[OpenLayers-Commits] r11781 - in trunk/openlayers: examples lib lib/OpenLayers/Format lib/OpenLayers/Format/XLS tests tests/Format tests/Format/XLS
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Mar 30 09:27:35 EDT 2011
Author: bartvde
Date: 2011-03-30 06:27:30 -0700 (Wed, 30 Mar 2011)
New Revision: 11781
Added:
   trunk/openlayers/examples/openls.html
   trunk/openlayers/lib/OpenLayers/Format/XLS.js
   trunk/openlayers/lib/OpenLayers/Format/XLS/
   trunk/openlayers/lib/OpenLayers/Format/XLS/v1.js
   trunk/openlayers/lib/OpenLayers/Format/XLS/v1_1_0.js
   trunk/openlayers/tests/Format/XLS/
   trunk/openlayers/tests/Format/XLS/v1_1_0.html
   trunk/openlayers/examples/proxy.cgi
   trunk/openlayers/lib/OpenLayers.js
   trunk/openlayers/tests/list-tests.html
add support for OpenLS (Location Utility Service), thanks cmoullet for the great example, p=me,r=cmoullet,erilem,fredj (closes #2953)
Added: trunk/openlayers/examples/openls.html
--- trunk/openlayers/examples/openls.html	                        (rev 0)
+++ trunk/openlayers/examples/openls.html	2011-03-30 13:27:30 UTC (rev 11781)
@@ -0,0 +1,86 @@
+<html xmlns="http://www.w3.org/1999/xhtml">
+<head>
+    <meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;"/>
+    <meta name="apple-mobile-web-app-capable" content="yes"/>
+    <link rel="stylesheet" href="../theme/default/style.css" type="text/css"/>
+    <link rel="stylesheet" href="style.css" type="text/css"/>
+    <title>OpenLS: Geocoding Example</title>
+    <script type="text/javascript" src="../lib/OpenLayers.js"></script>
+    <script type="text/javascript">
+        var map, layer;
+        function init() {
+            OpenLayers.ProxyHost = "proxy.cgi?url=";
+            map = new OpenLayers.Map('map', {
+                controls: [
+                    new OpenLayers.Control.PanZoom(),
+                    new OpenLayers.Control.Permalink(),
+                    new OpenLayers.Control.Navigation()
+            layer = new OpenLayers.Layer.OSM("OpenStreetMap", null, {
+                transitionEffect: 'resize'
+            map.addLayers([layer]);
+            map.zoomToMaxExtent();
+        function submitform() {
+            var queryString = document.forms[0].query.value;
+            OpenLayers.Request.POST({
+                url: "http://www.openrouteservice.org/php/OpenLSLUS_Geocode.php",
+                scope: this,
+                failure: this.requestFailure,
+                success: this.requestSuccess,
+                headers: {"Content-Type": "application/x-www-form-urlencoded"},
+                data: "FreeFormAdress=" + encodeURIComponent(queryString) + "&MaxResponse=1"
+        function requestSuccess(response) {
+            var format = new OpenLayers.Format.XLS();
+            var output = format.read(response.responseXML);
+            if (output.responseLists[0]) {
+                var geometry = output.responseLists[0].features[0].geometry;
+                var foundPosition = new OpenLayers.LonLat(geometry.x, geometry.y).transform(
+                        new OpenLayers.Projection("EPSG:4326"),
+                        map.getProjectionObject()
+                map.setCenter(foundPosition, 16);
+            } else {
+                alert("Sorry, no address found");
+        function requestFailure(response) {
+            alert("An error occurred while communicating with the OpenLS service. Please try again.");
+    </script>
+</head>
+<body onload="init()">
+<h1 id="title">OpenLS Geocoding Example</h1>
+<div id="tags">
+    OpenLS, XLS, Geocoding
+</div>
+<p id="shortdesc">
+    Show how to use an OpenLS service.
+</p>
+<form name="input" action="javascript: submitform();" method="post">
+    <label for="query">Search for address:</label> <input type="text" id="query" size=50 name="query"
+                                                          value="Rue des Berges 37 Payerne"/>
+    <input type="submit" value="Submit"/>
+</form>
+<br>
+<div id="map" class="smallmap"></div>
+<div id="docs">
+    <p>
+        Geocoding example using the http://www.openrouteservice.org/ OpenLS service. Recenter to the first item of the results.
