[OpenLayers-Commits] r12360 - in sandbox/camptocamp/clientzoom: . apidoc_config doc_config examples lib lib/OpenLayers/Control lib/OpenLayers/Handler lib/OpenLayers/Layer lib/OpenLayers/Layer/Google lib/OpenLayers/Tile tests tests/Control tests/Format/WMSCapabilities tests/Handler tests/Layer tests/Tile tests/manual
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Sep 13 08:08:41 EDT 2011
Author: erilem
Date: 2011-09-13 05:08:41 -0700 (Tue, 13 Sep 2011)
New Revision: 12360
Added:
   sandbox/camptocamp/clientzoom/tests/manual/dateline-sketch.html
Removed:
   sandbox/camptocamp/clientzoom/examples/google-ng.html
   sandbox/camptocamp/clientzoom/examples/google-ng.js
   sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/GoogleNG.js
   sandbox/camptocamp/clientzoom/lib/OpenLayers/Tile/Google.js
   sandbox/camptocamp/clientzoom/tests/Layer/GoogleNG.html
   sandbox/camptocamp/clientzoom/tests/Tile/Google.html
   sandbox/camptocamp/clientzoom/apidoc_config/Menu.txt
   sandbox/camptocamp/clientzoom/doc_config/Menu.txt
   sandbox/camptocamp/clientzoom/examples/buffer.html
   sandbox/camptocamp/clientzoom/examples/measure.html
   sandbox/camptocamp/clientzoom/lib/OpenLayers.js
   sandbox/camptocamp/clientzoom/lib/OpenLayers/Control/EditingToolbar.js
   sandbox/camptocamp/clientzoom/lib/OpenLayers/Handler/Path.js
   sandbox/camptocamp/clientzoom/lib/OpenLayers/Handler/Point.js
   sandbox/camptocamp/clientzoom/lib/OpenLayers/Handler/Polygon.js
   sandbox/camptocamp/clientzoom/lib/OpenLayers/Handler/RegularPolygon.js
   sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/Google/v3.js
   sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/XYZ.js
   sandbox/camptocamp/clientzoom/tests/Control/EditingToolbar.html
   sandbox/camptocamp/clientzoom/tests/Format/WMSCapabilities/v1_1_1.html
   sandbox/camptocamp/clientzoom/tests/Handler/Path.html
   sandbox/camptocamp/clientzoom/tests/Handler/Polygon.html
   sandbox/camptocamp/clientzoom/tests/Handler/RegularPolygon.html
   sandbox/camptocamp/clientzoom/tests/list-tests.html
svn merge -r12300:HEAD http://svn.openlayers.org/trunk/openlayers
Property changes on: sandbox/camptocamp/clientzoom
___________________________________________________________________
Modified: svn:mergeinfo
   - /sandbox/roberthl/openlayers:9745-9748
   + /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:12301-12359
Modified: sandbox/camptocamp/clientzoom/apidoc_config/Menu.txt
--- sandbox/camptocamp/clientzoom/apidoc_config/Menu.txt	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/apidoc_config/Menu.txt	2011-09-13 12:08:41 UTC (rev 12360)
@@ -352,7 +352,6 @@
       File: GML  (no auto-title, OpenLayers/Layer/GML.js)
       File: Google  (no auto-title, OpenLayers/Layer/Google.js)
       File: Google.v3  (no auto-title, OpenLayers/Layer/Google/v3.js)
-      File: GoogleNG  (no auto-title, OpenLayers/Layer/GoogleNG.js)
       File: Grid  (no auto-title, OpenLayers/Layer/Grid.js)
       File: HTTPRequest  (no auto-title, OpenLayers/Layer/HTTPRequest.js)
       File: Image  (no auto-title, OpenLayers/Layer/Image.js)
@@ -475,7 +474,6 @@
    Group: Tile  {
       File: Tile  (no auto-title, OpenLayers/Tile.js)
-      File: Google  (no auto-title, OpenLayers/Tile/Google.js)
       File: Image  (no auto-title, OpenLayers/Tile/Image.js)
       File: Image.IFrame  (no auto-title, OpenLayers/Tile/Image/IFrame.js)
       File: WFS  (no auto-title, OpenLayers/Tile/WFS.js)
Modified: sandbox/camptocamp/clientzoom/doc_config/Menu.txt
--- sandbox/camptocamp/clientzoom/doc_config/Menu.txt	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/doc_config/Menu.txt	2011-09-13 12:08:41 UTC (rev 12360)
@@ -352,7 +352,6 @@
@@ -475,7 +474,6 @@
    Group: Tile  {
Modified: sandbox/camptocamp/clientzoom/examples/buffer.html
--- sandbox/camptocamp/clientzoom/examples/buffer.html	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/examples/buffer.html	2011-09-13 12:08:41 UTC (rev 12360)
@@ -48,7 +48,7 @@
         <div id="docs">
             Use the buffer property to control how many tiles are included
-            outside the visible map area. Default is 2.
+            outside the visible map area. Default is 0.
         </div>
     </body>
 </html>
Deleted: sandbox/camptocamp/clientzoom/examples/google-ng.html
--- sandbox/camptocamp/clientzoom/examples/google-ng.html	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/examples/google-ng.html	2011-09-13 12:08:41 UTC (rev 12360)
@@ -1,45 +0,0 @@
-<!DOCTYPE html>
-<html>
-    <head>
-        <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
-        <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0">
-        <meta name="apple-mobile-web-app-capable" content="yes">
-        <title>OpenLayers Google NG Layer Example</title>
-        <link rel="stylesheet" href="../theme/default/style.css" type="text/css">
-        <link rel="stylesheet" href="../theme/default/google.css" type="text/css">
-        <link rel="stylesheet" href="style.css" type="text/css">
-        <style type="text/css">
-        .olControlAttribution {
-            left: 2px;
-            right: inherit;
-            bottom: 3px;
-            line-height: 11px;
-            font-family: Arial, sans-serif;
-        </style>
-        <script src="http://maps.google.com/maps/api/js?v=3.5&amp;sensor=false"></script>
-        <script src="../lib/OpenLayers.js"></script>
-        <script src="google-ng.js"></script>
-    </head>
-    <body onload="init()">
-        <h1 id="title">Google NG Layer Example</h1>
-        <div id="tags">
-            Google, api key, apikey
-        </div>
-        <p id="shortdesc">
-            Demonstrate use of tiles from the Google Maps v3 API.
