[OpenLayers-Dev] Semicolons
Erik Uzureau erik.uzureau at metacarta.com
Fri Aug 31 10:50:59 EDT 2007
Excellent!
Thanks Paul and Jeff for your quick and insightful responses. I agree
with this approach and will go back and remove those extra ;'s I've
just added. :-)
Erik
On 8/31/07, Paul Spencer <pspencer at dmsolutions.ca> wrote:
> Erik,
> I am in favour of a coding style that is syntatically (?) correct
> while requiring the minimum amount of typing.
> I believe that using this style:
> var foo = function() {};
> does require the semi-colon at the end of the statement while:
> function foo() {}
> doesn't.  I have tested this with jslint and it reports a warning if
> the semi-colon is missing in the first case and not in the second
> case.  An extra semi-colon does not cause a syntax warning either.
> As you know, javascript allows some laxity with semi-colons and the
> only time it really bites you is when you want to compress stuff, so
> I'm not really strongly opinionated if this is for test cases that
> are unlikely to be compressed.  However, as a matter of habit, I
> believe that we should use semi-colons in the first style of coding
> and not in the second because the encourages an understanding of why
> the semi-colons are required (or not) which means we will understand
> the language a little better.
> Cheers
> Paul
> On 31-Aug-07, at 10:25 AM, Erik Uzureau wrote:
> > In a bout of friday afternoon lunacy, I began adding semicolons to the
> > end of the function declarations in the tests files.
> > The original impetus for this was that I noticed that doing so reduced
> > the number of errors reported by the JSEclipse plugin that I use for
> > my JS development work. Certainly neither an urgent nor universal
> > change, but I need to spin some brain cycles.
> > Someone else has brought it to my attention that s/he is *not* in
> > favor of that style....
> > I prefer:
> > function foo() {};
> > and
> > whereas s/he prefers:
> > function foo() {}
> > and
> > do others have an opinion on this? the OC in me wants everything to be
> > the same in our code, and I'm more than willing to rollback the
> > changes I've just done if people are in favour of the other way of
> > doing it.
> > Please cast a vote if you have some thoughts.
> > Erik
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
> |Paul Spencer                          pspencer at dmsolutions.ca    |
> |Chief Technology Officer                                         |
> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
> Dev mailing list
More information about the Dev mailing list