+    </p>
+</div>
+</body>
+</html>
Modified: trunk/openlayers/examples/proxy.cgi
--- trunk/openlayers/examples/proxy.cgi	2011-03-30 12:51:01 UTC (rev 11780)
+++ trunk/openlayers/examples/proxy.cgi	2011-03-30 13:27:30 UTC (rev 11781)
@@ -21,7 +21,7 @@
                 'sigma.openplans.org', 'demo.opengeo.org',
                 'www.openstreetmap.org', 'sample.azavea.com',
                 'v2.suite.opengeo.org', 'v-swe.uni-muenster.de:8080',
-                'vmap0.tiles.osgeo.org']
+                'vmap0.tiles.osgeo.org', 'www.openrouteservice.org']
 method = os.environ["REQUEST_METHOD"]
Added: trunk/openlayers/lib/OpenLayers/Format/XLS/v1.js
--- trunk/openlayers/lib/OpenLayers/Format/XLS/v1.js	                        (rev 0)
+++ trunk/openlayers/lib/OpenLayers/Format/XLS/v1.js	2011-03-30 13:27:30 UTC (rev 11781)
@@ -0,0 +1,307 @@
+/* Copyright (c) 2006-2010 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Format/XLS.js
+ * @requires OpenLayers/Format/GML/v3.js
+ * Class: OpenLayers.Format.XLS.v1
+ * Superclass for XLS version 1 parsers. Only supports GeocodeRequest for now.
+ * Inherits from:
+ *  - <OpenLayers.Format.XML>
+OpenLayers.Format.XLS.v1 = OpenLayers.Class(OpenLayers.Format.XML, {
+     * Property: namespaces
+     * {Object} Mapping of namespace aliases to namespace URIs.
+    namespaces: {
+        xls: "http://www.opengis.net/xls",
+        gml: "http://www.opengis.net/gml",
+        xsi: "http://www.w3.org/2001/XMLSchema-instance"
+     * Property: regExes
+     * Compiled regular expressions for manipulating strings.
+    regExes: {
+        trimSpace: (/^\s*|\s*$/g),
+        removeSpace: (/\s*/g),
+        splitSpace: (/\s+/),
+        trimComma: (/\s*,\s*/g)
+     * APIProperty: xy
+     * {Boolean} Order of the GML coordinate true:(x,y) or false:(y,x)
+     * Changing is not recommended, a new Format should be instantiated.
+    xy: true,
+     * Property: defaultPrefix
+    defaultPrefix: "xls",
+     * Property: schemaLocation
+     * {String} Schema location for a particular minor version.
+    schemaLocation: null,
+     * Constructor: OpenLayers.Format.XLS.v1
+     * Instances of this class are not created directly.  Use the
+     *     <OpenLayers.Format.XLS> constructor instead.
+     * Parameters:
+     * options - {Object} An optional object whose properties will be set on
+     *     this instance.
+    initialize: function(options) {
+        OpenLayers.Format.XML.prototype.initialize.apply(this, [options]);
+     * Method: read
+     * Parameters:
+     * data - {DOMElement} An XLS document element.
+     * options - {Object} Options for the reader.
+     * Returns:
+     * {Object} An object representing the XLSResponse.
+    read: function(data, options) {
+        options = OpenLayers.Util.applyDefaults(options, this.options);
+        var xls = {};
+        this.readChildNodes(data, xls);
+        return xls;
+     * Property: readers
+     * Contains public functions, grouped by namespace prefix, that will
+     *     be applied when a namespaced node is found matching the function
+     *     name.  The function will be applied in the scope of this parser
+     *     with two arguments: the node being read and a context object passed
+     *     from the parent.
