[OpenLayers-Commits] r11845 - in trunk/openlayers: lib/OpenLayers/Control tests/Control
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Mar 31 10:34:07 EDT 2011
Author: fredj
Date: 2011-03-31 07:34:05 -0700 (Thu, 31 Mar 2011)
New Revision: 11845
   trunk/openlayers/lib/OpenLayers/Control/DragFeature.js
   trunk/openlayers/tests/Control/DragFeature.html
drag feature support on mobile. r=erilem (closes #3231)
Modified: trunk/openlayers/lib/OpenLayers/Control/DragFeature.js
--- trunk/openlayers/lib/OpenLayers/Control/DragFeature.js	2011-03-31 14:32:54 UTC (rev 11844)
+++ trunk/openlayers/lib/OpenLayers/Control/DragFeature.js	2011-03-31 14:34:05 UTC (rev 11845)
@@ -151,6 +151,10 @@
             feature: new OpenLayers.Handler.Feature(
                 this, this.layer, OpenLayers.Util.extend({
+                    // 'click' and 'clickout' callback are for the mobile
+                    // support: no 'over' or 'out' in touch based browsers.
+                    click: this.clickFeature,
+                    clickout: this.clickoutFeature,
                     over: this.overFeature,
                     out: this.outFeature
                 }, this.featureCallbacks),
@@ -158,8 +162,35 @@
+     * Method: clickFeature
+     * Called when the feature handler detects a click-in on a feature.
+     * Parameters:
+     * feature - {<OpenLayers.Feature.Vector>}
+    clickFeature: function(feature) {
+        if (this.overFeature(feature)) {
+            this.handlers.drag.dragstart(this.handlers.feature.evt);
+            // to let the events propagate to the feature handler (click callback)
+            this.handlers.drag.stopDown = false;
+     * Method: clickoutFeature
+     * Called when the feature handler detects a click-out on a feature.
+     * Parameters:
+    clickoutFeature: function(feature) {
+        this.outFeature(feature);
+        this.handlers.drag.stopDown = true;
      * APIMethod: destroy
      * Take care of things that are not handled in superclass
@@ -207,11 +238,16 @@
      * Parameters:
      * feature - {<OpenLayers.Feature.Vector>} The selected feature.
+     * Returns:
+     * {Boolean} Successfully activated the drag handler.
     overFeature: function(feature) {
+        var activated = false;
         if(!this.handlers.drag.dragging) {
             this.feature = feature;
             this.handlers.drag.activate();
+            activated = true;
             this.over = true;
             OpenLayers.Element.addClass(this.map.viewPortDiv, this.displayClass + "Over");
             this.onEnter(feature);
@@ -222,6 +258,7 @@
                 this.over = false;
+        return activated;
Modified: trunk/openlayers/tests/Control/DragFeature.html
--- trunk/openlayers/tests/Control/DragFeature.html	2011-03-31 14:32:54 UTC (rev 11844)
+++ trunk/openlayers/tests/Control/DragFeature.html	2011-03-31 14:34:05 UTC (rev 11845)
@@ -103,6 +103,41 @@
              "onEnter called with expected feature");
+    function test_Control_DragFeature_over_touch(t) {
+        t.plan(7);
+        var log = [];
+        var map = new OpenLayers.Map("map");
+        var layer = new OpenLayers.Layer.Vector();
+        map.addLayer(layer);
+        var control = new OpenLayers.Control.DragFeature(layer, {
+            onEnter: function(f) { log.push({feature: f}); }
+        map.addControl(control);
+        control.activate();
+        t.ok(!control.handlers.drag.active,
+             "drag handler is not active before touch on a feature");
+        // simulate a touch on a feature
+        var feature = new OpenLayers.Feature.Vector();
+        feature.layer = layer;
+        layer.getFeatureFromEvent = function(evt) {
+            return feature;
+        map.events.triggerEvent("touchstart", {type: "touchstart", touches: ['foo']});
+        t.eq(control.feature.id, feature.id,
+             "control gets the proper feature from the feature handler");
+        t.ok(control.handlers.drag.active,
+             "drag handler activated when touch on a feature");
+        t.ok(control.handlers.drag.started, "drag handler has started");
+        t.ok(!control.handlers.drag.stopDown, "drag handler is not stopping down");
+        t.eq(log.length, 1,
+             "onEnter called exactly once");
+        t.eq(log[0].feature.id, feature.id,
+             "onEnter called with expected feature");
     function test_Control_DragFeature_down(t) {
         t.plan(3);
@@ -284,6 +319,44 @@
              "onLeave called with expected feature");
+    function test_Control_DragFeature_out_touch(t) {
+        t.plan(5);
+        var log = [];
+            onLeave: function(f) { log.push({feature: f}); }
+        layer.getFeatureFromEvent = function() {
+            return feature;
+             "feature is set on mouse over");
+        // simulate a touch outside the feature
+            return null;
+        t.ok(control.feature == null,
+             "feature is set to null on mouse out");
+        t.ok(control.handlers.drag.stopDown,
+             "drag handler is stopping down again");
+             "onLeave called exactly once");
+             "onLeave called with expected feature");
     </script>
 </head>
 <body>
More information about the Commits mailing list
