[OpenLayers-Dev] Layers into Groups
olivier.terral olivier.terral at geomatys.fr
Fri Oct 19 12:47:27 EDT 2007
Ola,
Sorry , I think it's  Vincent Schut who did that but I 've often
manipulated  Group layers .
I don't know what is it specified in OWS spec but I know  what is done
in Mapbuilder.
We have choosen to add <Group> in an Extension tag because the spec was
not clear with groups and the Extension tag permits to add everything we
want  (that's I've understood).
All groups are specified inside the  General/Extension tags :
  <ViewContext>
           <General>
        <Extension>
            <GroupList>
                <Group name="groupe1" folded="1"/>
                <Group name="groupe2" folded="1"/>
            </GroupList>
        </Extension>
</General>
and if a Layer is a member of a Group, it's specified in its extension
tag like said Steven
<Layer queryable="1" hidden="0">
			<Server service="wms" version="1.1.1" title="geo-demo15">
			<OnlineResource xlink:type="simple" xlink:href="/geoserver/wms?" />
			</Server>
			<Name>geom:rivers_mercator</Name>
			<Title>Rivières,fleuves</Title>
			<SRS>EPSG:3395</SRS>
			<StyleList>
			</StyleList>
			<FormatList>
				<Format current="1">image/png</Format>
			</FormatList>
			<Extension>
				<Group name="groupe2" />
			</Extension>
</Layer>
But actually, this way of define groups is very limited because there is
only one level possible.
May be we should improve this solution to permit a tree view as I've
seen in the demo of Armïn
http://rips-uis.lubw.baden-wuerttemberg.de/rips/wms_viewer/test/myOpenLayer.php
Gertjan van Oosten a écrit :
> As quoted from "Steven M. Ottens" <steven at minst.net>:
>> The mapbuilder code uses
>> //wmc:ResourceList/wmc:Layer[wmc:Extension/wmc:Group/@name=$GroupName]
>> So this means that it selects the layers which have a group-extension.
> The grouping thing is only supported in the OWSContext spec I believe
> (not in the WMC).  The future of the OWSContext spec is unclear to me, BTW.
>> I believe the structure is hierarchical, so using group/layer approach
>> should be consistent with the OWS spec.
>> But I'm not the real expert, I though gertjan did the grouping code, but
>> could be wrong.
> I don't think I did that, I seem to recall Olivier (Cc'ed) did that?
> Regards,
More information about the Dev mailing list