-        </p>
-        <div id="map" class="smallmap"></div>
-        <div id="docs">
-            <p>
-                If you use OpenLayers.Layer.GoogleNG, the getTile method of the
-                GMaps v3 API's MapType is used to load tiles.  This allows for
-                better integration than interacting with a whole map generated
-                by a google.maps.Map instance, as done with
-                OpenLayers.Layer.Google.  See the
-                <a href="google-ng.js" target="_blank">google-ng.js source</a>
-                to see how this is done.
-            </p>
-        </div>
-    </body>
-</html>
Deleted: sandbox/camptocamp/clientzoom/examples/google-ng.js
--- sandbox/camptocamp/clientzoom/examples/google-ng.js	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/examples/google-ng.js	2011-09-13 12:08:41 UTC (rev 12360)
@@ -1,28 +0,0 @@
-var map;
-function init() {
-    map = new OpenLayers.Map('map');
-    map.addControl(new OpenLayers.Control.LayerSwitcher());
-    var gphy = new OpenLayers.Layer.GoogleNG(
-        {type: google.maps.MapTypeId.TERRAIN}
-    var gmap = new OpenLayers.Layer.GoogleNG(
-        // ROADMAP, the default
-    var ghyb = new OpenLayers.Layer.GoogleNG(
-        {type: google.maps.MapTypeId.HYBRID}
-    var gsat = new OpenLayers.Layer.GoogleNG(
-        {type: google.maps.MapTypeId.SATELLITE}
-    map.addLayers([gphy, gmap, ghyb, gsat]);
-    // GoogleNG uses EPSG:900913 as projection, so we have to
-    // transform our coordinates
-    map.setCenter(new OpenLayers.LonLat(10.2, 48.9).transform(
-        new OpenLayers.Projection("EPSG:4326"),
-        map.getProjectionObject()
-    ), 5);
Modified: sandbox/camptocamp/clientzoom/examples/measure.html
--- sandbox/camptocamp/clientzoom/examples/measure.html	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/examples/measure.html	2011-09-13 12:08:41 UTC (rev 12360)
@@ -70,12 +70,19 @@
             var styleMap = new OpenLayers.StyleMap({"default": style});
+            // allow testing of specific renderers via "?renderer=Canvas", etc
+            var renderer = OpenLayers.Util.getParameters(window.location.href).renderer;
+            renderer = (renderer) ? [renderer] : OpenLayers.Layer.Vector.prototype.renderers;
             measureControls = {
                 line: new OpenLayers.Control.Measure(
                     OpenLayers.Handler.Path, {
                         persist: true,
                         handlerOptions: {
-                            layerOptions: {styleMap: styleMap}
+                            layerOptions: {
+                                renderers: renderer,
+                                styleMap: styleMap
@@ -83,7 +90,10 @@
                     OpenLayers.Handler.Polygon, {
                         persist: true,
                         handlerOptions: {
+                            layerOptions: {
Modified: sandbox/camptocamp/clientzoom/lib/OpenLayers/Control/EditingToolbar.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Control/EditingToolbar.js	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Control/EditingToolbar.js	2011-09-13 12:08:41 UTC (rev 12360)
@@ -25,6 +25,13 @@
   OpenLayers.Control.Panel, {
+     * APIProperty: citeCompliant
+     * {Boolean} If set to true, coordinates of features drawn in a map extent
+     * crossing the date line won't exceed the world bounds. Default is false.
+    citeCompliant: false,
      * Constructor: OpenLayers.Control.EditingToolbar
      * Create an editing toolbar for a given layer.
@@ -39,9 +46,18 @@
           [ new OpenLayers.Control.Navigation() ]
         var controls = [
-          new OpenLayers.Control.DrawFeature(layer, OpenLayers.Handler.Point, {'displayClass': 'olControlDrawFeaturePoint'}),
-          new OpenLayers.Control.DrawFeature(layer, OpenLayers.Handler.Path, {'displayClass': 'olControlDrawFeaturePath'}),
-          new OpenLayers.Control.DrawFeature(layer, OpenLayers.Handler.Polygon, {'displayClass': 'olControlDrawFeaturePolygon'})
+            new OpenLayers.Control.DrawFeature(layer, OpenLayers.Handler.Point, {
+                displayClass: 'olControlDrawFeaturePoint',
+                handlerOptions: {citeCompliant: this.citeCompliant}
+            new OpenLayers.Control.DrawFeature(layer, OpenLayers.Handler.Path, {
+                displayClass: 'olControlDrawFeaturePath',
+            new OpenLayers.Control.DrawFeature(layer, OpenLayers.Handler.Polygon, {
+                displayClass: 'olControlDrawFeaturePolygon',
         this.addControls(controls);
Modified: sandbox/camptocamp/clientzoom/lib/OpenLayers/Handler/Path.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Handler/Path.js	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Handler/Path.js	2011-09-13 12:08:41 UTC (rev 12360)
@@ -108,7 +108,7 @@
      *     feature.
     createFeature: function(pixel) {
-        var lonlat = this.map.getLonLatFromPixel(pixel);
+        var lonlat = this.layer.getLonLatFromViewPortPx(pixel);
         var geometry = new OpenLayers.Geometry.Point(
             lonlat.lon, lonlat.lat
@@ -165,7 +165,7 @@
     addPoint: function(pixel) {
         this.layer.removeFeatures([this.point]);
-        var lonlat = this.control.map.getLonLatFromPixel(pixel);
         this.point = new OpenLayers.Feature.Vector(
             new OpenLayers.Geometry.Point(lonlat.lon, lonlat.lat)
@@ -326,7 +326,7 @@
         if(!this.line) {
             this.createFeature(pixel);
         this.point.geometry.x = lonlat.lon;
         this.point.geometry.y = lonlat.lat;
         this.callback("modify", [this.point.geometry, this.getSketch(), drawing]);
Modified: sandbox/camptocamp/clientzoom/lib/OpenLayers/Handler/Point.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Handler/Point.js	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Handler/Point.js	2011-09-13 12:08:41 UTC (rev 12360)
@@ -43,6 +43,13 @@
     multi: false,
      * Property: mouseDown
      * {Boolean} The mouse is down
@@ -164,7 +171,8 @@
             // without this, resolution properties must be specified at the
             // map-level for this temporary layer to init its resolutions
             // correctly
-            calculateInRange: OpenLayers.Function.True
+            calculateInRange: OpenLayers.Function.True,
+            wrapDateLine: this.citeCompliant
         }, this.layerOptions);
         this.layer = new OpenLayers.Layer.Vector(this.CLASS_NAME, options);
         this.map.addLayer(this.layer);
@@ -179,7 +187,7 @@
      * pixel - {<OpenLayers.Pixel>} A pixel location on the map.
