[OpenLayers-Commits] r12347 - in
sandbox/mpriour/temporal_map/openlayers:
lib/OpenLayers/Control lib/OpenLayers/Handler tests/Control
tests/Handler tests/manual
commits-20090109 at openlayers.org
Thu Sep 8 21:40:40 EDT 2011
Author: mpriour
Date: 2011-09-08 18:40:39 -0700 (Thu, 08 Sep 2011)
New Revision: 12347
Added:
sandbox/mpriour/temporal_map/openlayers/tests/manual/dateline-sketch.html
sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/EditingToolbar.js
sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Path.js
sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Point.js
sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Polygon.js
sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/RegularPolygon.js
sandbox/mpriour/temporal_map/openlayers/tests/Control/EditingToolbar.html
sandbox/mpriour/temporal_map/openlayers/tests/Handler/Path.html
sandbox/mpriour/temporal_map/openlayers/tests/Handler/Polygon.html
sandbox/mpriour/temporal_map/openlayers/tests/Handler/RegularPolygon.html
merge with trunk r12346
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/EditingToolbar.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/EditingToolbar.js 2011-09-08 17:53:44 UTC (rev 12346)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Control/EditingToolbar.js 2011-09-09 01:40:39 UTC (rev 12347)
@@ -25,6 +25,13 @@
OpenLayers.Control.Panel, {
+ * APIProperty: citeCompliant
+ * {Boolean} If set to true, coordinates of features drawn in a map extent
+ * crossing the date line won't exceed the world bounds. Default is false.
+ citeCompliant: false,
* Constructor: OpenLayers.Control.EditingToolbar
* Create an editing toolbar for a given layer.
@@ -39,9 +46,18 @@
[ new OpenLayers.Control.Navigation() ]
var controls = [
- new OpenLayers.Control.DrawFeature(layer, OpenLayers.Handler.Point, {'displayClass': 'olControlDrawFeaturePoint'}),
- new OpenLayers.Control.DrawFeature(layer, OpenLayers.Handler.Path, {'displayClass': 'olControlDrawFeaturePath'}),
- new OpenLayers.Control.DrawFeature(layer, OpenLayers.Handler.Polygon, {'displayClass': 'olControlDrawFeaturePolygon'})
+ new OpenLayers.Control.DrawFeature(layer, OpenLayers.Handler.Point, {
+ displayClass: 'olControlDrawFeaturePoint',
+ handlerOptions: {citeCompliant: this.citeCompliant}
+ new OpenLayers.Control.DrawFeature(layer, OpenLayers.Handler.Path, {
+ displayClass: 'olControlDrawFeaturePath',
+ new OpenLayers.Control.DrawFeature(layer, OpenLayers.Handler.Polygon, {
+ displayClass: 'olControlDrawFeaturePolygon',
this.addControls(controls);
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Path.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Path.js 2011-09-08 17:53:44 UTC (rev 12346)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Path.js 2011-09-09 01:40:39 UTC (rev 12347)
@@ -108,7 +108,7 @@
* feature.
createFeature: function(pixel) {
- var lonlat = this.map.getLonLatFromPixel(pixel);
+ var lonlat = this.layer.getLonLatFromViewPortPx(pixel);
var geometry = new OpenLayers.Geometry.Point(
lonlat.lon, lonlat.lat
@@ -165,7 +165,7 @@
addPoint: function(pixel) {
this.layer.removeFeatures([this.point]);
- var lonlat = this.control.map.getLonLatFromPixel(pixel);
this.point = new OpenLayers.Feature.Vector(
new OpenLayers.Geometry.Point(lonlat.lon, lonlat.lat)
@@ -326,7 +326,7 @@
if(!this.line) {
this.createFeature(pixel);
this.point.geometry.x = lonlat.lon;
this.point.geometry.y = lonlat.lat;
this.callback("modify", [this.point.geometry, this.getSketch(), drawing]);
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Point.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Point.js 2011-09-08 17:53:44 UTC (rev 12346)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Point.js 2011-09-09 01:40:39 UTC (rev 12347)
@@ -43,6 +43,13 @@
multi: false,
* Property: mouseDown
* {Boolean} The mouse is down
@@ -164,7 +171,8 @@
// without this, resolution properties must be specified at the
// map-level for this temporary layer to init its resolutions
// correctly
- calculateInRange: OpenLayers.Function.True
+ calculateInRange: OpenLayers.Function.True,
+ wrapDateLine: this.citeCompliant
}, this.layerOptions);
this.layer = new OpenLayers.Layer.Vector(this.CLASS_NAME, options);
this.map.addLayer(this.layer);
@@ -179,7 +187,7 @@
* pixel - {<OpenLayers.Pixel>} A pixel location on the map.
