[OpenLayers-Dev] GML examples?
John Cole john.cole at uai.com
Sun Aug 26 13:55:35 EDT 2007
Christopher,
  Try http://docs.codehaus.org/display/GEOS/Available+WMS+and+WFS+servers
  One way I want to use OL, is to have a simple web service that makes a SQL
call to PostGIS or MsSqlSpatial (using asGML) and have OL handle that
output.  That might not be the correct way, but its one way I want to do it
John
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Sunday, August 26, 2007 10:36 AM
To: John Cole
Cc: dev at openlayers.org
Subject: Re: [OpenLayers-Dev] GML examples?
On Sat, Aug 25, 2007 at 08:28:43PM -0500, John Cole wrote:
> Christopher,
>   Have you tried the PostGIS AsGML function?  I'm not sure if it will work
> for you or not.  You might only get fragments out of it.
John --
Generating chunks of GML that I would use isn't too hard -- I was hoping
to find things that other people would use, so we could confirm that
those work, since (as I've discovered the hard way) GML is an extremely
flexible language.
I'm oping to find some 'real life' examples -- at least some people are
using WFS against a variety of servers, and hopefully, they have some
output that they would like to see supported. I've found that creating
my own contrived examples is not the most effective mechanism for
solving the problem in the case of GML -- I always contrive the wrong
example. :)
Regards,
Christopher Schmidt
MetaCarta
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.484 / Virus Database: 269.12.8/973 - Release Date: 8/25/2007
5:00 PM
No virus found in this outgoing message.
5:00 PM
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
More information about the Dev mailing list