@@ -306,7 +314,7 @@
         if(!this.point) {
         this.callback("modify", [this.point.geometry, this.point, false]);
Modified: sandbox/camptocamp/clientzoom/lib/OpenLayers/Handler/Polygon.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Handler/Polygon.js	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Handler/Polygon.js	2011-09-13 12:08:41 UTC (rev 12360)
@@ -75,7 +75,7 @@
      *     feature.
Modified: sandbox/camptocamp/clientzoom/lib/OpenLayers/Handler/RegularPolygon.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Handler/RegularPolygon.js	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Handler/RegularPolygon.js	2011-09-13 12:08:41 UTC (rev 12360)
@@ -84,6 +84,13 @@
     irregular: false,
      * Property: angle
      * {Float} The angle from the origin (mouse down) to the current mouse
      *     position, in radians.  This is measured counterclockwise from the
@@ -174,7 +181,8 @@
                 // correctly
@@ -224,7 +232,7 @@
     down: function(evt) {
         this.fixedRadius = !!(this.radius);
-        var maploc = this.map.getLonLatFromPixel(evt.xy);
+        var maploc = this.layer.getLonLatFromViewPortPx(evt.xy);
         this.origin = new OpenLayers.Geometry.Point(maploc.lon, maploc.lat);
         // create the new polygon
         if(!this.fixedRadius || this.irregular) {
@@ -250,7 +258,7 @@
      * evt - {Evt} The move event
     move: function(evt) {
         var point = new OpenLayers.Geometry.Point(maploc.lon, maploc.lat);
         if(this.irregular) {
             var ry = Math.sqrt(2) * Math.abs(point.y - this.origin.y) / 2;
Modified: sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/Google/v3.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/Google/v3.js	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/Google/v3.js	2011-09-13 12:08:41 UTC (rev 12360)
@@ -203,7 +203,7 @@
     setGMapVisibility: function(visible) {
         var cache = OpenLayers.Layer.Google.cache[this.map.id];
-        if (cache && !cache.resized) {
+        if (cache) {
             var type = this.type;
             var layers = this.map.layers;
             var layer;
Deleted: sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/GoogleNG.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/GoogleNG.js	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/GoogleNG.js	2011-09-13 12:08:41 UTC (rev 12360)
@@ -1,336 +0,0 @@
-/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
- * full list of contributors). Published under the Clear BSD license.
- * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
- * full text of the license. */
- * @requires OpenLayers/Layer/XYZ.js
- * @requires OpenLayers/Tile/Google.js
- * @requires OpenLayers/Layer/SphericalMercator.js
- * Class: OpenLayers.Layer.GoogleNG
- * Google layer using <OpenLayers.Tile.Google> tiles.
- * Inherits from:
- *  - <OpenLayers.Layer.XYZ>
-OpenLayers.Layer.GoogleNG = OpenLayers.Class(OpenLayers.Layer.XYZ, {
-     * Property: SUPPORTED_TRANSITIONS
-     * {Array} An immutable (that means don't change it!) list of supported
-     *     transitionEffect values. This layer type supports none.
-    SUPPORTED_TRANSITIONS: [],
-     * Property: serverResolutions
-     * {Array} the resolutions provided by the Google API.
-    serverResolutions: [
-        156543.03390625, 78271.516953125, 39135.7584765625,
-        19567.87923828125, 9783.939619140625, 4891.9698095703125,
-        2445.9849047851562, 1222.9924523925781, 611.4962261962891,
-        305.74811309814453, 152.87405654907226, 76.43702827453613,
-        38.218514137268066, 19.109257068634033, 9.554628534317017,
-        4.777314267158508, 2.388657133579254, 1.194328566789627,
-        0.5971642833948135, 0.29858214169740677, 0.14929107084870338,
-        0.07464553542435169, 0.037322767712175846
-     * Property: attributionTemplate
-     * {String}
-    attributionTemplate: '<span class="olGoogleAttribution ${mapType}">' +
-         '<div><a title="Click to see this area on Google Maps" ' +
-         'target="_blank" href="http://maps.google.com/maps?' +
-         'll=${center}&z=${zoom}&t=${t}"><img width="62" height="24" ' +
-         'src="http://maps.gstatic.com/mapfiles/google_white.png"/></a>' +
-         '</div>${mapData}<a style="white-space: nowrap" target="_blank" ' +
-         'href="http://www.google.com/help/terms_maps.html">' +
-         'Terms of Use</a></span>',
-     * Property: mapTypes
-     * {Object} mapping of {google.maps.MapTypeId} to the t param of
-     * http://maps.google.com/maps? permalinks
-    mapTypes: {
-        "roadmap": "m",
-        "satellite": "k",
-        "hybrid": "h",
-        "terrain": "p"
-     * APIProperty: type
-     * {google.maps.MapTypeId} See
-     * http://code.google.com/apis/maps/documentation/javascript/reference.html#MapTypeId
-    type: null,
-     * Constructor: OpenLayers.Layer.GoogleNG
-     * Create a new GoogleNG layer. Requires the GMaps v3 JavaScript API script
-     * (http://maps.google.com/maps/api/js?v=3.5&amp;sensor=false) loaded in
-     * the html document. Note: Terms of Service compliant use requires the map
-     * to be configured with an <OpenLayers.Control.Attribution> control and
-     * the attribution placed on the map.
