[OpenLayers-Commits] r12338 - sandbox/mpriour/temporal_map/openlayers/examples
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Sep 7 13:34:09 EDT 2011
Author: mpriour
Date: 2011-09-07 10:34:09 -0700 (Wed, 07 Sep 2011)
New Revision: 12338
   sandbox/mpriour/temporal_map/openlayers/examples/time-control.html
Update time control example to that used in mapstory demo
Modified: sandbox/mpriour/temporal_map/openlayers/examples/time-control.html
--- sandbox/mpriour/temporal_map/openlayers/examples/time-control.html	2011-09-07 17:30:55 UTC (rev 12337)
+++ sandbox/mpriour/temporal_map/openlayers/examples/time-control.html	2011-09-07 17:34:09 UTC (rev 12338)
@@ -16,45 +16,65 @@
     </style>
     <script src="../lib/OpenLayers.js"></script>
     <script type="text/javascript">
-        var map, train_wms;
+        var map, pts_wms, line_wms, radii_wms, osm;
         function init(){
-            map = new OpenLayers.Map('map');
+            map = new OpenLayers.Map('map',{allOverlays:false});
-            var osm = new OpenLayers.Layer.OSM();
+            osm = new OpenLayers.Layer.OSM();
-            train_wms = new OpenLayers.Layer.WMS("Train Positions",
-            "http://mapstory.demo.opengeo.org:8080/wms", {
-				layers: "trainpositions",
+            pts_wms = new OpenLayers.Layer.WMS("Irene Centroid",
+            "http://mapstory.demo.opengeo.org:8080/geoserver/wms", {
+				layers: "irene_11_pts,irene_11_radii",
 				transparent: true,
 				format: 'image/png',
-				time:OpenLayers.Date.toISOString(OpenLayers.Date.parse('2007-05-10T05:00:00Z'))
+				time:OpenLayers.Date.toISOString(OpenLayers.Date.parse('2011-08-17T12:00:00Z')),
+				srs:'EPSG:900913'
-				timeInterval:[OpenLayers.Date.parse('2007-05-10T05:00:00Z'),OpenLayers.Date.parse('2007-05-10T23:59:00Z')],
-				timeStep:1,
-				timeUnit:OpenLayers.TimeUnit.MINUTES,
+				timeInterval:[OpenLayers.Date.parse('2011-08-17T12:00:00Z'),OpenLayers.Date.parse('2011-08-29T00:00:00Z')],
+				timeStep:6,
+				timeUnit:OpenLayers.TimeUnit.HOURS,
                 singleTile:true,
                 ratio:1,
-                transitionEffect:'resize'
-                //buffer:0,
-                //smoothRedraw:true
+                transitionEffect:'resize',
+		visibility:true,
+		projection:'EPSG:900913',
+		maxExtent:osm.maxExtent.clone(),
+		maxResolution:osm.maxResolution
+            line_wms = new OpenLayers.Layer.WMS("Irene Storm Track",
+				layers: "irene_11_lin",
+				transparent: true,
+				format: 'image/png',
+				srs:'EPSG:900913'
+                singleTile:true,
+                ratio:1,
+		visibility:true,
 			timeCtl = new OpenLayers.Control.TimeManager({
-				range:train_wms.timeInterval,
-				units:train_wms.timeUnit,
-				step:train_wms.timeStep,
-				layers:[train_wms]
+				range:pts_wms.timeInterval,
+				units:pts_wms.timeUnit,
+				step:pts_wms.timeStep,
+				frameRate:1.3,
+				layers:[pts_wms]
 			timeCtl.events.on({
 				'tick': update_date,
 				'reset': update_date,
-				'stop':function(evt){if(evt.rangeExceeded)alert('End of time range')},
+				'stop':timeCtl.reset,
 				scope: timeCtl
-            map.addLayers([ol_wms, train_wms]);
+            map.addLayers([osm,line_wms, pts_wms]);
             map.addControl(new OpenLayers.Control.LayerSwitcher());
-            map.zoomToExtent(new OpenLayers.Bounds(-100.898437,22.148438,-78.398437,39.726563));
+            map.zoomToExtent(new OpenLayers.Bounds(-8627260.535278,1425478.519205,-3729202.941056,5496444.989113));
 			update_date({
 				object: timeCtl,
 				currentTime: timeCtl.currentTime
@@ -62,28 +82,20 @@
         function update_date(evt) {
             var time = this.currentTime||evt.currentTime;
-			OpenLayers.Util.getElement('year').value = time.getFullYear();
-			OpenLayers.Util.getElement('month').value = time.getMonth();
-            OpenLayers.Util.getElement('day').value = time.getDate();
-            OpenLayers.Util.getElement('hour').value = time.getHours();
-            OpenLayers.Util.getElement('minute').value = time.getMinutes();
+	    OpenLayers.Util.getElement('timestamp').innerHTML = time.toString();
     </script>
   </head>
   <body onload="init()">
-     <h1 id="title"> WMS Time Example</h1>
+     <h1 id="title"> WMS Time Example - Hurricane Irene Aug 2011</h1>
         <div id="tags">
             wmst, wms-t
         </div>
         <p id="shortdesc">
-            Shows the use of the TimeManager control with a single simple WMS-T (time) layer<br>
+            Shows the use of the TimeManager control with a single simple WMS-T (time) layer served from Geoserver<br>
 			Click on the PLAY button to start.
         </p>
-    <input size="4" type='text' id='year' value="" readonly="true" />-
-	<input size="2" type="text" id="month" value="" readonly="true" />-
-	<input size="2" type="text" id="day" value="" readonly="true" />T
-	<input type="text" size="2" id="hour" value="" readonly="true" />:
-	<input type="text" size="2" id="minute" value=""  readonly="true"/>:00
+	<h2 id="timestamp"></h2>
 	<div>
 		<button type="button" onclick="timeCtl.loop=false;timeCtl.stop()">Stop</button>
 		&nbsp;|&nbsp;<button type="button" onclick="timeCtl.reset()">Reset</button>
@@ -91,12 +103,12 @@
 		&nbsp;|&nbsp;<button type="button" onclick="timeCtl.tick()">Step</button>
 		&nbsp;|&nbsp;<button type="button" onclick="timeCtl.play()">Play</button>
 	</div>
-    <div id="map" class="largemap"></div>
+    <div id="map" class="tallmap"></div>
     <div id="docs">
-        <p>Time Control example: hit PLAY, and the trains position will change along with the<br>
+        <p>Time Control example: hit PLAY, and the storm position will change along with the<br>
 		time display. Uses the OpenLayers.Control.TimeManager to update the date<br>
-		elements with the time of the animation. Starts at 05:00 UTC and continues until
-        23:59 UTC or until you stop it</p>
+		elements with the time of the animation. Starts at Aug 17, 2011 and continues until
+        Aug 29, 2011 or until you stop it</p>
     </div>
   </body>
 </html>
More information about the Commits mailing list
