[OpenLayers-Commits] r11840 - in sandbox/cmoullet/openlayers: . build examples lib/OpenLayers/Feature lib/OpenLayers/Handler lib/OpenLayers/Renderer tests/Control tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Mar 31 08:31:16 EDT 2011
Author: cmoullet
Date: 2011-03-31 05:31:16 -0700 (Thu, 31 Mar 2011)
New Revision: 11840
   sandbox/cmoullet/openlayers/
   sandbox/cmoullet/openlayers/build/mobile.cfg
   sandbox/cmoullet/openlayers/examples/mobile-drawing.html
   sandbox/cmoullet/openlayers/examples/mobile-drawing.js
   sandbox/cmoullet/openlayers/examples/vector-features-with-text.html
   sandbox/cmoullet/openlayers/lib/OpenLayers/Feature/Vector.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Path.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/Canvas.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/SVG.js
   sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/SVG2.js
   sandbox/cmoullet/openlayers/tests/Control/Measure.html
   sandbox/cmoullet/openlayers/tests/Handler/Path.html
Merge with trunk
Property changes on: sandbox/cmoullet/openlayers
___________________________________________________________________
Modified: svn:mergeinfo
   - /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11161-11775,11777-11831
   + /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11161-11775,11777-11839
Modified: sandbox/cmoullet/openlayers/build/mobile.cfg
--- sandbox/cmoullet/openlayers/build/mobile.cfg	2011-03-31 12:26:56 UTC (rev 11839)
+++ sandbox/cmoullet/openlayers/build/mobile.cfg	2011-03-31 12:31:16 UTC (rev 11840)
@@ -15,6 +15,7 @@
 OpenLayers/Control/Attribution.js
 OpenLayers/Control/SelectFeature.js
 OpenLayers/Control/DrawFeature.js
+OpenLayers/Control/ModifyFeature.js
 OpenLayers/Control/Panel.js
 OpenLayers/Handler/Point.js
Modified: sandbox/cmoullet/openlayers/examples/mobile-drawing.html
--- sandbox/cmoullet/openlayers/examples/mobile-drawing.html	2011-03-31 12:26:56 UTC (rev 11839)
+++ sandbox/cmoullet/openlayers/examples/mobile-drawing.html	2011-03-31 12:31:16 UTC (rev 11840)
@@ -55,6 +55,12 @@
             div.olControlZoomPanel .olControlZoomToMaxExtentItemInactive {
                 display: none;
+            .olControlEditingToolbar .olControlModifyFeatureItemInactive {
+                background-position: -1px -1px;
+            .olControlEditingToolbar .olControlModifyFeatureItemActive {
+                background-position: -1px -24px;
             #title, #tags, #shortdesc {
                 display: none;
Modified: sandbox/cmoullet/openlayers/examples/mobile-drawing.js
--- sandbox/cmoullet/openlayers/examples/mobile-drawing.js	2011-03-31 12:26:56 UTC (rev 11839)
+++ sandbox/cmoullet/openlayers/examples/mobile-drawing.js	2011-03-31 12:31:16 UTC (rev 11840)
@@ -20,6 +20,10 @@
         new OpenLayers.Control({
             displayClass: 'olControlNavigation'
+        new OpenLayers.Control.ModifyFeature(vector, {
+            vertexRenderIntent: 'temporary',
+            displayClass: 'olControlModifyFeature'
         new OpenLayers.Control.DrawFeature(vector, OpenLayers.Handler.Point, {
             displayClass: 'olControlDrawFeaturePoint'
Modified: sandbox/cmoullet/openlayers/examples/vector-features-with-text.html
--- sandbox/cmoullet/openlayers/examples/vector-features-with-text.html	2011-03-31 12:26:56 UTC (rev 11839)
+++ sandbox/cmoullet/openlayers/examples/vector-features-with-text.html	2011-03-31 12:31:16 UTC (rev 11840)
@@ -29,7 +29,8 @@
                     fillOpacity: 0.5,
                     pointRadius: 6,
                     pointerEvents: "visiblePainted",
-                    label : "name: ${name}, age: ${age}",
+                    // label with \n linebreaks
+                    label : "name: ${name}\n\nage: ${age}",
                     fontColor: "${favColor}",
                     fontSize: "12px",
@@ -113,7 +114,7 @@
             map.addLayer(vectorLayer);
             vectorLayer.drawFeature(multiFeature);
-            map.setCenter(new OpenLayers.LonLat(point.x, point.y), 3);
+            map.setCenter(new OpenLayers.LonLat(-109.370078125, 43.39484375), 4);
             vectorLayer.addFeatures([pointFeature, polygonFeature, multiFeature, labelOffsetFeature, nullFeature ]);
     </script>
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Feature/Vector.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Feature/Vector.js	2011-03-31 12:26:56 UTC (rev 11839)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Feature/Vector.js	2011-03-31 12:31:16 UTC (rev 11840)
@@ -365,7 +365,7 @@
  * graphicZIndex - {Number} The integer z-index value to use in rendering.
