId({fids: ["foo.2"]})
+        exp = readXML("LogicalFeatureIdNot");
+        t.xml_eq(got, exp, "wrote FID filter in logical NOT without complaint");
+    function readXML(id) {
+        var xml = document.getElementById(id).firstChild.nodeValue;
+        return new OpenLayers.Format.XML().read(xml).documentElement;
     </script>
 </head>
 <body>
+<div id="LogicalFeatureId"><!--
+<ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
+    <ogc:Or>
+        <ogc:PropertyIsLike wildCard="*" singleChar="." escape="!">
+            <ogc:PropertyName>person</ogc:PropertyName>
+            <ogc:Literal>me</ogc:Literal>
+        </ogc:PropertyIsLike>
+        <ogc:FeatureId fid="foo.1"/>
+        <ogc:FeatureId fid="foo.2"/>
+    </ogc:Or>
+</ogc:Filter>
+--></div>
+<div id="LogicalFeatureIdAnd"><!--
+    <ogc:And>
+    </ogc:And>
+</ogc:Filter>
+--></div>
+<div id="LogicalFeatureIdNot"><!--
+    <ogc:Not>
+    </ogc:Not>
+</ogc:Filter>
+--></div>
 </body>
 </html>
Copied: sandbox/cmoullet/openlayers/tests/Format/QueryStringFilter.html (from rev 11762, trunk/openlayers/tests/Format/QueryStringFilter.html)
--- sandbox/cmoullet/openlayers/tests/Format/QueryStringFilter.html	                        (rev 0)
+++ sandbox/cmoullet/openlayers/tests/Format/QueryStringFilter.html	2011-03-30 03:18:10 UTC (rev 11763)
@@ -0,0 +1,306 @@
+<html>
+<head>
+  <script src="../../lib/OpenLayers.js"></script>
+    function test_constructor(t) {
+        t.plan(4);
+        var options = {'foo': 'bar'};
+        var format  = new OpenLayers.Format.QueryStringFilter(options);
+        t.ok(format instanceof OpenLayers.Format.QueryStringFilter,
+           "new OpenLayers.Format.QueryStringFilter object");
+        t.eq(format.foo, "bar", "constructor sets options correctly")
+        t.eq(typeof format.write, 'function', 'format has a write function');
+        t.eq(format.options, options, "format.options correctly set");
+    function test_write(t) {
+        t.plan(30);
+        // setup
+        var format, filter, params;
+        format = new OpenLayers.Format.QueryStringFilter();
+        // 1 test
+        filter = new OpenLayers.Filter.Spatial({
+            type: OpenLayers.Filter.Spatial.BBOX,
+            value: new OpenLayers.Bounds(0, 1, 2, 3)
+        params = format.write(filter);
+        t.eq(params.bbox, [0, 1, 2, 3], "correct bbox param if passed a BBOX filter");
+        // 3 tests
+        var lon = 100, lat = 200, tolerance = 10;
+            type: OpenLayers.Filter.Spatial.DWITHIN,
+            value: new OpenLayers.Geometry.Point(lon, lat),
+            distance: tolerance
+        t.eq(params.lon, lon, "correct lon param if passed a DWITHIN filter");
+        t.eq(params.lat, lat, "correct lat param if passed a DWITHIN filter");
+        t.eq(params.tolerance, tolerance, "correct tolerance param if passed a DWITHIN filter");
+        // 2 tests
+            type: OpenLayers.Filter.Spatial.WITHIN,
+        t.eq(params.lon, lon, "correct lon param if passed a WITHIN filter");
+        t.eq(params.lat, lat, "correct lat param if passed a WITHIN filter");
+        // Some bbox filters used in the next tests.
+        var bboxFilter1 = new OpenLayers.Filter.Spatial({
+            value:  new OpenLayers.Bounds(0, 0, 10, 10)
+        var bboxFilter2 = new OpenLayers.Filter.Spatial({
+            value:  new OpenLayers.Bounds(0, 0, 20, 20)
+        // 1 test
+            filters: []
+        t.eq(params, {}, "returns empty object if given empty AND Logical filter");
+        // 1 test
+            filters: [
+                bboxFilter1
+        t.eq(params, {}, "does not support OR Logical filter");
+        // 1 test
+            filters: [
+                bboxFilter1
+        t.eq(params.bbox, [0, 0, 10, 10],
+             "correct bbox param if passed a Logical filter containing a BBOX");
+        // 1 test
+            filters: [
+                bboxFilter1, bboxFilter2
+        t.eq(params.bbox, [0, 0, 20, 20],
+             "correct bbox param if passed multiple BBOX filter in a Logical filter");
+        // 2 tests
+        filter = new OpenLayers.Filter.Comparison({
+            type: OpenLayers.Filter.Comparison.EQUAL_TO,
+            property: "foo",
+            value: "bar"
+        t.eq(params.queryable[0], "foo",
+             "correct queryable param if passed an EQUAL_TO filter");
+        t.eq(params["foo__eq"], "bar",
+             "correct param key and value if passed an EQUAL_TO filter");
+        // 2 tests
+            type: OpenLayers.Filter.Comparison.NOT_EQUAL_TO,
+            property: "foo",
+            value: "bar"
+             "correct queryable param if passed an NOT_EQUAL_TO filter");
+        t.eq(params["foo__ne"], "bar",
+             "correct param key and value if passed an NOT_EQUAL_TO filter");
+        // 2 tests
+            type: OpenLayers.Filter.Comparison.LESS_THAN,
+            property: "foo",
+            value: "bar"
+        var params = format.write(filter);
+             "correct queryable param if passed an LESS_THAN filter");
+        t.eq(params["foo__lt"], "bar",
+             "correct param key and value if passed an LESS_THAN filter");
+        // 2 tests
+            type: OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO,
+            property: "foo",
+            value: "bar"
+             "correct queryable param if passed an LESS_THAN_OR_EQUAL_TO filter");
+        t.eq(params["foo__lte"], "bar",