@@ -306,7 +314,7 @@
if(!this.point) {
this.callback("modify", [this.point.geometry, this.point, false]);
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Polygon.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Polygon.js 2011-09-08 17:53:44 UTC (rev 12346)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/Polygon.js 2011-09-09 01:40:39 UTC (rev 12347)
@@ -75,7 +75,7 @@
* feature.
Modified: sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/RegularPolygon.js
--- sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/RegularPolygon.js 2011-09-08 17:53:44 UTC (rev 12346)
+++ sandbox/mpriour/temporal_map/openlayers/lib/OpenLayers/Handler/RegularPolygon.js 2011-09-09 01:40:39 UTC (rev 12347)
@@ -84,6 +84,13 @@
irregular: false,
* Property: angle
* {Float} The angle from the origin (mouse down) to the current mouse
* position, in radians. This is measured counterclockwise from the
@@ -174,7 +181,8 @@
// correctly
@@ -224,7 +232,7 @@
down: function(evt) {
this.fixedRadius = !!(this.radius);
- var maploc = this.map.getLonLatFromPixel(evt.xy);
+ var maploc = this.layer.getLonLatFromViewPortPx(evt.xy);
this.origin = new OpenLayers.Geometry.Point(maploc.lon, maploc.lat);
// create the new polygon
if(!this.fixedRadius || this.irregular) {
@@ -250,7 +258,7 @@
* evt - {Evt} The move event
move: function(evt) {
var point = new OpenLayers.Geometry.Point(maploc.lon, maploc.lat);
if(this.irregular) {
var ry = Math.sqrt(2) * Math.abs(point.y - this.origin.y) / 2;
Modified: sandbox/mpriour/temporal_map/openlayers/tests/Control/EditingToolbar.html
--- sandbox/mpriour/temporal_map/openlayers/tests/Control/EditingToolbar.html 2011-09-08 17:53:44 UTC (rev 12346)
+++ sandbox/mpriour/temporal_map/openlayers/tests/Control/EditingToolbar.html 2011-09-09 01:40:39 UTC (rev 12347)
@@ -3,12 +3,14 @@
<script src="../OLLoader.js"></script>
<script type="text/javascript">
function test_ctor_draw(t) {
- t.plan(4);
+ t.plan(5);
var map = new OpenLayers.Map('map');
var vLayer = new OpenLayers.Layer.Vector();
map.addLayer(vLayer);
- var editingToolbar = new OpenLayers.Control.EditingToolbar(vLayer);
+ var editingToolbar = new OpenLayers.Control.EditingToolbar(vLayer, {
+ citeCompliant: "foo"
map.addControl(editingToolbar);
t.ok(editingToolbar instanceof OpenLayers.Control.EditingToolbar,
@@ -19,6 +21,7 @@
"First control is active" );
t.eq(editingToolbar.controls.length, 4,
"EditingToolbar contains 4 Controls" );
+ t.eq(editingToolbar.controls[1].handler.citeCompliant, "foo", "citeCompliant option passed to handler correctly")
map.destroy();
Modified: sandbox/mpriour/temporal_map/openlayers/tests/Handler/Path.html
--- sandbox/mpriour/temporal_map/openlayers/tests/Handler/Path.html 2011-09-08 17:53:44 UTC (rev 12346)
+++ sandbox/mpriour/temporal_map/openlayers/tests/Handler/Path.html 2011-09-09 01:40:39 UTC (rev 12347)
@@ -1376,6 +1376,32 @@
map.destroy();
+ function test_citeComplaint(t) {
+ t.plan(2);
+ var map = new OpenLayers.Map('map');
+ map.addLayer(new OpenLayers.Layer.OSM());
+ var layer = new OpenLayers.Layer.Vector();
+ map.addLayer(layer);
+ var control = new OpenLayers.Control({});
+ var handler = new OpenLayers.Handler.Path(control, {});
+ control.handler = handler;
+ map.addControl(control);
+ map.zoomToExtent(new OpenLayers.Bounds(-24225034.496992, -11368938.517442, -14206280.326992, -1350184.3474418));
+ handler.activate();
+ handler.createFeature(new OpenLayers.Pixel(100, 50));
+ t.ok(handler.point.geometry.x < 0, "Geometry started correctly when wrapping the dateline using citeCompliant false");
+ control.deactivate();
+ handler = new OpenLayers.Handler.Path(control, {}, {citeCompliant: true});
+ control.activate();
+ t.ok(handler.point.geometry.x > 0, "Geometry started correctly when wrapping the dateline using citeCompliant true");
+ map.destroy();
</script>
</head>
<body>
Modified: sandbox/mpriour/temporal_map/openlayers/tests/Handler/Polygon.html