-     * Example:
-     * (code)
-     * var terrain = new OpenLayers.Layer.GoogleNG({
-     *     name: "Google Terrain",
-     *     type: google.maps.MapTypeId.TERRAIN
-     * (end)
-     * Parameters:
-     * options - {Object} Configuration properties for the layer.
-     * Required configuration properties:
-     * type - {google.maps.MapTypeId} The layer identifier.  See
-     *     for valid types.
-     * Any other documented layer properties can be provided in the config object.
-    initialize: function(options) {
-        options = OpenLayers.Util.applyDefaults({
-            sphericalMercator: true
-        }, options);
-        if (!options.type) {
-            options.type = google.maps.MapTypeId.ROADMAP;
-        var newArgs = [options.name, null, options];
-        OpenLayers.Layer.XYZ.prototype.initialize.apply(this, newArgs);
-        if (!OpenLayers.Layer.GoogleNG.mapObject) {
-            OpenLayers.Layer.GoogleNG.mapObject =
-                new google.maps.Map(document.createElement("div"));
-        if (OpenLayers.Layer.GoogleNG.mapObject.mapTypes[this.type]) {
-            this.initLayer();
-        } else {
-            google.maps.event.addListenerOnce(
-                OpenLayers.Layer.GoogleNG.mapObject,
-                "idle",
-                OpenLayers.Function.bind(this.initLayer, this)
-     * Method: initLayer
-     * Sets layer properties according to the metadata provided by the API
-    initLayer: function() {
-        var mapType = OpenLayers.Layer.GoogleNG.mapObject.mapTypes[this.type];
-        if (!this.name) {
-            this.setName("Google " + mapType.name);
-        var minZoom = mapType.minZoom || 0;
-        this.addOptions({
-            maxResolution: Math.min(
-                this.serverResolutions[minZoom], this.maxResolution
-            zoomOffset: minZoom,
-            numZoomLevels: Math.min(
-                mapType.maxZoom + 1 - minZoom, this.numZoomLevels
-        }, true);
-     * Method: addTile
-     * Create a tile, initialize it, and add it to the layer div.
-     * Parameters
-     * bounds - {<OpenLayers.Bounds>}
-     * position - {<OpenLayers.Pixel>}
-     * Returns:
-     * {<OpenLayers.Tile.Google>} The added OpenLayers.Tile.Google
-    addTile:function(bounds, position) {
-        return new OpenLayers.Tile.Google(
-            this, position, bounds, this.tileOptions
-     * Method: updateAttribution
-     * Updates the attribution using the <attributionTemplate>
-     * Parameters:
-     * copyrights - {Object} Object with "m", "k", "h" and "p" properties (see
-     *     <mapTypes>), each holding an array of copyrights.
-    updateAttribution: function(copyrights) {
-        var myCopyrights;
-        if (this.type == google.maps.MapTypeId.HYBRID) {
-            // the Copyright Service returns "k" and "m" copyrights for the
-            // HYBRID layer type.
-            var candidates = [].concat(
-                copyrights["h"], copyrights["k"], copyrights["m"]
-            myCopyrights = [];
-            for (var i=candidates.length-1; i>=0; --i) {
-                if (OpenLayers.Util.indexOf(candidates, myCopyrights) == -1) {
-                    myCopyrights.push(candidates[i]);
-        } else {
-            myCopyrights = copyrights[this.mapTypes[this.type]];
-        var mapData = myCopyrights.length == 0 ? "" :
-            "Map Data &copy;" + new Date().getFullYear() + " " +
-            myCopyrights.join(", ") + " - ";
-        var center = this.map.getCenter();
-        center && center.transform(
-            this.map.getProjectionObject(),
-        var size = this.map.getSize();
-        this.attribution = OpenLayers.String.format(this.attributionTemplate, {
-            t: this.mapTypes[this.type],
-            zoom: this.map.getZoom(),
-            center: center.lat + "," + center.lon,
-            mapType: this.type,
-            mapData: mapData
-        this.map && this.map.events.triggerEvent("changelayer", {
-            layer: this,
-            property: "attribution"
-     * Method: setMap
-    setMap: function() {
-        OpenLayers.Layer.XYZ.prototype.setMap.apply(this, arguments);
-        this.events.register("moveend", this,
-            OpenLayers.Layer.GoogleNG.loadCopyrights
-     * Method: removeMap
-    removeMap: function() {
-        OpenLayers.Layer.XYZ.prototype.removeMap.apply(this, arguments);
-        this.events.unregister("moveend", this,
-     * APIMethod: clone
-     * Parameters:
-     * obj - {Object}
-     * Returns:
-     * {<OpenLayers.Layer.GoogleNG>} An exact clone of this
-     * <OpenLayers.Layer.GoogleNG>
-    clone: function(obj) {
-        if (obj == null) {
-            obj = new OpenLayers.Layer.GoogleNG(this.options);
-        //get all additions from superclasses
-        obj = OpenLayers.Layer.XYZ.prototype.clone.apply(this, [obj]);
-        // copy/set any non-init, non-simple values here
-        return obj;
-    CLASS_NAME: "OpenLayers.Layer.GoogleNG"
- * Property: mapObject
- * {google.maps.Map} Shared GMaps instance - will be set upon instantiation of
- * the 1st GoogleNG layer
-OpenLayers.Layer.GoogleNG.mapObject = null;
- * Function: loadCopyrights
- * Using the Google Maps Copyright Service mode (see
- * http://mapki.com/wiki/Google_Map_Parameters#Misc) to get the attribution for
- * the current map extent. Will be called by each GoogleNG layer instance on
- * moveend.
