[OpenLayers-Dev] status of translation possibilities
Tim Schaub tschaub at openplans.org
Fri Oct 19 12:53:52 EDT 2007
Or we could do like others and give elements that contain strings that
need translating a unique attribute.
Simplified, this could look something like this:
<span i18n="foo">foo in my lang</span>
Then, switching languages would comb through all elements on the page,
replacing the content of those with i18n attributes - determining the
appropriate content based on the global lang setting and the value of
the key in the appropriate dictionary.
Not efficient, but simple.
Tim
PS - I don't think we should go too heavy here because I think OL as a
mapping library should contain very few strings if any.  How can we get
strings out of the library you ask?  Use templates to make things like
the layer switcher - instead of cramming a bunch of text node creation
code in the controls.
Paul Spencer wrote:
> On 18-Oct-07, at 2:31 PM, Christopher Schmidt wrote:
>> setLanguage, if we're going to provide a method for it, is going to
>> need
>> to be more complex than that. We'd have to loop through the controls,
>> and call redraw() on them, to update their text, and I'm not sure that
>> all controls would support a redraw correctly.
> Could we use an event that is triggered and then controls that have
> strings can register (or be registered) for the language changing?
> OpenLayers.String.events.register('languagechange',
> OpenLayers.Function.bind(this, this.onLanguageChange));
> Then it is a matter of implementing support in specific controls that
> need it or can use it.  And if there are things other than controls
> that can use the current language, they can take advantage easily.
> For instance, some layer types might be able to use the current
> language for labeling.  And applications (or application frameworks)
> around OpenLayers could also take advantage of it.
> We will probably want a LanguageSwitcher control that sets the
> language and tracks the current language too, mostly for testing and
> development.
> We need a way of indicating what languages to support in any given
> application, and of enumerating the supported languages through the
> OpenLayers API.
> We need a way to extend the base set of translations with other,
> application-specific translations.
> Cheers
> Paul
> |Paul Spencer                          pspencer at dmsolutions.ca    |
> |Chief Technology Officer                                         |
> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
> !DSPAM:4033,4717b81f246325210051143!
More information about the Dev mailing list