+             "correct param key and value if passed an LESS_THAN_OR_EQUAL_TO filter");
+        // 2 tests
+            type: OpenLayers.Filter.Comparison.GREATER_THAN,
+            property: "foo",
+            value: "bar"
+             "correct queryable param if passed an GREATER_THAN filter");
+        t.eq(params["foo__gt"], "bar",
+             "correct param key and value if passed an GREATER_THAN filter");
+        // 2 tests
+            type: OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO,
+            property: "foo",
+            value: "bar"
+             "correct queryable param if passed an GREATER_THAN_OR_EQUAL_TO filter");
+        t.eq(params["foo__gte"], "bar",
+             "correct param key and value if passed an GREATER_THAN_OR_EQUAL_TO filter");
+        // 2 tests
+            property: "foo",
+            value: "bar"
+             "correct queryable param if passed a LIKE filter");
+        t.eq(params["foo__ilike"], "bar",
+             "correct param key and value if passed an LIKE filter");
+        // 4 tests
+            filters: [
+                    property: "foo",
+                    value: "bar"
+                    property: "foo2",
+                    value: "baz"
+             "correct queryable param if passed an EQUAL_TO filter within a AND filter");
+             "correct param key and value if passed an EQUAL_TO filter within a AND filter");
+        t.eq(params.queryable[1], "foo2",
+             "correct queryable param if passed a LESS_THAN filter within a AND filter");
+        t.eq(params["foo2__lt"], "baz",
+             "correct param key and value if passed a LESS_THAN filter within a AND filter");
+        // 2 tests
+        format = new OpenLayers.Format.QueryStringFilter({wildcarded: true});
+            property: "foo",
+            value: "bar"
+             "correct queryable param if passed a LIKE filter (wildcarded true)");
+        t.eq(params["foo__ilike"], "%bar%",
+             "correct param key and value if passed an LIKE filter (wildcarded true)");
+    function test_regex2value(t) {
+        t.plan(16);
+        // setup
+        var format = new OpenLayers.Format.QueryStringFilter();
+        var value;
+        var filter = new OpenLayers.Filter.Comparison({
+            property: "prop"
+        function serialize(value) {
+            filter.value = value;
+            return format.write(filter).prop__ilike;
+        // test
+        value = serialize("foo");
+        t.eq(value, "foo", 'regex2value converts "foo" to "foo"');
+        value = serialize("foo%");
+        t.eq(value, "foo\\%", 'regex2value converts "foo%" to "foo\\%"');
+        value = serialize("foo.*");
+        t.eq(value, "foo%", 'regex2value converts "foo.*" to "foo%"');
+        value = serialize("f.*oo.*");
+        t.eq(value, "f%oo%", 'regex2value converts "f.*oo.*" to "f%oo%"');
+        value = serialize("foo.");
+        t.eq(value, "foo_", 'regex2value converts "foo." to "foo_"');
+        value = serialize("f.oo.");
+        t.eq(value, "f_oo_", 'regex2value converts "f.oo." to "f_oo_"');
+        value = serialize("f.oo.*");
+        t.eq(value, "f_oo%", 'regex2value converts "f.oo.*" to "f_oo%"');
+        value = serialize("foo\\\\");
+        t.eq(value, "foo\\\\", 'regex2value converts "foo\\\\" to "foo\\\\"');
+        value = serialize("foo\\.");
+        t.eq(value, "foo.", 'regex2value converts "foo\\." to "foo."');
+        value = serialize("foo\\\\.");
+        t.eq(value, "foo\\\\_", 'regex2value converts "foo\\\\." to "foo\\\\_"');
+        value = serialize("foo\\*");
+        t.eq(value, "foo*", 'regex2value converts "foo\\*" to "foo*"');
+        value = serialize("foo\\\\*");
+        t.eq(value, "foo\\\\*", 'regex2value converts "foo\\\\*" to "foo\\\\*"');
+        value = serialize("foo\\\\.*");
+        t.eq(value, "foo\\\\%", 'regex2value converts "foo\\\\.*" to "foo\\\\%"');
+        value = serialize("fo\\.o.*");
+        t.eq(value, "fo.o%", 'regex2value converts from "fo\\.o.*" to "fo.o%"');
+        value = serialize("fo.*o\\.");
+        t.eq(value, "fo%o.", 'regex2value converts from "fo.*o\\." to "to%o."');
+        value = serialize("\\*\\..*.\\\\.*\\\\.%");
+        t.eq(value, "*.%_\\\\%\\\\_\\%",
+             'regex2value converts from "\\*\\..*.\\\\.*\\\\.%" ' +
+             'to "*.%_\\\\%\\\\_\\%"');
+  </script>
+</head>
+<body>
+</body>
+</html>
Added: sandbox/cmoullet/openlayers/tests/Format/XLS/v1_1_0.html
--- sandbox/cmoullet/openlayers/tests/Format/XLS/v1_1_0.html	                        (rev 0)
+++ sandbox/cmoullet/openlayers/tests/Format/XLS/v1_1_0.html	2011-03-30 03:18:10 UTC (rev 11763)
@@ -0,0 +1,98 @@
+<html>
+<head>
+    <script src="../../../lib/OpenLayers.js"></script>
+    function test_read(t) {
+        t.plan(16);
+        var response = '<xls:GeocodeResponse xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/xls http://schemas.opengis.net/ols/1.1.0/LocationUtilityService.xsd" xmlns:xls="http://www.opengis.net/xls" xmlns:gml="http://www.opengis.net/gml"><xls:GeocodeResponseList numberOfGeocodedAddresses="1"><xls:GeocodedAddress><gml:Point srsName="EPSG:28992"><gml:pos dimension="2">122650 483904</gml:pos></gml:Point><xls:Address countryCode="NL"><xls:StreetAddress><xls:Building number="1"/><xls:Street>president kennedylaan</xls:Street></xls:StreetAddress><xls:Place type="MunicipalitySubdivision">amsterdam</xls:Place><xls:Place type="Municipality">amsterdam</xls:Place><xls:Place type="CountrySubdivision">noord holland</xls:Place><xls:PostalCode>1079MB</xls:PostalCode></xls:Address></xls:GeocodedAddress></xls:GeocodeResponseList></xls:GeocodeResponse>';