-OpenLayers.Layer.GoogleNG.loadCopyrights = function() {
-    var me = OpenLayers.Layer.GoogleNG.loadCopyrights;
-    if (me.numLoadingScripts == undefined) {
-        me.loadingScripts = [];
-        me.numLoadingScripts = 0;
-        me.copyrights = {"m": [], "k": [], "h": [], "p": []};
-        // store window scope functions before overwriting them
-        me.origGAddCopyright = window.GAddCopyright;
-        me.origGVerify = window.GVerify;
-        me.origGAppFeatures = window.GAppFeatures;
-        // defining window scope functions called by the script that the
-        // Copyright Service returns
-        window.GAddCopyright = function() {
-            var copyright = arguments[7];
-            var category = me.copyrights[arguments[0]];
-            if (OpenLayers.Util.indexOf(category, copyright) == -1) {
-                copyright && category.push(copyright);
-        window.GVerify = OpenLayers.Function.True;
-        window.GAppFeatures = OpenLayers.Function.bind(function() {
-            me.numLoadingScripts--;
-            if (me.numLoadingScripts == 0) {
-                var script;
-                for (var i=me.loadingScripts.length-1; i>=0; --i) {
-                    script = me.loadingScripts[i][0];
-                    me.loadingScripts[i][1].updateAttribution(me.copyrights);
-                    script.parentNode.removeChild(script);
-                // restore original functions
-                window.GAddCopyright = me.origGAddCopyright;
-                delete me.origGAddCopyright;
-                window.GVerify = me.origGVerify;
-                delete me.origGVerify;
-                window.GAppFeatures = me.origGAppFeatures;
-                delete me.origGAppFeatures;
-                delete me.loadingScripts;
-                delete me.numLoadingScripts;
-                delete me.copyrights;
-        }, this);
-    var mapProj = this.map.getProjectionObject();
-    var llProj = new OpenLayers.Projection("EPSG:4326");
-    var center = this.map.getCenter().transform(mapProj, llProj);
-    var extent = this.map.getExtent().transform(mapProj, llProj);
-    var params = {
-        spn: extent.getHeight() + "," + extent.getWidth(),
-        z: this.map.getZoom(),
-        vp: center.lat + "," + center.lon
-    var url = "http://maps.google.com/maps?" +
-        OpenLayers.Util.getParameterString(params);
-    var script = document.createElement("script");
-    script.type = "text/javascript";
-    script.src = url;
-    me.numLoadingScripts++;
-    me.loadingScripts.push([script, this]);
-    document.getElementsByTagName("head")[0].appendChild(script);
Modified: sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/XYZ.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/XYZ.js	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Layer/XYZ.js	2011-09-13 12:08:41 UTC (rev 12360)
@@ -153,8 +153,9 @@
             (res * this.tileSize.w));
         var y = Math.round((this.maxExtent.top - bounds.top) /
             (res * this.tileSize.h));
-        var z = this.serverResolutions != null ?
-            OpenLayers.Util.indexOf(this.serverResolutions, res) :
+        var resolutions = this.serverResolutions || this.resolutions;
+        var z = this.zoomOffset == 0 ?
+            OpenLayers.Util.indexOf(resolutions, res) :
             this.getServerSupportedZoom() + this.zoomOffset;
         var limit = Math.pow(2, z);
Deleted: sandbox/camptocamp/clientzoom/lib/OpenLayers/Tile/Google.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers/Tile/Google.js	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers/Tile/Google.js	2011-09-13 12:08:41 UTC (rev 12360)
@@ -1,154 +0,0 @@
- * @requires OpenLayers/BaseTypes/Class.js
- * @requires OpenLayers/Util.js
- * @requires OpenLayers/Tile.js
- * Class: OpenLayers.Tile.Google
- * Instances of OpenLayers.Tile.Google are used to manage the tiles created
- * by google.maps.MapType (see
- * http://code.google.com/apis/maps/documentation/javascript/reference.html#MapType).
- * Inherits from:
- *  - <OpenLayers.Tile>
-OpenLayers.Tile.Google = OpenLayers.Class(OpenLayers.Tile, {
-     * Property: node
-     * {DOMElement} The tile node from the MapType's getTile method
-    node: null,
-     * Constructor: OpenLayers.Tile.Google
-     * Constructor for a new <OpenLayers.Tile.Google> instance.
-     * Parameters:
-     * layer - {<OpenLayers.Layer>} layer that the tile will go in.
-    initialize: function(layer, position, bounds, options) {
-        OpenLayers.Tile.prototype.initialize.apply(this, [
-            layer, position, bounds, null, null, options
-     * APIMethod: destroy
-     * Nullify references to prevent circular references and memory leaks.
-    destroy:function() {
-        this.node && this.clear();
-        this.node = null;
-        OpenLayers.Tile.prototype.destroy.apply(this, arguments);
-     * Method: clone
-     * Parameters:
-     * obj - {<OpenLayers.Tile>} The tile to be cloned
-     * Returns:
-     * {<OpenLayers.Tile>} An exact clone of this <OpenLayers.Tile.Google>
-    clone: function (obj) {
-            obj = new OpenLayers.Tile.Google(this.layer,
-                                      this.position,
-                                      this.bounds);
-        // catch any randomly tagged-on properties
-        OpenLayers.Util.applyDefaults(obj, this);
-        obj.node = null;
-        return obj;
-     * Method: draw
-     * Check that a tile should be drawn, and draw it.
-     * Returns:
-     * {Boolean} Always returns true.
-    draw: function() {
-        var layerType = OpenLayers.Layer.GoogleNG.mapObject.mapTypes[
-            this.layer.type
-        if (layerType && OpenLayers.Tile.prototype.draw.apply(this, arguments)) {
-            var xyz = this.layer.getXYZ(this.bounds);
-            var point = new google.maps.Point(xyz.x, xyz.y);
-            // The hybrid tile consists of two images. For some reason, we have
-            // to make sure that the satellite image loads first, otherwise we
-            // occasionally get blank tiles for one of the two images. This is
-            // done by requesting the tile for just the satellite mapType
-            // first, before requesting the hybrid one.
-            //TODO revisit this - it may be a temporary issue with GMaps
-            var tempTile;
-            if (this.layer.type === google.maps.MapTypeId.HYBRID) {
-                tempTile = layerType.getTile(point, xyz.z, document);
-            this.node = layerType.getTile(point, xyz.z, document);
-            this.isLoading = true;
-            this.events.triggerEvent("loadstart");
-            this.layer.div.appendChild(this.node);
-            // We only modify what we need to - we expect the size to be set
-            // by getTile, and we have a test that will fail if this changes.
