[OpenLayers-Commits] r11818 - in sandbox/tschaub/canvas: . lib/OpenLayers/Handler lib/OpenLayers/Strategy tests/Handler tests/Strategy
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Mar 30 19:38:32 EDT 2011
Author: tschaub
Date: 2011-03-30 16:38:31 -0700 (Wed, 30 Mar 2011)
New Revision: 11818
   sandbox/tschaub/canvas/
   sandbox/tschaub/canvas/lib/OpenLayers/Handler/Click.js
   sandbox/tschaub/canvas/lib/OpenLayers/Handler/Drag.js
   sandbox/tschaub/canvas/lib/OpenLayers/Strategy/Filter.js
   sandbox/tschaub/canvas/tests/Handler/Click.html
   sandbox/tschaub/canvas/tests/Handler/Drag.html
   sandbox/tschaub/canvas/tests/Strategy/Filter.html
Merge r11803:11817 from trunk.
Property changes on: sandbox/tschaub/canvas
___________________________________________________________________
Modified: svn:mergeinfo
   - /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:10737-11416,11422-11762,11766-11802
   + /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:10737-11416,11422-11762,11766-11817
Modified: sandbox/tschaub/canvas/lib/OpenLayers/Handler/Click.js
--- sandbox/tschaub/canvas/lib/OpenLayers/Handler/Click.js	2011-03-30 23:35:42 UTC (rev 11817)
+++ sandbox/tschaub/canvas/lib/OpenLayers/Handler/Click.js	2011-03-30 23:38:31 UTC (rev 11818)
@@ -515,6 +515,8 @@
             this.clearTimer();
             this.down = null;
             this.first = null;
+            this.last = null;
+            this.touch = false;
             deactivated = true;
         return deactivated;
Modified: sandbox/tschaub/canvas/lib/OpenLayers/Handler/Drag.js
--- sandbox/tschaub/canvas/lib/OpenLayers/Handler/Drag.js	2011-03-30 23:35:42 UTC (rev 11817)
+++ sandbox/tschaub/canvas/lib/OpenLayers/Handler/Drag.js	2011-03-30 23:38:31 UTC (rev 11818)
@@ -145,6 +145,7 @@
      * Method: dragstart
@@ -507,6 +508,7 @@
     deactivate: function() {
         var deactivated = false;
         if(OpenLayers.Handler.prototype.deactivate.apply(this, arguments)) {
             this.started = false;
             this.dragging = false;
             this.start = null;
Modified: sandbox/tschaub/canvas/lib/OpenLayers/Strategy/Filter.js
--- sandbox/tschaub/canvas/lib/OpenLayers/Strategy/Filter.js	2011-03-30 23:35:42 UTC (rev 11817)
+++ sandbox/tschaub/canvas/lib/OpenLayers/Strategy/Filter.js	2011-03-30 23:38:31 UTC (rev 11818)
@@ -138,17 +138,19 @@
         // cache now contains features to remove from layer
         if (this.cache.length > 0) {
             this.caching = true;
-            this.layer.removeFeatures(this.cache.slice(), {silent: true});
+            this.layer.removeFeatures(this.cache.slice());
             this.caching = false;
         // now look through previous cache for features to add to layer
         if (previousCache.length > 0) {
             var event = {features: previousCache};
             this.handleAdd(event);
-            // event has features to add to layer
-            this.caching = true;
-            this.layer.addFeatures(event.features, {silent: true});
-            this.caching = false;
+            if (event.features.length > 0) {
+                // event has features to add to layer
+                this.caching = true;
+                this.layer.addFeatures(event.features);
+                this.caching = false;
Modified: sandbox/tschaub/canvas/tests/Handler/Click.html
--- sandbox/tschaub/canvas/tests/Handler/Click.html	2011-03-30 23:35:42 UTC (rev 11817)
+++ sandbox/tschaub/canvas/tests/Handler/Click.html	2011-03-30 23:38:31 UTC (rev 11818)
@@ -410,7 +410,7 @@
     function test_Handler_Click_deactivate(t) {
-        t.plan(4);
+        t.plan(6);
         var control = {
             map: new OpenLayers.Map('map')
@@ -422,6 +422,8 @@
         handler.active = true;
         handler.down = true;
         handler.timerId = true;
+        handler.touch = true;
+        handler.last = true;
         deactivated = handler.deactivate();