  * graphicName - {String} Named graphic to use when rendering points.  Supported values include "circle" (default),
  *     "square", "star", "x", "cross", "triangle".
- * graphicTitle - {String} Tooltip for an external graphic. Only supported in Firefox and Internet Explorer.
+ * graphicTitle - {String} Tooltip for an external graphic.
  * backgroundGraphic - {String} Url to a graphic to be used as the background under an externalGraphic.
  * backgroundGraphicZIndex - {Number} The integer z-index value to use in rendering the background graphic.
  * backgroundXOffset - {Number} The x offset (in pixels) for the background graphic.
@@ -377,10 +377,9 @@
  * labelAlign - {String} Label alignment. This specifies the insertion point relative to the text. It is a string
  *     composed of two characters. The first character is for the horizontal alignment, the second for the vertical
  *     alignment. Valid values for horizontal alignment: "l"=left, "c"=center, "r"=right. Valid values for vertical
- *     alignment: "t"=top, "m"=middle, "b"=bottom. Example values: "lt", "cm", "rb". The canvas renderer does not
- *     support vertical alignment, it will always use "b".
- * labelXOffset - {Number} Pixel offset along the positive x axis for displacing the label.
- * labelYOffset - {Number} Pixel offset along the positive y axis for displacing the label.
+ *     alignment: "t"=top, "m"=middle, "b"=bottom. Example values: "lt", "cm", "rb".
+ * labelXOffset - {Number} Pixel offset along the positive x axis for displacing the label. Not supported by the canvas renderer.
+ * labelYOffset - {Number} Pixel offset along the positive y axis for displacing the label. Not supported by the canvas renderer.
  * labelSelect - {Boolean} If set to true, labels will be selectable using SelectFeature or similar controls.
  *     Default is false.
  * fontColor - {String} The font color for the label, to be provided like CSS.
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Path.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Path.js	2011-03-31 12:26:56 UTC (rev 11839)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Handler/Path.js	2011-03-31 12:31:16 UTC (rev 11840)
@@ -157,6 +157,7 @@
         this.line.geometry.addComponent(
             this.point.geometry, this.line.geometry.components.length
+        this.layer.addFeatures([this.point]);
         this.callback("point", [this.point.geometry, this.getGeometry()]);
         this.callback("modify", [this.point.geometry, this.getSketch()]);
         this.drawFeature();
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/Canvas.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/Canvas.js	2011-03-31 12:26:56 UTC (rev 11839)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/Canvas.js	2011-03-31 12:31:16 UTC (rev 11840)
@@ -9,7 +9,7 @@
  * Class: OpenLayers.Renderer.Canvas
- * A renderer based on the 2D 'canvas' drawing element.element
+ * A renderer based on the 2D 'canvas' drawing element.
