[OpenLayers-Commits] r11807 - in trunk/openlayers: lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Mar 30 16:53:50 EDT 2011
Author: tschaub
Date: 2011-03-30 13:53:46 -0700 (Wed, 30 Mar 2011)
New Revision: 11807
   trunk/openlayers/lib/OpenLayers/Handler/Click.js
   trunk/openlayers/tests/Handler/Click.html
Restore click handler state in deactivate. r=erilem (closes #3217)
Modified: trunk/openlayers/lib/OpenLayers/Handler/Click.js
--- trunk/openlayers/lib/OpenLayers/Handler/Click.js	2011-03-30 20:52:01 UTC (rev 11806)
+++ trunk/openlayers/lib/OpenLayers/Handler/Click.js	2011-03-30 20:53:46 UTC (rev 11807)
@@ -515,6 +515,8 @@
             this.clearTimer();
             this.down = null;
             this.first = null;
+            this.last = null;
+            this.touch = false;
             deactivated = true;
         return deactivated;
Modified: trunk/openlayers/tests/Handler/Click.html
--- trunk/openlayers/tests/Handler/Click.html	2011-03-30 20:52:01 UTC (rev 11806)
+++ trunk/openlayers/tests/Handler/Click.html	2011-03-30 20:53:46 UTC (rev 11807)
@@ -410,7 +410,7 @@
     function test_Handler_Click_deactivate(t) {
-        t.plan(4);
+        t.plan(6);
         var control = {
             map: new OpenLayers.Map('map')
@@ -422,6 +422,8 @@
         handler.active = true;
         handler.down = true;
         handler.timerId = true;
+        handler.touch = true;
+        handler.last = true;
         deactivated = handler.deactivate();
         t.ok(deactivated,
              "deactivate returns true if the handler was active already");
@@ -429,6 +431,11 @@
              "deactivate sets down to null");
         t.eq(handler.timerId, null,
              "deactivate sets timerId to null");
+        t.eq(handler.touch, false,
+             "deactivate sets touch to false");
+        t.eq(handler.last, null,
+            "deactivate sets last to null");
     function test_Handler_Click_mouseup(t) {
More information about the Commits mailing list
