[OpenLayers-Commits] r11774 - in sandbox/tschaub/canvas: . examples lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Mar 30 07:49:28 EDT 2011
Author: fredj
Date: 2011-03-30 04:49:27 -0700 (Wed, 30 Mar 2011)
New Revision: 11774
   sandbox/tschaub/canvas/
   sandbox/tschaub/canvas/examples/mobile-navigation.html
   sandbox/tschaub/canvas/lib/OpenLayers/Handler/Click.js
   sandbox/tschaub/canvas/lib/OpenLayers/Handler/Path.js
   sandbox/tschaub/canvas/lib/OpenLayers/Handler/Point.js
   sandbox/tschaub/canvas/lib/OpenLayers/Handler/RegularPolygon.js
   sandbox/tschaub/canvas/tests/Handler/Click.html
   sandbox/tschaub/canvas/tests/Handler/Path.html
   sandbox/tschaub/canvas/tests/Handler/Polygon.html
Merge r11765:11773 from trunk.
Property changes on: sandbox/tschaub/canvas
___________________________________________________________________
Modified: svn:mergeinfo
   - /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:10737-11416,11422-11762
   + /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:10737-11416,11422-11762,11766-11773
Modified: sandbox/tschaub/canvas/examples/mobile-navigation.html
--- sandbox/tschaub/canvas/examples/mobile-navigation.html	2011-03-30 11:30:07 UTC (rev 11773)
+++ sandbox/tschaub/canvas/examples/mobile-navigation.html	2011-03-30 11:49:27 UTC (rev 11774)
@@ -23,8 +23,8 @@
     <div id="docs">
         <p>
-            This example demonstates what OpenLayers provides for map
-            navigation on mobile.
+            This example demonstrates what OpenLayers provides for map
+            navigation on mobile devices.
         </p>
         <p>
Modified: sandbox/tschaub/canvas/lib/OpenLayers/Handler/Click.js
--- sandbox/tschaub/canvas/lib/OpenLayers/Handler/Click.js	2011-03-30 11:30:07 UTC (rev 11773)
+++ sandbox/tschaub/canvas/lib/OpenLayers/Handler/Click.js	2011-03-30 11:49:27 UTC (rev 11774)
@@ -191,6 +191,7 @@
             evt.xy = this.last.xy;
             evt.lastTouches = this.last.touches;
             this.handleSingle(evt);
+            this.down = null;
         return true;
Modified: sandbox/tschaub/canvas/lib/OpenLayers/Handler/Path.js
--- sandbox/tschaub/canvas/lib/OpenLayers/Handler/Path.js	2011-03-30 11:30:07 UTC (rev 11773)
+++ sandbox/tschaub/canvas/lib/OpenLayers/Handler/Path.js	2011-03-30 11:49:27 UTC (rev 11774)
@@ -45,6 +45,12 @@
     freehandToggle: 'shiftKey',
+     * Property: timerId
+     * {Integer} The timer used to test the double touch.
+    timerId: null,
      * Constructor: OpenLayers.Handler.Path
      * Create a new path hander
@@ -214,6 +220,38 @@
+     * method: touchstart
+     * handle touchstart.
+     * parameters:
+     * evt - {event} the browser event
+     * returns:
+     * {boolean} allow event propagation
+    touchstart: function(evt) {
+        if (this.timerId &&
+            this.passesTolerance(this.lastTouchPx, evt.xy, this.dblclickTolerance)) {
+            // double-tap, finalize the geometry
+            this.lastTouchPx = evt.xy; // for up() to detect dblclick and do nothing
+            this.finishTouchGeometry();
+            window.clearTimeout(this.timerId);
+            this.timerId = null;
+            return false;
+        } else {
+            if (this.timerId) {
+            this.timerId = window.setTimeout(
+                OpenLayers.Function.bind(function() {
+                }, this), 300);
+            return OpenLayers.Handler.Point.prototype.touchstart.call(this, evt);
      * Method: mousedown
      * Handle mouse down.  Add a new point to the geometry and
      * render it. Return determines whether to propagate the event on the map.