+    readers: {
+        "xls": {
+            "XLS": function(node, xls) {
+                xls.version = node.getAttribute("version");
+                this.readChildNodes(node, xls);
+            "Response": function(node, xls) {
+            "GeocodeResponse": function(node, xls) {
+               xls.responseLists = [];
+            "GeocodeResponseList": function(node, xls) {
+                var responseList = {
+                    features: [],
+                    numberOfGeocodedAddresses:
+                        parseInt(node.getAttribute("numberOfGeocodedAddresses"))
+                xls.responseLists.push(responseList);
+                this.readChildNodes(node, responseList);
+            "GeocodedAddress": function(node, responseList) {
+                var feature = new OpenLayers.Feature.Vector();
+                responseList.features.push(feature);
+                this.readChildNodes(node, feature);
+                // post-process geometry
+                feature.geometry = feature.components[0];
+            "GeocodeMatchCode": function(node, feature) {
+                feature.attributes.matchCode = {
+                    accuracy: parseFloat(node.getAttribute("accuracy")),
+                    matchType: node.getAttribute("matchType")
+            "Address": function(node, feature) {
+                var address = {
+                    countryCode: node.getAttribute("countryCode"),
+                    addressee: node.getAttribute("addressee"),
+                    street: [],
+                    place: []
+                feature.attributes.address = address;
+                this.readChildNodes(node, address);
+            "freeFormAddress": function(node, address) {
+                address.freeFormAddress = this.getChildValue(node);
+            "StreetAddress": function(node, address) {
+            "Building": function(node, address) {
+                address.building = {
+                    'number': node.getAttribute("number"),
+                    subdivision: node.getAttribute("subdivision"),
+                    buildingName: node.getAttribute("buildingName")
+            "Street": function(node, address) {
+                // only support the built-in primitive type for now
+                address.street.push(this.getChildValue(node));
+            "Place": function(node, address) {
+                // type is one of CountrySubdivision,
+                // CountrySecondarySubdivision, Municipality or
+                // MunicipalitySubdivision
+                address.place[node.getAttribute("type")] =
+                    this.getChildValue(node);
+            "PostalCode": function(node, address) {
+                address.postalCode = this.getChildValue(node);
+        "gml": OpenLayers.Format.GML.v3.prototype.readers.gml
+     * Method: write
+     * Parameters:
+     * request - {Object} An object representing the geocode request.
+     * Returns:
+     * {DOMElement} The root of an XLS document.
+    write: function(request) {
+        return this.writers.xls.XLS.apply(this, [request]);
+     * Property: writers
+     * As a compliment to the readers property, this structure contains public
+     *     writing functions grouped by namespace alias and named like the
+     *     node names they produce.
+    writers: {
+        "xls": {
+            "XLS": function(request) {
+                var root = this.createElementNSPlus(
+                    "xls:XLS",
+                    {attributes: {
+                        "version": this.VERSION,
+                        "xsi:schemaLocation": this.schemaLocation
+                this.writeNode("RequestHeader", request.header, root);
+                this.writeNode("Request", request, root);
+                return root;
+            "RequestHeader": function(header) {
+                return this.createElementNSPlus("xls:RequestHeader");
+            "Request": function(request) {
+                var node = this.createElementNSPlus("xls:Request", {
+                    attributes: {
+                        methodName: "GeocodeRequest",
+                        requestID: request.requestID || "",
+                        version: this.VERSION
+                this.writeNode("GeocodeRequest", request.addresses, node);
+                return node;
+            "GeocodeRequest": function(addresses) {
+                var node = this.createElementNSPlus("xls:GeocodeRequest");
+                for (var i=0, len=addresses.length; i<len; i++) {
+                    this.writeNode("Address", addresses[i], node);
+                return node;
+            "Address": function(address) {
+                var node = this.createElementNSPlus("xls:Address", {
+                    attributes: {
+                        countryCode: address.countryCode
+                if (address.freeFormAddress) {
+                    this.writeNode("freeFormAddess", address.freeFormAddress, node);
