[OpenLayers-Commits] r11829 - in trunk/openlayers: examples lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Mar 31 05:45:52 EDT 2011
Author: sbrunner
Date: 2011-03-31 02:45:50 -0700 (Thu, 31 Mar 2011)
New Revision: 11829
   trunk/openlayers/examples/mobile.html
   trunk/openlayers/examples/mobile.js
   trunk/openlayers/lib/OpenLayers/Handler/Feature.js
   trunk/openlayers/lib/OpenLayers/Handler/Path.js
   trunk/openlayers/tests/Handler/Feature.html
fix Don't let the browser to zoom or select the map on feature selection, r=erilem (closes #3212)
Modified: trunk/openlayers/examples/mobile.html
--- trunk/openlayers/examples/mobile.html	2011-03-31 09:06:33 UTC (rev 11828)
+++ trunk/openlayers/examples/mobile.html	2011-03-31 09:45:50 UTC (rev 11829)
@@ -7,6 +7,10 @@
         <meta name="apple-mobile-web-app-capable" content="yes">
         <link rel="stylesheet" href="style.mobile.css" type="text/css">
         <script src="../lib/OpenLayers.js?mobile"></script>
+        <script src="http://192.168.1.49:8124/debug.js?ns=OpenLayers.Console"></script>
+        <script>
+            OpenLayers.Console.log("start");
+        </script>
         <script src="mobile.js"></script>
         <style>
             html, body {
Modified: trunk/openlayers/examples/mobile.js
--- trunk/openlayers/examples/mobile.js	2011-03-31 09:06:33 UTC (rev 11828)
+++ trunk/openlayers/examples/mobile.js	2011-03-31 09:45:50 UTC (rev 11829)
@@ -1,34 +1,14 @@
 // initialize map when page ready
 var map;
-// Get rid of address bar on iphone/ipod
-var fixSize = function() {
-    window.scrollTo(0,0);
-    document.body.style.height = '100%';
-    if (!(/(iphone|ipod)/.test(navigator.userAgent.toLowerCase()))) {
-        if (document.body.parentNode) {
-            document.body.parentNode.style.height = '100%';
-setTimeout(fixSize, 700);
-setTimeout(fixSize, 1500);
 var init = function () {
     // create map
     map = new OpenLayers.Map({
         div: "map",
         theme: null,
-        controls: [
-            new OpenLayers.Control.Attribution(),
-            new OpenLayers.Control.TouchNavigation({
-                dragPanOptions: {
-                    interval: 100,
-                    enableKinetic: true
-            new OpenLayers.Control.ZoomPanel()
+        controls: [],
         layers: [
             new OpenLayers.Layer.OSM("OpenStreetMap", null, {
                 transitionEffect: 'resize'
Modified: trunk/openlayers/lib/OpenLayers/Handler/Feature.js
--- trunk/openlayers/lib/OpenLayers/Handler/Feature.js	2011-03-31 09:06:33 UTC (rev 11828)
+++ trunk/openlayers/lib/OpenLayers/Handler/Feature.js	2011-03-31 09:45:50 UTC (rev 11829)
@@ -56,6 +56,13 @@
      * {<OpenLayers.Pixel>} The location of the last mouseup.
     up: null,
+     * Property: touch
+     * {Boolean} When a touchstart event is fired, touch will be true and all
+     *     mouse related listeners will do nothing.
+    touch: false,
      * Property: clickTolerance
@@ -129,10 +136,34 @@
      * {Boolean} Let the event propagate.
     touchstart: function(evt) {
+        if(!this.touch) {
+            this.touch =  true;
+            this.map.events.un({
+                mousedown: this.mousedown,
+                mouseup: this.mouseup,
+                mousemove: this.mousemove,
+                click: this.click,
+                dblclick: this.dblclick,
+                scope: this
         return this.mousedown(evt);
+     * Method: touchmove
+     * Handle touchmove events. We just prevent the browser default behavior,
+     *    for Android Webkit not to select text when moving the finger after
+     *    selecting a feature.
+     * Parameters:
+     * evt - {Event}
+    touchmove: function(evt) {
+        OpenLayers.Event.stop(evt);
      * Method: mousedown
      * Handle mouse down.  Stop propagation if a feature is targeted by this
      *     event (stops map dragging during feature selection).
@@ -251,6 +282,11 @@
             this.lastFeature = null;
         if(this.feature) {
+            if(evt.type === "touchstart") {
+                // stop the event to prevent Android Webkit from
+                // "flashing" the map div
             var inNew = (this.feature != this.lastFeature);
             if(this.geometryTypeMatches(this.feature)) {
                 // in to a feature
@@ -349,6 +385,7 @@
             this.down = null;
             this.up = null;
+            this.touch = false;
                 "removelayer": this.handleMapEvents,
                 "changelayer": this.handleMapEvents,
Modified: trunk/openlayers/lib/OpenLayers/Handler/Path.js
--- trunk/openlayers/lib/OpenLayers/Handler/Path.js	2011-03-31 09:06:33 UTC (rev 11828)
+++ trunk/openlayers/lib/OpenLayers/Handler/Path.js	2011-03-31 09:45:50 UTC (rev 11829)
@@ -60,6 +60,12 @@
     timerId: null,
+     * Propery: stopTouchEnd
+     * {Boolean} Stop event propagation of the next touch up.