@@ -295,7 +333,7 @@
         this.stoppedDown = this.stopDown;
         this.mouseDown = false;
-        return !this.stopUp && !this.isDblclick;
+        return !this.stopUp;
Modified: sandbox/tschaub/canvas/lib/OpenLayers/Handler/Point.js
--- sandbox/tschaub/canvas/lib/OpenLayers/Handler/Point.js	2011-03-30 11:30:07 UTC (rev 11773)
+++ sandbox/tschaub/canvas/lib/OpenLayers/Handler/Point.js	2011-03-30 11:49:27 UTC (rev 11774)
@@ -120,26 +120,13 @@
     touch: false,
-     * Property: timerId
-     * {Integer} The timer used to test the double touch.
-    timerId: null,
-     * Property: last
+     * Property: lastTouchPx
      * {<OpenLayers.Pixel>} The last pixel used to know the distance between
      * two touches (for double touch).
-    last: null,
+    lastTouchPx: null,
-     * Property: dblclick
-     * {Boolean} The current event is a dblclick.
-    isDblclick: false,
      * Constructor: OpenLayers.Handler.Point
      * Create a new point handler.
@@ -281,6 +268,7 @@
         this.lastDown = null;
         this.lastUp = null;
+        this.lastTouchPx = null;
         this.callback(key, [this.geometryClone()]);
         if(cancel || !this.persist) {
             this.destroyFeature();
@@ -415,32 +403,8 @@
         this.touch = true;
-        var last = this.last;
-        this.last = evt.xy;
-        if (this.timerId &&
-            this.passesTolerance(last, evt.xy, this.dblclickTolerance)) {
-            this.isDblclick = true;
-            // a valid touch immediately adds a component and leaves us with a
-            // complete geometry
-            this.finishTouchGeometry();
-            window.clearTimeout(this.timerId);
-            this.timerId = null;
-            return false;
-        else {
-            if (this.timerId) {
-            this.isDblclick = false;
-            this.timerId = window.setTimeout(
-                OpenLayers.Function.bind(function() {
-                }, this), 300);
-            return this.down(evt);
+        return this.down(evt);
@@ -471,7 +435,7 @@
      * {Boolean} Allow event propagation
     touchmove: function(evt) {
         return this.move(evt);
@@ -503,7 +467,7 @@
     touchend: function(evt) {
-        evt.xy = this.last;
+        evt.xy = this.lastTouchPx;
         return this.up(evt);
Modified: sandbox/tschaub/canvas/lib/OpenLayers/Handler/RegularPolygon.js
--- sandbox/tschaub/canvas/lib/OpenLayers/Handler/RegularPolygon.js	2011-03-30 11:30:07 UTC (rev 11773)
+++ sandbox/tschaub/canvas/lib/OpenLayers/Handler/RegularPolygon.js	2011-03-30 11:49:27 UTC (rev 11774)
@@ -303,7 +303,7 @@
      * evt - {Event} The mouse out event
     out: function(evt) {
-        this.finalize();
+        this.cancel();
Modified: sandbox/tschaub/canvas/tests/Handler/Click.html
--- sandbox/tschaub/canvas/tests/Handler/Click.html	2011-03-30 11:30:07 UTC (rev 11773)
+++ sandbox/tschaub/canvas/tests/Handler/Click.html	2011-03-30 11:49:27 UTC (rev 11774)
@@ -489,7 +489,7 @@
     function test_touch_click(t) {
-        t.plan(4);
+        t.plan(5);
         // set up
@@ -511,6 +511,7 @@
         // test
+        // the common case: a touchstart followed by a touchend
         log = null;
         handler.touchstart({xy: px(1, 1), touches: ["foo"]});
         handler.touchend({touches: ["foo"]});
@@ -522,8 +523,19 @@
                 t.eq(log.y, 1, "evt.xy.y as expected");
                 t.ok(log.lastTouches, "evt.lastTouches as expected");
-            // tear down
-            map.destroy();
+            // now emulate a touch where touchstart doesn't propagate
+            // to the click handler, i.e. the click handler gets a
+            // touchend only
+            log = null;
+            handler.touchend({touches: ["foo"]});
+            t.delay_call(1, function() {
+                t.ok(log == null, "click callback not called");
+                // tear down