+                } else {
+                    if (address.street) {
+                        this.writeNode("StreetAddress", address, node);
+                    if (address.municipality) {
+                        this.writeNode("Municipality", address.municipality, node);
+                    if (address.countrySubdivision) {
+                        this.writeNode("CountrySubdivision", address.countrySubdivision, node);
+                    if (address.postalCode) {
+                        this.writeNode("PostalCode", address.postalCode, node);
+                return node;
+            "freeFormAddress": function(freeFormAddress) {
+                return this.createElementNSPlus("freeFormAddress",
+                    {value: freeFormAddress});
+            "StreetAddress": function(address) {
+                var node = this.createElementNSPlus("xls:StreetAddress");
+                if (address.building) {
+                    this.writeNode(node, "Building", address.building);
+                var street = address.street;
+                if (!(street instanceof Array)) {
+                    street = [street];
+                for (var i=0, len=street.length; i < len; i++) {
+                    this.writeNode("Street", street[i], node);
+                return node;
+            "Building": function(building) {
+                return this.createElementNSPlus("xls:Building", {
+                    attributes: {
+                        "number": building["number"],
+                        "subdivision": building.subdivision,
+                        "buildingName": building.buildingName
+            "Street": function(street) {
+                return this.createElementNSPlus("xls:Street", {value: street});
+            "Municipality": function(municipality) {
+                return this.createElementNSPlus("xls:Place", {
+                    attributes: {
+                        type: "Municipality"
+                    value: municipality
+            "CountrySubdivision": function(countrySubdivision) {
+                    attributes: {
+                        type: "CountrySubdivision"
+                    value: countrySubdivision
+            "PostalCode": function(postalCode) {
+                return this.createElementNSPlus("xls:PostalCode", {
+                    value: postalCode
+    CLASS_NAME: "OpenLayers.Format.XLS.v1"
Added: trunk/openlayers/lib/OpenLayers/Format/XLS/v1_1_0.js
--- trunk/openlayers/lib/OpenLayers/Format/XLS/v1_1_0.js	                        (rev 0)
+++ trunk/openlayers/lib/OpenLayers/Format/XLS/v1_1_0.js	2011-03-30 13:27:30 UTC (rev 11781)
@@ -0,0 +1,53 @@
+ * @requires OpenLayers/Format/XLS/v1.js
+ * Class: OpenLayers.Format.XLS.v1_1_0
+ * Read / write XLS version 1.1.0.
+ * Inherits from:
+ *  - <OpenLayers.Format.XLS.v1>
+OpenLayers.Format.XLS.v1_1_0 = OpenLayers.Class(
+    OpenLayers.Format.XLS.v1, {
+     * Constant: VERSION
+     * {String} 1.1
+    VERSION: "1.1",
+     * {String} http://www.opengis.net/xls
+     *   http://schemas.opengis.net/ols/1.1.0/LocationUtilityService.xsd
+    schemaLocation: "http://www.opengis.net/xls http://schemas.opengis.net/ols/1.1.0/LocationUtilityService.xsd",
+     * Constructor: OpenLayers.Format.XLS.v1_1_0
+     * Parameters:
+     *     this instance.
+        OpenLayers.Format.XLS.v1.prototype.initialize.apply(
+            this, [options]
+    CLASS_NAME: "OpenLayers.Format.XLS.v1_1_0"
+// Support non standard implementation
+OpenLayers.Format.XLS.v1_1 = OpenLayers.Format.XLS.v1_1_0;
Added: trunk/openlayers/lib/OpenLayers/Format/XLS.js
--- trunk/openlayers/lib/OpenLayers/Format/XLS.js	                        (rev 0)
+++ trunk/openlayers/lib/OpenLayers/Format/XLS.js	2011-03-30 13:27:30 UTC (rev 11781)
@@ -0,0 +1,118 @@
+ * @requires OpenLayers/Format/XML.js
+ * Read/Wite XLS (OpenLS). Create a new instance with the <OpenLayers.Format.XLS>
+ *     constructor. Currently only implemented for Location Utility Services, more
+ *     specifically only for Geocoding. No support for Reverse Geocoding as yet.
+ * Inherits from:
+OpenLayers.Format.XLS = OpenLayers.Class(OpenLayers.Format.XML, {
+     * APIProperty: defaultVersion
+     * {String} Version number to assume if none found.  Default is "1.1.0".
+    defaultVersion: "1.1.0",
+     * APIProperty: version
+     * {String} Specify a version string if one is known.
+    version: null,
+     * Property: parser
+     * {Object} Instance of the versioned parser.  Cached for multiple read and
+     *     write calls of the same version.
+    parser: null,
+     * Create a new parser for XLS.
+     * Parameters:
+     *     this instance.
+     * APIMethod: write
+     * Write out an XLS request.
+     * Parameters:
+     * request - {Object} An object representing the LUS request.
+     * options - {Object} Optional configuration object.
+     * Returns:
+     * {String} An XLS document string.
