[OpenLayers-Dev] Drag events + OpenLayers
Christopher Schmidt crschmidt at metacarta.com
Tue Aug 28 09:55:14 EDT 2007
In response to:
http://openlayers.org/pipermail/dev/2007-July/001069.html
[OpenLayers-Dev] OpenLayers dragging issue
I remembered a couple weeks ago that the way to make this work --
without adding code to OpenLayers -- is to set the fallThrough property
on the map to 'true'.
http://dev.openlayers.org/apidocs/files/OpenLayers/Map-js.html#OpenLayers.Map.fallThrough
http://trac.openlayers.org/ticket/457
Just so everyone knows that you can let the events fall through the map.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
