[OpenLayers-Dev] Dev Digest, Vol 11, Issue 28
lszklanny at where2getit.com lszklanny at where2getit.com
Fri Aug 31 12:46:04 EDT 2007
> Send Dev mailing list submissions to
> 	dev at openlayers.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://openlayers.org/mailman/listinfo/dev
> or, via email, send a message with subject or body 'help' to
> 	dev-request at openlayers.org
> You can reach the person managing the list at
> 	dev-owner at openlayers.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Dev digest..."
> Today's Topics:
>   1. Semicolons (Erik Uzureau)
>   2. Re: Semicolons (Jeff Dege)
>   3. Re: Semicolons (Paul Spencer)
>   4. Re: Semicolons (Erik Uzureau)
>   5. Re: Semicolons (John Cole)
> Message: 1
> Date: Fri, 31 Aug 2007 16:25:56 +0200
> From: "Erik Uzureau" <erik.uzureau at metacarta.com>
> Subject: [OpenLayers-Dev] Semicolons
> To: "dev at openlayers" <dev at openlayers.org>
> Message-ID:
> 	<6ae3fb590708310725m7e93433bj79cbf4550cde1e61 at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> In a bout of friday afternoon lunacy, I began adding semicolons to the
> end of the function declarations in the tests files.
> The original impetus for this was that I noticed that doing so reduced
> the number of errors reported by the JSEclipse plugin that I use for my
> JS development work. Certainly neither an urgent nor universal
> change, but I need to spin some brain cycles.
> Someone else has brought it to my attention that s/he is *not* in
> favor of that style....
> I prefer:
> function foo() {};
> and
> var foo = function() {};
> whereas s/he prefers:
> function foo() {}
> and
> do others have an opinion on this? the OC in me wants everything to be
> the same in our code, and I'm more than willing to rollback the
> changes I've just done if people are in favour of the other way of
> doing it.
> Please cast a vote if you have some thoughts.
> Erik
> Message: 2
> Date: Fri, 31 Aug 2007 09:30:32 -0500
> From: "Jeff Dege" <jdege at korterra.com>
> Subject: Re: [OpenLayers-Dev] Semicolons
> To: "Erik Uzureau" <erik.uzureau at metacarta.com>,	"dev at openlayers"
> Message-ID:
> 	<34E056CD4D475841B8C9ABCE956F92F6370B15 at mrburns.KorOffice.local>
> Content-Type: text/plain;	charset="us-ascii"
>> On Friday, August 31, 2007 9:26 AM, Erik Uzureau wrote:
>> To: dev at openlayers
>> I prefer:
>> function foo() {};
>> and
>> function foo() {}
>> and
>> doing it.
> In the languages I cut my teeth on, this is a function declaration:
> function foo() {}
> And this is an assignment statement with an inline function for the
> rhs:
> And I'm used to semicolon terminators for assignment statements, but
> not for function declarations.
> The most important question, though, is what does the language standard
>  say?
> Message: 3
> Date: Fri, 31 Aug 2007 10:34:26 -0400
> From: Paul Spencer <pspencer at dmsolutions.ca>
> Cc: "dev at openlayers" <dev at openlayers.org>
> Message-ID: <EB23FA0D-B690-4645-864F-A7132B0D3097 at dmsolutions.ca>
> Content-Type: text/plain; charset=US-ASCII; delsp=yes; format=flowed
> Erik,
> I am in favour of a coding style that is syntatically (?) correct
> while requiring the minimum amount of typing.
> I believe that using this style:
> does require the semi-colon at the end of the statement while:
> function foo() {}
> doesn't.  I have tested this with jslint and it reports a warning if
> the semi-colon is missing in the first case and not in the second
> case.  An extra semi-colon does not cause a syntax warning either.
> As you know, javascript allows some laxity with semi-colons and the
> only time it really bites you is when you want to compress stuff, so
> I'm not really strongly opinionated if this is for test cases that
> are unlikely to be compressed.  However, as a matter of habit, I
> believe that we should use semi-colons in the first style of coding
> and not in the second because the encourages an understanding of why
> the semi-colons are required (or not) which means we will understand
> the language a little better.
> Cheers
> Paul
>> my JS development work. Certainly neither an urgent nor universal
>> I prefer:
>> function foo() {};
>> and
>> function foo() {}
>> and
>> doing it.
