[OpenLayers-Dev] Vector Diffs
Erik Uzureau erik.uzureau at metacarta.com
Thu Mar 15 01:52:46 EDT 2007
On 3/14/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> Tonight, I went through
> svn diff http://svn.openlayers.org/trunk/openlayers/lib/
> http://svn.openlayers.org/sandbox/vector-2.4/lib/  and looked at every
> line.
> Follows is a summary of changes to the existing OpenLayers code. The only
> non-documentation/functional changes to existing files were:
> Events:
> OpenLayers/Events.js
> Added registerPriority function, which puts a listener at the beginning of
> the list.
> OpenLayers/Control.js
>  * Added activate/deactivate methods which set active flag and return
>    true or false depending on whether the state has changed.
>  * Calculate a default displayClass:
>    this.displayClass = this.CLASS_NAME.replace("OpenLayers.",
>                                     "ol").replace(".","");
>  * Added OpenLayers.Control.TYPE_BUTTON, TYPE_TOOL constants for
>    building toolbar controls.
>  * setMap will now call setMap on any handler property on the control.
> OpenLayers/Map.js
> default controls changed from using MouseDefaults to using Navigation
> control.
This is the only item in this entire list that peaks my interest. I'm
wondering if
for any reason this might cause problems for some people? Anyone out
there in the community see any danger in this? I have no technical justification
for this curiosity, it just makes me nervous is all.
> OpenLayers/Ajax.js
> If given a 'postBody' parameter, the content-type is no longer set to
> x-www-form-encoded. This allows us to post WFS data. x-www-form-encoded
> data can still be passed using parameters and setting 'method' to 'post'.
> OpenLayers/BaseTypes.js
> Add an 'extend' method to Bounds().
> OpenLayers/Layer/WFS.js -- still working on this one.
> The rest of the changes are either:
>  * New files
>  * Only documentation changes.
> In total, changes in existing files account for only ~50 lines of code.
> The rest of the changes are described here.
> Controls:
> OpenLayers/Control/EditingToolbar.js -- New file.
> OpenLayers/Control/DrawFeature.js -- New file.
> OpenLayers/Control/DragPan.js -- new file. Used by navigation control.
> OpenLayers/Control/ZoomToMaxExtent.js -- new file. demo of 'button' functionality.
> OpenLayers/Control/SelectFeature.js -- new file.
> OpenLayers/Control/ZoomBox.js -- new file. used by Navigation control.
> OpenLayers/Control/Panel.js -- new file. Used for building toolbars
>                                (navtoolbar,editingtoolbar)
> OpenLayers/Control/MouseDefaults.js -- added deprecation warning.
> OpenLayers/Control/MouseToolbar.js -- added deprecation warning.
> OpenLayers/Control/Scale.js
> OpenLayers/Control/OverviewMap.js
> OpenLayers/Control/MousePosition.js
> OpenLayers/Control/Permalink.js
> Modified classNames to use new 'this.displayClass', so constants like
> 'olControlOverviewMapElement' can now be overridden by setting displayClass
> as an option on the layer. No functional changes.
> OpenLayers/Control/KeyboardDefaults.js
> Refactored to use Handlers. (Since this has never been released, changing
> the internals is not painful.)
> OpenLayers/Control/Navigation.js -- replaces MouseDefaults.
> OpenLayers/Control/NavToolbar.js -- replaces MouseToolbar.
> OpenLayers/Renderer.js
> OpenLayers/Renderer/Elements.js
> OpenLayers/Renderer/SVG.js
> OpenLayers/Renderer/VML.js
> New files to support vector drawing. Used by Layer.Vector and its
> subclasses. Renderer/Elements is a subclass of SVG/VML, used to capture the
> similiarities inherent in element-based renderers.
Just a small note for the record -- Renderer.Elements is a
*super*class of SVG/VML :-)
> Handlers:
> OpenLayers/Handler.js
> OpenLayers/Handler/Polygon.js
> OpenLayers/Handler/Box.js
> OpenLayers/Handler/Keyboard.js
> OpenLayers/Handler/Path.js
> OpenLayers/Handler/Point.js
> OpenLayers/Handler/Drag.js
> OpenLayers/Handler/Select.js
> OpenLayers/Handler/MouseWheel.js
> As part of evaluation of the MouseListener code, we realized that there is
> a level of abstraction that was not really well defined in the code.
> Essentially, there are a number of core events -- like drawing a box,
> dragging the mouse, and drawing point/path/polygon features -- below the level
> of the "Controls". In order to make developing controls more modular and
> easier, we've migrated this functionality into a set of handlers which
> encapsulates these methods. As described in a mailing list post, this has
> made things like MouseDefaults a trivial control using these handlers.
> -- http://trac.openlayers.org/wiki/Handlers
> Formats:
> OpenLayers/Format.js
> OpenLayers/Format/GML.js -- full read/write
> OpenLayers/Format/WFS.js -- subclass of GML, WFS-T writing
> OpenLayers/Format/KML.js -- read only
> OpenLayers/Format/GeoRSS.js -- write only
> Formats define two methods: a 'read' and 'write'. read takes some data --
> string, XML document, etc. -- and returns a list of features. KML and
> GeoRSS are partial implementations as part of a proof of concept, and can
> be finished via interested parties. Formats are new in the vector-2.4
> branch.
> Geometries:
> OpenLayers/Geometry.js
> OpenLayers/Geometry/Curve.js
> OpenLayers/Geometry/MultiPoint.js
> OpenLayers/Geometry/Rectangle.js
> OpenLayers/Geometry/Polygon.js
> OpenLayers/Geometry/Surface.js
> OpenLayers/Geometry/MultiLineString.js
> OpenLayers/Geometry/Point.js
> OpenLayers/Geometry/LinearRing.js
> OpenLayers/Geometry/Collection.js
> OpenLayers/Geometry/LineString.js
> OpenLayers/Geometry/MultiPolygon.js
> Geometries store geographic information. Features have geometries. (You
> can't draw a geometry: you draw a feature, which has a geometry and style.)
> OpenLayers/Feature/Vector.js
> Subclass of Feature specifically for Vector rendering.
> Layers:
> OpenLayers/Layer/Vector.js -- Simple base class. Allows for drawing of
>  features directly.
> OpenLayers/Layer/GML.js -- Load remote data, parse it based on the chosen
>   parser, and display it as vectors. (This means it is also Layer.KML,
>   by changing the format in use.)
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
