[OpenLayers-Dev] EPSG:41001
Christopher Schmidt crschmidt at metacarta.com
Fri May 25 09:35:39 EDT 2007
On Fri, May 25, 2007 at 09:21:35AM -0400, Gilbert, Antoine wrote:
> Ok I finally made it, I had lot of errors, now it seems to be ok, my
> tiles are fitting perfectly and the bounds passed to my getURL() method
> are in 41001 format instead of long-lat.
> As I was expecting I have some issues with labels and symbols (I was
> figuring it before knowing openlayers). For example, one label rendered
> in one tile but not displayed entirely in the tile may not fit with the
> same label on the next tile, etc. etc.
Yes. If you're using mapserver, "PARTIALS OFF" is good. either way,
TileCache with metatiling would also help.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