+        var output = format.read(response);
+        t.eq(output.responseLists.length, 1, "Output contains 1 responseList");
+        var responseList = output.responseLists[0];
+        t.eq(responseList.numberOfGeocodedAddresses, 1, "Responselist contains 1 geocoded address");
+        t.eq(responseList.features.length, 1, "1 feature parsed");
+        var feature = responseList.features[0];
+        var address = feature.attributes.address;
+        t.eq(address.building["number"], "1", "Building number correctly parsed");
+        t.eq(address.countryCode, "NL", "Country code correctly parsed");
+        t.eq(address.place.CountrySubdivision, "noord holland", "CountrySubDivision correctly parsed");
+        t.eq(address.place.Municipality, "amsterdam", "Municipality correctly parsed");
+        t.eq(address.place.MunicipalitySubdivision, "amsterdam", "MunicipalitySubdivision correctly parsed");
+        t.eq(address.postalCode, "1079MB", "Postalcode correctly parsed");
+        t.eq(address.street[0], "president kennedylaan", "Street correctly parsed");
+        t.eq(feature.geometry.x, 122650, "Geometry [x] correctly parsed");
+        t.eq(feature.geometry.y, 483904, "Geometry [y] correctly parsed");
+        var responseList = [];
+        responseList.push('<?xml version="1.0" encoding="UTF-8" ?>',
+'<XLS xmlns="http://www.opengis.net/xls" xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/xls LocationUtilityService.xsd" version="1.1">',
+'	<ResponseHeader/>',
+'	<Response version="1.1" requestID="">',
+'		<GeocodeResponse>',
+'			<GeocodeResponseList numberOfGeocodedAddresses="2">',
+'				<GeocodedAddress>',
+'					<gml:Point>',
+'						<gml:pos>-71.4589837781615 41.8317239069808</gml:pos>',
+'					</gml:Point>',
+'					<Address countryCode="">',
+'						<StreetAddress>',
+'							<Street></Street>',
+'							<Street/>',
+'						</StreetAddress>',
+'						<Place type="Municipality"></Place>',
+'						<Place type="CountrySubdivision"></Place>',
+'						<PostalCode></PostalCode>',
+'					</Address>',
+'					<GeocodeMatchCode accuracy="100.0"/>',
+'				</GeocodedAddress>',
+'					<gml:Point>',
+'						<gml:pos>-71.4087296631643 41.8269575002255</gml:pos>',
+'					</gml:Point>',
+'							<Street/>',
+'					</Address>',
+'			</GeocodeResponseList>',
+'		</GeocodeResponse>',
+'	</Response>',
+'</XLS>');
+        response = responseList.join("");
+        output = format.read(response);
+        t.eq(output.version, "1.1", "Version correctly parsed");
+        t.eq(responseList.numberOfGeocodedAddresses, 2, "2 addresses parsed");
+        t.eq(responseList.features.length, 2, "2 features parsed");
+        t.eq(responseList.features[0].attributes.matchCode.accuracy, 100.0, "Accuracy correctly parsed");
+        t.plan(1);
+        var format = new OpenLayers.Format.XLS();
+        var address = {
+            countryCode: 'US',
+            street: '1 Freedom Rd',
+            municipality: 'Providence',
+            countrySubdivision: 'RI',
+            postalCode: '02909'
+        var request = format.write({addresses: [address]});
+        var expected = '<xls:XLS xmlns:xls="http://www.opengis.net/xls" version="1.1" xsi:schemaLocation="http://www.opengis.net/xls http://schemas.opengis.net/ols/1.1.0/LocationUtilityService.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><xls:RequestHeader/><xls:Request methodName="GeocodeRequest" requestID="" version="1.1"><xls:GeocodeRequest><xls:Address countryCode="US"><xls:StreetAddress><xls:Street>1 Freedom Rd</xls:Street></xls:StreetAddress><xls:Place type="Municipality">Providence</xls:Place><xls:Place type="CountrySubdivision">RI</xls:Place><xls:PostalCode>02909</xls:PostalCode></xls:Address></xls:GeocodeRequest></xls:Request></xls:XLS>';
+        t.xml_eq(request, expected, "XLS geocode request correctly written");
+    </script>
+</head>
+<body>
+</body>
+</html>
Modified: sandbox/cmoullet/openlayers/tests/Handler/Box.html
--- sandbox/cmoullet/openlayers/tests/Handler/Box.html	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/tests/Handler/Box.html	2011-03-30 03:18:10 UTC (rev 11763)
@@ -2,6 +2,64 @@
 <head>
   <script src="../OLLoader.js"></script>
   <script type="text/javascript">
+    function test_Handler_Box_constructor(t) {
+        t.plan(4);
+        var control = new OpenLayers.Control();
+        control.id = Math.random();
+        var callbacks = {done: "bar"};
+        var options = {bar: "foo"};
+        var handler = new OpenLayers.Handler.Box(control, callbacks, options);
+        t.eq(handler.control.id, control.id, "handler created with the correct control");
+        t.eq(handler.callbacks.done, "bar", "handler created with the correct callback");
+        t.eq(handler.bar, "foo", "handler created with the correct options");
+        t.ok(handler.dragHandler instanceof OpenLayers.Handler.Drag, "drag handler created");
+    function test_Handler_Box_draw(t) {
+        var testAll = true;
+        if (document.defaultView && document.defaultView.getComputedStyle &&
+                    !document.defaultView.getComputedStyle(document.body)) {
+            // we don't get dimensions for hidden frames in FF4, and our test
+            // runs in a hidden frame.
