[OpenLayers-Dev] Vector rendering status
Pierre GIRAUD bluecarto at gmail.com
Tue Nov 14 04:15:53 EST 2006
I'm about to continue your work on GML. What is the best way. Do I try
to implement the handles for other geometries ? Or do you want me to
have a look at the mapBuilder GML parser (using xpath) and try to
reuse it in OL ?
Regards
Pierre
On 11/14/06, Cameron Shorter <cameron.shorter at gmail.com> wrote:
> Status after the Australian shift:
> 1. I've renamed examples/wfs_features.html to examples/GML.html
> 2. I've created a Layer/GML.js class (used by the GML.html class). This
> is based on the previous code in the example.
> 3. We can raise any issues with the Vector branch in Trac now. Chris has
> created a milestone = "Vector RC1" which we can use to assign to our issues.
> 4. Raised ticked #395 "Remove dependancy upon Prototype.js"
> http://trac.openlayers.org/ticket/395#preview
> 5. For those interested in Mapbuilder, I've updated MapPaneOL so that it
> loads a GML file defined in the Context into an OpenLayers Layer/Gml object.
> 6. I've created an examples/GMLTasmania.html which contains a sample of
> GML2 lines, polygons, and points. At the moment, only some of the lines
> are displayed. Our parser needs to process all feature types.
> I'm about to have dinner soon, but will be back on later tonight - in
> 2hrs or so.
> Cameron Shorter
> http://cameron.shorter.net
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