  * Inherits:
  *  - <OpenLayers.Renderer>
@@ -329,42 +329,61 @@
             labelAlign: "cm"
         }, style);
         var pt = this.getLocalXY(location);
         this.setCanvasStyle("reset");
         this.canvas.fillStyle = style.fontColor;
         this.canvas.globalAlpha = style.fontOpacity || 1.0;
         var fontStyle = [style.fontStyle ? style.fontStyle : "normal",
                          "normal", // "font-variant" not supported
                          style.fontWeight ? style.fontWeight : "normal",
-                         style.fontSize ? style.fontSize : "10px",
+                         style.fontSize ? style.fontSize : "1em",
                          style.fontFamily ? style.fontFamily : "sans-serif"].join(" ");
+        var labelRows = style.label.split('\n');
+        var numRows = labelRows.length;
         if (this.canvas.fillText) {
             // HTML5
-            var labelAlign =
+            this.canvas.font = fontStyle;
+            this.canvas.textAlign =
                 OpenLayers.Renderer.Canvas.LABEL_ALIGN[style.labelAlign[0]] ||
                 "center";
-            this.canvas.font = fontStyle;
-            this.canvas.textAlign = labelAlign;
-            this.canvas.fillText(style.label, pt[0], pt[1]);
+            this.canvas.textBaseline =
+                OpenLayers.Renderer.Canvas.LABEL_ALIGN[style.labelAlign[1]] ||
+                "middle";
+            var vfactor =
+                OpenLayers.Renderer.Canvas.LABEL_FACTOR[style.labelAlign[1]];
+            if (vfactor == null) {
+                vfactor = -.5;
+            var lineHeight =
+                this.canvas.measureText('Mg').height ||
+                this.canvas.measureText('xx').width;
+            pt[1] += lineHeight*vfactor*(numRows-1);
+            for (var i = 0; i < numRows; i++) {
+                this.canvas.fillText(labelRows[i], pt[0], pt[1] + (lineHeight*i));
         } else if (this.canvas.mozDrawText) {
             // Mozilla pre-Gecko1.9.1 (<FF3.1)
             this.canvas.mozTextStyle = fontStyle;
             // No built-in text alignment, so we measure and adjust the position
-            var len = this.canvas.mozMeasureText(style.label);
-            switch(style.labelAlign[0]) {
-                case "l":
-                    break;
-                case "r":
-                    pt[0] -= len;
-                    break;
-                case "c":
-                default:
-                    pt[0] -= len / 2;
+            var hfactor =
+                OpenLayers.Renderer.Canvas.LABEL_FACTOR[style.labelAlign[0]];
+            if (hfactor == null) {
+                hfactor = -.5;
-            this.canvas.translate(pt[0], pt[1]);
-            this.canvas.mozDrawText(style.label);
-            this.canvas.translate(-1*pt[0], -1*pt[1]);
+            var vfactor =
+                vfactor = -.5;
+            var lineHeight = this.canvas.mozMeasureText('xx');
+            pt[1] += lineHeight*(1 + (vfactor*numRows));
+                var x = pt[0] + (hfactor*this.canvas.mozMeasureText(labelRows[i]));
+                var y = pt[1] + (i*lineHeight);
+                this.canvas.translate(x, y);
+                this.canvas.mozDrawText(labelRows[i]);
+                this.canvas.translate(-x, -y);
@@ -478,5 +497,18 @@
 OpenLayers.Renderer.Canvas.LABEL_ALIGN = {
     "l": "left",
-    "r": "right"
+    "r": "right",
+    "t": "top",
+    "b": "bottom"
+ * Constant: OpenLayers.Renderer.Canvas.LABEL_FACTOR
+ * {Object}
+OpenLayers.Renderer.Canvas.LABEL_FACTOR = {
+    "l": 0,
+    "r": -1,
+    "t": 0,
+    "b": -1
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/SVG.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/SVG.js	2011-03-31 12:26:56 UTC (rev 11839)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/SVG.js	2011-03-31 12:31:16 UTC (rev 11840)
@@ -679,24 +679,23 @@
      * Method: drawText
      * This method is only called by the renderer itself.
