[OpenLayers-Dev] OpenLayers.Popup status
Christopher Schmidt crschmidt at metacarta.com
Fri Oct 12 09:57:23 EDT 2007
On Fri, Oct 12, 2007 at 07:10:58AM +0200, Jachym Cepicky wrote:
> hi,
> I wanted to ask about the status of "Google" popups in OpenLayers. I
> managed more or less to port example from Richard Thurbin [1] to current
> trunk version of OpenLayers. However, as far as I saw, the code uses
> different approach for Popup decorations (images vs. rico rounded
> corners) and other details. So, I would like to ask, if it makes sense
> to continue in the porting and clean the code little bit, so it could be
> merged to trunk
> or
> if completely different approach is to be used and there is already
> defined concept or living demo, which will go to trunk in the future.
It is expected that the work done on the CloudAmber popups will be moved
into trunk directly -- the rico rounded corners style popups simply
don't have the ability to do what people want as far as 'pretty' look
and feel, so we're going to need the option that the CloudAmber popups
provide.
I do not think we've done neough investigation to figure out the exact
method of plling them in, but writing tests, etc. for them at this point
is likely to be extremely beneficial and accelerate acceptance into
trunk, even if things change.
Regards,
Christopher Schmidt
MetaCarta
More information about the Dev mailing list
