[OpenLayers-Commits] r11972 - in sandbox/bartvde/wps/openlayers: lib/OpenLayers/Format lib/OpenLayers/Format/OWSCommon tests/Format
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed May 18 11:13:24 EDT 2011
Author: bartvde
Date: 2011-05-18 08:13:23 -0700 (Wed, 18 May 2011)
New Revision: 11972
   sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/OWSCommon/v1.js
   sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/OWSCommon/v1_1_0.js
   sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/WPSExecute.js
   sandbox/bartvde/wps/openlayers/tests/Format/WPSExecute.html
work in progress on WPS Execute Format
Modified: sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/OWSCommon/v1.js
--- sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/OWSCommon/v1.js	2011-05-17 15:29:44 UTC (rev 11971)
+++ sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/OWSCommon/v1.js	2011-05-18 15:13:23 UTC (rev 11972)
@@ -241,6 +241,11 @@
                     value: options.bounds.right + " " + options.bounds.top });
                 return node;
+            "Identifier": function(identifier) {
+                var node = this.createElementNSPlus("ows:Identifier", {
+                    value: identifier });
+                return node;
             "Title": function(title) {
                 var node = this.createElementNSPlus("ows:Title", {
                     value: title });
Modified: sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/OWSCommon/v1_1_0.js
--- sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/OWSCommon/v1_1_0.js	2011-05-17 15:29:44 UTC (rev 11971)
+++ sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/OWSCommon/v1_1_0.js	2011-05-18 15:13:23 UTC (rev 11972)
@@ -61,7 +61,7 @@
         }, OpenLayers.Format.OWSCommon.v1.prototype.readers["ows"])
     CLASS_NAME: "OpenLayers.Format.OWSCommon.v1_1_0"
Modified: sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/WPSExecute.js
--- sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/WPSExecute.js	2011-05-17 15:29:44 UTC (rev 11971)
+++ sandbox/bartvde/wps/openlayers/lib/OpenLayers/Format/WPSExecute.js	2011-05-18 15:13:23 UTC (rev 11972)
@@ -20,7 +20,7 @@
      * {Object} Mapping of namespace aliases to namespace URIs.
     namespaces: {
-        ows: "http://www.opengis.net/ows",
+        ows: "http://www.opengis.net/ows/1.1",
         gml: "http://www.opengis.net/gml",
         wps: "http://www.opengis.net/wps/1.0.0",
         ogc: "http://www.opengis.net/ogc",
@@ -92,16 +92,43 @@
     writers: {
         "wps": {
             "Execute": function(options) {
-                var node = this.createElementNSPlus("Execute", {
+                var node = this.createElementNSPlus("wps:Execute", {
                     attributes: {
                         version: this.VERSION,
                         service: 'WPS'
-                this.writeNode("ows:Identifier", options, node);
+                this.writeNode("ows:Identifier", options.identifier, node);
+                this.writeNode("wps:DataInputs", options.dataInputs, node);
                 return node;
+            "DataInputs": function(dataInputs) {
+                var node = this.createElementNSPlus("wps:DataInputs", {});
+                for (var i=0, ii=dataInputs.inputs.length; i<ii; ++i) {
+                    this.writeNode("wps:Input", dataInputs.inputs[i], node);
+                return node;
+            "Input": function(input) {
+                var node = this.createElementNSPlus("wps:Input", {});
+                this.writeNode("ows:Identifier", input.identifier, node);
+                if (input.reference) {
+                    this.writeNode("wps:Reference", input.reference, node);
+                return node;
+            "Reference": function(reference) {
+                var node = this.createElementNSPlus("wps:Reference", {
+                    attributes: {
+                        mimeType: reference.mimeType,
+                        "xlink:href": reference.href,
+                        method: reference.method
+                return node;
+        "ows": OpenLayers.Format.OWSCommon.v1_1_0.prototype.writers.ows
     CLASS_NAME: "OpenLayers.Format.WPSExecute"
Modified: sandbox/bartvde/wps/openlayers/tests/Format/WPSExecute.html
--- sandbox/bartvde/wps/openlayers/tests/Format/WPSExecute.html	2011-05-17 15:29:44 UTC (rev 11971)
+++ sandbox/bartvde/wps/openlayers/tests/Format/WPSExecute.html	2011-05-18 15:13:23 UTC (rev 11972)
@@ -51,6 +51,11 @@
 '    </wps:ResponseForm>' +
 '</wps:Execute>';
+        var format = new OpenLayers.Format.WPSExecute();
+        var result = format.write({identifier: "JTS:area", dataInputs: {inputs: [{identifier: 'geom',
+            reference: {mimeType: "text/xml; subtype=gml/3.1.1", href: "http://geoserver/wps", method: "POST"}
+        console.log(result);
     </script>
More information about the Commits mailing list
