[OpenLayers-Dev] Code Sprint: Context
Cameron Shorter cameron.shorter at gmail.com
Mon Oct 1 17:46:08 EDT 2007
Mapbuilder has history tools.
When you get to implementing this, could you please touch base with the
Mapbuilder developers and code. If done right it should make it easier
for Mapbuilder to integrate with the Openlayers functionality.
Christopher Schmidt wrote:
> Tim Schaub and Lorenzo (of the little green men) sat down and started
> working on serializing and deserializing OpenLayers Map objects: you can
> see some results of that work in the context sandbox:
> http://dev.openlayers.org/sandbox/context/examples/context.html
> This is the first step to having a full history tool, which allows a
> user to do things like 'back button support' that have been worked on in
> the past.
> Regards,
Cameron Shorter
Systems Architect, http://lisasoft.com.au
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
More information about the Dev mailing list