+            testAll = false;
+        t.plan(testAll ? 12 : 2);
+        var map = new OpenLayers.Map('map');
+        map.addControl(control);
+        var handler = new OpenLayers.Handler.Box(control, {done: function(e) {
+            t.ok(e.equals(new OpenLayers.Bounds(5, 11, 11, 5)), "box result correct");
+        handler.activate();
+        handler.dragHandler.start = {x: 5, y: 5};
+        handler.startBox({x: 5, y: 5});
+        var offset = handler.getBoxOffsets();
+        if (testAll) {
+            t.eq(parseInt(handler.zoomBox.style.left), 5 - offset.left, "x position of box correct");
+            t.eq(parseInt(handler.zoomBox.style.top), 5 - offset.top, "y position of box correct");
+        handler.moveBox({x: 10, y: 10});
+        if (testAll) {
+            t.eq(parseInt(handler.zoomBox.style.left), 5 - offset.left, "x position of box still correct");
+            t.eq(parseInt(handler.zoomBox.style.top), 5 - offset.top, "y position of box still correct");
+            t.eq(parseInt(handler.zoomBox.style.width), 5 + offset.width + 1, "x dimension of box correct");
+            t.eq(parseInt(handler.zoomBox.style.height), 5 + offset.height + 1, "y dimension of box correct");
+        handler.moveBox({x: 0, y: 0});
+        if (testAll) {
+            t.eq(parseInt(handler.zoomBox.style.left), 0 - offset.left, "new x position of box correct");
+            t.eq(parseInt(handler.zoomBox.style.top), 0 - offset.top, "new y position of box correct");
+            t.eq(parseInt(handler.zoomBox.style.width), 5 + offset.width + 1, "x dimension of box still correct");
+            t.eq(parseInt(handler.zoomBox.style.height), 5 + offset.height + 1, "y dimension of box still correct");
+        handler.endBox({x: 11, y: 11});
+        t.eq(handler.zoomBox, null, "box removed after endBox");
     function test_Handler_Box_destroy(t) {
         t.plan(1);
@@ -21,6 +79,6 @@
   </script>
 </head>
 <body>
-    <div id="map" style="width: 300px; height: 150px;"/>
+    <div id="map" style="width: 300px; height: 150px;"></div>
 </body>
 </html>
Modified: sandbox/cmoullet/openlayers/tests/Handler/Path.html
--- sandbox/cmoullet/openlayers/tests/Handler/Path.html	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/tests/Handler/Path.html	2011-03-30 03:18:10 UTC (rev 11763)
@@ -67,7 +67,7 @@
              "activate adds the line feature to the layer");
         t.eq(log.length, 1,
              "activate calls \"create\" once");
-        t.geom_eq(log[0].geometry, handler.point.geometry,
+        t.ok(log[0].geometry == handler.point.geometry,
                   "\"create\" called with expected geometry");
         t.ok(log[0].feature == handler.line,
              "\"create\" called with expected feature");
@@ -78,6 +78,32 @@
         map.destroy();
+    // See: http://trac.osgeo.org/openlayers/ticket/3179
+    function test_activate_before_map_is_centered(t) {
+        t.plan(1);
+        var map = new OpenLayers.Map('map', {
+            resolutions: [1]
+        var layer = new OpenLayers.Layer.Vector("foo", {
+            maxExtent: new OpenLayers.Bounds(-10, -10, 10, 10),
+            isBaseLayer: true
+        map.addLayer(layer);
+        var handler = new OpenLayers.Handler.Path(control, {});
+        control.handler = handler;
+        var error;
+        try {
+            error = false;
+        } catch(err) {
+            error = true;
+        t.ok(!error, "no error on activate");
     function test_bounds(t) {
         t.plan(2);
         var geometry;
@@ -159,8 +185,8 @@
         t.eq(logs.length, 1, "[activate] called back");
         log = logs.shift();
         t.eq(log.type, "create", "[activate] create called");
-        t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-200, 125),
-                  "[activate] correct point");
+        t.ok(isNaN(log.args[0].x) && isNaN(log.args[0].y),
+                  "[activate] initial point");
         t.ok(log.args[1] == handler.line,
              "[activate] correct feature");
         // mouse move
@@ -260,8 +286,8 @@
         log = logs.shift();
         t.eq(log.type, "create", "[dblclick] create called");
-                  "[dblclick] correct point");
+                  "[dblclick] initial point");
              "[dblclick] correct feature");
         // cancel
@@ -269,16 +295,13 @@
         t.eq(logs.length, 2, "[cancel] called back");
         log = logs.shift();
         t.eq(log.type, "cancel", "[cancel] canced called");
-            new OpenLayers.Geometry.LineString([
-                new OpenLayers.Geometry.Point(-200, 125)
-            "[cancel] correct linestring"
+        t.ok(isNaN(log.args[0].components[0].x) && isNaN(log.args[0].components[0].y),
+            "[cancel] initial linestring"
         log = logs.shift();
         t.eq(log.type, "create", "[cancel] create called");
-                  "[cancel] correct point");
+                  "[cancel] initial point");
         map.destroy();
@@ -749,95 +772,180 @@
             ]), "geometry is correct after mousemove");
-    function test_sequence_touch_1(t) {
-        t.plan(19);
-        log = [];
-        var map = new OpenLayers.Map("map", { // 300 x 150
+    // a) tap
+    // b) tap
+    // c) doubletap
+    function test_touch_sequence1(t) {
+        t.plan(17);
+        // set up
+        var log;
+        var map = new OpenLayers.Map("map", {
             resolutions: [1]
-            maxExtent: new OpenLayers.Bounds(-100, -100, 100, 100),
             isBaseLayer: true
         var control = new OpenLayers.Control({});
-            "done": function(g, f) {
-                log.push({geometry: g, feature: f});
+            done: function(g, f) {
+                log = {type: 'done', geometry: g, feature: f};
+            modify: function(g, f) {
+                log = {type: 'modify', geometry: g, feature: f};
+            dblclickTolerance: 2
-        map.setCenter(new OpenLayers.LonLat(0, 0), 5);
+        map.setCenter(new OpenLayers.LonLat(0, 0), 0);
         handler.activate();
-        handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(49, 75)});
-        t.eq(log.length, 0, "touch start 1");
+        // test
-        handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(50, 75)});
-        t.eq(log.length, 0, "touch move");
+        var ret;
-        handler.touchend({type: "touchend"});
-        t.eq(log.length, 0, "touch end");
-        t.geom_eq(handler.line.geometry,
+        // tap on (1, 0)
+        log = null;
+        ret = handler.touchstart({xy: new OpenLayers.Pixel(0, 0)});
+        t.ok(ret, '[touchstart] event propagates');
+        t.eq(log, null, '[touchstart] feature not finalized or modified');
+        ret = handler.touchmove({xy: new OpenLayers.Pixel(1, 0)});
+        t.ok(ret, '[touchmove] event propagates');
+        t.eq(log, null, '[touchmove] feature not finalized or modified');
+        ret = handler.touchend({});
+        t.ok(ret, '[touchend] event propagates');
+        t.eq(log.type, 'modify', '[touchend] feature modified');
+        t.geom_eq(log.geometry, new OpenLayers.Geometry.Point(-149, 75),
+                  "[touchend] correct point");
+        // tap on (10, 10)
+        log = null;
+        ret = handler.touchstart({xy: new OpenLayers.Pixel(9, 10)});
+        ret = handler.touchmove({xy: new OpenLayers.Pixel(10, 10)});
