[OpenLayers-Commits] r11779 - in trunk/openlayers: lib/OpenLayers/Format/WFST lib/OpenLayers/Protocol/WFS tests/Format/WFST
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Mar 30 08:47:46 EDT 2011
Author: bartvde
Date: 2011-03-30 05:47:42 -0700 (Wed, 30 Mar 2011)
New Revision: 11779
   trunk/openlayers/lib/OpenLayers/Format/WFST/v1_1_0.js
   trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js
   trunk/openlayers/tests/Format/WFST/v1_1_0.html
make use of WFS paging backported to WFS 1.1, thanks ahocevar for the improved patch, r=ahocevar (closes #3213)
Modified: trunk/openlayers/lib/OpenLayers/Format/WFST/v1_1_0.js
--- trunk/openlayers/lib/OpenLayers/Format/WFST/v1_1_0.js	2011-03-30 12:40:58 UTC (rev 11778)
+++ trunk/openlayers/lib/OpenLayers/Format/WFST/v1_1_0.js	2011-03-30 12:47:42 UTC (rev 11779)
@@ -109,8 +109,10 @@
         "wfs": OpenLayers.Util.applyDefaults({
             "GetFeature": function(options) {
                 var node = OpenLayers.Format.WFST.v1.prototype.writers["wfs"]["GetFeature"].apply(this, arguments);
-                options && options.resultType && this.setAttributes(node, {
-                    resultType: options.resultType
+                options && this.setAttributes(node, {
+                    resultType: options.resultType,
+                    startIndex: options.startIndex,
+                    count: options.count
                 return node;
Modified: trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js
--- trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js	2011-03-30 12:40:58 UTC (rev 11778)
+++ trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js	2011-03-30 12:47:42 UTC (rev 11779)
@@ -167,6 +167,16 @@
      * (end)
+     * To use a configured protocol to use WFS paging (if supported by the
+     * server), applications could do the following:
+     * (code)
+     * protocol.read({
+     *     startIndex: 0,
+     *     count: 50
+     * (end)
      * To limit the attributes returned by the GetFeature request, applications
      * can use the propertyNames option to specify the properties to include in
      * the response:
Modified: trunk/openlayers/tests/Format/WFST/v1_1_0.html
--- trunk/openlayers/tests/Format/WFST/v1_1_0.html	2011-03-30 12:40:58 UTC (rev 11778)
+++ trunk/openlayers/tests/Format/WFST/v1_1_0.html	2011-03-30 12:47:42 UTC (rev 11779)
@@ -75,6 +75,13 @@
                 resultType: "hits",
                 propertyNames: ["STATE_NAME", "STATE_FIPS", "STATE_ABBR"]
+            id: "getfeature1",
+            writer: "wfs:GetFeature",
+            arg: {
+                count: 10,
+                startIndex: 20
         t.plan(cases.length);
@@ -150,6 +157,16 @@
     </wfs:Query>
 </wfs:GetFeature>
 --></div>
+<div id="getfeature1"><!--
+<wfs:GetFeature service="WFS" version="1.1.0" startIndex="20" count="10" xmlns:topp="http://www.openplans.org/topp"
+                xmlns:wfs="http://www.opengis.net/wfs"
+                xmlns:ogc="http://www.opengis.net/ogc"
+                xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
+                xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
+    <wfs:Query xmlns:wfs="http://www.opengis.net/wfs" typeName="topp:states" srsName="urn:ogc:def:crs:EPSG::4326" xmlns:topp="http://www.openplans.org/topp">
+    </wfs:Query>
+</wfs:GetFeature>
+--></div>
 <div id="boundedBy"><!--
 <?xml version='1.0' encoding="ISO-8859-1" ?>
 <wfs:FeatureCollection
More information about the Commits mailing list