-            OpenLayers.Util.modifyDOMElement(
-                this.node, null, this.position, null, "absolute"
-            // The images inside the node returned from getTile seem to be
-            // preloaded already, so registering onload events on these images
-            // won't work. Instead, we trigger the loadend event immediately
-            // in the next cycle.
-            window.setTimeout(OpenLayers.Function.bind(function() {
-                this.isLoading = false;
-                // check for this.events - we may be destroyed already
-                this.events && this.events.triggerEvent("loadend");
-                // see hybrid tile issue above
-                if (tempTile) {
-                    layerType.releaseTile(tempTile);
-            }, this), 0);
-        return true;
-     * Method: clear
-     * Clear the tile of any bounds/position-related data so that it can
-     *     be reused in a new location. To be implemented by subclasses.
-    clear: function() {
-        if (this.node) {
-            this.node.parentNode &&
-                this.node.parentNode.removeChild(this.node);
-            OpenLayers.Layer.GoogleNG.mapObject.mapTypes[
-                this.layer.type
-            ].releaseTile(this.node);
-    CLASS_NAME: "OpenLayers.Tile.Google"
Modified: sandbox/camptocamp/clientzoom/lib/OpenLayers.js
--- sandbox/camptocamp/clientzoom/lib/OpenLayers.js	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/lib/OpenLayers.js	2011-09-13 12:08:41 UTC (rev 12360)
@@ -122,7 +122,6 @@
                 "OpenLayers/Popup.js",
                 "OpenLayers/Tile.js",
                 "OpenLayers/Tile/BackBufferable.js",
-                "OpenLayers/Tile/Google.js",
                 "OpenLayers/Tile/Image.js",
                 "OpenLayers/Tile/Image/IFrame.js",
                 "OpenLayers/Tile/WFS.js",
@@ -155,7 +154,6 @@
                 "OpenLayers/Layer/Boxes.js",
                 "OpenLayers/Layer/XYZ.js",
                 "OpenLayers/Layer/Bing.js",
-                "OpenLayers/Layer/GoogleNG.js",
                 "OpenLayers/Layer/TMS.js",
                 "OpenLayers/Layer/TileCache.js",
                 "OpenLayers/Layer/Zoomify.js",
Modified: sandbox/camptocamp/clientzoom/tests/Control/EditingToolbar.html
--- sandbox/camptocamp/clientzoom/tests/Control/EditingToolbar.html	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/tests/Control/EditingToolbar.html	2011-09-13 12:08:41 UTC (rev 12360)
@@ -3,12 +3,14 @@
   <script src="../OLLoader.js"></script>
   <script type="text/javascript">
     function test_ctor_draw(t) {
-        t.plan(4);
+        t.plan(5);
         var map = new OpenLayers.Map('map');
         var vLayer = new OpenLayers.Layer.Vector();
         map.addLayer(vLayer);
-        var editingToolbar = new OpenLayers.Control.EditingToolbar(vLayer);
+        var editingToolbar = new OpenLayers.Control.EditingToolbar(vLayer, {
+            citeCompliant: "foo"
         map.addControl(editingToolbar);
         t.ok(editingToolbar instanceof OpenLayers.Control.EditingToolbar,
@@ -19,6 +21,7 @@
                 "First control is active" );
         t.eq(editingToolbar.controls.length, 4,
                 "EditingToolbar contains 4 Controls" );
+        t.eq(editingToolbar.controls[1].handler.citeCompliant, "foo", "citeCompliant option passed to handler correctly")
         map.destroy();
Modified: sandbox/camptocamp/clientzoom/tests/Format/WMSCapabilities/v1_1_1.html
--- sandbox/camptocamp/clientzoom/tests/Format/WMSCapabilities/v1_1_1.html	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/tests/Format/WMSCapabilities/v1_1_1.html	2011-09-13 12:08:41 UTC (rev 12360)
@@ -535,13 +535,12 @@
   <Layer>
     <Title>Acme Corp. Map Server</Title>
     <SRS>EPSG:4326</SRS>
+    <BoundingBox SRS="EPSG:4326"
+     minx="-1" miny="-1" maxx="1" maxy="1" resx="0.0" resy="0.0"/>
     <AuthorityURL name="DIF_ID">
       <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple"
        xlink:href="http://gcmd.gsfc.nasa.gov/difguide/whatisadif.html" />
     </AuthorityURL>
-    <BoundingBox SRS="EPSG:4326"
-     minx="-1" miny="-1" maxx="1" maxy="1" resx="0.0" resy="0.0"/>
     <Layer>
       <Name>ROADS_RIVERS</Name>
       <Title>Roads and Rivers</Title>
Modified: sandbox/camptocamp/clientzoom/tests/Handler/Path.html
--- sandbox/camptocamp/clientzoom/tests/Handler/Path.html	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/tests/Handler/Path.html	2011-09-13 12:08:41 UTC (rev 12360)
@@ -1376,6 +1376,32 @@
         map.destroy();
+    function test_citeComplaint(t) {
+        t.plan(2);
+        var map = new OpenLayers.Map('map');
+        map.addLayer(new OpenLayers.Layer.OSM());
+        var layer = new OpenLayers.Layer.Vector();
+        map.addLayer(layer);
+        var control = new OpenLayers.Control({});
+        var handler = new OpenLayers.Handler.Path(control, {});
+        control.handler = handler;
+        map.addControl(control);
+        map.zoomToExtent(new OpenLayers.Bounds(-24225034.496992, -11368938.517442, -14206280.326992, -1350184.3474418));
+        handler.activate();
+        handler.createFeature(new OpenLayers.Pixel(100, 50));
+        t.ok(handler.point.geometry.x < 0, "Geometry started correctly when wrapping the dateline using citeCompliant false");
+        control.deactivate();
+        handler = new OpenLayers.Handler.Path(control, {}, {citeCompliant: true});
+        control.activate();
+        t.ok(handler.point.geometry.x > 0, "Geometry started correctly when wrapping the dateline using citeCompliant true");
+        map.destroy();
   </script>
 </head>
 <body>
Modified: sandbox/camptocamp/clientzoom/tests/Handler/Polygon.html