+    write: function(request, options) {
+        var version = (options && options.version) ||
+                      this.version || this.defaultVersion;
+        if(!this.parser || this.parser.VERSION != version) {
+            var format = OpenLayers.Format.XLS[
+                "v" + version.replace(/\./g, "_")
+            if(!format) {
+                throw "Can't find an XLS parser for version " +
+                      version;
+            this.parser = new format(this.options);
+        var root = this.parser.write(request);
+        return OpenLayers.Format.XML.prototype.write.apply(this, [root]);
+     * APIMethod: read
+     * Read an XLS doc and return an object representing the result.
+     * Parameters:
+     * data - {String | DOMElement} Data to read.
+     * Returns:
+     * {Object} An object representing the GeocodeResponse.
+        if(typeof data == "string") {
+            data = OpenLayers.Format.XML.prototype.read.apply(this, [data]);
+        var root = data.documentElement;
+        var version = this.version;
+        if(!version) {
+            version = root.getAttribute("version");
+            if(!version) {
+                version = this.defaultVersion;
+            if(!format) {
+                      version;
+        var xls = this.parser.read(data, options);
+        return xls;
+    CLASS_NAME: "OpenLayers.Format.XLS"
Modified: trunk/openlayers/lib/OpenLayers.js
--- trunk/openlayers/lib/OpenLayers.js	2011-03-30 12:51:01 UTC (rev 11780)
+++ trunk/openlayers/lib/OpenLayers.js	2011-03-30 13:27:30 UTC (rev 11781)
@@ -329,6 +329,9 @@
                 "OpenLayers/Format/OWSContext/v0_3_1.js",
                 "OpenLayers/Format/WMTSCapabilities.js",
                 "OpenLayers/Format/WMTSCapabilities/v1_0_0.js",
+                "OpenLayers/Format/XLS.js",
+ 		        "OpenLayers/Format/XLS/v1.js",
+ 		        "OpenLayers/Format/XLS/v1_1_0.js",
                 "OpenLayers/Layer/WFS.js",
                 "OpenLayers/Control/GetFeature.js",
                 "OpenLayers/Control/MouseToolbar.js",
Added: trunk/openlayers/tests/Format/XLS/v1_1_0.html
--- trunk/openlayers/tests/Format/XLS/v1_1_0.html	                        (rev 0)
+++ trunk/openlayers/tests/Format/XLS/v1_1_0.html	2011-03-30 13:27:30 UTC (rev 11781)
@@ -0,0 +1,98 @@
+<html>
+<head>
+    <script src="../../../lib/OpenLayers.js"></script>
+    function test_read(t) {
+        t.plan(16);
+        var response = '<xls:GeocodeResponse xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/xls http://schemas.opengis.net/ols/1.1.0/LocationUtilityService.xsd" xmlns:xls="http://www.opengis.net/xls" xmlns:gml="http://www.opengis.net/gml"><xls:GeocodeResponseList numberOfGeocodedAddresses="1"><xls:GeocodedAddress><gml:Point srsName="EPSG:28992"><gml:pos dimension="2">122650 483904</gml:pos></gml:Point><xls:Address countryCode="NL"><xls:StreetAddress><xls:Building number="1"/><xls:Street>president kennedylaan</xls:Street></xls:StreetAddress><xls:Place type="MunicipalitySubdivision">amsterdam</xls:Place><xls:Place type="Municipality">amsterdam</xls:Place><xls:Place type="CountrySubdivision">noord holland</xls:Place><xls:PostalCode>1079MB</xls:PostalCode></xls:Address></xls:GeocodedAddress></xls:GeocodeResponseList></xls:GeocodeResponse>';
+        var output = format.read(response);
+        t.eq(output.responseLists.length, 1, "Output contains 1 responseList");
+        var responseList = output.responseLists[0];
+        t.eq(responseList.numberOfGeocodedAddresses, 1, "Responselist contains 1 geocoded address");
+        t.eq(responseList.features.length, 1, "1 feature parsed");
+        var feature = responseList.features[0];
+        var address = feature.attributes.address;
+        t.eq(address.building["number"], "1", "Building number correctly parsed");
