[OpenLayers-Dev] Know of any offline datasets compatible with OpenLayers?
Christopher Schmidt crschmidt at metacarta.com
Fri Nov 23 08:44:41 EST 2007
On Fri, Nov 23, 2007 at 09:07:47AM +0000, Ian Mayo wrote:
> > Totally offline data can be easy... if it is small or your storage is
> > big. Storing the top 7 levels of the vmap0 dataset as tiles
> > is something like 200MB of data. Depending what you actually want to do,
> > this might be useful or not -- but I'm almost positive that it's going
> > to be more useful than trying to actually draw the world as a vector.
> I presume you're describing the use of a standalone mapping server to
> support the OpenLayer instance.
Nope. I've done it in the past (http://labs.metacarta.com/on-a-stick/)
by pre-generating a cache using TileCache, then using the
Layer.TileCache class to access it.
> I'm hoping to avoid this - with the
> user just having to double-click on "index.html" & view the mapping
> data.
Right, I understand that. Though I'll point out that it is possible to
bundle all dependancies for a full OpenLayers stack into a single,
small, Python based Webserver, and use that to server data... Then
you've got Linux and OS X support, and if you build your distribution
right, Windows support too.
> Overall, it seems the only way to get external data in is via cached
> WMS images.  So, the best I can think of is to "somehow" get a world
> vector shoreline dataset written as transparent-gif images in world
> wind data format, then display these images as a "higher" layer than
> any other image layers: thus overlaying a coastline.
Er, yes. I'm not sure why you make it sound so speculative, though :)
Does the task sound unusual or difficult to you in some way?
You can use the world freemap dataset:
http://data.freemap.in/view/DataSet/1
Combined with a lightweight mapfile, you can get a nice set of world
borders from this: http://world.freemap.in/
Then use TileCache, tilecache_seed it down to zoom 6 or what have you,
and dump the tiles over to a disk.
This isn't new territory for me, so if you're confused on the matter,
please feel free to respond and ask more questions.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
