[OpenLayers-Dev] Question about GML serialization
Tim Schaub tschaub at openplans.org
Wed Aug 22 17:49:07 EDT 2007
Cross-browser GML serialization will be in the 2.5 release.
Tim
Jc Albert wrote:
> Hello,
> I have problems about GML serialization : when I serialize a gml layer,
> I loose original polygons coordinates.
> I did the following test :
> example/gml-serialize.html
> L29 - var pointLayer = new OpenLayers.Layer.Vector("Point Layer");
> L29 + var pointLayer = new OpenLayers.Layer.GML("Point
> Layer","gml/polygon.xml");
> When you start the sample, you'll see that polygons described inside
> polygon.xml have 'undefined,undefined' as coordinates when they are
> serialized. I you draw a new polygon, coordinates are ok for this new one.
> Do I forget something to make it work correctly ?
> And about dom serialization on IE/Opera , I found this doc if someone is
> interrested :
> http://www.faqts.com/knowledge_base/view.phtml/aid/34646
> Thanks.
> Jc.
> Ne gardez plus qu'une seule adresse mail ! Copiez vos mails
> <http://www.trueswitch.com/yahoo-fr/> vers Yahoo! Mail
> !DSPAM:4033,46cc0020315074901796417!
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