>> Erik
>> Dev mailing list
>> Dev at openlayers.org
> |Paul Spencer                          pspencer at dmsolutions.ca    |
> |Chief Technology Officer                                         | |DM
> Solutions Group Inc                http://www.dmsolutions.ca/ |
> Message: 4
> Date: Fri, 31 Aug 2007 16:50:59 +0200
> To: "Paul Spencer" <pspencer at dmsolutions.ca>
> Message-ID:
> 	<6ae3fb590708310750y58025743s152a161e11f6b5ad at mail.gmail.com>
> Excellent!
> Thanks Paul and Jeff for your quick and insightful responses. I agree
> with this approach and will go back and remove those extra ;'s I've
> just added. :-)
> Erik
> On 8/31/07, Paul Spencer <pspencer at dmsolutions.ca> wrote:
>> Erik,
>> function foo() {}
>> I'm not really strongly opinionated if this is for test cases that are
>> unlikely to be compressed.  However, as a matter of habit, I believe
>> that we should use semi-colons in the first style of coding and not in
>> the second because the encourages an understanding of why the
>> semi-colons are required (or not) which means we will understand the
>> Cheers
>> Paul
>> > the end of the function declarations in the tests files.
>> > reduced the number of errors reported by the JSEclipse plugin that I
>> > use for my JS development work. Certainly neither an urgent nor
>> > universal change, but I need to spin some brain cycles.
>> > I prefer:
>> > function foo() {};
>> > and
>> > function foo() {}
>> > and
>> > be the same in our code, and I'm more than willing to rollback the
>> > doing it.
>> > Erik
>> > Dev mailing list
>> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
>> Dev mailing list
> Message: 5
> Date: Fri, 31 Aug 2007 10:18:40 -0500
> From: John Cole <john.cole at uai.com>
> To: 'Erik Uzureau' <erik.uzureau at metacarta.com>, Paul Spencer
> Message-ID: <76758090F8686C47A44B6FF52514A1D307909E44 at hermes.uai.int>
> Content-Type: text/plain;	charset="windows-1250"
> To add a different opinion, I always use the semicolons.  Why?  To
> avoid side effects and avoid ambiguity.  With large projects, we have
> run into the situation where a dangling line creates syntactically
> legal, but logically wrong code.  And it can be confusing trying to
> understand why removing (or adding) a blank line can change how a
> program operates.
>>From the O'reilly JS book:
> return
> true
> Is interpreted as
> return;
> true;
> When you really meant "return true;"
> You can also find weird assignments when someone doesn?t remove a '+'
> at the end of a concatenation that would be easier to see if the ';'
> were always at the end of the line.
> Remember, JS is actually putting the ';' in, it's just trying to figure
> out where they go.  It's not that they are not needed; it's a matter of
> who puts them in.
> "Omitting semicolons is not a good programming practice; you should get
> in the habit of using them." --JavaScript, The Definitive Guide,
> O'Reilly, 4th Edition
> John
> -----Original Message-----
> From: dev-bounces at openlayers.org [mailto:dev-bounces at openlayers.org] On
> Behalf Of Erik Uzureau
> Sent: Friday, August 31, 2007 9:51 AM
> To: Paul Spencer
> Cc: dev at openlayers
> Excellent!
> just added. :-)
> Erik
>> Erik,
>> function foo() {}
>> Cheers
>> Paul
>> > I prefer:
>> > function foo() {};
>> > and
>> > function foo() {}
>> > and
>> > doing it.
>> > Erik
>> > Dev mailing list
>> Dev mailing list
> Dev mailing list
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.484 / Virus Database: 269.13.1/981 - Release Date:
> 8/31/2007 6:13 AM
> No virus found in this outgoing message.
> 8/31/2007 6:13 AM
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed. If you have received this email in error please notify
> the sender. This message contains confidential information and is
> intended only for the individual named. If you are not the named
> addressee you should not disseminate, distribute or copy this e-mail.
> Dev mailing list
> End of Dev Digest, Vol 11, Issue 28
I'd like to point that some compressors are very sensitive to missing
semicolons separating statements, e.g. Dean Edward's Packer.
Les
More information about the Dev mailing list
