[Dev] [webmap-discuss] VectorLayer design
Dan R. Greening greening at bigtribe.com
Fri Oct 13 12:05:22 EDT 2006
Just some skimmed-it comments:
Don't Polygon and Line each aggregate a List of Coord?  I would use
the diamond aggregate to denote this, because if you delete a Polygon
you presumably want all the Coords deleted also.  Pointer sort-of
implies the Coords have a life of their own.  Also maybe you want a
3..* on Polygon and a 2 on Line.
Dan R. Greening, Ph.D.,  CEO BigTribe Corporation,  http://
dan.greening.name/contact.htm
On Oct 13, 2006, at 5:32 AM, Cameron Shorter wrote:
> Following on from the discussion about Vector Rendering in browsers,
> I've put together my thoughts as to what the design should look like.
> (As a UML diagram)
> I've also included the raw UML (it was created on Umbrello using
> Linux).
> Cameron Shorter
> http://cameron.shorter.net
> <Layers.png>
> <Graphics.png>
> <Controls.png>
> <graphics.xmi>
> To unsubscribe, e-mail: webmap-discuss-unsubscribe at mail.osgeo.org
> For additional commands, e-mail: webmap-discuss-help at mail.osgeo.org
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20061013/933cb4ad/attachment.html
More information about the Dev mailing list
