[OpenLayers-Dev] [crschmidt@metacarta.com: [OSM-dev] Faster Commercial Layers]
Paul Spencer pspencer at dmsolutions.ca
Wed Nov 21 08:29:17 EST 2007
Chris,
this works really well for me in firefox on macosx.  Excellent find.
Paul
On 21-Nov-07, at 8:20 AM, Christopher Schmidt wrote:
> Sigh. Sending emails at 3:45 is worse than committing at 3:30. This
> went
> to the osm-dev instead of ol-dev list.
> -- Chris
> ----- Forwarded message from Christopher Schmidt <crschmidt at metacarta.com
> From: Christopher Schmidt <crschmidt at metacarta.com>
> To: dev at openstreetmap.org
> Date: Wed, 21 Nov 2007 03:49:34 -0500
> Subject: [OSM-dev] Faster Commercial Layers
> The three commonly used commercial layers -- Google, VirtualEarth, and
> Yahoo -- now each have a mechanism using the internals of their
> respective APIs to grab faster ways to move map tiles around.
> http://openlayers.org/dev/examples/spherical-mercator.html now
> demonstrates this.
> Erik reports that IE is throwing an error. Since is it 3:45 in the
> morning, I'm going to go to sleep now, get an early start and try to
> hack on the IE issue first thing before work, and get it resolved.
> In the meantime, Firefox browsers might be interested in checking the
> uRL above and checking out the other APIs.
> (Note that Yahoo/VE both have weird ideas about what to do when
> viewing
> the whole world -- best to zoom in a couple notches.)
> Additionally, there is an option on the EventPane layer class:
> {Boolean} smoothDragPan determines whether non-public/internal API
> methods are used for better performance while dragging EventPane
> layers.
> When not in sphericalMercator mode, the smoother dragging doesn’t
> actually move north/south directly with the number of pixels moved,
> resulting in a slight offset when you drag your mouse north south with
> this option on.  If this visual disparity bothers you, you should turn
> this option off, or use spherical mercator.  Default is on.
> Feedback welcome; I'm hoping that at least some if it will be positive
> Regards,
> Christopher Schmidt
> MetaCarta
> dev mailing list
> http://lists.openstreetmap.org/cgi-bin/mailman/listinfo/dev
> ----- End forwarded message -----
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
More information about the Dev mailing list