+    stopTouchEnd: false,
      * Constructor: OpenLayers.Handler.Path
      * Create a new path hander
@@ -244,6 +250,8 @@
             // double-tap, finalize the geometry
             this.lastTouchPx = evt.xy; // for up() to detect dblclick and do nothing
             this.finishGeometry();
+            this.stopTouchEnd = true;
             window.clearTimeout(this.timerId);
             this.timerId = null;
             return false;
@@ -259,6 +267,27 @@
             return OpenLayers.Handler.Point.prototype.touchstart.call(this, evt);
+     * Method: touchend
+     * Handle touchend.
+     * Parameters:
+     * evt - {Event} The browser event
+     * Returns:
+     * {Boolean} Allow event propagation
+    touchend: function(evt) {
+        evt.xy = this.lastTouchPx;
+        if (this.stopTouchEnd) {
+            // don't zoom on the page at feature end
+            this.stopTouchEnd = false;
+            return false;
+        return this.up(evt);
      * Method: mousedown
@@ -330,6 +359,8 @@
             } else {
                 if (this.passesTolerance(this.lastDown, evt.xy, this.pixelTolerance)) {
                     if (this.touch) {
+                        // don't allow the browser to zoom
                         this.modifyFeature(evt.xy);
                     if(this.lastUp == null && this.persist) {
@@ -370,6 +401,9 @@
     dblclick: function(evt) {
+        if (this.touch) {
+            return;
         if(!this.freehandMode(evt)) {
Modified: trunk/openlayers/tests/Handler/Feature.html
--- trunk/openlayers/tests/Handler/Feature.html	2011-03-31 09:06:33 UTC (rev 11828)
+++ trunk/openlayers/tests/Handler/Feature.html	2011-03-31 09:45:50 UTC (rev 11829)
@@ -53,7 +53,7 @@
     function test_events(t) {
-        t.plan(30);
+        t.plan(35);
         var map = new OpenLayers.Map('map');
         var control = new OpenLayers.Control();
@@ -64,8 +64,8 @@
         // list below events that should be handled (events) and those
         // that should not be handled (nonevents) by the handler
-        var events = ["mousedown", "mouseup", "mousemove", "click", "dblclick", "touchstart"];
-        var nonevents = ["mouseout", "resize", "focus", "blur"];
+        var events = ["mousedown", "mouseup", "mousemove", "click", "dblclick", "touchstart", "touchmove"];
+        var nonevents = ["mouseout", "resize", "focus", "blur", "touchend"];
         map.events.registerPriority = function(type, obj, func) {
             var output = func();
             // Don't listen for setEvent handlers (#902)
@@ -255,6 +255,82 @@
         map.events.triggerEvent('touchstart', evtPx);
+    function test_touchstart(t) {
+        // a test to verify that the touchstart function does
+        // unregister the mouse listeners when it's called the
+        // first time
+        t.plan(4);
+        // set up
+        var map = new OpenLayers.Map('map', {controls: []});
+        var control = new OpenLayers.Control();
+        map.addControl(control);
+        var layer = new OpenLayers.Layer();
+        map.addLayer(layer);
+        var handler = new OpenLayers.Handler.Feature(control, layer, {});
+        handler.mousedown = function() {}; // mock mousedown
+        handler.activate();
+        function allRegistered() {
+            var eventTypes = ['mousedown', 'mouseup', 'mousemove', 'click', 'dblclick'],
+                eventType,
+                listeners,
+                listener,
+                flag;
+            for(var i=0, ilen=eventTypes.length; i<ilen; i++) {
+                flag =  false;
+                eventType = eventTypes[i];
+                listeners = map.events.listeners[eventType];
+                for(var j=0, jlen=listeners.length; j<jlen; j++) {
+                    listener = listeners[j];
+                    if(listener.func === handler[eventType] && listener.obj === handler) {
+                        flag = true;
+                        break;
+                if(!flag) {
+                    return false;
+            return true;
+        function noneRegistered() {
+                eventType,
+                listeners,
+                listener;
+                        return false;
+            return true;
+        // test
+        t.ok(allRegistered(), 'mouse listeners are registered');
+        handler.touchstart({xy: new OpenLayers.Pixel(0, 0)});
+        t.ok(noneRegistered(), 'mouse listeners are unregistered');
+        t.ok(handler.touch, 'handler.touch is set');
+        handler.deactivate();
+        t.ok(!handler.touch, 'handler.touch is not set');
+        // tear down
+        map.destroy();
     function test_deactivate(t) {
         t.plan(3);
More information about the Commits mailing list
