[OpenLayers-Dev] overview map on safari 3
nuzakat nuzakat.ali at gmail.com
Sun Aug 19 21:11:05 EDT 2007
Glen u silly bum, u cud've just turned around n said that to me =^D
Anyways the problem was that our div was initially set to hide, and wen it
was meant to unhide safari wouldn't let this happen coz it still saw the div
as size 0 (or something on the lines of that) There is actually a fix made
for this div size 0 problem, but for some reason wouldn't work with the
overview map, most probably due to layers.
So solution was to simply say overViewMapDiv.style.display="block" in the
section of code that unhides the overview map.
Nuzakat
Glen Stampoultzis-2 wrote:
> On 09/08/07, Lance Dyas <lancelot at inetnebr.com> wrote:
>> nuzakat wrote:
>> > Hi, i was wondering if there was a workaround or fix to get the
>> overview
>> map
>> > working on safari for windows - safari beta 3.
>> > Currently my overview map works on firefox n ie, but not safari. In
>> safari
>> > it doesn't even show up, only the border divs do.
>> > Any help would b superb.
>> Not that I know of... this problem has yet to be addressed.
>> Safari 3 is blazing fast in the JavaScript intensive arena like Open
>> Layers and similar mapping api.
>> http://celtickane.com/projects/jsspeed.php
>> the above test page clocks it as fast as opera.
> Actually we ran into this issue as well.  I think the solution was
> something
> to do with a layer visibility bug in Safari.  I'll chase down the exact
> details and post back.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
View this message in context: http://www.nabble.com/overview-map-on-safari-3-tf4239997.html#a12228761
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
