[OpenLayers-Commits] r12388 - sandbox/jsdoc/jsd/OpenLayers/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Sat Sep 17 15:42:32 EDT 2011
Author: tschaub
Date: 2011-09-17 12:42:31 -0700 (Sat, 17 Sep 2011)
New Revision: 12388
   sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js
More doc.
Modified: sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js
--- sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js	2011-09-17 19:23:28 UTC (rev 12387)
+++ sandbox/jsdoc/jsd/OpenLayers/Layer/WMS.js	2011-09-17 19:42:31 UTC (rev 12388)
@@ -13,12 +13,21 @@
  * Instances of OpenLayers.Layer.WMS are used to display data from OGC Web
  *     Mapping Services. Create a new WMS layer with the <OpenLayers.Layer.WMS>
  *     constructor.
- * Inherits from:
- *  @extends OpenLayers.Layer.Grid
- * @constructor OpenLayers.Layer.WMS
+ * <pre>
+ * // The code below creates a transparent WMS layer with additional options.
+ * var wms = new OpenLayers.Layer.WMS(
+ *     "NASA Global Mosaic",
+ *     "http://wms.jpl.nasa.gov/wms.cgi",
+ *         layers: "modis,global_mosaic",
+ *         transparent: true
+ *         opacity: 0.5,
+ *         singleTile: true
+ * </pre>
  * @param {string} name  A name for the layer
  * @param {string} url  Base url for the WMS
  *                (e.g. http://wms.jpl.nasa.gov/wms.cgi)
@@ -27,12 +36,16 @@
  * @param {Object=} options options - {Object} Hashtable of extra options to tag onto the layer.
  *     These options include all properties listed above, plus the ones
  *     inherited from superclasses.
+ * @constructor OpenLayers.Layer.WMS
+ * @extends OpenLayers.Layer.Grid
 OpenLayers.Layer.WMS = OpenLayers.Class(OpenLayers.Layer.Grid, {
+     * Hashtable of default parameter key/value pairs
      * @const Constant: DEFAULT_PARAMS
-     * @type {Object}  Hashtable of default parameter key/value pairs
+     * @type {Object}
+     * @memberOf OpenLayers.Layer.WMS.prototype
     DEFAULT_PARAMS: { service: "WMS",
                       version: "1.1.1",
@@ -42,13 +55,13 @@
-     * Property: reproject
      * *Deprecated*. See http://trac.openlayers.org/wiki/SphericalMercator
      * for information on the replacement for this functionality.
      * @type {boolean}  Try to reproject this layer if its coordinate reference system
      *           is different than that of the base layer.  Default is false.
      *           Set this in the layer options.  Should be set to false in
      *           most cases.
     reproject: false,
@@ -60,9 +73,10 @@
     isBaseLayer: true,
-     * APIProperty: encodeBBOX
-     * @type {boolean}  Should the BBOX commas be encoded? The WMS spec says 'no',
+     * Should the BBOX commas be encoded? The WMS spec says 'no',
      * but some services want it that way. Default false.
+     * @type {boolean}
     encodeBBOX: false,
@@ -77,10 +91,11 @@
     noMagic: false,
-     * Property: yx
-     * @type {Object}  Keys in this object are EPSG codes for which the axis order
+     *   Keys in this object are EPSG codes for which the axis order
      *     is to be reversed (yx instead of xy, LatLon instead of LonLat), with
      *     true as value. This is only relevant for WMS versions >= 1.3.0.
+     * @type {Object}
     yx: {'EPSG:4326': true},
@@ -103,25 +118,11 @@
      * always be ignored. Instead, it will be derived from the baseLayer's or
      * map's projection.
-     * The code below creates a transparent WMS layer with additional options.
-     * (code)
-     * var wms = new OpenLayers.Layer.WMS("NASA Global Mosaic",
-     *                                    "http://wms.jpl.nasa.gov/wms.cgi",
-     *                                        layers: "modis,global_mosaic",
-     *                                        transparent: true
-     *                                        opacity: 0.5,
-     *                                        singleTile: true
-     * (end)
      * Note that by default, a WMS layer is configured as baseLayer. Setting
      * the "transparent" param to true will apply some magic (see <noMagic>).
      * The default image format changes from image/jpeg to image/png, and the
      * layer is not configured as baseLayer.
     initialize: function(name, url, params, options) {
         var newArguments = [];
         //uppercase params
@@ -167,11 +168,10 @@
-     * Method: clone
      * Create a clone of this layer
-     * Returns:
      * @return {OpenLayers.Layer.WMS}  An exact clone of this layer
+     * @methodOf OpenLayers.Layer.WMS.prototype
     clone: function (obj) {
@@ -191,12 +191,11 @@
-     * APIMethod: reverseAxisOrder
      * Returns true if the axis order is reversed for the WMS version and
      * projection of the layer.
-     * Returns:
      * @return {boolean}  true if the axis order is reversed, false otherwise.
     reverseAxisOrder: function() {
         return (parseFloat(this.params.VERSION) >= 1.3 &&
@@ -204,17 +203,15 @@
-     * Method: getURL
      * Return a GetMap query string for this layer
-     * Parameters:
      * @param {OpenLayers.Bounds} bounds  A bounds representing the bbox for the
      *                                request.
-     * Returns:
      * @return {string}  A string with the layer's url and parameters and also the
      *          passed-in bounds and appropriate tile size specified as
      *          parameters.
     getURL: function (bounds) {
         bounds = this.adjustBounds(bounds);
@@ -233,15 +230,14 @@
-     * APIMethod: mergeNewParams
      * Catch changeParams and uppercase the new params to be merged in
      *     before calling changeParams on the super class.
      *     Once params have been changed, the tiles will be reloaded with
      *     the new parameters.
-     * Parameters:
      * @param {Object} newParams  Hashtable of new params to use
     mergeNewParams:function(newParams) {
         var upperParams = OpenLayers.Util.upperCaseObject(newParams);
@@ -251,19 +247,17 @@
-     * APIMethod: getFullRequestString
      * Combine the layer's url with its params and these newParams.
      *     Add the SRS parameter from projection -- this is probably
      *     more eloquently done via a setProjection() method, but this
      *     works for now and always.
-     * Parameters:
      * @param {string} altUrl  Use this as the url instead of the layer's url
-     * Returns:
      * @return {string}
     getFullRequestString:function(newParams, altUrl) {
         var mapProjection = this.map.getProjectionObject();
More information about the Commits mailing list