-     * Parameters:
+     * Parameters:
      * featureId - {String}
      * style -
      * location - {<OpenLayers.Geometry.Point>}
     drawText: function(featureId, style, location) {
         var resolution = this.getResolution();
         var x = (location.x / resolution + this.left);
         var y = (location.y / resolution - this.top);
         var label = this.nodeFactory(featureId + this.LABEL_ID_SUFFIX, "text");
-        var tspan = this.nodeFactory(featureId + this.LABEL_ID_SUFFIX + "_tspan", "tspan");
         label.setAttributeNS(null, "x", x);
         label.setAttributeNS(null, "y", -y);
         if (style.fontColor) {
             label.setAttributeNS(null, "fill", style.fontColor);
@@ -715,12 +714,9 @@
         if (style.fontStyle) {
             label.setAttributeNS(null, "font-style", style.fontStyle);
-        if(style.labelSelect === true) {
+        if (style.labelSelect === true) {
             label.setAttributeNS(null, "pointer-events", "visible");
             label._featureId = featureId;
-            tspan._featureId = featureId;
-            tspan._geometry = location;
-            tspan._geometryClass = location.CLASS_NAME;
         } else {
             label.setAttributeNS(null, "pointer-events", "none");
@@ -731,17 +727,43 @@
         if (OpenLayers.IS_GECKO === true) {
             label.setAttributeNS(null, "dominant-baseline",
                 OpenLayers.Renderer.SVG.LABEL_ALIGN[align[1]] || "central");
-        } else {
-            tspan.setAttributeNS(null, "baseline-shift",
-                OpenLayers.Renderer.SVG.LABEL_VSHIFT[align[1]] || "-35%");
-        tspan.textContent = style.label;
-        if(!label.parentNode) {
-            label.appendChild(tspan);
+        while (label.childNodes.length > numRows) {
+            label.removeChild(label.lastChild);
+            var tspan = this.nodeFactory(featureId + this.LABEL_ID_SUFFIX + "_tspan_" + i, "tspan");
+                tspan._featureId = featureId;
+                tspan._geometry = location;
+                tspan._geometryClass = location.CLASS_NAME;
+            if (OpenLayers.IS_GECKO === false) {
+                tspan.setAttributeNS(null, "baseline-shift",
+                    OpenLayers.Renderer.SVG.LABEL_VSHIFT[align[1]] || "-35%");
+            tspan.setAttribute("x", x);
+            if (i == 0) {
+                var vfactor = OpenLayers.Renderer.SVG.LABEL_VFACTOR[align[1]];
+                     vfactor = -.5;
+                tspan.setAttribute("dy", (vfactor*(numRows-1)) + "em");
+            } else {
+                tspan.setAttribute("dy", "1em");
+            tspan.textContent = (labelRows[i] === '') ? ' ' : labelRows[i];
+            if (!tspan.parentNode) {
+                label.appendChild(tspan);
+        if (!label.parentNode) {
             this.textRoot.appendChild(label);
@@ -989,6 +1011,15 @@
+ * Constant: OpenLayers.Renderer.SVG.LABEL_VFACTOR
+ * {Object}
+OpenLayers.Renderer.SVG.LABEL_VFACTOR = {
+    "t": 0,
+    "b": -1
  * Function: OpenLayers.Renderer.SVG.preventDefault
  * Used to prevent default events (especially opening images in a new tab on
  * ctrl-click) from being executed for externalGraphic symbols
Modified: sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/SVG2.js
--- sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/SVG2.js	2011-03-31 12:26:56 UTC (rev 11839)
+++ sandbox/cmoullet/openlayers/lib/OpenLayers/Renderer/SVG2.js	2011-03-31 12:31:16 UTC (rev 11840)
@@ -570,8 +570,8 @@
      * Method: drawText
      * Function for drawing text labels.
-     * Parameters:
+     * Parameters:
      * featureId - {String|DOMElement}
      * style - {Object}
      * location - {<OpenLayers.Geometry.Point>}, will be modified inline
@@ -583,14 +583,12 @@
         var g = OpenLayers.Renderer.NG.prototype.drawText.apply(this, arguments);
         var text = g.firstChild ||
             this.nodeFactory(featureId + this.LABEL_ID_SUFFIX + "_text", "text");
-        var tspan = text.firstChild ||
-            this.nodeFactory(featureId + this.LABEL_ID_SUFFIX + "_tspan", "tspan");
         var res = this.getResolution();
         text.setAttributeNS(null, "x", location.x / res);
         text.setAttributeNS(null, "y", - location.y / res);
         g.setAttributeNS(null, "transform", "scale(" + res + ")");
             text.setAttributeNS(null, "fill", style.fontColor);
@@ -609,10 +607,9 @@
             text.setAttributeNS(null, "font-style", style.fontStyle);
             text.setAttributeNS(null, "pointer-events", "visible");
