[OpenLayers-Dev] Debugging OpenLayers
Erik Uzureau erik.uzureau at metacarta.com
Tue Jun 5 16:28:41 EDT 2007
Seems OK to me. My only fear is that our code becomes littered with these
debug statements.
Assuming that we can:
 * follow a sane policy of only committing code with these debug statements
in cases where it is *known* that the code will fail
 * avoid slipping into the habit of developing code that fails and raises
exceptions instead of simply writing good working code in the first place.
...then I suppose I'm a +0 :-)
Erik
On 6/5/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Tue, Jun 05, 2007 at 01:15:48AM -0600, Tim Schaub wrote:
> > If this sounds like a good idea to folks, I'd encourage us to start
> > using OpenLayers.Console methods and come up with some best practices
> > for the first two points above.
> I'm totally in favor of this, and think that you've done a great job on
> it. Thanks for pounding through it.
> I'd like to hear from other developers: What do you like about this?
> What does it do that you want? What doesn't it do that you do want? What
> does it do that you don't want?
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070605/a255c09c/attachment.html
More information about the Dev mailing list