+        t.eq(address.countryCode, "NL", "Country code correctly parsed");
+        t.eq(address.place.CountrySubdivision, "noord holland", "CountrySubDivision correctly parsed");
+        t.eq(address.place.Municipality, "amsterdam", "Municipality correctly parsed");
+        t.eq(address.place.MunicipalitySubdivision, "amsterdam", "MunicipalitySubdivision correctly parsed");
+        t.eq(address.postalCode, "1079MB", "Postalcode correctly parsed");
+        t.eq(address.street[0], "president kennedylaan", "Street correctly parsed");
+        t.eq(feature.geometry.x, 122650, "Geometry [x] correctly parsed");
+        t.eq(feature.geometry.y, 483904, "Geometry [y] correctly parsed");
+        var responseList = [];
+        responseList.push('<?xml version="1.0" encoding="UTF-8" ?>',
+'<XLS xmlns="http://www.opengis.net/xls" xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/xls LocationUtilityService.xsd" version="1.1">',
+'	<ResponseHeader/>',
+'	<Response version="1.1" requestID="">',
+'		<GeocodeResponse>',
+'			<GeocodeResponseList numberOfGeocodedAddresses="2">',
+'				<GeocodedAddress>',
+'					<gml:Point>',
+'						<gml:pos>-71.4589837781615 41.8317239069808</gml:pos>',
+'					</gml:Point>',
+'					<Address countryCode="">',
+'						<StreetAddress>',
+'							<Street></Street>',
+'							<Street/>',
+'						</StreetAddress>',
+'						<Place type="Municipality"></Place>',
+'						<Place type="CountrySubdivision"></Place>',
+'						<PostalCode></PostalCode>',
+'					</Address>',
+'					<GeocodeMatchCode accuracy="100.0"/>',
+'				</GeocodedAddress>',
+'					<gml:Point>',
+'						<gml:pos>-71.4087296631643 41.8269575002255</gml:pos>',
+'					</gml:Point>',
+'							<Street/>',
+'					</Address>',
+'			</GeocodeResponseList>',
+'		</GeocodeResponse>',
+'	</Response>',
+'</XLS>');
+        response = responseList.join("");
+        output = format.read(response);
+        t.eq(output.version, "1.1", "Version correctly parsed");
+        t.eq(responseList.numberOfGeocodedAddresses, 2, "2 addresses parsed");
+        t.eq(responseList.features.length, 2, "2 features parsed");
+        t.eq(responseList.features[0].attributes.matchCode.accuracy, 100.0, "Accuracy correctly parsed");
+    function test_write(t) {
+        t.plan(1);
+        var address = {
+            countryCode: 'US',
+            street: '1 Freedom Rd',
+            municipality: 'Providence',
+            countrySubdivision: 'RI',
+            postalCode: '02909'
+        var request = format.write({addresses: [address]});
+        var expected = '<xls:XLS xmlns:xls="http://www.opengis.net/xls" version="1.1" xsi:schemaLocation="http://www.opengis.net/xls http://schemas.opengis.net/ols/1.1.0/LocationUtilityService.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><xls:RequestHeader/><xls:Request methodName="GeocodeRequest" requestID="" version="1.1"><xls:GeocodeRequest><xls:Address countryCode="US"><xls:StreetAddress><xls:Street>1 Freedom Rd</xls:Street></xls:StreetAddress><xls:Place type="Municipality">Providence</xls:Place><xls:Place type="CountrySubdivision">RI</xls:Place><xls:PostalCode>02909</xls:PostalCode></xls:Address></xls:GeocodeRequest></xls:Request></xls:XLS>';
+        t.xml_eq(request, expected, "XLS geocode request correctly written");
+    </script>
+</head>
+<body>
+</body>
+</html>
Modified: trunk/openlayers/tests/list-tests.html
--- trunk/openlayers/tests/list-tests.html	2011-03-30 12:51:01 UTC (rev 11780)
+++ trunk/openlayers/tests/list-tests.html	2011-03-30 13:27:30 UTC (rev 11781)
@@ -103,6 +103,7 @@
     <li>Format/SOSGetObservation.html</li>
     <li>Format/SOSGetFeatureOfInterest.html</li>
     <li>Format/OWSContext/v0_3_1.html</li>
+    <li>Format/XLS/v1_1_0.html</li>
     <li>Format/XML.html</li>
     <li>Geometry.html</li>
     <li>Geometry/Collection.html</li>
More information about the Commits mailing list