             text._featureId = featureId;
         } else {
             text.setAttributeNS(null, "pointer-events", "none");
@@ -623,18 +620,43 @@
             text.setAttributeNS(null, "dominant-baseline",
                 OpenLayers.Renderer.SVG2.LABEL_ALIGN[align[1]] || "central");
-        } else {
-                OpenLayers.Renderer.SVG2.LABEL_VSHIFT[align[1]] || "-35%");
-        if(!text.parentNode) {
-            text.appendChild(tspan);
+        while (text.childNodes.length > numRows) {
+            text.removeChild(text.lastChild);
+            var tspan = text.childNodes[i] ||
+                this.nodeFactory(featureId + this.LABEL_ID_SUFFIX + "_tspan_" + i, "tspan");
+                    OpenLayers.Renderer.SVG2.LABEL_VSHIFT[align[1]] || "-35%");
+            tspan.setAttribute("x", location.x / res);
+            if (i == 0) {
+                var vfactor = OpenLayers.Renderer.SVG2.LABEL_VFACTOR[align[1]];
+                    vfactor = -.5;
+            } else {
+                text.appendChild(tspan);
+        if (!text.parentNode) {
             g.appendChild(text);
         return g;
@@ -786,6 +808,15 @@
     "b": "0"
+ * Constant: OpenLayers.Renderer.SVG2.LABEL_VFACTOR
+ * {Object}
+OpenLayers.Renderer.SVG2.LABEL_VFACTOR = {
+    "t": 0,
+    "b": -1
  * Function: OpenLayers.Renderer.SVG2.preventDefault
Modified: sandbox/cmoullet/openlayers/tests/Control/Measure.html
--- sandbox/cmoullet/openlayers/tests/Control/Measure.html	2011-03-31 12:26:56 UTC (rev 11839)
+++ sandbox/cmoullet/openlayers/tests/Control/Measure.html	2011-03-31 12:31:16 UTC (rev 11840)
@@ -19,7 +19,6 @@
-    // test for <http://trac.openlayers.org/ticket/2691>
     function test_cancel(t) {
         t.plan(4);
@@ -37,7 +36,7 @@
         map.addControl(control);
         control.activate();
         try {
             control.cancel();
             t.ok(true, "calling cancel before drawing works");
@@ -52,24 +51,29 @@
                 xy: new OpenLayers.Pixel(x, y)
+        // keep a reference to the line being drawn
+        var line = control.handler.line;
         trigger("mousemove", 0, 0);
         trigger("mousedown", 0, 0);
         trigger("mouseup", 0, 0);
         trigger("mousemove", 10, 10);
         trigger("mousedown", 10, 10);
         trigger("mouseup", 10, 10);
+        trigger("dblclick", 10, 10);
+        // the geometry is finalized, we first confirm that it is persisted
+        t.ok(line.layer === control.handler.layer, "feature persists");
-        // confirm that the sketch persists
-        t.eq(control.handler.layer.features.length, 1, "feature persists");
-        // cancel and see that sketch is gone (do not forget that
-        // cancel will create the new feature)
+        // cancel and see that sketch is gone
         control.cancel();
-        t.eq(control.handler.layer.features.length, 2, "feature is gone after cancel");
+        t.eq(line.layer, null, "feature is gone after cancel");
         map.destroy();
+    // test for <http://trac.openlayers.org/ticket/2691>
     function test_partial(t) {
         t.plan(28);
Modified: sandbox/cmoullet/openlayers/tests/Handler/Path.html
--- sandbox/cmoullet/openlayers/tests/Handler/Path.html	2011-03-31 12:26:56 UTC (rev 11839)
+++ sandbox/cmoullet/openlayers/tests/Handler/Path.html	2011-03-31 12:31:16 UTC (rev 11840)
@@ -105,7 +105,7 @@
     function test_bounds(t) {
-        t.plan(2);
+        t.plan(5);
         var geometry;
         var map = new OpenLayers.Map('map');
         map.addLayer(new OpenLayers.Layer.WMS("", "", {}));
@@ -115,16 +115,22 @@
         var handler = new OpenLayers.Handler.Path(control, {},
             {stopDown: true, stopUp: true});
         var activated = handler.activate();
+        t.eq(handler.layer.features.length, 2,
+            "There are two features in the layer after activation.");
         // click on (150, 75)
         var evt = {xy: new OpenLayers.Pixel(150, 75), which: 1};
         handler.mousemove(evt);
         handler.mousedown(evt);
         handler.mouseup(evt);
+            "There are two features in the layer after first click.");
         // click on (175, 100)
         evt = {xy: new OpenLayers.Pixel(175, 100), which: 1};
+            "There are two features in the layer after second click.");
         t.ok(handler.line.geometry.getBounds().equals(
                     new OpenLayers.Bounds(0,-35.15625,35.15625,0)),
              "Correct bounds");
More information about the Commits mailing list