+                map.destroy();
Modified: sandbox/tschaub/canvas/tests/Handler/Path.html
--- sandbox/tschaub/canvas/tests/Handler/Path.html	2011-03-30 11:30:07 UTC (rev 11773)
+++ sandbox/tschaub/canvas/tests/Handler/Path.html	2011-03-30 11:49:27 UTC (rev 11774)
@@ -774,7 +774,6 @@
     // a) tap
-    // b) tap
     // c) doubletap
     function test_touch_sequence1(t) {
         t.plan(17);
@@ -824,7 +823,7 @@
         t.geom_eq(log.geometry, new OpenLayers.Geometry.Point(-149, 75),
                   "[touchend] correct point");
-        // tap on (10, 10)
+        // doubletap on (10, 10)
         log = null;
         ret = handler.touchstart({xy: new OpenLayers.Pixel(9, 10)});
         t.ok(ret, '[touchstart] event propagates');
@@ -837,8 +836,6 @@
         t.eq(log.type, 'modify', '[touchend] feature modified');
         t.geom_eq(log.geometry, new OpenLayers.Geometry.Point(-140, 65),
-        // tap on (11, 10) -> doubletap
         log = null;
         ret = handler.touchstart({xy: new OpenLayers.Pixel(11, 10)});
         t.ok(!ret, '[touchstart] event does not propagate');
@@ -856,8 +853,7 @@
     // a) tap
     // b) tap-move
-    // c) tap
-    // d) doubletap
+    // c) doubletap
     function test_touch_sequence2(t) {
         t.plan(23);
@@ -918,7 +914,7 @@
         t.ok(ret, '[touchend] event propagates');
         t.eq(log, null, '[touchend] feature not finalized or modified');
         log = null;
@@ -931,8 +927,6 @@
         log = null;
Modified: sandbox/tschaub/canvas/tests/Handler/Polygon.html
--- sandbox/tschaub/canvas/tests/Handler/Polygon.html	2011-03-30 11:30:07 UTC (rev 11773)
+++ sandbox/tschaub/canvas/tests/Handler/Polygon.html	2011-03-30 11:49:27 UTC (rev 11774)
@@ -904,103 +904,209 @@
             ]), "geometry is correct");
+    // a) tap
+    // b) tap
+    // c) doubletap
+    function test_touch_sequence1(t) {
+        t.plan(24);
-    function test_sequence_touch_1(t) {
-        t.plan(19);
-        log = [];
-        var map = new OpenLayers.Map("map", { // 300 x 150
+        // set up
+        var log;
+        var map = new OpenLayers.Map("map", {
             resolutions: [1]
         var layer = new OpenLayers.Layer.Vector("foo", {
-            maxExtent: new OpenLayers.Bounds(-100, -100, 100, 100),
+            maxExtent: new OpenLayers.Bounds(-10, -10, 10, 10),
             isBaseLayer: true
         map.addLayer(layer);
         var control = new OpenLayers.Control({});
         var handler = new OpenLayers.Handler.Polygon(control, {
-            "done": function(g, f) {
-                log.push({geometry: g, feature: f});
+            done: function(g, f) {
+                log = {type: 'done', geometry: g, feature: f};
+            modify: function(g, f) {
+                log = {type: 'modify', geometry: g, feature: f};
+            dblclickTolerance: 2
         control.handler = handler;
-        control.layer = layer;
         map.addControl(control);
-        map.setCenter(new OpenLayers.LonLat(0, 0), 5);
+        map.setCenter(new OpenLayers.LonLat(0, 0), 0);
         handler.activate();
-        handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(49, 75)});
-        t.eq(log.length, 0, "touch start 1");
-        var expectedRing = new OpenLayers.Geometry.LinearRing([
-            new OpenLayers.Geometry.Point(-100, 0),
-        handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(50, 75)});
-        t.eq(log.length, 0, "touch move");
-        handler.touchend({type: "touchend"});
-        t.eq(log.length, 0, "touch end");
-        expectedRing.addComponent(new OpenLayers.Geometry.Point(-100,0), 1);
+        // test
-        t.geom_eq(handler.polygon.geometry.components[0], expectedRing, "geometry is correct");
+        var ret;
-        handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(100, 75)});
-        t.eq(log.length, 0, "touch start 2");
