[OpenLayers-Dev] [Dev] Re: Vectors in OpenLayers?
Cameron Shorter cameron.shorter at gmail.com
Fri Oct 20 07:15:22 EDT 2006
Bart van den Eijnden (OSGIS) wrote:
> Also, if somebody starts drawing new geometries from scratch, you will
> need a way to generate GML to insert them using a WFS. So not in all use
> cases will the client already have the data in GML format.
We already cover this use case in Mapbuilder, and I suggest we use the
same design pattern in this design.
When a User draws on a map, we process the mouseActions and create a GML
Layer. The GML Layer is rendered the normal way GML->Geometry
Classes->Vector Renderer.
Then when the user presses the SAVE button, you build a WFS Transaction
from the GML and send it to the server.
So there is no need for serialising from Geometry->GML.
> Cameron, are you suggesting to go for one format (WKT or GML), and then
> use the server-side to transform if necessary?
I think it will be a rare user requirement to convert from WKT->GML or
visa-versa in a Web Client. So I don't think it is worth spending too
much time addressing yet.
> If so, would you go for
> WKT or GML? In my opinion GML is the most logical option, it can always
> be transformed server-side to WKT if you need to go to something like
> PostGIS directly (without a WFS), since mostly we will talk to OGC web
> services and not to something like PostGIS directly. Disadvantage is
> that its structures are more elaborate than WKT.
I agree that GML would probably be better.
We have quite a bit of experience and code dealing with GML and WFS in
Mapbuilder, and we should be able to reuse that.
> Best regards,
> Bart
> Cameron Shorter schreef:
>> I'm wondering whether we will need to create a Geometry->GML serialiser.
>> In an application which uses GML, the rendering logic will go:
>> GML -> Geometry Classes -> Vector Rendering HTML
>> Ie, the client will already have the data in GML format.
>> If the user edits features, then we can have the tools update the data
>> source (GML in this case) which in turn will propagate the update
>> though to the Geometry and Renderer.
>> The other reason you might want to serialise is so that you can
>> convert from one format to another, eg WKT->Geometry->GML or similar.
>> However I suggest we keep vector transformation on the server,
>> probably as a web service.
>> Paul Spencer wrote:
>>> For you maybe ;)  GML would be another good output choice I guess
>>> Paul
>>> On 19-Oct-06, at 3:44 AM, Bart van den Eijnden (OSGIS) wrote:
>>>> Will there also be an option to serialize the objects as GML?
>>>> Since interaction will mostly be against OGC Web Services.
>>>> Best regards,
>>>> Bart
>>>> OSGIS, Open Source GIS
>>>> http://www.osgis.nl
>>>> --------- Oorspronkelijk bericht --------
>>>> Van: Paul Spencer <pspencer at dmsolutions.ca>
>>>> Naar: Pierre GIRAUD <bluecarto at gmail.com>
>>>> Cc: dev at openlayers.org
>>>> Onderwerp: Re: [OpenLayers-Dev] [Dev]  Re: Vectors in OpenLayers?
>>>> Datum: 19/10/06 00:09
>>>>> Hi Pierre,
>>>>> I haven't looked at the code but I think that this will be needed in
>>>>> some sort of factory object that can create Geometry (and associated
>>>>> Shape) objects from WKT.  We are a bit early for implementation
>>>>> details right now (despite the fact that I've already done a bunch of
>>>>> implementation), but when the design is finalized, we'll need this
>>>>> piece.
>>>>> This reminds me that Geometry objects need to be able to serialize
>>>>> themselves as WKT.
>>>>> Cheers
>>>>> Paul
>>>>> On 13-Oct-06, at 12:46 PM, Pierre GIRAUD wrote:
>>>>> &gt; I wanna propose you some peace of code for this.
>>>>> &gt; Hope you'll be able to have a quick look and check if I'm the
>>>>> good
>>>>> &gt; way.