+        t.geom_eq(log.geometry, new OpenLayers.Geometry.Point(-140, 65),
+        // tap on (11, 10) -> doubletap
+        log = null;
+        ret = handler.touchstart({xy: new OpenLayers.Pixel(11, 10)});
+        t.ok(!ret, '[touchstart] event does not propagate');
+        t.eq(log.type, 'done', '[touchend] feature finalized');
-                new OpenLayers.Geometry.Point(-100, 0),
-            ]), "geometry is correct");
+                new OpenLayers.Geometry.Point(-149, 75),  // (1, 0)
+                new OpenLayers.Geometry.Point(-140, 65)   // (10, 10)
+            ]), "[touchstart] final geometry is correct");
-        handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(100, 75)});
-        t.eq(log.length, 0, "touch start 2");
+        // tear down
-        handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(250, 75)});
+        map.destroy();
-        t.eq(log.length, 0, "touch start 3");
+    // a) tap
+    // b) tap-move
+    // c) tap
+    // d) doubletap
+    function test_touch_sequence2(t) {
+        t.plan(23);
-        handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(100, 75)});
+        // set up
-                new OpenLayers.Geometry.Point(-50, 0),
-        handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(252, 100)});
-        t.eq(log.length, 0, "touch start 4");
+        var log;
+            resolutions: [1]
+            isBaseLayer: true
+        var control = new OpenLayers.Control({});
-        handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(252, 100)});
+        // test
-        handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(250, 100)});
-        t.eq(log.length, 1, "touch start");
+        var ret;
-        handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(250, 100)});
-        t.eq(log.length, 1, "touch move");
+        // tap on (1, 0)
+        log = null;
-        t.eq(log.length, 1, "touch end");
+        // tap-move
+        log = null;
+        ret = handler.touchmove({xy: new OpenLayers.Pixel(20, 20)});
+        t.eq(log, null, '[touchend] feature not finalized or modified');
+        log = null;
+        log = null;
-                new OpenLayers.Geometry.Point(102, -25)
+        // tear down
+        map.destroy();
   </script>
Modified: sandbox/cmoullet/openlayers/tests/Handler/Point.html
--- sandbox/cmoullet/openlayers/tests/Handler/Point.html	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/tests/Handler/Point.html	2011-03-30 03:18:10 UTC (rev 11763)
@@ -416,50 +416,121 @@
         t.eq(handler.point, null,
              "handler.point is null after destroy");
-        t.plan(7);
-        log = [];
+    // Sequence tests
+    // Sequence tests basically involve executing a sequence of events
+    // and testing the resulting geometry.
+    // Below are tests for various drawing sequences. Tests can be
+    // added here each a non-working sequence is found.
+    // tap
+        t.plan(8);
+        // set up
+        var log;
             resolutions: [1]
             isBaseLayer: true
-        var control = new OpenLayers.Control();
         var handler = new OpenLayers.Handler.Point(control, {
+                log = {geometry: g, feature: f};
         handler.activate();
-        handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(50, 75)});
-        handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(99, 75)});
+        // test
+        var ret;
-        t.geom_eq(log[0].geometry, new OpenLayers.Geometry.Point(-50, 0), "geometry is correct");
+        // tap on (1, 0)
+        log = null;
+        t.eq(log, null, '[touchstart] no finalization');
+        t.ok(isNaN(handler.point.geometry.x) && isNaN(handler.point.geometry.y),
+             '[touchstart] feature not modified');
+        t.eq(log, null, '[touchmove] no finalization');
+             '[touchmove] feature not modified');
+        // tear down
+        map.destroy();
+    // tap-move
+        t.plan(9);
+        // set up
+        var log;
+            resolutions: [1]
+            isBaseLayer: true
+        var handler = new OpenLayers.Handler.Point(control, {
+        // test
+        var ret;
+        // tap-move (0, 0) -> (9, 0)
+        log = null;
+        ret = handler.touchmove({xy: new OpenLayers.Pixel(9, 0)});
+        t.eq(log, null, '[touchend] no finalization');
+             '[touchend] feature not modified');
+        // tear down
+        map.destroy();
   </script>
 </head>
 <body>
Modified: sandbox/cmoullet/openlayers/tests/Handler/Polygon.html
--- sandbox/cmoullet/openlayers/tests/Handler/Polygon.html	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/tests/Handler/Polygon.html	2011-03-30 03:18:10 UTC (rev 11763)
@@ -69,7 +69,7 @@
              "activate adds the polygin feature to the layer");
         t.eq(log.length, 1,
         t.ok(log[0].feature == handler.polygon,
@@ -80,6 +80,32 @@
         map.destroy();
+        t.plan(1);
+            resolutions: [1]
+            isBaseLayer: true
+        var handler = new OpenLayers.Handler.Polygon(control, {});
+        var error;
+        try {
+            error = false;
+        } catch(err) {
+            error = true;
     function test_bounds_stopDown_true(t) {
         t.plan(2);
@@ -157,8 +183,8 @@
         log = logs.shift();
         t.ok(log.args[1] == handler.polygon,
         handler.mousemove(
@@ -279,8 +305,8 @@
         log = logs.shift();
         // cancel
@@ -290,8 +316,8 @@
         log = logs.shift();
         map.destroy();
Deleted: sandbox/cmoullet/openlayers/tests/Protocol/SimpleFilterSerializer.html
--- sandbox/cmoullet/openlayers/tests/Protocol/SimpleFilterSerializer.html	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/tests/Protocol/SimpleFilterSerializer.html	2011-03-30 03:18:10 UTC (rev 11763)
@@ -1,310 +0,0 @@
-<html>
-<head>
-  <script src="../../lib/OpenLayers.js"></script>
-  <script type="text/javascript">
-    function test_filterToParams(t) {
-        t.plan(30);
-        // setup
-        var protocol, filter, params;
-        protocol = new OpenLayers.Protocol.HTTP({
-            filterToParams: OpenLayers.Protocol.simpleFilterSerializer
-        // 1 test
-        var filter = new OpenLayers.Filter.Spatial({
-            type: OpenLayers.Filter.Spatial.BBOX,
-            value: new OpenLayers.Bounds(0, 1, 2, 3)
-        params = protocol.filterToParams(filter);
-        t.eq(params.bbox, [0, 1, 2, 3],
-             "filterToParams sets correct bbox param if passed a BBOX filter");
-        // 3 tests
-        var lon = 100, lat = 200, tolerance = 10;
-        filter = new OpenLayers.Filter.Spatial({
-            type: OpenLayers.Filter.Spatial.DWITHIN,
-            value: new OpenLayers.Geometry.Point(lon, lat),
-            distance: tolerance
-        t.eq(params.lon, lon,
-             "filterToParams sets correct lon param if passed a DWITHIN filter");
-        t.eq(params.lat, lat,
-             "filterToParams sets correct lat param if passed a DWITHIN filter");
-        t.eq(params.tolerance, tolerance,
-             "filterToParams sets correct tolerance param if passed a DWITHIN filter");
-        // 2 tests
-            type: OpenLayers.Filter.Spatial.WITHIN,
-             "filterToParams sets correct lon param if passed a WITHIN filter");
-             "filterToParams sets correct lat param if passed a WITHIN filter");
-        // Some bbox filters used in the next tests.
