[OpenLayers-Commits] r11837 - trunk/openlayers/lib/OpenLayers/Feature
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Mar 31 07:53:47 EDT 2011
Author: ahocevar
Date: 2011-03-31 04:53:46 -0700 (Thu, 31 Mar 2011)
New Revision: 11837
   trunk/openlayers/lib/OpenLayers/Feature/Vector.js
apidoc updates
Modified: trunk/openlayers/lib/OpenLayers/Feature/Vector.js
--- trunk/openlayers/lib/OpenLayers/Feature/Vector.js	2011-03-31 11:35:24 UTC (rev 11836)
+++ trunk/openlayers/lib/OpenLayers/Feature/Vector.js	2011-03-31 11:53:46 UTC (rev 11837)
@@ -365,7 +365,7 @@
  * graphicZIndex - {Number} The integer z-index value to use in rendering.
  * graphicName - {String} Named graphic to use when rendering points.  Supported values include "circle" (default),
  *     "square", "star", "x", "cross", "triangle".
- * graphicTitle - {String} Tooltip for an external graphic. Only supported in Firefox and Internet Explorer.
+ * graphicTitle - {String} Tooltip for an external graphic.
  * backgroundGraphic - {String} Url to a graphic to be used as the background under an externalGraphic.
  * backgroundGraphicZIndex - {Number} The integer z-index value to use in rendering the background graphic.
  * backgroundXOffset - {Number} The x offset (in pixels) for the background graphic.
@@ -377,10 +377,9 @@
  * labelAlign - {String} Label alignment. This specifies the insertion point relative to the text. It is a string
  *     composed of two characters. The first character is for the horizontal alignment, the second for the vertical
  *     alignment. Valid values for horizontal alignment: "l"=left, "c"=center, "r"=right. Valid values for vertical
- *     alignment: "t"=top, "m"=middle, "b"=bottom. Example values: "lt", "cm", "rb". The canvas renderer does not
- *     support vertical alignment, it will always use "b".
- * labelXOffset - {Number} Pixel offset along the positive x axis for displacing the label.
- * labelYOffset - {Number} Pixel offset along the positive y axis for displacing the label.
+ *     alignment: "t"=top, "m"=middle, "b"=bottom. Example values: "lt", "cm", "rb".
+ * labelXOffset - {Number} Pixel offset along the positive x axis for displacing the label. Not supported by the canvas renderer.
+ * labelYOffset - {Number} Pixel offset along the positive y axis for displacing the label. Not supported by the canvas renderer.
  * labelSelect - {Boolean} If set to true, labels will be selectable using SelectFeature or similar controls.
  *     Default is false.
  * fontColor - {String} The font color for the label, to be provided like CSS.
More information about the Commits mailing list