>>>>> &gt;
>>>>> &gt; I tried to follow the &quot;factory&quot; pattern, but I'm
>>>>> not sure I
>>>>> &gt; implemented it right considering the rest of the architecture.
>>>>> &gt;
>>>>> &gt; Regards and nice week-end
>>>>> &gt;
>>>>> &gt; Pierre
>>>>> &gt;
>>>>> &gt; ps : this code might be useable in the current vector sandbox
>>>>> &gt;
>>>>> &gt; On 10/13/06, Pierre GIRAUD &lt;bluecarto at gmail.com&gt; wrote:
>>>>> &gt;&gt; I don't know if this is a needed functionnality, but it can
>>>> probably
>>>>> &gt;&gt; help. I was trying to think about and implement a way to
>>>>> add a
>>>>> &gt;&gt; feature
>>>>> &gt;&gt; by its WKT string writing.
>>>>> &gt;&gt;
>>>>> &gt;&gt; Something like :
>>>>> &gt;&gt;
>>>>> &gt;&gt; OpenLayers.Vector.WKT
>>>>> &gt;&gt;
>>>>> &gt;&gt; p4 = new OpenLayers.Vector.WKT('POINT(-40 30)');
>>>>> &gt;&gt;
>>>>> &gt;&gt; Regards
>>>>> &gt;&gt;
>>>>> &gt;&gt; Pierre
>>>>> &gt;&gt;
>>>>> &gt;&gt; On 10/13/06, Paul Spencer &lt;pspencer at dmsolutions.ca&gt;
>>>>> wrote:
>>>>> &gt;&gt; &gt; Thanks Chris :)
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; Performance really sucks if you add a lot of
>>>>> features.  I
>>>> wrote a
>>>>> &gt;&gt; &gt; quick loop to add a 1 degree box every 10 degrees and
>>>> brought my
>>>>> &gt;&gt; &gt; firefox to a halt.  Profiling reveals a number of
>>>> problematic
>>>>> &gt;&gt; areas,
>>>>> &gt;&gt; &gt; the biggest of which is getPx (of course).
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; I've done some optimization that improves
>>>>> performance in
>>>> this case:
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; * remove the call to Pixel.add(x,y) and directly
>>>>> modify the
>>>> pixel
>>>>> &gt;&gt; &gt; position - this was a big savings ...
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; * cached px location in the Point object based on
>>>>> the bounds
>>>> of the
>>>>> &gt;&gt; &gt; containing vectorLayer so getPx is only called when the
>>>> bounds have
>>>>> &gt;&gt; &gt; actually changed.
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; attached is a patch against the sandbox to
>>>>> incorporate these
>>>>> &gt;&gt; changes.
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; Next steps for me are:
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; * fix rendering in IE and Safari (that was the whole
>>>>> point
>>>> of using
>>>>> &gt;&gt; &gt; excanvas)
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; * further optimizations, including:
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt;    o try caching the bounds of each vector and test for
>>>>> &gt;&gt; intersection
>>>>> &gt;&gt; &gt; with layer bounds before rendering
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt;    o tighten inner loops and remove deep call chains
>>>> (possibly
>>>>> &gt;&gt; &gt; putting some of the pixel conversion stuff right into
>>>> convertToPx)
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt;   o anything else you can think of
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; * convenience functions for constructing polygons
>>>>> and lines
>>>> from
>>>>> &gt;&gt; &gt; points without having to construct intermediate objects
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; Other things that need to be done at some point, but
>>>>> not
>>>>> &gt;&gt; necessarily
>>>>> &gt;&gt; &gt; for 2.3:
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; * refactor the code (what, already?) so that the Vector