-        var bboxFilter1 = new OpenLayers.Filter.Spatial({
-            value:  new OpenLayers.Bounds(0, 0, 10, 10)
-        var bboxFilter2 = new OpenLayers.Filter.Spatial({
-            value:  new OpenLayers.Bounds(0, 0, 20, 20)
-        // 1 test
-        filter = new OpenLayers.Filter.Logical({
-            type: OpenLayers.Filter.Logical.AND,
-            filters: []
-        t.eq(params, {},
-             "filterToParams returns empty object if given empty AND Logical filter");
-        // 1 test
-            type: OpenLayers.Filter.Logical.OR,
-            filters: [
-                bboxFilter1
-        t.eq(params, {},
-             "filterToParams does not support OR Logical filter");
-        // 1 test
-            filters: [
-                bboxFilter1
-        t.eq(params.bbox, [0, 0, 10, 10],
-             "filterToParams sets correct bbox param if passed " +
-             "a Logical filter containing a BBOX");
-        // 1 test
-            filters: [
-                bboxFilter1, bboxFilter2
-        t.eq(params.bbox, [0, 0, 20, 20],
-             "multiple BBOX filter in a Logical filter");
-        // 2 tests
-        filter = new OpenLayers.Filter.Comparison({
-            type: OpenLayers.Filter.Comparison.EQUAL_TO,
-            property: "foo",
-            value: "bar"
-        t.eq(params.queryable[0], "foo",
-             "filterToParams sets correct queryable param if passed an EQUAL_TO filter");
-        t.eq(params["foo__eq"], "bar",
-             "filterToParams sets correct param key and value if passed an EQUAL_TO filter");
-        // 2 tests
-            type: OpenLayers.Filter.Comparison.NOT_EQUAL_TO,
-            property: "foo",
-            value: "bar"
-             "filterToParams sets correct queryable param if passed an NOT_EQUAL_TO filter");
-        t.eq(params["foo__ne"], "bar",
-             "filterToParams sets correct param key and value if passed an NOT_EQUAL_TO filter");
-        // 2 tests
-            type: OpenLayers.Filter.Comparison.LESS_THAN,
-            property: "foo",
-            value: "bar"
-        var params = protocol.filterToParams(filter);
-             "filterToParams sets correct queryable param if passed an LESS_THAN filter");
-        t.eq(params["foo__lt"], "bar",
-             "filterToParams sets correct param key and value if passed an LESS_THAN filter");
-        // 2 tests
-            type: OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO,
-            property: "foo",
-            value: "bar"
-             "filterToParams sets correct queryable param if passed an LESS_THAN_OR_EQUAL_TO filter");
-        t.eq(params["foo__lte"], "bar",
-             "filterToParams sets correct param key and value if passed an LESS_THAN_OR_EQUAL_TO filter");
-        // 2 tests
-            type: OpenLayers.Filter.Comparison.GREATER_THAN,
-            property: "foo",
-            value: "bar"
-             "filterToParams sets correct queryable param if passed an GREATER_THAN filter");
-        t.eq(params["foo__gt"], "bar",
-             "filterToParams sets correct param key and value if passed an GREATER_THAN filter");
-        // 2 tests
-            type: OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO,
-            property: "foo",
-            value: "bar"
-             "filterToParams sets correct queryable param if passed an GREATER_THAN_OR_EQUAL_TO filter");
-        t.eq(params["foo__gte"], "bar",
-             "filterToParams sets correct param key and value if passed an GREATER_THAN_OR_EQUAL_TO filter");
-        // 2 tests
-            type: OpenLayers.Filter.Comparison.LIKE,
-            property: "foo",
-            value: "bar"
-             "filterToParams sets correct queryable param if passed a LIKE filter");
-        t.eq(params["foo__ilike"], "bar",
-             "filterToParams sets correct param key and value if passed an LIKE filter");
-        // 4 tests
-            filters: [
-                new OpenLayers.Filter.Comparison({
-                    property: "foo",
-                    value: "bar"
-                    property: "foo2",
-                    value: "baz"
-             "filterToParams sets correct queryable param if passed an EQUAL_TO filter within a AND filter");
-             "filterToParams sets correct param key and value if passed an EQUAL_TO filter within a AND filter");
-        t.eq(params.queryable[1], "foo2",
-             "filterToParams sets correct queryable param if passed a LESS_THAN filter within a AND filter");
-        t.eq(params["foo2__lt"], "baz",
-             "filterToParams sets correct param key and value if passed a LESS_THAN filter within a AND filter");
-        // 2 tests
-        protocol = new OpenLayers.Protocol.HTTP({wildcarded: true});
-            property: "foo",
-            value: "bar"
-             "filterToParams sets correct queryable param if passed a LIKE filter (wildcarded true)");
-        t.eq(params["foo__ilike"], "%bar%",
-             "filterToParams sets correct param key and value if passed an LIKE filter (wildcarded true)");
-    function test_regex2value(t) {
-        t.plan(16);
-        // setup