--- sandbox/mpriour/temporal_map/openlayers/tests/Handler/Polygon.html 2011-09-08 17:53:44 UTC (rev 12346)
+++ sandbox/mpriour/temporal_map/openlayers/tests/Handler/Polygon.html 2011-09-09 01:40:39 UTC (rev 12347)
@@ -1128,6 +1128,31 @@
map.destroy();
+ t.plan(2);
+ var handler = new OpenLayers.Handler.Polygon(control, {});
+ var handler = new OpenLayers.Handler.Polygon(control, {}, {citeCompliant: true});
+ map.destroy();
</script>
</head>
<body>
Modified: sandbox/mpriour/temporal_map/openlayers/tests/Handler/RegularPolygon.html
--- sandbox/mpriour/temporal_map/openlayers/tests/Handler/RegularPolygon.html 2011-09-08 17:53:44 UTC (rev 12346)
+++ sandbox/mpriour/temporal_map/openlayers/tests/Handler/RegularPolygon.html 2011-09-09 01:40:39 UTC (rev 12347)
@@ -149,9 +149,6 @@
function test_Handler_RegularPolygon_irregular(t) {
t.plan(4);
var map = {
- getLonLatFromPixel: function(px) {
- return {lon: px.x, lat: px.y};
getResolution: function() {
return 1;
@@ -164,6 +161,9 @@
t.eq(ring.components[0].y, 10, "correct bottom");
t.eq(ring.components[2].x, 10, "correct left");
t.eq(ring.components[2].y, 15, "correct top");
+ getLonLatFromViewPortPx: function(px) {
+ return {lon: px.x, lat: px.y};
var control = {};
@@ -190,11 +190,7 @@
t.plan(1);
// setup
- var map = new OpenLayers.Map("map", {
+ var map = new OpenLayers.Map("map");
var control = {"map": map};
@@ -211,6 +207,17 @@
var isLeftClick = OpenLayers.Event.isLeftClick;
OpenLayers.Event.isLeftClick = function() { return true; };
+ handler.layer = {
+ renderer: {
+ clear: OpenLayers.Function.Void
+ addFeatures: OpenLayers.Function.Void,
+ drawFeature: OpenLayers.Function.Void,
+ destroyFeatures: OpenLayers.Function.Void,
+ getLonLatFromViewPortPx: function() {
+ return xy;
// test
map.events.triggerEvent("mousedown", {"xy": xy});
Copied: sandbox/mpriour/temporal_map/openlayers/tests/manual/dateline-sketch.html (from rev 12346, trunk/openlayers/tests/manual/dateline-sketch.html)
--- sandbox/mpriour/temporal_map/openlayers/tests/manual/dateline-sketch.html (rev 0)
+++ sandbox/mpriour/temporal_map/openlayers/tests/manual/dateline-sketch.html 2011-09-09 01:40:39 UTC (rev 12347)
@@ -0,0 +1,59 @@
+<!DOCTYPE html>
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+ <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0">
+ <meta name="apple-mobile-web-app-capable" content="yes">
+ <title>OpenLayers: Sketch handlers crossing the dateline</title>
+ <link rel="stylesheet" href="../../theme/default/style.css" type="text/css">
+ <link rel="stylesheet" href="../../examples/style.css" type="text/css">
+ <style type="text/css">
+ #map {
+ height: 512px;
+ </style>
+ <script src="http://maps.google.com/maps/api/js?v=3.5&sensor=false"></script>
+ <script src="../../lib/OpenLayers.js"></script>
+ <script type="text/javascript">
+// make map available for easy debugging
+var map;
+function init(){
+ map = new OpenLayers.Map('map');
+ var gmap = new OpenLayers.Layer.Google(
+ "Google Streets",
+ {sphericalMercator: true}
+ var vector = new OpenLayers.Layer.Vector("Editable Vectors");
+ map.addLayers([gmap, vector]);
+ map.addControl(new OpenLayers.Control.EditingToolbar(vector));
+ var extent = new OpenLayers.Bounds(-24225034.496992, -11368938.517442, -14206280.326992, -1350184.3474418);
+ map.zoomToExtent(extent);
+ </script>
+ </head>
+ <body onload="init()">
+ <h1 id="title">OpenLayers sketch handlers crossing the dateline example</h1>
+ <div id="tags">
+ international date line, dateline, sketch
+ </div>
+ <p id="shortdesc">
+ Start digitizing a polygon or line
+ on one side of the international dateline, and then cross the dateline
+ whilst digitizing. The feature should behave like digitizing on any
+ other location.
+ </p>
+ <div id="map" class="smallmap"></div>
+ <div id="docs">
+ </div>
+ </body>
+</html>
More information about the Commits