>>>>> &gt;&gt; architecture
>>>>> &gt;&gt; &gt; can support multiple rendering types (Canvas, SVG, VML,
>>>> possibly
>>>>> &gt;&gt; &gt; others in the future) by introducing Layer.Vector
>>>>> subclasses
>>>> and a
>>>>> &gt;&gt; &gt; new Rendering class that knows how to render into the
>>>> sub-classed
>>>>> &gt;&gt; &gt; layer types
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; * refactor styling support to make it less specific to
>>>> Canvas
>>>>> &gt;&gt; &gt; rendering stuff
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; * add some Controls for digitizing and possibly editing
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; Cheers
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; Paul
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; On 12-Oct-06, at 7:55 PM, Christopher Schmidt wrote:
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; &gt; On Thu, Oct 12, 2006 at 05:02:00PM -0400, Paul
>>>>> Spencer
>>>> wrote:
>>>>> &gt;&gt; &gt; &gt;&gt; Schuyler, et al
>>>>> &gt;&gt; &gt; &gt;&gt; attached is a first cut at the vector
>>>>> stuff.  It
>>>> extracts
>>>>> &gt;&gt; over an
>>>>> &gt;&gt; &gt; &gt;&gt; existing openlayers folder and contains
>>>>> only the
>>>> new files
>>>>> &gt;&gt; I've added
>>>>> &gt;&gt; &gt; &gt;&gt; plus a change to OpenLayers.js to load the
>>>>> extra
>>>> files by
>>>>> &gt;&gt; default
>>>>> &gt;&gt; &gt; &gt;&gt; (except for excanvas for some reason ;)).
>>>>> &gt;&gt; &gt; &gt;&gt; There is a vector.html in the examples folder.
>>>>> &gt;&gt; &gt; &gt;
>>>>> &gt;&gt; &gt; &gt; This code, with some improvements from Schuyler
>>>>> and I,
>>>> is now
>>>>> &gt;&gt; in place
>>>>> &gt;&gt; &gt; &gt; in a sandbox in the OpenLayers SVN. You can
>>>>> check out
>>>> with:
>>>>> &gt;&gt; &gt; &gt;
>>>>> &gt;&gt; &gt; &gt; svn co http://svn.openlayers.org/sandbox/sderle/
>>>>> vector/
>>>>> &gt;&gt; &gt; &gt;
>>>>> &gt;&gt; &gt; &gt; You can try it out at:
>>>>> &gt;&gt; &gt; &gt;
>>>>> &gt;&gt; &gt; &gt;
>>>> http://openlayers.org/~crschmidt/vector/examples/vector.html
>>>>> &gt;&gt; &gt; &gt;
>>>>> &gt;&gt; &gt; &gt; Click once to start drawing a line -- click
>>>>> again to
>>>> end it.
>>>>> &gt;&gt; &gt; &gt;
>>>>> &gt;&gt; &gt; &gt; FF only at the moment.
>>>>> &gt;&gt; &gt; &gt;
>>>>> &gt;&gt; &gt; &gt; Cool stuff, Paul, thanks for getting the ball
>>>>> rolling
>>>> on this.
>>>>> &gt;&gt; &gt; &gt; --
>>>>> &gt;&gt; &gt; &gt; Christopher Schmidt
>>>>> &gt;&gt; &gt; &gt; Web Developer
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; |Paul Spencer
>>>> pspencer at dmsolutions.ca    |
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; |Chief Technology Officer
>>>>> &gt;&gt; &gt; |DM Solutions Group Inc
>>>> http://www.dmsolutions.ca/ |
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt; _______________________________________________
>>>>> &gt;&gt; &gt; Dev mailing list
>>>>> &gt;&gt; &gt; Dev at openlayers.org
>>>>> &gt;&gt; &gt; http://openlayers.org/mailman/listinfo/dev
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt; &gt;
>>>>> &gt;&gt;
>>>>> &gt;&gt; &lt;wkt.html&gt;
>>>>> &gt;&gt; &lt;WKT.js&gt;
>>>>> |Paul Spencer                          pspencer at dmsolutions.ca    |
>>>>> |Chief Technology Officer                                         |
>>>>> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
>>>>> Dev mailing list
>>> Dev mailing list
Cameron Shorter
http://cameron.shorter.net
More information about the Dev mailing list