+        // tap on (0, 0)
+        log = null;
+        ret = handler.touchstart({xy: new OpenLayers.Pixel(1, 0)});
+        t.ok(ret, '[touchstart] event propagates');
+        t.eq(log, null, '[touchstart] feature not finalized or modified');
+        ret = handler.touchmove({xy: new OpenLayers.Pixel(0, 0)});
+        t.ok(ret, '[touchmove] event propagates');
+        t.eq(log, null, '[touchmove] feature not finalized or modified');
+        ret = handler.touchend({});
+        t.ok(ret, '[touchend] event propagates');
+        t.eq(log.type, 'modify', '[touchend] feature modified');
+        t.geom_eq(log.geometry, new OpenLayers.Geometry.Point(-150, 75),
+                  "[touchend] correct point");
-        handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(250, 75)});
+        // tap on (0, 10)
+        log = null;
+        ret = handler.touchstart({xy: new OpenLayers.Pixel(1, 10)});
+        ret = handler.touchmove({xy: new OpenLayers.Pixel(0, 10)});
+        t.geom_eq(log.geometry, new OpenLayers.Geometry.Point(-150, 65),
-        t.eq(log.length, 0, "touch start 3");
+        log = null;
+        ret = handler.touchstart({xy: new OpenLayers.Pixel(9, 10)});
+        ret = handler.touchmove({xy: new OpenLayers.Pixel(10, 10)});
+        t.geom_eq(log.geometry, new OpenLayers.Geometry.Point(-140, 65),
+        log = null;
+        ret = handler.touchstart({xy: new OpenLayers.Pixel(11, 10)});
+        t.ok(!ret, '[touchstart] event does not propagate');
+        t.eq(log.type, 'done', '[touchend] feature finalized');
+            new OpenLayers.Geometry.Polygon([
+                new OpenLayers.Geometry.LinearRing([
+                    new OpenLayers.Geometry.Point(-150, 75), // (0, 0)
+                    new OpenLayers.Geometry.Point(-150, 65), // (0, 10)
+                    new OpenLayers.Geometry.Point(-140, 65)  // (10, 10)
+            ]), "[touchstart] geometry is correct");
-        handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(100, 75)});
+        // tear down
-        t.geom_eq(handler.polygon.geometry,
-            new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([
-                new OpenLayers.Geometry.Point(-50, 0),
-            ])]), "geometry is correct");
-        handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(252, 100)});
-        t.eq(log.length, 0, "touch start 4");
+        map.destroy();
-        handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(252, 100)});
+    // a) tap
+    // b) tap-move
+    // c) tap
+    // d) doubletap
+    function test_touch_sequence2(t) {
+        t.plan(30);
-        handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(250, 100)});
-        t.eq(log.length, 1, "touch start");
+        // set up
-        handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(250, 100)});
-        t.eq(log.length, 1, "touch move");
+        var log;
+            resolutions: [1]
+        var layer = new OpenLayers.Layer.Vector("foo", {
+            isBaseLayer: true
+        map.addLayer(layer);
+        var control = new OpenLayers.Control({});
+        var handler = new OpenLayers.Handler.Polygon(control, {
+        control.handler = handler;
+        map.addControl(control);
+        handler.activate();
-        t.eq(log.length, 1, "touch end");
-        t.geom_eq(log[0].geometry,
-                new OpenLayers.Geometry.Point(102, -25),
+        // test
+        var ret;
+        // tap on (0, 0)
+        log = null;
+        // tap-move
+        log = null;
+        ret = handler.touchmove({xy: new OpenLayers.Pixel(20, 20)});
+        t.eq(log, null, '[touchend] feature not finalized or modified');
+        // tap on (0, 10)
+        log = null;
+        log = null;
+        log = null;
+        // tear down
+        map.destroy();
   </script>
More information about the Commits mailing list
