[OpenLayers-Dev] WMC on WMSManager
Lorenzo Becchi lorenzo at ominiverdi.com
Wed Aug 1 06:08:20 EDT 2007
Thx Cameron, great news from you.
> I'm CCing Tom Kralidis who is/was/should be/.. the editor of the OWS
> Context spec and has been very helpful with the Mapbuilder use of
> Context.
> Tom should be able to add insight into upcoming Context terms. For
> example, the visibility attribute has been earmarked for future
> versions and is already implemented by Mapbuilder.
> A good test of interoperability would be to export a Context document
> from Mapbuilder then load it into Openlayers and visa-versa.
it would be a great test.
are there some desktop applications (uDig maybe) supporting WMC?
ciao
Lorenzo
> Lorenzo Becchi wrote:
>> Tim, I do agree with all your suggestions.
>> Actually I can just go on holidays and wait you to do the job for us,
>> I'm sure it will be better that whatever I can do alone.
>> I'll go on holidays tomorrow (15 days) but I'm available for the
>> debate today.
>> Let me know if you want to chat about it.
>> #openlayers ?
>> I think we can already debate about a timetable and see if and where
>> I can help you to integrate your work.
>> Let's try to see who else want to join (seems Erik has already
>> something in his hands).
>> I suggest to use your Wiki page to manage this:
>> http://trac.openlayers.org/wiki/Future/MapContext
>> see you later
>> Lorenzo
>> Tim Schaub wrote:
>>> A few ideas:
>>> It would be good to start working towards a JavaScript structure for
>>> the map context.  For OL, this structure would contain all relevant
>>> layer information and the current map center/resolution.  On the WMC
>>> side, we should discuss how to standardize the extensions to WMC to
>>> account for OL specific stuff.
>>>   This structure should be serialized/deserialized with a JSON parser.
>>> http://dev.openlayers.org/sandbox/tschaub/geojson/lib/OpenLayers/Format/JSON.js
>>> (for example - and you can do format.write(obj, pretty) too)
>>> In addition to translating this structure into a WMC doc, we should
>>> be able to translate it into a short string - though this will be
>>> lossy, it can be used to replace the permalink logic.
>>> All this could be handled by a control like
>>> OpenLayers.Control.Context or OpenLayers.Control.ApplicationState.
>>> This control would use the JSON format and a (yet to be built) WMC
>>> format.
>>> I'll be working on this sort of stuff over the next couple months.
>>> I look forward to collaborating.
>>> Tim
>>>> Click on the bottom-right button "WMC Exporter" to see a pop-up
>>>> with the JSON code of the WMC.
>>>> Naturally you can alter the map with WMSManager and the WMC
>>>> "should" be updated.
>>>> as you can see:
>>>> - the structure is not a perfect WMC. I've took a look from the 1.1
>>>> specs but there are things to be cleaned up.
>>>> - some values are empty or null. Still have to decide if it make
>>>> sense to use all of them. We can decide together which optional
>>>> elements not to support.
>>>> - I've added a "visibility" attribute to Layer object because WMC
>>>> is not providing it. Some hint how to avoid this? I'm sure you
>>>> understand how this is important for OL to define base or overlay
>>>> layers.
>>>> as you can't see:
>>>> - not all values are dinamically set. Some are still hardcoded.
>>>> there's another problem about attributes of Layers with multiple
>>>> WMS layers inside. Which title, abstract to use? does it make sense
>>>> to create a comma (or something else) separated list of values?
>>>> I'm still not sure if the MapContext should be part of the OL.Map
>>>> object or an external Tool.
>>>> I'll go on with the external tool and hope to create soon a
>>>> WMCParser to import WMCs.
>>>> My hope was to offer something better before leaving for holidays
>>>> but many meeting/debate/ecc at work delayed coding time.
>>>> I'll leave in 2 days and be back for the third week of August. In
>>>> the meantime I'll be available for debate about this solution.
>>>> ciao
>>>> Lorenzo
>>>> _______________________________________________
>>>> Dev mailing list
>>>> Dev at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/dev
>>>> !DSPAM:4033,46adec84154021431913854!
>>> Dev mailing list
>> Dev mailing list
More information about the Dev mailing list