--- sandbox/camptocamp/clientzoom/tests/Handler/Polygon.html	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/tests/Handler/Polygon.html	2011-09-13 12:08:41 UTC (rev 12360)
@@ -1128,6 +1128,31 @@
         map.destroy();
+        t.plan(2);
+        var handler = new OpenLayers.Handler.Polygon(control, {});
+        var handler = new OpenLayers.Handler.Polygon(control, {}, {citeCompliant: true});
+        map.destroy();
   </script>
 </head>
 <body>
Modified: sandbox/camptocamp/clientzoom/tests/Handler/RegularPolygon.html
--- sandbox/camptocamp/clientzoom/tests/Handler/RegularPolygon.html	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/tests/Handler/RegularPolygon.html	2011-09-13 12:08:41 UTC (rev 12360)
@@ -149,9 +149,6 @@
     function test_Handler_RegularPolygon_irregular(t) {
         t.plan(4);
         var map = {
-            getLonLatFromPixel: function(px) {
-                return {lon: px.x, lat: px.y};
             getResolution: function() {
                 return 1;
@@ -164,6 +161,9 @@
                 t.eq(ring.components[0].y, 10, "correct bottom");
                 t.eq(ring.components[2].x, 10, "correct left");
                 t.eq(ring.components[2].y, 15, "correct top");
+            getLonLatFromViewPortPx: function(px) {
+                return {lon: px.x, lat: px.y};
         var control = {};
@@ -190,11 +190,7 @@
         t.plan(1);
         // setup
-        var map = new OpenLayers.Map("map", {
+        var map = new OpenLayers.Map("map");
         var control = {"map": map};
@@ -211,6 +207,17 @@
         var isLeftClick = OpenLayers.Event.isLeftClick;
         OpenLayers.Event.isLeftClick = function() { return true; };
+        handler.layer = {
+            renderer: {
+                clear: OpenLayers.Function.Void
+            addFeatures: OpenLayers.Function.Void,
+            drawFeature: OpenLayers.Function.Void,
+            destroyFeatures: OpenLayers.Function.Void,
+            getLonLatFromViewPortPx: function() {
+                return xy;
         // test
         map.events.triggerEvent("mousedown", {"xy": xy});
Deleted: sandbox/camptocamp/clientzoom/tests/Layer/GoogleNG.html
--- sandbox/camptocamp/clientzoom/tests/Layer/GoogleNG.html	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/tests/Layer/GoogleNG.html	2011-09-13 12:08:41 UTC (rev 12360)
@@ -1,104 +0,0 @@
-<html>
-<head>
-  <script src="http://maps.google.com/maps/api/js?sensor=false&v=3.5"></script>
-  <script src="../OLLoader.js"></script>
-  <script type="text/javascript">
-    var map, layer;
-    function test_constructor(t) {
-        t.plan(2);
-        layer = new OpenLayers.Layer.GoogleNG({type: google.maps.MapTypeId.HYBRID});
-        t.ok(layer instanceof OpenLayers.Layer.GoogleNG, "returns OpenLayers.Layer.GoogleNG object" );
-        t.eq(layer.type, google.maps.MapTypeId.HYBRID, "Layer type set");
-    function test_initLayer(t) {
-        t.plan(6);
-        map = new OpenLayers.Map("map");
-        var log = {};
-            numZoomLevels: 10,
-            maxResolution: 39135.7584765625,
-                log[layer.id] = true;
-                OpenLayers.Layer.GoogleNG.prototype.initLayer.apply(this, arguments);
-        map.addLayer(layer);
-        map.zoomToMaxExtent();
-        var map2 = new OpenLayers.Map("map2");
-        var minZoom = 1;
-        var layer2 = new OpenLayers.Layer.GoogleNG({
-            numZoomLevels: 24,
-                log[layer2.id] = true;
-                var origMinZoom = OpenLayers.Layer.GoogleNG.mapObject.mapTypes[layer2.type].minZoom;
-                // pretend the API reports a different minZoom
-                OpenLayers.Layer.GoogleNG.mapObject.mapTypes[layer2.type].minZoom = minZoom;
-                OpenLayers.Layer.GoogleNG.mapObject.mapTypes[layer2.type].minZoom = origMinZoom;
-        map2.addLayer(layer2);
-        map2.zoomToMaxExtent();
-        t.delay_call(1, function() {
-            t.eq(log[layer.id], true, "initLayer called for 1st layer");
-            t.eq(log[layer2.id], true, "initLayer called for 2nd layer");
-            t.eq(layer.numZoomLevels, 10, "numZoomLevels from configuration takes precedence if lower");
-            t.eq(layer2.numZoomLevels, OpenLayers.Layer.GoogleNG.mapObject.mapTypes[layer2.type].maxZoom + 1 - minZoom, "numZoomLevels from API takes precedence if lower");
-            t.eq(layer.maxResolution, 39135.7584765625, "maxResolution from configuration takes precedence if higher");
-            t.eq(layer2.maxResolution, 78271.516953125, "maxResolution from API takes precedence if higher");
-            map.destroy();
-            map2.destroy();
-    function test_attribution(t) {
-        t.plan(4);
-        var log = [];
-            type: google.maps.MapTypeId.HYBRID,
-                log.push(copyrights);
-                OpenLayers.Layer.GoogleNG.prototype.updateAttribution.apply(this, arguments);
-        map.setCenter(new OpenLayers.LonLat(16, 48).transform(new OpenLayers.Projection("EPSG:4326"), map.getProjectionObject()), 5);
-        t.delay_call(3, function() {
-            t.eq(log.length, 1, "updateAttribution was called once");
-            t.ok(log[0]["m"].length && log[0]["k"].length, "'m' and 'k' copyrights populated for hybrid layer");
-            t.ok(layer.attribution.indexOf('olGoogleAttribution hybrid') != -1, "Attribution has the correct css class");
-            t.ok(layer.attribution.indexOf('?ll=48,16&z=5&t=h"') != -1, "maps.google.com link has correct parameters");
-            map.destroy();
-    function test_clone(t) {
-        t.plan(2);
-        var clone;
-        clone = layer.clone();
-        t.ok(clone instanceof OpenLayers.Layer.GoogleNG, "clone is a Layer.GoogleNG instance");
