[Dev] [webmap-discuss] VectorLayer design
Cameron Shorter cameron.shorter at gmail.com
Sat Oct 14 22:40:02 EDT 2006
Take 2 at the design:
To avoid swamping the list with large images, I've copied the diagrams
to my blog:
http://cameronshorter2.blogspot.com/2006/10/ajax-vector-rendering-design.html
On 10/15/06, Cameron Shorter <cameron.shorter at gmail.com> wrote:
> Thanks Dan, you are right. Now updated.
> Dan R. Greening wrote:
> > Just some skimmed-it comments:
> > Don't Polygon and Line each aggregate a List of Coord?  I would use the
> > diamond aggregate to denote this, because if you delete a Polygon you
> > presumably want all the Coords deleted also.  Pointer sort-of implies
> > the Coords have a life of their own.  Also maybe you want a 3..* on
> > Polygon and a 2 on Line.
> > Dan R. Greening, Ph.D.,  CEO BigTribe Corporation,
> > http://dan.greening.name/contact.htm
> > On Oct 13, 2006, at 5:32 AM, Cameron Shorter wrote:
> >> Following on from the discussion about Vector Rendering in browsers,
> >> I've put together my thoughts as to what the design should look like.
> >> (As a UML diagram)
> >> I've also included the raw UML (it was created on Umbrello using Linux).
> >> Cameron Shorter
> >> http://cameron.shorter.net
> >> <Layers.png>
> >> <Graphics.png>
> >> <Controls.png>
> >> <graphics.xmi>
> >> To unsubscribe, e-mail: webmap-discuss-unsubscribe at mail.osgeo.org
> >> <mailto:webmap-discuss-unsubscribe at mail.osgeo.org>
> >> For additional commands, e-mail: webmap-discuss-help at mail.osgeo.org
> >> <mailto:webmap-discuss-help at mail.osgeo.org>
> Cameron Shorter
Cameron Shorter
More information about the Dev mailing list
