[OpenLayers-Commits] r11949 - in trunk/openlayers: lib/OpenLayers/Renderer tests/Renderer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed May 4 08:08:29 EDT 2011
Author: bbinet
Date: 2011-05-04 05:08:25 -0700 (Wed, 04 May 2011)
New Revision: 11949
   trunk/openlayers/lib/OpenLayers/Renderer/Canvas.js
   trunk/openlayers/tests/Renderer/Canvas.html
fix regression introduced in [11881]: redraw is needed for unrendered features to be properly cleared. r=erilem (closes #3224)
Modified: trunk/openlayers/lib/OpenLayers/Renderer/Canvas.js
--- trunk/openlayers/lib/OpenLayers/Renderer/Canvas.js	2011-05-04 10:37:09 UTC (rev 11948)
+++ trunk/openlayers/lib/OpenLayers/Renderer/Canvas.js	2011-05-04 12:08:25 UTC (rev 11949)
@@ -145,8 +145,12 @@
             if (rendered) {
                 // keep track of what we have rendered for redraw
                 this.features[feature.id] = [feature, style];
-                this.pendingRedraw = true;
+            else {
+                // remove from features tracked for redraw
+                delete(this.features[feature.id]);
+            this.pendingRedraw = true;
         if (this.pendingRedraw && !this.locked) {
             this.redraw();
Modified: trunk/openlayers/tests/Renderer/Canvas.html
--- trunk/openlayers/tests/Renderer/Canvas.html	2011-05-04 10:37:09 UTC (rev 11948)
+++ trunk/openlayers/tests/Renderer/Canvas.html	2011-05-04 12:08:25 UTC (rev 11949)
@@ -171,7 +171,7 @@
             {display: "none"}
         t.eq(exp, false, "c) drawFeature returns false");
-        t.eq(count, 0, "c) redraw is not called when drawing a feature with display 'none'");
+        t.eq(count, 1, "c) redraw is called when drawing a feature with display 'none'");
         renderer.clear();
         // d) draw a point feature outside renderer extent
@@ -180,7 +180,7 @@
             new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(-1000, 0)), {}
         t.eq(exp, false, "d) drawFeature returns false");
-        t.eq(count, 0, "d) redraw is not called when drawing a feature outside renderer extent");
+        t.eq(count, 1, "d) redraw is called when drawing a feature outside renderer extent");
         renderer.clear();
         map.destroy();
More information about the Commits mailing list