-        t.eq(clone.type, google.maps.MapTypeId.HYBRID, "with the correct map type");
-  </script>
-</head>
-<body>
-<div id="map" style="width:500px;height:550px"></div>
-<div id="map2" style="width:500px;height:550px"></div>
-</body>
-</html>
Deleted: sandbox/camptocamp/clientzoom/tests/Tile/Google.html
--- sandbox/camptocamp/clientzoom/tests/Tile/Google.html	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/tests/Tile/Google.html	2011-09-13 12:08:41 UTC (rev 12360)
@@ -1,74 +0,0 @@
-<html>
-<head>
-    var tile;
-    var layer = new OpenLayers.Layer.GoogleNG();
-    var position = new OpenLayers.Pixel(20,30);
-    var bounds = new OpenLayers.Bounds(1,2,3,4);
-    function test_constructor (t) {
-        t.plan( 4 );
-        tile = new OpenLayers.Tile.Google(layer, position, bounds);
-        t.ok( tile instanceof OpenLayers.Tile.Google, "new OpenLayers.Tile.Google returns Tile object" );
-        t.ok( tile.layer == layer, "tile.layer is set correctly");
-        t.ok( tile.position.equals(position), "tile.position is set correctly");
-        t.ok( tile.bounds.equals(bounds), "tile.bounds is set correctly");
-    function test_clone (t) {
-        t.plan( 5 );
-        tile.node = document.createElement("div");
-        var clone = tile.clone();
-        t.ok( clone instanceof OpenLayers.Tile.Google, "OpenLayers.Tile.Google.clone returns Tile.Google object" );
-        t.ok( clone.layer == layer, "clone.layer is set correctly");
-        t.ok( clone.position.equals(position), "clone.position is set correctly");
-        t.ok( clone.bounds.equals(bounds), "clone.bounds is set correctly");
-        t.ok( !clone.node, "node not cloned");
-    function test_draw (t) {
-        t.plan( 5 );
-        var map = new OpenLayers.Map('map');
-        tile.events.register("loadstart", this, function() {
-            t.ok(true, "loadstart triggered");
-        tile.events.register("loadend", this, function() {
-            t.ok(true, "loadend triggered");
-            //this should trigger a "loadstart" event
-            tile.draw();
-            t.ok( tile.node, "tile.draw creates a node");
-            // The two tests below will fail when getTile doesn't set the tile size
-            t.eq( tile.node.style.width, layer.tileSize.w+"px", "Image width is correct" );
-            t.eq( tile.node.style.height, layer.tileSize.h+"px", "Image height is correct" );
-        t.delay_call(2, function() {
-            map.removeLayer(layer);
-            map.destroy();
-            /* wait until "loadend" fires */
-  </script>
-</head>
-<body>
-<div id="map" style="height:550px;width:500px"></div>
-</body>
-</html>
\ No newline at end of file
Modified: sandbox/camptocamp/clientzoom/tests/list-tests.html
--- sandbox/camptocamp/clientzoom/tests/list-tests.html	2011-09-12 11:43:22 UTC (rev 12359)
+++ sandbox/camptocamp/clientzoom/tests/list-tests.html	2011-09-13 12:08:41 UTC (rev 12360)
@@ -153,7 +153,6 @@
     <li>Layer/GML.html</li>
     <li>Layer/Google.html</li>
     <li>Layer/Google/v3.html</li>
-    <li>Layer/GoogleNG.html</li>
     <li>Layer/Grid.html</li>
     <li>Layer/HTTPRequest.html</li>
     <li>Layer/Image.html</li>
@@ -224,7 +223,6 @@
     <li>Symbolizer/Raster.html</li>
     <li>Symbolizer/Text.html</li>
     <li>Tile.html</li>
-    <li>Tile/Google.html</li>
     <li>Tile/Image.html</li>
     <li>Tile/BackBufferable.html</li>
     <li>Tile/Image/IFrame.html</li>
Copied: sandbox/camptocamp/clientzoom/tests/manual/dateline-sketch.html (from rev 12359, trunk/openlayers/tests/manual/dateline-sketch.html)
--- sandbox/camptocamp/clientzoom/tests/manual/dateline-sketch.html	                        (rev 0)
+++ sandbox/camptocamp/clientzoom/tests/manual/dateline-sketch.html	2011-09-13 12:08:41 UTC (rev 12360)
@@ -0,0 +1,59 @@
+<!DOCTYPE html>
+<html>
+  <head>
+    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+    <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=0">
+    <meta name="apple-mobile-web-app-capable" content="yes">
+    <title>OpenLayers: Sketch handlers crossing the dateline</title>
+    <link rel="stylesheet" href="../../theme/default/style.css" type="text/css">
+    <link rel="stylesheet" href="../../examples/style.css" type="text/css">
+    <style type="text/css">
+        #map {
+            height: 512px;
+    </style>
+    <script src="http://maps.google.com/maps/api/js?v=3.5&amp;sensor=false"></script>
+    <script src="../../lib/OpenLayers.js"></script>
+    <script type="text/javascript">
+// make map available for easy debugging
+var map;
+function init(){
+    map = new OpenLayers.Map('map');
+    var gmap = new OpenLayers.Layer.Google(
+        "Google Streets",
+        {sphericalMercator: true}
+    var vector = new OpenLayers.Layer.Vector("Editable Vectors");
+    map.addLayers([gmap, vector]);
+    map.addControl(new OpenLayers.Control.EditingToolbar(vector));
+    var extent = new OpenLayers.Bounds(-24225034.496992, -11368938.517442, -14206280.326992, -1350184.3474418);
+    map.zoomToExtent(extent);
+    </script>
+  </head>
+  <body onload="init()">
+    <h1 id="title">OpenLayers sketch handlers crossing the dateline example</h1>
+    <div id="tags">
+        international date line, dateline, sketch
+    </div>
+    <p id="shortdesc">
+        Start digitizing a polygon or line
+        on one side of the international dateline, and then cross the dateline
+        whilst digitizing. The feature should behave like digitizing on any
+        other location.
+    </p>
+    <div id="map" class="smallmap"></div>
+    <div id="docs">
+    </div>
+  </body>
+</html>
More information about the Commits mailing list