-        var protocol = new OpenLayers.Protocol.HTTP({
-        var value;
-        var filter = new OpenLayers.Filter.Comparison({
-            property: "prop"
-        function serialize(value) {
-            filter.value = value;
-            return protocol.filterToParams(filter).prop__ilike;
-        // test
-        value = serialize("foo");
-        t.eq(value, "foo", 'regex2value converts "foo" to "foo"');
-        value = serialize("foo%");
-        t.eq(value, "foo\\%", 'regex2value converts "foo%" to "foo\\%"');
-        value = serialize("foo.*");
-        t.eq(value, "foo%", 'regex2value converts "foo.*" to "foo%"');
-        value = serialize("f.*oo.*");
-        t.eq(value, "f%oo%", 'regex2value converts "f.*oo.*" to "f%oo%"');
-        value = serialize("foo.");
-        t.eq(value, "foo_", 'regex2value converts "foo." to "foo_"');
-        value = serialize("f.oo.");
-        t.eq(value, "f_oo_", 'regex2value converts "f.oo." to "f_oo_"');
-        value = serialize("f.oo.*");
-        t.eq(value, "f_oo%", 'regex2value converts "f.oo.*" to "f_oo%"');
-        value = serialize("foo\\\\");
-        t.eq(value, "foo\\\\", 'regex2value converts "foo\\\\" to "foo\\\\"');
-        value = serialize("foo\\.");
-        t.eq(value, "foo.", 'regex2value converts "foo\\." to "foo."');
-        value = serialize("foo\\\\.");
-        t.eq(value, "foo\\\\_", 'regex2value converts "foo\\\\." to "foo\\\\_"');
-        value = serialize("foo\\*");
-        t.eq(value, "foo*", 'regex2value converts "foo\\*" to "foo*"');
-        value = serialize("foo\\\\*");
-        t.eq(value, "foo\\\\*", 'regex2value converts "foo\\\\*" to "foo\\\\*"');
-        value = serialize("foo\\\\.*");
-        t.eq(value, "foo\\\\%", 'regex2value converts "foo\\\\.*" to "foo\\\\%"');
-        value = serialize("fo\\.o.*");
-        t.eq(value, "fo.o%", 'regex2value converts from "fo\\.o.*" to "fo.o%"');
-        value = serialize("fo.*o\\.");
-        t.eq(value, "fo%o.", 'regex2value converts from "fo.*o\\." to "to%o."');
-        value = serialize("\\*\\..*.\\\\.*\\\\.%");
-        t.eq(value, "*.%_\\\\%\\\\_\\%",
-             'regex2value converts from "\\*\\..*.\\\\.*\\\\.%" ' +
-             'to "*.%_\\\\%\\\\_\\%"');
-  </script>
-</head>
-<body>
-</body>
-</html>
Modified: sandbox/cmoullet/openlayers/tests/list-tests.html
--- sandbox/cmoullet/openlayers/tests/list-tests.html	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/tests/list-tests.html	2011-03-30 03:18:10 UTC (rev 11763)
@@ -74,6 +74,7 @@
     <li>Format/Filter/v1.html</li>
     <li>Format/Filter/v1_0_0.html</li>
     <li>Format/Filter/v1_1_0.html</li>
+    <li>Format/QueryStringFilter.html</li>
     <li>Format/WFS.html</li>
     <li>Format/WFSCapabilities.html</li>
     <li>Format/WFSCapabilities/v1.html</li>
@@ -102,6 +103,7 @@
     <li>Format/SOSGetObservation.html</li>
     <li>Format/SOSGetFeatureOfInterest.html</li>
     <li>Format/OWSContext/v0_3_1.html</li>
+    <li>Format/XLS/v1_1_0.html</li>
     <li>Format/XML.html</li>
     <li>Geometry.html</li>
     <li>Geometry/Collection.html</li>
@@ -179,7 +181,6 @@
     <li>Protocol.html</li>
     <li>Protocol/HTTP.html</li>
     <li>Protocol/Script.html</li>
-    <li>Protocol/SimpleFilterSerializer.html</li>
     <li>Protocol/SQL.html</li>
     <li>Protocol/SQL/Gears.html</li>
     <li>Protocol/WFS.html</li>
Copied: sandbox/cmoullet/openlayers/tests/manual/box-quirks.html (from rev 11762, trunk/openlayers/tests/manual/box-quirks.html)
--- sandbox/cmoullet/openlayers/tests/manual/box-quirks.html	                        (rev 0)
+++ sandbox/cmoullet/openlayers/tests/manual/box-quirks.html	2011-03-30 03:18:10 UTC (rev 11763)
@@ -0,0 +1,52 @@
+<html xmlns="http://www.w3.org/1999/xhtml">
+  <head>
+    <title>Box Handler Quirks Mode Test</title>
+    <link rel="stylesheet" href="../../theme/default/style.css" type="text/css" />
+    <link rel="stylesheet" href="../../examples/style.css" type="text/css" />
+    <style type="text/css">
+    /* simulate quirks mode (traditional box model) in browsers other than IE */
+    div {
+        box-sizing: border-box;
+        -moz-box-sizing: border-box;
+        -ms-box-sizing: border-box;
+        -webkit-box-sizing: border-box;
+    .olHandlerBoxZoomBox {
+        border: 20px solid red;
+        border-left-width: 10px;
+        border-bottom-width: 30px;
+    </style>
+    <script type="text/javascript">
+        var map, layer;
+        function init(){
+            map = new OpenLayers.Map( 'map' );
+            layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
+                    "http://vmap0.tiles.osgeo.org/wms/vmap0",
+                    {layers: 'basic'} );
+            map.zoomToMaxExtent();
+    </script>
+  </head>
+  <body onload="init()">
+    <h1 id="title">Box handler Quirks Mode Test</h1>
+    <div id="shortdesc">Test the correct appearance of the ZoomBox in quirks mode</div>
+    <div id="map" class="smallmap"></div>
+    <div id="docs">
+        <p>For the box to be positioned correctly, we need to know the
+            width of the borders.</p>
+        <p>Shift-click on the map. A red box should be visible around the mouse