         t.ok(deactivated,
              "deactivate returns true if the handler was active already");
@@ -429,6 +431,11 @@
              "deactivate sets down to null");
         t.eq(handler.timerId, null,
              "deactivate sets timerId to null");
+        t.eq(handler.touch, false,
+             "deactivate sets touch to false");
+        t.eq(handler.last, null,
+            "deactivate sets last to null");
     function test_Handler_Click_mouseup(t) {
Modified: sandbox/tschaub/canvas/tests/Handler/Drag.html
--- sandbox/tschaub/canvas/tests/Handler/Drag.html	2011-03-30 23:35:42 UTC (rev 11817)
+++ sandbox/tschaub/canvas/tests/Handler/Drag.html	2011-03-30 23:38:31 UTC (rev 11818)
@@ -416,7 +416,7 @@
     function test_Handler_Drag_deactivate(t) {
-        t.plan(6);
+        t.plan(7);
         var map = new OpenLayers.Map('map');
         var control = new OpenLayers.Control();
         map.addControl(control);
@@ -427,6 +427,7 @@
              "deactivate returns false if the handler was not already active");
         handler.dragging = true;
         t.ok(deactivated,
@@ -437,7 +438,9 @@
         t.ok(handler.start == null,
              "deactivate sets start to null");
         t.ok(handler.last == null,
-             "deactivate sets start to null");
+        t.ok(!handler.touch,
     function test_interval_timer_after_mouseup(t) {
Modified: sandbox/tschaub/canvas/tests/Strategy/Filter.html
--- sandbox/tschaub/canvas/tests/Strategy/Filter.html	2011-03-30 23:35:42 UTC (rev 11817)
+++ sandbox/tschaub/canvas/tests/Strategy/Filter.html	2011-03-30 23:38:31 UTC (rev 11818)
@@ -70,7 +70,7 @@
 function test_setFilter(t) {
-    t.plan(7);
+    t.plan(13);
     var strategy = new OpenLayers.Strategy.Filter({filter: filter});
     var layer = new OpenLayers.Layer.Vector(null, {
@@ -84,24 +84,43 @@
         center: new OpenLayers.LonLat(0, 0),
         zoom: 1
+    var log = [];
+    layer.events.on({
+        beforefeaturesadded:  function(event) {
+            log.push(event.type);
+        beforefeaturesremoved: function(event) {
-    // add all features
+    // a) add all features
+    log = [];
     layer.addFeatures(features);
-    t.eq(features.length, 20, "collection of 20 features")
-    t.eq(layer.features.length, 10, "layer got 10 with filter 'index < 10'");
-    t.eq(strategy.cache.length, 10, "strategy cached 10 with filter 'index < 10'");
+    t.eq(features.length, 20, "a) collection of 20 features")
+    t.eq(layer.features.length, 10, "a) layer got 10 with filter 'index < 10'");
+    t.eq(strategy.cache.length, 10, "a) strategy cached 10 with filter 'index < 10'");
+    t.eq(log.length, 1, "a) one event logged");
+    t.eq(log[0], "beforefeaturesadded", "a) beforefeaturesadded fired");
-    // update filter
+    // b) update filter
+    log = [];
     filter.value = 5;
     strategy.setFilter(filter);
-    t.eq(layer.features.length, 5, "layer got 5 with filter 'index < 5'");
-    t.eq(strategy.cache.length, 15, "strategy cached 15 with filter 'index < 5'");
+    t.eq(layer.features.length, 5, "b) layer got 5 with filter 'index < 5'");
+    t.eq(strategy.cache.length, 15, "b) strategy cached 15 with filter 'index < 5'");
+    t.eq(log.length, 1, "b) one event logged");
+    t.eq(log[0], "beforefeaturesremoved", "b) beforefeaturesremoved fired");
-    // update filter
+    // c) update filter
+    log = [];
     filter.value = 15;
-    t.eq(layer.features.length, 15, "layer got 15 with filter 'index < 15'");
-    t.eq(strategy.cache.length, 5, "strategy cached 5 with filter 'index < 15'");
+    t.eq(layer.features.length, 15, "c) layer got 15 with filter 'index < 15'");
+    t.eq(strategy.cache.length, 5, "c) strategy cached 5 with filter 'index < 15'");
+    t.eq(log.length, 1, "c) one event logged");
+    t.eq(log[0], "beforefeaturesadded", "c) beforefeaturesadded fired");
     map.destroy();
More information about the Commits mailing list