+            cursor position, with 20 pixels to the top and right, 10 pixels to
+            the left and 30 pixels to the bottom edge of the box.</p>
+        <p>Drag the box both to the top-left and the bottom-right. The cursor
+            should always be at the top-left or bottom-right inner corner of
+            the box.</p>
+    </div>
+  </body>
+</html>
Copied: sandbox/cmoullet/openlayers/tests/manual/box-strict.html (from rev 11762, trunk/openlayers/tests/manual/box-strict.html)
--- sandbox/cmoullet/openlayers/tests/manual/box-strict.html	                        (rev 0)
+++ sandbox/cmoullet/openlayers/tests/manual/box-strict.html	2011-03-30 03:18:10 UTC (rev 11763)
@@ -0,0 +1,46 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN"
+    "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+  <head>
+    <title>Box Handler Strict Mode Test</title>
+    </style>
+        var map, layer;
+        function init(){
+    </script>
+  </head>
+    <h1 id="title">Box Handler Strict Mode Test</h1>
+    <div id="shortdesc">Test the correct appearance of the ZoomBox in strict mode</div>
+    <div id="docs">
+            the box.</p>
+    </div>
+  </body>
+</html>
Modified: sandbox/cmoullet/openlayers/theme/default/style.css
--- sandbox/cmoullet/openlayers/theme/default/style.css	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/theme/default/style.css	2011-03-30 03:18:10 UTC (rev 11763)
@@ -1,7 +1,7 @@
 div.olMap {
     z-index: 0;
-    padding: 0px!important;
-    margin: 0px!important;
+    padding: 0 !important;
+    margin: 0 !important;
     cursor: default;
@@ -80,8 +80,8 @@
 .olControlOverviewMapContainer {
     position: absolute;
-    bottom: 0px;
-    right: 0px;
+    bottom: 0;
+    right: 0;
 .olControlOverviewMapElement {
@@ -91,13 +91,13 @@
 .olControlOverviewMapMinimizeButton {
-    right: 0px;
+    right: 0;
     bottom: 80px;
     cursor: pointer;
 .olControlOverviewMapMaximizeButton {
-    right: 0px;
+    right: 0;
     bottom: 80px;
     cursor: pointer;
@@ -146,13 +146,13 @@
 .olControlNavigationHistoryPreviousItemActive {
-  background-position: 0px 0px;
+  background-position: 0 0;
 .olControlNavigationHistoryPreviousItemInactive {
-   background-position: 0px -24px;
+   background-position: 0 -24px;
 .olControlNavigationHistoryNextItemActive {
-   background-position: -24px 0px;
+   background-position: -24px 0;
 .olControlNavigationHistoryNextItemInactive {
    background-position: -24px -24px;
@@ -161,12 +161,12 @@
 div.olControlSaveFeaturesItemActive {
     background-image: url(img/save_features_on.png);
     background-repeat: no-repeat;
-    background-position: 0px 1px;
+    background-position: 0 1px;
 div.olControlSaveFeaturesItemInactive {
     background-image: url(img/save_features_off.png);
@@ -200,20 +200,20 @@
 .olControlPanPanel .olControlPanNorthItemInactive {
-    top: 0px;
+    top: 0;
     left: 9px;
 .olControlPanPanel .olControlPanSouthItemInactive {
     top: 36px;
     left: 9px;
-    background-position: 18px 0px;
+    background-position: 18px 0;
 .olControlPanPanel .olControlPanWestItemInactive {
     position: absolute;
     top: 18px;
-    left: 0px;
-    background-position: 0px 18px;
+    left: 0;
+    background-position: 0 18px;
 .olControlPanPanel .olControlPanEastItemInactive {
     top: 18px;
@@ -235,21 +235,21 @@
 .olControlZoomPanel .olControlZoomInItemInactive {
-    top: 0px;
-    left: 0px;
+    top: 0;
+    left: 0;
 .olControlZoomPanel .olControlZoomToMaxExtentItemInactive {
     top: 18px;
-    left: 0px;
-    background-position: 0px -18px;
+    left: 0;
+    background-position: 0 -18px;
 .olControlZoomPanel .olControlZoomOutItemInactive {
     top: 36px;
-    left: 0px;
+    left: 0;
@@ -307,7 +307,7 @@
 .olControlLayerSwitcher {
     position: absolute;
     top: 25px;
-    right: 0px;
+    right: 0;
     width: 20em;
     font-family: sans-serif;
     font-weight: bold;
@@ -344,7 +344,7 @@
 .olControlLayerSwitcher .maximizeDiv,
 .olControlLayerSwitcher .minimizeDiv {
     top: 5px;
-    right: 0px;
+    right: 0;
     cursor: pointer;
@@ -361,21 +361,21 @@
 .olControlNavToolbar ,
 .olControlEditingToolbar {
-    margin: 5px 5px 0px 0px;
+    margin: 5px 5px 0 0;
 .olControlNavToolbar div,
 .olControlEditingToolbar div {
     background-image: url("img/editing_tool_bar.png");
-    margin: 0px 0px 5px 5px;
+    margin: 0 0 5px 5px;
     width: 24px;
     height: 22px;
     cursor: pointer
 /* positions */
-    right: 0px;
-    top: 0px;
+    right: 0;
+    top: 0;
     width: 200px; /* Only for IE6 or IE without DOCTYPE */
 .olControlNavToolbar {
Modified: sandbox/cmoullet/openlayers/tools/mergejs.py
--- sandbox/cmoullet/openlayers/tools/mergejs.py	2011-03-30 02:33:13 UTC (rev 11762)
+++ sandbox/cmoullet/openlayers/tools/mergejs.py	2011-03-30 03:18:10 UTC (rev 11763)
@@ -43,7 +43,7 @@
 SUFFIX_JAVASCRIPT = ".js"
-RE_REQUIRE = "@requires:? (.*)\n" # TODO: Ensure in comment?
+RE_REQUIRE = "@requires?:? (.*)\n" # TODO: Ensure in comment?
 class MissingImport(Exception):
     """Exception raised when a listed import is not found in the lib."""
More information about the Commits mailing list
